execve("/usr/bin/scanimage", ["scanimage", "-L"], [/* 170 vars */]) = 0
svr4_syscall() = -1 ERRNO_4090 (Unknown error 4090)
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libsane.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libsane.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libsane.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libsane.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=389688, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaae000
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\220=\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 471040, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
old_mmap(0x2aabe000, 386436, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
old_mmap(0x2ab2c000, 3456, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5e000) = 0x2ab2c000
old_mmap(0x2ab2d000, 15580, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ab2d000
close(3) = 0
munmap(0x2aaae000, 4096) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=9372, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\220\7\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 77824, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab31000
old_mmap(0x2ab31000, 6208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab31000
old_mmap(0x2ab42000, 4200, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2ab42000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libusb-0.1.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libusb-0.1.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libusb-0.1.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libusb-0.1.so.4", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=29368, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\320\17\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 94208, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab44000
old_mmap(0x2ab44000, 22796, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab44000
old_mmap(0x2ab59000, 7736, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5000) = 0x2ab59000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libpthread.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=94518, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\00004\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 147456, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab5b000
old_mmap(0x2ab5b000, 51124, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab5b000
old_mmap(0x2ab77000, 22448, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc000) = 0x2ab77000
old_mmap(0x2ab7d000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ab7d000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libm.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libm.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libm.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=105256, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\0\25\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 167936, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab7f000
old_mmap(0x2ab7f000, 98788, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab7f000
old_mmap(0x2aba7000, 976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x18000) = 0x2aba7000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libjpeg.so.62", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libjpeg.so.62", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=133296, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0`\35\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 135168, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aba8000
old_mmap(0x2aba8000, 131044, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aba8000
old_mmap(0x2abc8000, 1016, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x2abc8000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=55452, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\340\30\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 122880, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abc9000
old_mmap(0x2abc9000, 53908, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abc9000
old_mmap(0x2abe6000, 1052, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x2abe6000
close(3) = 0
open("/opt/freetz/7270/freetz-trunkdann/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=427348, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\0\252\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 466944, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abe7000
old_mmap(0x2abe7000, 375716, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abe7000
old_mmap(0x2ac52000, 8076, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5b000) = 0x2ac52000
old_mmap(0x2ac54000, 18896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ac54000
close(3) = 0
mprotect(0x2abe7000, 375716, PROT_READ|PROT_WRITE|PROT_EXEC) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
stat("/lib/ld-uClibc.so.0", {st_mode=S_IFREG|0755, st_size=22664, ...}) = 0
mprotect(0x2ab42000, 4096, PROT_READ) = 0
mprotect(0x2ab77000, 4096, PROT_READ) = 0
mprotect(0x2ac52000, 4096, PROT_READ) = 0
mprotect(0x2aabc000, 4096, PROT_READ) = 0
mprotect(0x2abe7000, 375716, PROT_READ|PROT_EXEC) = 0
ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
getpid() = 3570
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=715822628}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2040*1024, rlim_max=715822628}) = 0
rt_sigaction(SIGRT_0, {SIG_DFL}, NULL, 16) = 0
rt_sigaction(SIGRT_1, {SIG_DFL}, NULL, 16) = 0
rt_sigaction(SIGRT_2, {SIG_DFL}, NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [RT_0], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 16) = 0
brk(0) = 0x41d470
brk(0x41e470) = 0x41e470
brk(0x41f000) = 0x41f000
open("./dll.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/mod/etc/dll.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
stat64(0x2ab1bbf8, 0x7ff76530) = 0
open("/dev/", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 3
fstat(3, {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
fcntl(3, F_SETFD, FD_CLOEXEC) = 0
getdents64(3, /* 129 entries */, 4096) = 4096
getdents64(3, /* 133 entries */, 4096) = 3904
getdents64(3, /* 0 entries */, 4096) = 0
close(3) = 0
stat64(0x2ab1bc0c, 0x7ff76530) = -1 ENOENT (No such file or directory)
open("/dev/bus/usb", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = -1 ENOENT (No such file or directory)
open("/proc/bus/usb", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 3
getdents64(3, /* 4 entries */, 4096) = 104
close(3) = 0
brk(0x420000) = 0x420000
close(3) = 0
open("/proc/bus/usb/001", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = 3
fstat(3, {st_mode=S_IFDIR|0555, st_size=0, ...}) = 0
getdents64(3, /* 9 entries */, 4096) = 216
brk(0x421000) = 0x421000
open("/proc/bus/usb/001/007", O_RDWR|O_LARGEFILE) = 4
ioctl(4, USBDEVFS_CONNECTINFO, 0x7ff744a8) = 0
read(4, "\22\1\0\2\0\0\0@\f\t\0\20\0\21\1\2\3\1", 18) = 18
read(4, "\t\2 \0\1\1\0\200", 8) = 8
read(4, "2\t\4\0\0\2\10\6P\0\7\5\201\2\0\2\377\7\5\2\2\0\2\377", 24) = 24
close(4) = 0
brk(0x422000) = 0x422000
open("/proc/bus/usb/001/006", O_RDWR|O_LARGEFILE) = 4
read(4, "\22\1\0\1\0\0\0\10_\5\1\0\0\1\0\0\0\1", 18) = 18
read(4, "\t\2\'\0\1\1\0@", 8) = 8
read(4, " \t\4\0\0\3\0\0\0\0\7\5\1\2\2\0\0\7\5\202\2@\0\0\7\5\203\3\1\0\1", 31) = 31
close(4) = 0
brk(0x423000) = 0x423000
open("/proc/bus/usb/001/005", O_RDWR|O_LARGEFILE) = 4
read(4, "\22\1\0\2\t\0\1@\343\5\6\6\2\7\0\1\0\1", 18) = 18
read(4, "\t\2\31\0\1\1\0\340", 8) = 8
read(4, "2\t\4\0\0\1\t\0\0\0\7\5\201\3\1\0\f", 17) = 17
close(4) = 0
brk(0x424000) = 0x424000
open("/proc/bus/usb/001/004", O_RDWR|O_LARGEFILE) = 4
read(4, "\22\1\0\2\0\0\0\10\371\4(\0\0\1\1\2\3\1", 18) = 18
read(4, "\t\2 \0\1\1\0\300", 8) = 8
read(4, "\1\t\4\0\0\2\7\1\2\0\7\5\1\2@\0\0\7\5\202\2\20\0\0", 24) = 24
close(4) = 0
brk(0x425000) = 0x425000
open("/proc/bus/usb/001/003", O_RDWR|O_LARGEFILE) = 4
read(4, "\22\1\0\2\0\0\0@\343\5\2\0073\0\0\1\0\1", 18) = 18
read(4, "0\t\4\0\0\2\10\6P\0\7\5\201\2\0\2\1\7\5\2\2\0\2\1", 24) = 24
close(4) = 0
brk(0x426000) = 0x426000
open("/proc/bus/usb/001/002", O_RDWR|O_LARGEFILE) = 4
close(4) = 0
brk(0x427000) = 0x427000
open("/proc/bus/usb/001/001", O_RDWR|O_LARGEFILE) = 4
read(4, "\22\1\0\2\t\0\1@\0\0\0\0\6\2\3\2\1\1", 18) = 18
read(4, "\0\t\4\0\0\1\t\0\0\0\7\5\201\3\2\0\f", 17) = 17
close(4) = 0
close(3) = 0
open("/proc/bus/usb/001/007", O_RDWR|O_LARGEFILE) = 3
ioctl(3, USBDEVFS_IOCTL, 0x7ff76080) = -1 ENOTTY (Inappropriate ioctl for device)
close(3) = 0
open("/proc/bus/usb/001/006", O_RDWR|O_LARGEFILE) = 3
close(3) = 0
open("/proc/bus/usb/001/005", O_RDWR|O_LARGEFILE) = 3
ioctl(3, USBDEVFS_IOCTL, 0x7ff76080) = 5
close(3) = 0
open("/proc/bus/usb/001/004", O_RDWR|O_LARGEFILE) = 3
close(3) = 0
open("/proc/bus/usb/001/003", O_RDWR|O_LARGEFILE) = 3
close(3) = 0
open("/proc/bus/usb/001/002", O_RDWR|O_LARGEFILE) = 3
close(3) = 0
open("/proc/bus/usb/001/001", O_RDWR|O_LARGEFILE) = 3
ioctl(3, USBDEVFS_IOCTL, 0x7ff76080) = 2
close(3) = 0
open("./net.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/mod/etc/net.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("./mustek_usb.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/mod/etc/mustek_usb.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
write(1, "\nNo scanners were identified. If"..., 266
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).) = 266
write(1, "\n", 1
) = 1
exit(0) = ?
