7141 firmware über ds-mod kitt entpacken
heini66
Gesperrt
12 Mrz 2005
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
create_inode: could not create character device build/original/filesystem/dev/Piglet, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/acxHwDrv, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/avm_event, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/avm_power, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/capi20, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/console, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/debug, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsld, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsldptrace0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsldptrace1, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsldptrace2, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsldptrace3, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kdsldptrace4, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/kmem, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/led, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mem, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd1, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd10, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd2, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd3, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd4, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd5, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd6, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd7, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd8, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/mtd9, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock0, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock1, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock10, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock2, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock3, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock4, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock5, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock6, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock7, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock8, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/mtdblock9, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/new_led, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/null, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ptmx, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/1, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/2, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/3, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/4, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/5, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/6, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/pts/7, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/random, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda1, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda10, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda11, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda12, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda13, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda14, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda15, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda2, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda3, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda4, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda5, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda6, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda7, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda8, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sda9, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb1, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb10, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb11, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb12, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb13, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb14, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb15, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb2, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb3, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb4, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb5, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb6, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb7, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb8, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdb9, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc1, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc10, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc11, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc12, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc13, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc14, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc15, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc2, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc3, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc4, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc5, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc6, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc7, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc8, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdc9, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd1, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd10, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd11, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd12, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd13, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd14, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd15, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd2, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd3, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd4, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd5, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd6, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd7, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd8, because you're not superuser!
create_inode: could not create block device build/original/filesystem/dev/sdd9, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/tffs, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/tiatm, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/tty, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/tty0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ttyS0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ttyp0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ttyp1, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ttyp2, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/ubik, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/urandom, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/usblp0, because you're not superuser!
create_inode: could not create character device build/original/filesystem/dev/watchdog, because you're not superuser!
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
make: *** [firmware] Fehler 2
wie bekomm ich diese 1.te problem gelöst? you're not superuser?
sudo make mag er auch nicht. :(
das das mit dem kitt ohne sourcen nix wird, is mir schon klar... bin aber neugierig und würd gern mal in den kompletten kram reinsehen.
