Seite 9 von 22 ErsteErste ... 567891011121319 ... LetzteLetzte
Ergebnis 161 bis 180 von 429
Thema: [Problem gelöst, FBF neu geflasht über JTag] FBF7050, adam2 Bootloader deadlock?
  1. #161
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    Hello Stefano,
    try to add these command-line-options: "/instrlen:5 /instrprefix:4 /dataprefix:1"
    best regards,
    Feadi
  2. #162
    IPPF-Aufsteiger
    Registriert seit
    11.07.2007
    Hi @feadi
    >wrt54g-v4.8.exe -probeonly
    WRT54G/GS EJTAG Debrick Utility v4.8
    Probing bus ... Done
    Instruction Length set to 5
    CPU Chip ID: 00010101100101000110111100001111 (15946F0F)
    *** Unknown or NO CPU Chip ID Detected ***
    *** Possible Causes:
        1) WRT54G/GS is not Connected.
        2) WRT54G/GS is not Powered On.
        3) Improper JTAG Cable.
        4) Unrecognized CPU Chip ID.
    >wrt54g-v4.8.exe -probeonly /skipdetect
    Instruction Length set to 0
    CPU Chip ID: 00000000000000000000000000000100 (00000004)
    *** CHIP DETECTION OVERRIDDEN ***
        - EJTAG IMPCODE ....... : 00000000000000000000000000000100 (00000004)
        - EJTAG Version ....... : 1 or 2.0
        - EJTAG DMA Support ... : Yes
    Issuing Processor / Peripheral Reset ... Done
    Enabling Memory Writes ... Done
    Halting Processor ... <Processor did NOT enter Debug Mode!> ... Done
    Clearing Watchdog ... Done
    Probing Flash at (Flash Window: 0x1fc00000) ... Done
    *** Unknown or NO Flash Chip Detected ***
     *** REQUESTED OPERATION IS COMPLETE ***
    If I use /instrprefix:4 /dataprefix:1, I get
    *** ERROR - Invalid <option> specified ***
    if I test IR with feadi-jtag.exe I get
    IR length: 9
    IR length: 9
    IR length: 9
    IR length: 9
    IR length: 9
    wrt.exe -backup:custom /instrlen:5 /instrprefix:4 /
    efix:1 /window:90000000 /start:90000000 /length:10000
    WRT54G/GS EJTAG Debrick Utility v4.5
    Probing bus ... Power up now...
    Done
    CPU Chip ID: 00000000000000000001000000001111 (0000100F)
    *** Found a TI AR7WRD TNETD7300* Rev 1 CPU chip ***
    reading IMPCODE register... 00000000000000000000000000000000 (00000000)
    reading IMPCODE register... 01000001010000000100000000000000 (41404000)
        - EJTAG IMPCODE ....... : 01000001010000000100000000000000 (41404000)
        - EJTAG Version ....... : 2.6
        - EJTAG DMA Support ... : No
    Enabling Memory Writes ... Skipped
    Clearing Watchdog ... blocked
    regards, stefano
    Geändert von stefanoIT (18.10.2007 um 18:50 Uhr)
  3. #163
    IPPF-Aufsteiger
    Registriert seit
    11.07.2007
    Hi @feadi
    the command
    wrt.exe -flash:custom /instrlen:5 /instrprefix:4 /dataprefix:1 /window:90000000 /start:90000000 /length:10000
    worked very well.
    7050 comes back to life.
    I think the most important thing is that wrt.exe waits for power on.
    your comment?
    best regards and thank you for your precious help.
    stefano
  4. #164
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    Ciao Stefano,
    "/instrprefix:" and "/dataprefix:" is an extension from me. so only the wrt.exe from here understands this commands.
    feadi-jtag.exe is just a little test-program, for the jtag-interface. this program helps a lot, if you have a bug in your jtag-interface.
    best regards,
    Feadi
  5. #165
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Hi Feadi (and of course @all )
    Hi have some problem with jtag interface with level shifter.
    The box is an 7170sl v1, i follow your scheme for spartan to connect the fbf to pc but there isn't a response from the box.
    I have rewritten in telnet the bootloader adam for a some test and the box now not responding in any case (ftp, telnet web). I meseaure up the tension on 3.3v on fbf jtag connector and the level is set to 2.8v~ now i'm trying to find an scheme for 3.3v power supplies and then can try to power up a jtag from that instead of a fbf, what do you think?
    I've got only ffffffffff... from fbf connect on jtag to pc, ever fffff , tonight i can re-test the jtag and the level on the TDI TDO etc...
    One question, the cTRST and the RTST on spartan config there ever connect to 3.3v with 300ohm?
    Thks
  6. #166
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    Hi Katagy,
    This is really really bad. Maybe you have a short-circuit? Does your volt-meter work properly?
    best regards,
    Feadi
  7. #167
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Hi Feadi.
    Now i can retest the volt on 3.3v on fbf jtag, i replace the old analogic volmeter with a new digital (with must precision).
    But i have the problem with lpt port on pc. I follow your instruction for verify the correct work in older post (in this 3ad) and on lpt port if i don't made anything the volt on tdi tms and tck are around 0 (0,51 or less). For speed up the volt to 4,56~V (directly on lpt prt) i made a new recognition of hardware. I can test the feadi-jtag.exe and on tdi, tms, tck i have the 3,25 V (the jtag interface isn't conneceted to fbf and the power i can get from a lm1086 connected on usb port on other pc), then i digit 134 and retest but the voltage is the same, not put on 0, i think there is a problem with pc/software, can you help me?
    What i can do for retry? Now i suppose to test on other pc for verify...
    thks a lt for all.
  8. #168
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    is your interface different to this one? (see attachment)
    Angehängte Grafiken Angehängte Grafiken
  9. #169
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    NO is the same, only for 74hc573 that for me is N and not D.
    I now test the voltage with your program and now the voltage is ok, TDI TMS and TCK is on 3.25V when start and press 2, after 123 the voltage are for all 0. Then i press 5 i joyn tdi and tdo and repress 5 but notthin happnes, after i re-press 5 and say me:
    choose one of this:
    1 = toggle TDI
    2 = read TDO
    3 = toggle TMS
    4 = toggle TCK
    5 = test IR len
    6 = test IR len (over and over again...)
    7 = shift IR
    8 = shift DR
    9 = reset JTAG
    q = exit
    and press <return>
    2
    jtag: TDI=1 TDO=1 TMS=1 TCK=1
    134
    jtag: TDI=0 TDO=0 TMS=1 TCK=1
    jtag: TDI=0 TDO=0 TMS=0 TCK=1
    jtag: TDI=0 TDO=0 TMS=0 TCK=0
    5
    IR length: 0
    5
    5
    IR length: 17
    5
    This is the result for wrt.exe -flash:custom /instrlen:5 /instrprefix:4 /dataprefix:1 /window:90000000 /start:90000000 /length:10000
    Microsoft Windows XP [Versione 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    K:\fritz\fritz jtag>wrt3.exe -flash:custom /instrlen:5 /instrprefix:4 /dataprefi
    Done
    CPU Chip ID: 00100100111111111111111111111111 (24FFFFFF)
    exit, Premere un tasto per continuare . . .
    Geändert von katagy (24.10.2007 um 16:17 Uhr)
  10. #170
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    I retry and the result, with the sam command wrt, are different, ever different the cpu do not detect. there is possible problem with long cable? now is 35cm long.
  11. #171
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    I'm sorry. I just don't understand.
  12. #172
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    ok, sorry for my bad english
    I've connect the fbf to the pc with your interface (74hc573n) REsistence on pc connector side 301 ohm on pin 2-3-4, on pin 13 100ohm.
    On fbf side all 100ohm.
    With feadi-jtag i test the function of jtag interface and on 2 option the value of TDI, TMS, TCK are 3.3v (on TDO 0.51~v)
    then (after press 134) the value are 0v for TDI, TMS, TCK and TDO (if i remember correct). When join the TDI and TDO sometime (rare) i've got no chain detect, but often value 0.
    WHen i disconnect the tdo from tdi is alternate 0 with strange value 17 or 9 or 24 or 4 or 5.
    I try to conncet on fbf to recover that with flash custom but... no cpu detect with diffeerent cpu ID, everytime that i start the cpu id is change.
    What happens? what i can do? Is possible that cable is too long? (total 40 cm from lpt pc to fbf pin).
    I'm not sure that the jtag interface is functionally correct, if there is some other test to try it...
    I'm nno newer on jtag i've used for some stb sat and no longer problem have found (on similar circuit) but this time... is so hard for me.
    I hope that you help me.
    I've tryed to dump ip code and when the fbf is on power off the code are only ffffff.. when pluged on the fbf the code are f45ab576... and the led of fbf blink with no sense.
  13. #173
    IPPF-Erfahrener
    Registriert seit
    25.01.2005
    Did you connect TRST and cTRST with a resistor to 3v3 ?
    Can you make a picture of your interface+cabling?
    your interface seems to be okay, except one point: "When join the TDI and TDO sometime (rare) i've got no chain detect,..."
    try feadi-jtag, press <6> <return> (for endless test), connect interface to PC and connect TDO&TDI. then try to provocate this error (no chain detected) again.
    maybe you have a:
    - defective wire, or
    - bad solder point, or
    - slack joint
    try to find this error and get rid of it.
    best regards,
    Feadi
  14. #174
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Ok Feadi, thks
    When is possible i try your suggest, and in second way i remake the jtag interface with must short cable as possible.
  15. #175
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Hi Feadi, i retest all, i remade e jatg interface and the result is the same.
    On feadi-jtag > 2:
    3.25Volt on TDI, TMS and TCK, 0Volt on TDO
    After press 134 0Volt on TDI, TDO, TMS and TCK (and it's seem to be ok)
    Then press 5 and join TDI with TDO and IR Lenght: 0, after that i retest with option 6 and the IR Lenth is set to 0 for most of the string, but also other value then 0 are displayed.
    None "no chain detect" are displayed and it's seem to be ok.
    After that i connect pc with fbf and try to do some operation but the cpu is not detected and the cpu id is ever different at every test.
    The cable is not so lon now, there is something to strange.
    What can i do now?
  16. #176
    IPPF-Aufsteiger
    Registriert seit
    11.07.2007
    hi @katagy
    first double check the connection on your interface
    using feadi-jtag.exe you had to check on signal at time, to be sure that no signal was swapped with another
    TDI -> (pin 2)
    TDO -> (pin 13)
    TMS -> (pin 4)
    TCK -> (pin 3)
    TDO (Test Data Out) would be always 1
    double check the pinout on your fritz
    may we have a picture of your interface and your fritz?
    regards.
    stefano
  17. #177
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Hi Stefano.
    I've just checked jtag, without the fbf connected, and it's seem to be ok, i've no idea in what is wrong, at this point i think that fbf is damaged...
  18. #178
    IPPF-Aufsteiger
    Registriert seit
    11.07.2007
    are you sure about pinout on fritz?
    post the pictures, please.
    stefano
  19. #179
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    The pin of connector on jtag (to semply the connect and disconnect) are from left cTRST 3.3v (join with last pin trst on 301ohm) TCK, TMS, TDO, TDI, TRST 3,3v
    [Edit wichard: Please attach your pictures in this forum - don't use any external hoster.]
  20. #180
    IPPF-Einsteiger
    Registriert seit
    25.05.2006
    Sorry for the link, but when i try to upload directly on forum, it send me an error...
    @All, my 7170 back to life i remake every connection on jtag and remade short cable, now it's ok 100% Thks to Feadi and Stefano
    One question now, i've a problem on dsl, the fbf see the signal, try to hook up the connection but still up on training.
    The dsl is a annex A, i have modified the fbf to annex a (via software), with 7050 and 7141 no problem, but with 7170 there isn't a solution (software).
    I just try the english firmware and the new ch/au firmware both original annex A, but no change. Some suggest?
Ähnliche Themen
  1. fritzbox 7170 jtag ADAM2
    Von amandegar im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 15
    Letzter Beitrag: 19.07.2010, 15:09
  2. W900V Bootloader ADAM2 oder EVA ?
    Von Kater432 im Forum Speedport2Fritz
    Antworten: 2
    Letzter Beitrag: 12.12.2007, 09:30
  3. Wiki: ADAM2-Bootloader
    Von kriegaex im Forum Freetz
    Antworten: 0
    Letzter Beitrag: 12.02.2007, 16:04
  4. Wiki: ADAM2-Bootloader
    Von kriegaex im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 0
    Letzter Beitrag: 12.02.2007, 16:01
  5. FBF7050 broken bootloader in mtd2
    Von skalita im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 15
    Letzter Beitrag: 20.03.2006, 20:58
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
