/var/mod/root $ /etc/version
29.04.29
/var/mod/root $ busybox
BusyBox v1.4.1 (2007-05-01 11:36:35 CEST) multi-call binary
Copyright (C) 1998-2006 Â Erik Andersen, Rob Landley, and others.
Licensed under GPLv2. Â See source distribution for full notice.
Usage: busybox [function] [arguments]...
or: [function] [arguments]...
BusyBox is a multi-call binary that combines many common Unix
utilities into a single executable. Most people will create a
link to busybox for each function they wish to use and BusyBox
will act like whatever it was invoked as!
Currently defined functions:
[, [[, arp, arping, ash, awk, basename, bunzip2, bzcat, cat, chmod, chown, chroot, clear, cmp, cp, crond,
crontab, cut, date, dd, df, dirname, dmesg, dos2unix, du, echo, egrep, env, ether-wake, expr, false, fgrep,
find, free, ftpget, ftpput, getopt, grep, gunzip, gzip, halt, hdparm, head, hexdump, hostid, hostname, httpd,
id, ifconfig, ifdown, ifup, init, insmod, install, ip, kill, killall, klogd, ln, logger, login, logname, logread,
losetup, ls, lsmod, makedevs, md5sum, mdev, mkdir, mkfifo, mknod, mkswap, modprobe, more, mount, mv, nc, netstat,
nohup, nslookup, od, passwd, pidof, ping, pivot_root, poweroff, printf, ps, pwd, rdate, realpath, reboot,
reset, rm, rmdir, rmmod, route, run-parts, sed, setconsole, setlogcons, sh, sha1sum, sleep, sort, strings,
stty, swapoff, swapon, sync, sysctl, syslogd, tail, tar, tee, telnet, telnetd, test, tftp, time, top, touch,
tr, traceroute, true, tty, umount, uname, uniq, unix2dos, uptime, usleep, uudecode, uuencode, vconfig, vi,
wc, wget, which, xargs, yes, zcat
