22:33:41.626 dtmfbox.c dtmfbox 0.4.1 ($Revision: 163 $) - rc3
22:33:41.628 dtmfbox.c PJSIP 0.8.0
22:33:41.656 pjlib select() I/O Queue created (0x4eed0c)
22:33:41.656 sip_endpoint.c Module "mod-msg-print" registered
22:33:41.658 voip_ctrl.c Init VOIP...
22:34:11.669 voip_ctrl.c Resolve IP from stun.fwdnet.net:3478 ...
22:34:11.836 voip_ctrl.c Use IP: 195.4.186.244
22:34:11.838 udp0x4ff76c SIP UDP transport started, published address is 195.4.186.244:5061
22:34:11.839 voip_ctrl.c UDP server listening on port 5061
22:34:11.843 sip_endpoint.c Module "mod-tsx-layer" registered
22:34:11.844 sip_endpoint.c Module "mod-stateful-util" registered
22:34:11.849 sip_endpoint.c Module "mod-ua" registered
22:34:11.850 sip_endpoint.c Module "mod-100rel" registered
22:34:11.850 voip_ctrl.c VOIP callbacks initialized
22:34:11.851 sip_endpoint.c Module "mod-invite" registered
22:34:11.852 sip_endpoint.c Module "dtmfbox" registered
22:34:11.866 pjlib select() I/O Queue created (0x525a9c)
22:34:11.884 icstr0x551470 ICE stream transport created
22:36:11.886 voip_ctrl.c RTP/RTCP: 195.4.186.244:4000-4001 (ICE)
22:36:11.887 icstr0x555fd0 ICE stream transport created
22:38:11.887 voip_ctrl.c RTP/RTCP: 195.4.186.244:4002-4003 (ICE)
22:38:11.887 icstr0x55a818 ICE stream transport created
