21:36:37.585 script_funcs.c [-1] (SCRIPT) - Queue: 205, Pending: 0
21:36:37.585 conference.c Port 2 (capi port [0]) transmitting to port 1 (null port)
21:36:37.585 conference.c Port 1 (null port) transmitting to port 2 (capi port [0])
21:36:37.585 capi_funcs.c (CTRL 1, SRC: 95894xx, DST: 01762xxx) - CONNECT_REQ
21:36:37.585 script_funcs.c [-1] (SCRIPT) - CAPI-CALL - 95894xx -> 01762xxx [1]
21:36:37.585 capi_ctrl.c (CNF, CTRL 1, PLCI: 3329) - CAPI_CONNECT
21:36:37.605 script_funcs.c RUN SCRIPT: "none" "CONNECT" "CAPI" "OUTGOING" "0" "-1" "95894xx" "01762xxx" "1" ""
21:36:37.665 funcs.c Set high priority
21:36:37.775 script_funcs.c [0] (SCRIPT) - Queue: 206, Pending: 0
21:36:37.775 script_funcs.c [0] (SCRIPT) - wait for event (2)
21:36:37.965 script_funcs.c [0] (SCRIPT) - Queue: 207, Pending: 1
21:36:37.965 script_funcs.c [0] (SCRIPT) - [play_id: -1] - playing stopped!
21:36:37.985 script_funcs.c [0] (SCRIPT) - Queue: 208, Pending: 0
21:36:37.985 capi_funcs.c Send Display-Message: "Hauptmenue"
21:36:37.985 capi_ctrl.c (CNF, CTRL 1, PLCI: 3329) - CAPI_INFO
21:36:38.115 script_funcs.c [0] (SCRIPT) - Queue: 209, Pending: 0
21:36:38.115 port_filestrea Stream player created (/var/tmp/0.espeak_13174, 8000hz, 16bit, mono)
21:36:38.115 conference.c Port 3 (player [0,0]) transmitting to port 2 (capi port [0])
21:36:38.115 script_funcs.c [0] (SCRIPT) [play_id: -1] - playing /var/tmp/0.espeak_13174...
21:36:38.115 mixer.c [0] - mixer - play_id: 0, rec_id: -1
21:36:38.495 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0x800d) - SETUP ACK
21:36:38.495 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x01)
21:36:38.495 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0xc000) - UNKNOWN INFO
21:36:39.755 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0x8045) - DISCONNECT
21:36:39.755 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0x001e) - PROGRESS INDICATOR (0x02)
21:36:39.755 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0x0008) - CAUSE (0x04)
21:36:39.755 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_INFO (0xc000) - UNKNOWN INFO
21:36:39.895 capi_events.c (IND, CTRL 1, PLCI: 3329) - CAPI_DISCONNECT
21:36:39.895 capi_funcs.c CAPI 0x34aa - Switching equipment congestion
21:36:39.895 conference.c Port 3 (player [0,0]) stop transmitting to port 2 (capi port [0])
21:36:39.895 conference.c Port 2 (capi port [0]) stop transmitting to port 1 (null port)
21:36:39.905 conference.c Port 1 (null port) stop transmitting to port 2 (capi port [0])
21:36:39.905 funcs.c Set low priority
