Ergebnis 1 bis 10 von 10
Thema: How to modify FRITZ!Box 7050 annex B in annex A?
  1. #1
    IPPF-Einsteiger Avatar von voipuser.int
    Registriert seit
    05.12.2006
    I live in Denmark and buyed a FRITZ!Box 7050 on Germany Ebay.
    Unfortunately I found this one cant' work in Denmark becouse the ANNEX standard is different.
    So, I would resell this device again on Ebay of Germany until I found this wonderful forum where there are person able to change the ANNEX standard from B to A by firmware upgrade.
    But because is really my first time I'm doing an upgrade like this I would be very grateful to somebody able to help me in do this step by step.
    Thanks in advance to the volunteer who will help me!
    Idress
  2. #2
    IPPF-Urgestein Avatar von doc456
    Registriert seit
    27.04.2006
    Hi, an Welcome!
    Basicly you should read this Thread:
    http://www.ip-phone-forum.de/showthr...ighlight=Annex
    or if able to read German try this one:
    EDIT: here the Original: http://www.ip-phone-forum.de/showthr...=Annex+english
    --Horst
    Router: FBF 6360
    | FBF 7390-84.05.51-24828 | FBF 7270-54.05.50 | FBF 7050-14.04.50-1009 | UM 3pl 50/5 | Telefone: diverse
    Handbücher AVM | Recover - ruKernelTool | Sip BoxToBox | Sip TelAtBox | [HowTo] Installation Fritz!Fax | [Kompendium] Fritz!Fax
    Es werden keine Fragen per PN, etc. beantwortet, denn Support gehört ins Forum!
  3. #3
    Registriert seit
    05.12.2006
    Daumen hoch Upgrade firmware from German to English
    Hello
    Sorry sir only English speak. not german
    I have upload the file fritz box 7050 to Annex A. English Firmware FRITZ!Box Fon WLAN 7050 (Annex A) Firmware Version 14.04.20.
    Nex step by step..
    Still not finsh
    I would transform it in English language (because Deutsch language is very hard for me to understand).
    Is possible to install this down-grade version?
    Or I will experience some trouble?
    Again, the difference beetwen 14.04.25
    Deutsch firmware and 14.04.20 english Firmware is just a matter of numbering or the Deutsch version is really more complete?
    Thanks in advance for your help.
    Idress
  4. #4
    Registriert seit
    27.04.2006
    no Problem with the language, O.K.!
    First: it is not possible to load the english Firmware onto a German based Box.
    Therefore you get the Problem!
    Go back with an german Firmware such as 14.04.15.
    You can get ist on the AVM-FTP-Server: ftp://ftp.avm.de/fritz.box/fritzbox....an_7050/x_misc
    Follow the Instructions that will announced.
    Listen: only connect the PC via LAN to the BOX, Static-IP 192.168.178.100 for the PC and start the Recover-File!
    After that, you should read the Original Thread to Convert the Box to ANNEX A.
    There is no Possibilty to update a German-Based Box with the english Firmware-Version, Sorry!
    --Horst
    Router: FBF 6360
  5. #5
    Registriert seit
    05.12.2006
    Thanks Sir. u are help full.
    Please can u send more information A - Z , must info is in german language.
    Plz tel me step by step ?
    May be i have damag my frit box 7050...
    when i Go back with an german Firmware such as 14.04.15, re install german Firmware vision ?
    Idress
  6. #6
    Registriert seit
    27.04.2006
    Welcome!
    No you did not!
    Yes of course, you shall do so!
    BtW, at the AVM-Server you can find handbooks of the Box in English as well.
    Take the english Site of AVM please.
    See the Pictures on the english Handbook and the german one, so you can compare it, O.K.?
    --Horst
    Router: FBF 6360
  7. #7
    Registriert seit
    05.12.2006
    Dear sir doc456 1000 time thanks
    fb working whit internet . I happy<<<<<<<>>>>>>>>>>>>
    Thanks
    Idress
  8. #8
    Registriert seit
    27.04.2006
    Hi Idress,
    you are Welcome!
    Have a nice day.
    --Horst
    Router: FBF 6360
  9. #9
    IPPF-Einsteiger
    Registriert seit
    03.08.2011
    Hello I have a problem with the router fritzbox 7050, by no means impossible to access the router via Telenet and if I do everything according to your instructions in the cmd> Telenet when I want to access this throws me: cold not open connection to the host on port 23,help plz
  10. #10
    IPPF-Fünftausend-VIP
    Registriert seit
    01.02.2005
    This is a really old thread, in the last years, there have been some changes in firmware
    There should be some more recent threads about changing a box to an Annex A firmware.
    In every case: which firmware version has your box? And what exactly did you try to enable telnet?
    The most convenient way is using a phone and dial #96*7*. Some firmwares (e.g. 14.04.30) are known to contain no telnet daemon, so you can't enable it. If this is the case, you may want to try a modded firmware ("freetz") which will not only give the possibility of a telnet connection but a nice GUI, too.
    (FR) Eumex 300IP FW 06.04.49 (englisch) und "relativ aktuellem" freetz-devel mit openvpn und dropbear hinter AGFEO TK-HomeServer
    Fritz!BoxFon WLAN FW 08.04.27 mit ds-0.2.9-p7 und openvpn-2.1_rc2
Ähnliche Themen
  1. Anleitung für patchen von AVM 7050 von Annex B zu Annex A
    Von wafdi73 im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 1
    Letzter Beitrag: 08.03.2010, 11:24
  2. How to modify a 7050 annex B in annex A?
    Von zooster im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 29
    Letzter Beitrag: 13.02.2010, 10:29
  3. How To Modify Fritzbox 7050 Annex B. INT. Annex A
    Von Ushar im Forum FRITZ!Box tot? Recover, Firmware Up-/ Downgrade
    Antworten: 4
    Letzter Beitrag: 30.01.2010, 19:54
  4. How to modify FritzBox Fon WLAN 7140 annex B to annex A
    Von voipuser.int im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 0
    Letzter Beitrag: 06.12.2006, 23:40
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
