Hi.
Nachdem ich hier immer wieder in Posts lesen muss, dass die Box mehrmals täglich neu startet, sollen in diesem Thread Erkenntnisse dazu gesammelt werden.
Ich fang mal an:
7170 mit 29.04.30_ds-0.2.9_26-13 und eigenem Kernel
edit1: Und die orignal Firmware soll stabiler sein?Code:09:09:55 up 17:49, load average: 0.11, 0.10, 0.08 Unhandled kernel unaligned access in arch/mips/kernel/unaligned.c::emulate_load_ store_insn, line 475[#1]: Cpu 0 $ 0 : 00000000 7fa5ff90 40003c1b 1401a8c0 $ 4 : 00000000 ffffffff 00005305 00000006 $ 8 : 00000000 00000000 00000000 00000000 $12 : 00000000 00000057 7fa5fcc0 00000000 $16 : 95c662a0 c0132fb8 7ffffffe ffffffff $20 : 94fa5df8 00005305 00005305 00000258 $24 : 00000000 c00e1d70 $28 : 94fa4000 94fa5cb8 00000006 c00ca04c Hi : 00000001 Lo : 00000000 epc : c00e1e58 timercb_del+0xe8/0x1cc [kdsldmod] Tainted: P ra : c00ca04c dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] Status: 1000ce03 KERNEL EXL IE Cause : 90800010 BadVA : 7ffffffe PrId : 00018448 Modules linked in: vfat fat nls_cp437 nls_iso8859_1 usb_storage sd_mod scsi_mod kdsldmod usbahcicore usbcore isdn_fbox_fon4 ubik2 tiatm Piglet Process dsld (pid: 1274, threadinfo=94fa4000, task=94fc2830) Stack : 00000000 953ad000 94fa5ce8 00000008 95c662a0 95c662a0 94872528 94e6a2b8 c00ca04c 950b31c0 948274a8 00000000 00000000 00000001 940a51bc 940a5178 00000000 94fa5e00 00000000 00000000 c0133ee0 00000000 94839f60 94839f60 7fa5ff30 00000000 10001390 00000001 00000258 c00b9420 9487201c 00000000 00000040 950b32f4 1401a8c0 00005305 00000001 94fa5df8 00000258 00000000 ... Call Trace: [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<940a51bc>] sys_semtimedop+0x4a4/0x638 [<940a5178>] sys_semtimedop+0x460/0x638 [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<94109888>] sock_sendmsg+0xac/0xdc [<94029ecc>] tasklet_action+0x88/0xdc [<c0047cc0>] dslhal_support_byteSwap32+0x0/0x8 [tiatm] [<c0049184>] dslhal_support_parseInterruptSource+0xc8/0xec [tiatm] [<9403b458>] autoremove_wake_function+0x0/0x44 [<c00475bc>] dslhal_api_handleTrainingInterrupt+0x9c/0xb8 [tiatm] [<94115868>] dev_ifsioc+0x20/0x49c [<94113db0>] dev_load+0x14/0x64 [<9410c814>] lock_sock+0xc4/0xd8 [<9410bbc4>] sk_free+0xec/0x14c [<94158cc4>] inet_ioctl+0x114/0x130 [<9410d7ac>] sk_common_release+0x58/0x9c [<9410d778>] sk_common_release+0x24/0x9c [<9407dca8>] clear_inode+0x14/0xa4 [<94076624>] do_ioctl+0x64/0x78 [<9407bd58>] dput+0x204/0x220 [<9410a5a4>] sock_close+0x48/0x5c [<9407696c>] vfs_ioctl+0x334/0x354 [<940769dc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Code: 34420001 02629026 8e420004 <10400003> 8e450000 0803879b ac450000 ae25 0004 8e430000 Call Trace: [<94023dc8>] panic+0x30/0x194 [<940265d0>] do_exit+0x84/0xad8 [<9400bb1c>] __die_if_kernel+0x0/0x24 [<9400c83c>] do_ade+0x22c/0x330 [<9400c810>] do_ade+0x200/0x330 [<9400647c>] handle_adel_int+0x34/0x58 [<c00e1d70>] timercb_del+0x0/0x1cc [kdsldmod] [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<c00e1e58>] timercb_del+0xe8/0x1cc [kdsldmod] [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<940a51bc>] sys_semtimedop+0x4a4/0x638 [<940a5178>] sys_semtimedop+0x460/0x638 [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<94109888>] sock_sendmsg+0xac/0xdc [<94029ecc>] tasklet_action+0x88/0xdc [<c0047cc0>] dslhal_support_byteSwap32+0x0/0x8 [tiatm] [<c0049184>] dslhal_support_parseInterruptSource+0xc8/0xec [tiatm] [<9403b458>] autoremove_wake_function+0x0/0x44 [<c00475bc>] dslhal_api_handleTrainingInterrupt+0x9c/0xb8 [tiatm] [<94115868>] dev_ifsioc+0x20/0x49c [<94113db0>] dev_load+0x14/0x64 [<9410c814>] lock_sock+0xc4/0xd8 [<9410bbc4>] sk_free+0xec/0x14c [<94158cc4>] inet_ioctl+0x114/0x130 [<9410d7ac>] sk_common_release+0x58/0x9c [<9410d778>] sk_common_release+0x24/0x9c [<9407dca8>] clear_inode+0x14/0xa4 [<94076624>] do_ioctl+0x64/0x78 [<9407bd58>] dput+0x204/0x220 [<9410a5a4>] sock_close+0x48/0x5c [<9407696c>] vfs_ioctl+0x334/0x354 [<940769dc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Kernel panic - not syncing: Aiee, killing interrupt handler! <0>Rebooting in 5 seconds.. (AVM) EVA Revision: 1.153 Version: 1153
7170 mit 29.04.30 (original)
edit2:Code:13:53:00 up 4:20, load average: 0.00, 0.00, 0.00 extract_dst: dev lan no iph found total used free shared buffers Mem: 30384 25332 5052 0 3244 Swap: 0 0 0 Total: 30384 25332 5052 Mar 1 13:53:02 igdd[1126]: pending_timeout: Action=AddPortMapping Mar 1 13:53:02 igdd[1126]: pending_timeout: Action=AddPortMapping Mar 1 13:53:03 igdd[1126]: pending_timeout: Action=AddPortMapping Mar 1 13:53:06 igdd[1126]: pending_timeout: Action=AddPortMapping Unhandled kernel unaligned access in arch/mips/kernel/unaligned.c::emulate_load_ store_insn, line 475[#1]: Cpu 0 $ 0 : 00000000 7ffab0c0 40003c1b 1401a8c0 $ 4 : 00000000 ffffffff 0000e11a 00000006 $ 8 : 00000000 00000000 00000000 00000000 $12 : 00000000 00000000 00000057 00000000 $16 : 94b4a15c c01e6fb8 7ffffffe ffffffff $20 : 9519bdf8 0000e11a 0000e11a 00000000 $24 : 00000000 c0195d70 $28 : 9519a000 9519bcb8 00000006 c017e04c Hi : 00000006 Lo : 00000000 epc : c0195e58 timercb_del+0xe8/0x1cc [kdsldmod] Tainted: P ra : c017e04c dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] Status: 1000ce03 KERNEL EXL IE Cause : 90800010 BadVA : 7ffffffe PrId : 00018448 Modules linked in: isdn_fbox_fon4 kdsldmod ubik2 vfat fat nls_cp437 nls_iso8859_ 1 usb_storage sd_mod scsi_mod usbahcicore usbcore tiatm Piglet Process dsld (pid: 1139, threadinfo=9519a000, task=94301080) Stack : 00000000 95d56200 9519bce8 00000008 94b4a15c 94b4a15c 9497c528 95fd32b8 c017e04c 9484cce0 94d52b68 00000000 00000000 00000001 940a497c 940a4938 00000000 9519be00 00000000 00000000 c01e7ee0 00000000 94a756a0 94a756a0 7ffab060 00000000 10001390 00000001 00000000 c016d420 9497c01c 00000000 00000040 9484ce14 1401a8c0 0000e11a 00000001 9519bdf8 00000000 00000000 ... Call Trace: [<c017e04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<940a497c>] sys_semtimedop+0x4a4/0x638 [<940a4938>] sys_semtimedop+0x460/0x638 [<c016d420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<94108eb8>] sock_sendmsg+0xac/0xdc [<940494b8>] __alloc_pages+0x11c/0x448 [<94114e28>] dev_ifsioc+0x20/0x49c [<9411338c>] dev_load+0x10/0x44 [<9410bdf4>] lock_sock+0xc4/0xd8 [<9410b1a4>] sk_free+0xec/0x14c [<94157e14>] inet_ioctl+0x114/0x130 [<9410cd8c>] sk_common_release+0x58/0x9c [<9410cd58>] sk_common_release+0x24/0x9c [<9407d998>] clear_inode+0x14/0xa4 [<94076314>] do_ioctl+0x64/0x78 [<9407ba48>] dput+0x204/0x220 [<94109b9c>] sock_close+0x48/0x5c [<9407665c>] vfs_ioctl+0x334/0x354 [<940766cc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Code: 34420001 02629026 8e420004 <10400003> 8e450000 0806579b ac450000 ae25 0004 8e430000 Call Trace: [<94023d58>] panic+0x30/0x194 [<94026560>] do_exit+0x84/0xad8 [<9400bb1c>] __die_if_kernel+0x0/0x24 [<9400c83c>] do_ade+0x22c/0x330 [<9400c810>] do_ade+0x200/0x330 [<9400647c>] handle_adel_int+0x34/0x58 [<c0195d70>] timercb_del+0x0/0x1cc [kdsldmod] [<c017e04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<c0195e58>] timercb_del+0xe8/0x1cc [kdsldmod] [<c017e04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<940a497c>] sys_semtimedop+0x4a4/0x638 [<940a4938>] sys_semtimedop+0x460/0x638 [<c016d420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<94108eb8>] sock_sendmsg+0xac/0xdc [<940494b8>] __alloc_pages+0x11c/0x448 [<94114e28>] dev_ifsioc+0x20/0x49c [<9411338c>] dev_load+0x10/0x44 [<9410bdf4>] lock_sock+0xc4/0xd8 [<9410b1a4>] sk_free+0xec/0x14c [<94157e14>] inet_ioctl+0x114/0x130 [<9410cd8c>] sk_common_release+0x58/0x9c [<9410cd58>] sk_common_release+0x24/0x9c [<9407d998>] clear_inode+0x14/0xa4 [<94076314>] do_ioctl+0x64/0x78 [<9407ba48>] dput+0x204/0x220 [<94109b9c>] sock_close+0x48/0x5c [<9407665c>] vfs_ioctl+0x334/0x354 [<940766cc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Kernel panic - not syncing: Aiee, killing interrupt handler! <0>Rebooting in 5 seconds.. (AVM) EVA Revision: 1.153 Version: 1153
Das passiert reproduzierbar, wenn ich azureus starte...
Code:Mar 1 14:02:10 igdd[603]: pending_timeout: Action=AddPortMapping Mar 1 14:02:10 igdd[603]: pending_timeout: Action=AddPortMapping Mar 1 14:02:11 igdd[603]: pending_timeout: Action=AddPortMapping Mar 1 14:02:13 igdd[603]: pending_timeout: Action=AddPortMappiUnhandled kernel unaligned access in arch/mips/kernel/unaligned.c::emulate_load_store_insn, line 475[#1]: Cpu 0 $ 0 : 00000000 7fc48fc0 40003c1b 1401a8c0 $ 4 : 00000000 ffffffff 0000e11a 00000006 $ 8 : 00000000 00000000 00000000 00000000 $12 : 00000000 00000000 00000057 00000000 $16 : 95a9e27c c0132fb8 7ffffffe ffffffff $20 : 95273df8 0000e11a 0000e11a 00000000 $24 : 00000000 c00e1d70 $28 : 95272000 95273cb8 00000006 c00ca04c Hi : 00000006 Lo : 00000000 epc : c00e1e58 timercb_del+0xe8/0x1cc [kdsldmod] Tainted: P ra : c00ca04c dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] Status: 1000ce03 KERNEL EXL IE Cause : 90800010 BadVA : 7ffffffe PrId : 00018448 Modules linked in: isdn_fbox_fon4 ubik2 vfat fat nls_cp437 nls_iso8859_1 usb_sto rage sd_mod scsi_mod kdsldmod usbahcicore usbcore tiatm Piglet Process dsld (pid: 761, threadinfo=95272000, task=95261ba8) Stack : 95272000 95273ce0 00000000 c00b9420 95a9e27c 95a9e27c 94d4e528 94d4c2b8 c00ca04c c00f9370 94d32b68 00000000 00000000 00000001 940a497c 940a4938 940209d4 94200000 00000001 94220000 c0133ee0 00000000 94ccff60 94ccff60 7fc48f60 00000000 10001390 00000001 00000000 c00b9420 94d4e01c 00000000 1000ce01 94200000 1401a8c0 0000e11a 00000001 95273df8 00000000 95273d60 ... Call Trace: [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<c00f9370>] dslinterface_igdportmapping_add+0x84/0xe0 [kdsldmod] [<940a497c>] sys_semtimedop+0x4a4/0x638 [<940a4938>] sys_semtimedop+0x460/0x638 [<940209d4>] __wake_up+0x40/0x7c [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<940209d4>] __wake_up+0x40/0x7c [<94029e5c>] tasklet_action+0x88/0xdc [<94029a80>] do_softirq+0x58/0x8c [<9402999c>] __do_softirq+0x6c/0xf8 [<94029978>] __do_softirq+0x48/0xf8 [<940422bc>] handle_IRQ_event+0x64/0xd8 [<94114e28>] dev_ifsioc+0x20/0x49c [<94000f68>] mips_irq_check_hw_interrupt_0+0x10/0x18 [<941f0000>] netlink_proto_init+0x224/0x2ac [<94076314>] do_ioctl+0x64/0x78 [<94029e5c>] tasklet_action+0x88/0xdc [<9407665c>] vfs_ioctl+0x334/0x354 [<94029a80>] do_softirq+0x58/0x8c [<940766cc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Code: 34420001 02629026 8e420004 <10400003> 8e450000 0803879b ac450000 ae25 0004 8e430000 ngCall Trace: [<94023d58>] panic+0x30/0x194 [<94026560>] do_exit+0x84/0xad8 [<9400bb1c>] __die_if_kernel+0x0/0x24 [<9400c83c>] do_ade+0x22c/0x330 [<9400c810>] do_ade+0x200/0x330 [<94042420>] __do_IRQ+0xf0/0x150 [<9400647c>] handle_adel_int+0x34/0x58 [<94001430>] ohio_hw0_irqdispatch+0xe0/0xf8 [<c00e1d70>] timercb_del+0x0/0x1cc [kdsldmod] [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<c00e1e58>] timercb_del+0xe8/0x1cc [kdsldmod] [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<c00ca04c>] dp_ipmasq_igdportmapping_add+0xbc/0x3cc [kdsldmod] [<c00f9370>] dslinterface_igdportmapping_add+0x84/0xe0 [kdsldmod] [<940a497c>] sys_semtimedop+0x4a4/0x638 [<940a4938>] sys_semtimedop+0x460/0x638 [<940209d4>] __wake_up+0x40/0x7c [<c00b9420>] kdsld_ioctl+0x2044/0x2628 [kdsldmod] [<940209d4>] __wake_up+0x40/0x7c [<94029e5c>] tasklet_action+0x88/0xdc [<94029a80>] do_softirq+0x58/0x8c [<9402999c>] __do_softirq+0x6c/0xf8 [<94029978>] __do_softirq+0x48/0xf8 [<940422bc>] handle_IRQ_event+0x64/0xd8 [<94114e28>] dev_ifsioc+0x20/0x49c [<94000f68>] mips_irq_check_hw_interrupt_0+0x10/0x18 [<941f0000>] netlink_proto_init+0x224/0x2ac [<94076314>] do_ioctl+0x64/0x78 [<94029e5c>] tasklet_action+0x88/0xdc [<9407665c>] vfs_ioctl+0x334/0x354 [<94029a80>] do_softirq+0x58/0x8c [<940766cc>] sys_ioctl+0x50/0x94 [<9400d380>] stack_done+0x20/0x3c [<9400d380>] stack_done+0x20/0x3c Kernel panic - not syncing: Aiee, killing interrupt handler! <0>Rebooting in 5 seconds..
Zitieren
