Debian Linux Kernel 2.6.18-4-686 #1 SMP mit einer Sirrix 4S0-Karte. Es sind noch keine ISDN-Kabel angeschlossen (bin nicht vor Ort).
Sirrix-Treiberpaket: srx-pci-070214
Asterisk 1.2.13 (Debian-Paket, Classic, kein Bristuff).
Treiber kompilieren klappt. Ich lade dann
modprobe sirrix_base
modprobe sirrix_pfic
das klappt.
Beim Laden von
modprobe sirrix_bch
kommt:
dmesg zeigt:Code:FATAL: Error inserting sirrix_bch (/lib/modules/2.6.18-4-686/extra/bchdev/sirrix_bch.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Code:sirrix_base Sirrix.PCI release-070214 sirrix_base Initializing Layer 1 Dev sirrix_base Initializing Layer 1 functions sirrix_base Initializing Port Management sirrix_base Initializing Card Management sirrix_base Initializing datastructure for PCM sirrix_base initialized sirrix_pfic Sirrix.PCI release-070214 PCI: Enabling device 0000:06:00.0 (0000 -> 0002) ACPI: PCI Interrupt 0000:06:00.0[A] -> GSI 21 (level, low) -> IRQ 66 sirrix_pfic Card with correct VERSION_ID (0x20061123) found! sirrix_pfic Card with correct serial number 0x0303718e found! sirrix_pfic Found 1 devices sirrix_pfic Starting up PFIC 00 with serial number 0x0303718e sirrix_pfic Disabling interrupts from all IPACs sirrix_pfic Clearing RAM sirrix_pfic Enabling PFIC 00 as PCM MASTER sirrix_pfic Enabling PFIC 00 as SYNC MASTER sirrix_pfic initialized sirrix_bch: Unknown symbol layer1_set_all_buf_size sirrix_bch: Unknown symbol management1_inc_chan_use sirrix_bch: Unknown symbol management1_dec_chan_useRatlos ... hat jemand 'ne Idee?
Udo
Zitieren
