Where is the output of dmesg? There you can see the missing symbols when you try to insmod this modules.
Greets Oliver
Greets Oliver
Router: Fritz!Box Fon WLAN 7570, 7390, 7320, 7270, 3170
Anbindung: T-Online DSL 16.000 RAM
Visit ##fritzbox on Freenode for help
Spenden für Freetz
It show something strange
Code:insmod: cannot insert `/var/tmp/usbserial.ko': Success (17): Success # insmod /var/tmp/ti_usb_3410_5052.ko -v insmod: cannot insert `/var/tmp/ti_usb_3410_5052.ko': Success (2): Success # insmod /var/tmp/safe_serial.ko -v insmod: cannot insert `/var/tmp/safe_serial.ko': Success (2): Success # insmod /var/tmp/pl2303.ko -v insmod: cannot insert `/var/tmp/pl2303.ko': Success (2): Success # insmod /var/tmp/keyspan.ko -v insmod: cannot insert `/var/tmp/keyspan.ko': Success (2): Success # insmod /var/tmp/io_ti.ko -v insmod: cannot insert `/var/tmp/io_ti.ko': Success (2): Success # insmod /var/tmp/mct_u232.ko -v insmod: cannot open module `/var/tmp/mct_u232.ko': No such file or directory # insmod /var/tmp/mct_u.ko -v insmod: cannot open module `/var/tmp/mct_u.ko': No such file or directory # insmod /var/tmp/mct_u232.ko -v insmod: cannot open module `/var/tmp/mct_u232.ko': No such file or directory # insmod /var/tmp/mct_u232.ko -v insmod: cannot open module `/var/tmp/mct_u232.ko': No such file or directory # insmod /var/tmp/mct_u232.ko -v insmod: cannot insert `/var/tmp/mct_u232.ko': Success (2): Success # # dmesg nd extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found extract_dst: dev lan no iph found kdsld: Channel 0 closed (physical) kdsld: internet: disconnected kdsld: PPP led: off (value=0) kdsld: Channel 0 up (physical outgoing) kdsld: Channel 0 closed (physical) kdsld: internet: Auth failed (permission denied) username "GMX/(B40b6e6fe)3876-245@online.de" retry 0 kdsld: Channel 0 up (physical outgoing) kdsld: internet: set_snd_ipaddr: 77.176.223.139 kdsld: internet: connected kdsld: PPP led: on (value=1) kdsld: internet: IGMPv3 report (1 groups) kdsld: internet: IGMPv3 report (group=239.192.152.143,exclude,nsrc=0) kdsld: internet: mc group 239.192.152.143 added kdsld: ERROR: internet: ipmasq: pptp: ill. pptp packet (>>>) count=1 err=-1 kdsld: ERROR: internet: ipmasq: pptp: 192.168.178.23:2953 <-> 85.21.143.174:1723 kdsld: ERROR: internet: ipmasq: pptp: h->len=4930 datalen=68 kdsld: ERROR: internet: ipmasq: pptp: msg_type=26996 ctrl_msg_type=25966 kdsld: ERROR: internet: ipmasq: pptp: cookie=0x546f7272 reserved0=8308 kdsld: ERROR: internet: ipmasq: pptp: ill. pptp packet (<<<) count=1 err=-1 kdsld: ERROR: internet: ipmasq: pptp: 192.168.178.23:2953 <-> 85.21.143.174:1723 kdsld: ERROR: internet: ipmasq: pptp: h->len=4930 datalen=197 kdsld: ERROR: internet: ipmasq: pptp: msg_type=26996 ctrl_msg_type=25966 kdsld: ERROR: internet: ipmasq: pptp: cookie=0x546f7272 reserved0=8308 kdsld: ERROR: internet: ipmasq: pptp: ill. pptp packet (>>>) count=1 err=-2 kdsld: ERROR: internet: ipmasq: pptp: 192.168.178.23:2953 <-> 85.21.143.174:1723 kdsld: ERROR: internet: ipmasq: pptp: h->len=0 datalen=130 kdsld: ERROR: internet: ipmasq: pptp: msg_type=57 ctrl_msg_type=14949 kdsld: ERROR: internet: ipmasq: pptp: cookie=0x14006431 reserved0=12393 #
Geändert von frank_m24 (15.01.2008 um 19:32 Uhr) Grund: QUOTE -> CODE TAGS
I thought about something like this:
While trying to load this modules I recognized that "insmod /var/tmp/ti_usb_3410_5052.ko -v" is not correct.Code:pl2303: Unknown symbol usb_serial_disconnect pl2303: Unknown symbol usb_serial_probe pl2303: Unknown symbol usb_serial_register pl2303: Unknown symbol usb_serial_deregister
It works for me this way:
Greets OliverCode:/var/mod/root/serial # insmod pl2303.ko /var/mod/root/serial # lsmod |grep pl2303 pl2303 20240 0 usbserial 28320 1 pl2303 usbcore 113328 5 pl2303,usbserial,usb_storage,usbahcicore
Spenden für Freetz
if new device "usbserial" appeared in lsmod, does it mean that module was successfully loaded?
this means only that the usbserial.ko module is loaded.
this is needed for the following device-special *.ko.
seem's that your adapter hasn't a general kernel support in 2.6.13.1
purchase another one like the ftdi or pl2303. they are working.
partly dmesg:Code:insmod usbserial.ko insmod pl2303.ko lsmod Module Size Used by Tainted: P pl2303 20240 0 usbserial 28320 1 pl2303 tiap 450752 0 usbahcicore 26064 0 usbcore 113328 4 pl2303,usbserial,usbahcicore capi_codec 93456 0 isdn_fbox_fon4 964336 1 capi_codec ubik2 78608 3 isdn_fbox_fon4 tiatm 109008 1 ubik2 jffs2 108832 1 Piglet 9312 0
Code:usb 1-1: new full speed USB device using ahci and address 2 usb 1-1: reset full speed USB device using ahci and address 2 usbcore: registered new driver usbserial drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0 drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303 usbcore: registered new driver pl2303 drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.12
Geändert von heini66 (15.01.2008 um 10:00 Uhr)
Well, this is a strange idea.
You already know that your USB converter is a ch341.
You already know that someone took the time to write a driver for it. That would have been unnecessary if one of the present drivers would support it.
As such it is unlikely that one of the other drivers would recognize your converter, and the (lack of) results so far show it.
You could try to use the driver that you found. It may or may not work with the older kernel on the FritzBox.
But it seems that you are not familiar enough with kernel modules to even try it.
Also, some of your questions seem to indicate that you may even not be familiar enough with Linux to use it, even if you had a driver to support it.
The easiest solution for you would be to find an USB converter that is supported by the current drivers.
RalfFriedl, you are right - I'v never worked with linux before, never compiled something in linux and never installed modules for FritzBox.
Thats why my questions are so stupid
Also I understand that nobody write driver for me - thats why I try existing drivers.
I'l try to purchase converter, based on pl2303 chipset.
Is it correct one?http://cgi.ebay.de/ws/eBayISAPI.dll?...link:middle:de
Will it defenetely work with
insmod usbserial.ko
insmod pl2303.ko
I never used a USB to serial converter, neither on a FritzBox nor on PC Linux and also not on Windows.
But as far as I know, others had success with the pl2303 chip, and the converter from your link claims to have a pl2303 Chip, so it will probably work.
However, the problem remains that you also need an application for your box.
I suggest that you first try it on a normal PC Linux.
Many things are similar, but overall it will be easier than to develop a program for your box. After you have a working program on your PC Linux system, you can try to port it to your box.
I made already some simple scripts for FB (debug.cfg), so I think this will be next step, after I'l be able to send some data to serial port.
i could only tell that this
http://cgi.ebay.de/USB-DATENKABEL-FU...QQcmdZViewItem
has a pl2303 inside the usb plug. cut the phone jack, bl = gnd, tx = bl ans ws = rx.
Thats again me
I have now converter, based on pl2303 chip.
I can execute now "-insmod pl2303.ko", but only after command "insmod usbserial.ko".
finally that is my lsmod output:
I see there is device pl2303 in lsmod list.Code:# lsmod Module Size Used by Tainted: P pl2303 20240 0 usbserial 28320 1 pl2303 vfat 11392 1 fat 49072 1 vfat nls_cp437 5248 1 nls_iso8859_1 3584 1 usb_storage 33008 1 sd_mod 14864 2 scsi_mod 92560 2 usb_storage,sd_mod kdsldmod 540160 2 usbahcicore 25616 0 usbcore 113232 5 pl2303,usbserial,usb_storage,usbahcicore isdn_fbox_fon4 896960 0 ubik2 69168 3 isdn_fbox_fon4 tiatm 107712 1 ubik2 Piglet 9312 0 # cd /dev/ # ls Piglet mtd6 sda13 sdb8 sdd15 acxHwDrv mtd7 sda14 sdb9 sdd2 avm_event mtd8 sda15 sdc sdd3 avm_power mtd9 sda2 sdc1 sdd4 capi20 mtdblock0 sda3 sdc10 sdd5 console mtdblock1 sda4 sdc11 sdd6 debug mtdblock10 sda5 sdc12 sdd7 kdsld mtdblock2 sda6 sdc13 sdd8 kdsld_traffic mtdblock3 sda7 sdc14 sdd9 kdsld_user mtdblock4 sda8 sdc15 tffs kdsldptrace0 mtdblock5 sda9 sdc2 tiatm kdsldptrace1 mtdblock6 sdb sdc3 tty kdsldptrace2 mtdblock7 sdb1 sdc4 tty0 kdsldptrace3 mtdblock8 sdb10 sdc5 ttyS0 kdsldptrace4 mtdblock9 sdb11 sdc6 ttyp0 kmem new_led sdb12 sdc7 ttyp1 led null sdb13 sdc8 ttyp2 mem ptmx sdb14 sdc9 ubik_debug mtd0 pts sdb15 sdd urandom mtd1 random sdb2 sdd1 usblp0 mtd10 sda sdb3 sdd10 userman mtd2 sda1 sdb4 sdd11 watchdog mtd3 sda10 sdb5 sdd12 mtd4 sda11 sdb6 sdd13 mtd5 sda12 sdb7 sdd14
But how can I find comport name to use in echo command?
Geändert von frank_m24 (26.01.2008 um 18:24 Uhr) Grund: QUOTE -> CODE Tags
You could use "modload pl2303", if your modules are installed in the right place. modload also loads the dependant modules.
With insmod you must load all modules manually.
TryBut how can I find comport name to use in echo command?
Code:mknod /dev/ttyUSB0 c 188 0 echo TEST > /dev/ttyUSB0
Great!!!
I just found solution, return back to this thread to write it in - and see that U already gave answer! Thanx a lot.
One correction - /dev/... rise error - readonly mode.
If I use /var/ instead of /dev/ - all works and I can send data to my display!
I'm very happy with this solved problem
