asterisk 1.4.18 released
Netview
IPPF-Promi
1 Apr 2004
changelog:
    1 2008-01-30  Russell Bryant <[email protected]>
    2
    3 	* Asterisk 1.4.18 released.
    4
    5 2008-01-30 15:41 +0000 [r101222]  Joshua Colp <[email protected]>
    6
    7 	* main/slinfactory.c: Fix an issue where if a frame of higher
    8 	  sample size preceeded a frame of lower sample size and
    9 	  ast_slinfactory_read was called with a sample size of the
   10 	  combined values or higher a crash would happen. (closes issue
   11 	  #11878) Reported by: stuarth
   12
   13 2008-01-30 15:34 +0000 [r101219]  Jason Parker <[email protected]>
   14
   15 	* configs/extensions.conf.sample: Change default config to use
   16 	  descending channel order of groups, rather than ascending. Fixes
   17 	  a potential source of confusion in glare-type situations. Issue
   18 	  11875, reported by JimVanM.
   19
   20 2008-01-30 15:23 +0000 [r101216]  Mark Michelson <[email protected]>
   21
   22 	* apps/app_queue.c: Fix a logic error with regards to autofill.
   23 	  Prior to this change, it was possible for a caller to go out of
   24 	  turn if autofill were enabled and callers ahead in the queue were
   25 	  attempting to call a member. This change fixes this.
   26
   27 2008-01-30 11:20 +0000 [r101152]  Olle Johansson <[email protected]>
   28
   29 	* channels/chan_sip.c: Stop musiconhold on attended transfer.
   30 	  (closes issue #11872) Reported by: gareth Patches:
   31 	  svn-101018.patch uploaded by gareth (license 208)
   32
   33 2008-01-29 23:50 +0000 [r101080]  Dwayne M. Hubbard <[email protected]>
   34
   35 	* build_tools/make_version: updated build_tools to handle the
   36 	  autotag directory structure changes; changes related to BE-353.
   37 	  Patch by The Russell and reviewed by The Me.
   38
   39 2008-01-29 23:02 +0000 [r100973-101035]  Mark Michelson <[email protected]>
   40
   41 	* apps/app_queue.c: Remove a memory leak from updating realtime
   42 	  queues
   43
   44 	* apps/app_queue.c: Fixing an erroneous return value returned when
   45 	  attempting to pause or unpause a queue member fails. Fixes
   46 	  BE-366, thanks to John Bigelow for writing the patch.
   47
   48 2008-01-29 17:57 +0000 [r100934]  Joshua Colp <[email protected]>
   49
   50 	* apps/app_mixmonitor.c: Don't forget to record the channel so we
   51 	  know whether it is bridged or not later. (closes issue #11811)
   52 	  Reported by: slavon
   53
   54 2008-01-29 17:43 +0000 [r100932]  Russell Bryant <[email protected]>
   55
   56 	* main/Makefile: Fix the last couple of issues related to building
   57 	  from a path that contains spaces. (closes issue #11834)
   58
   59 2008-01-29 17:41 +0000 [r100930]  Jason Parker <[email protected]>
   60
   61 	* channels/misdn_config.c: Initialize an array to 0s if config
   62 	  option not specified. (closes issue #11860) Patches:
   63 	  misdn_get_config.v1.diff uploaded by IgorG (license 20)
   64
   65 2008-01-29 17:21 +0000 [r100882-100922]  Russell Bryant <[email protected]>
   66
   67 	* Makefile: Use GNU make magic instead of shell magic to escape
   68 	  spaces in the working directory. (related to issue #11834)
   69
   70 	* Makefile: Fix building Asterisk when the working path has spaces
   71 	  in it. (closes issue #11834) Reported by: spendergrass Patched
   72 	  by: me
   73
   74 2008-01-29 16:10 +0000 [r100835]  Jason Parker <[email protected]>
   75
   76 	* channels/chan_zap.c: Allow zap groups above 30 to work properly.
   77 	  (closes issue #11590) Reported by: tbsky
   78
   79 2008-01-29 10:36 +0000 [r100793]  Christian Richter <[email protected]>
   80
   81 	* channels/chan_misdn.c: fixed potential segfault in misdn show
   82 	  channels CLI command
   83
   84 2008-01-29 08:26 +0000 [r100740]  Olle Johansson <[email protected]>
   85
   86 	* channels/chan_sip.c: (closes issue #11736) Reported by: MVF
   87 	  Patches: bug11736-2.diff uploaded by oej (license 306) Tested by:
   88 	  oej, MVF, revolution (russellb: This was the showstopper for the
   89 	  release.)
   90
   91 2008-01-28 21:02 +0000 [r100675]  Tilghman Lesher <[email protected]>
   92
   93 	* main/pbx.c: WaitExten didn't handle AbsoluteTimeout properly
   94 	  (went to 't' instead of 'T')
   95
   96 2008-01-28 20:55 +0000 [r100673]  Mark Michelson <[email protected]>
   97
   98 	* channels/chan_vpb.cc, UPGRADE.txt: Undoing the deprecation of
   99 	  chan_vpb. It is alive and well.
  100
  101 2008-01-28 20:42 +0000 [r100672]  Jason Parker <[email protected]>
  102
  103 	* apps/app_voicemail.c: When using ODBC_STORAGE, make sure we put
  104 	  greeting files into the database like we do with the others.
  105 	  Issue #11795 Reported by: dimas Patches: vmgreet.patch uploaded
  106 	  by dimas (license 88)
  107
  108 2008-01-28 18:34 +0000 [r100626-100629]  Russell Bryant <[email protected]>
  109
  110 	* channels/chan_sip.c: For some reason, the use of this strdupa()
  111 	  is leading to memory corruption on freebsd sparc64. This trivial
  112 	  workaround fixes it. (closes issue #10300, closes issue #11857,
  113 	  reported by mattias04 and Home-of-the-Brave)
  114
  115 	* res/res_features.c: Fix a crash in ast_masq_park_call() (issue
  116 	  #11342) Reported by: DEA Patches: res_features-park.txt uploaded
  117 	  by DEA (license 3)
  118
  119 2008-01-28 18:23 +0000 [r100624]  Jason Parker <[email protected]>
  120
  121 	* channels/chan_zap.c: Correct a comment which made little/no
  122 	  sense.
  123
  124 2008-01-28 17:15 +0000 [r100581]  Russell Bryant <[email protected]>
  125
  126 	* main/channel.c, channels/chan_local.c,
  127 	  include/asterisk/channel.h: Make some deadlock related fixes.
  128 	  These bugs were discovered and reported internally at Digium by
  129 	  Steve Pitts. - Fix up chan_local to ensure that the channel lock
  130 	  is held before the local pvt lock. - Don't hold the channel lock
  131 	  when executing the timing function, as it can cause a deadlock
  132 	  when using chan_local. This actually changes the code back to be
  133 	  how it was before the change for issue #10765. But, I added some
  134 	  other locking that I think will prevent the problem reported
  135 	  there, as well.
  136
  137 2008-01-27 21:59 +0000 [r100465]  Tilghman Lesher <[email protected]>
  138
  139 	* main/rtp.c, channels/chan_mgcp.c, main/cdr.c,
  140 	  channels/chan_misdn.c, main/dnsmgr.c, channels/chan_sip.c,
  141 	  channels/chan_h323.c, include/asterisk/sched.h, main/file.c,
  142 	  pbx/pbx_dundi.c, channels/chan_iax2.c: When deleting a task from
  143 	  the scheduler, ignoring the return value could possibly cause
  144 	  memory to be accessed after it is freed, which causes all sorts
  145 	  of random memory corruption. Instead, if a deletion fails, wait a
  146 	  bit and try again (noting that another thread could change our
  147 	  taskid value). (closes issue #11386) Reported by: flujan Patches:
  148 	  20080124__bug11386.diff.txt uploaded by Corydon76 (license 14)
  149 	  Tested by: Corydon76, flujan, stuarth`
  150
  151 2008-01-25 22:32 +0000 [r100418]  Mark Michelson <[email protected]>
  152
  153 	* channels/chan_vpb.cc, UPGRADE.txt: Deprecating chan_vpb. It is
  154 	  now preferred that users of Voicetronix products use chan_zap in
  155 	  combination with their zaptel drivers.
  156
  157 2008-01-25 21:24 +0000 [r100378]  Jason Parker <[email protected]>
  158
  159 	* channels/chan_sip.c: This would have never been true, since we're
  160 	  passing (sizeof(req.data) - 1) as the len to recvfrom().
  161
  162 2008-01-24 21:57 +0000 [r100264]  Kevin P. Fleming <[email protected]>
  163
  164 	* include/asterisk/app.h: make these macros not assume that the
  165 	  only other field in the structure is 'argc'... this is true when
  166 	  someone uses AST_DECLARE_APP_ARGS, but it's perfectly reasonable
  167 	  to define your own structure as long as it has the right fields
  168
  169 2008-01-24 17:22 +0000 [r100164]  Russell Bryant <[email protected]>
  170
  171 	* main/asterisk.c: Update main Asterisk copyright info to 2008
  172
  173 2008-01-24 16:41 +0000 [r100138]  Jason Parker <[email protected]>
  174
  175 	* main/acl.c: Fix compilation on Solaris. (closes issue #11832)
  176 	  Patches: bug-11832.diff uploaded by snuffy (license 35)
  177
  178 2008-01-23 21:07 +0000 [r99977-99978]  Olle Johansson <[email protected]>
  179
  180 	* channels/chan_sip.c: Second attempt. Don't change invitestate
  181 	  when receiving 18x messages in CANCEL state. (issue #11736)
  182 	  Reported by: MVF Patch by oej.
  183
  184 	* channels/chan_sip.c: Make sure we don't cancel destruction on
  185 	  calls in CANCEL state, even if we get 183 while waiting for
  186 	  answer on our CANCEL. (issue #11736) Reported by: MVF Patches:
  187 	  bug11736.txt uploaded by oej (license 306) Tested by: MVF
  188
  189 2008-01-23 20:25 +0000 [r99975]  Mark Michelson <[email protected]>
  190
  191 	* apps/app_externalivr.c: Fixing a typo.
  192
  193 2008-01-23 17:46 +0000 [r99923]  Russell Bryant <[email protected]>
  194
  195 	* apps/app_chanspy.c: ChanSpy issues a beep when it starts at the
  196 	  beginning of a list of channels to potentially spy on. However,
  197 	  if there were no matching channels, it would beep at you over and
  198 	  over, which is pretty annoying. Now, it will only beep once in
  199 	  the case that there are no channels to spy on, but it will still
  200 	  beep again once it reaches the beginning of the channel list
  201 	  again. (closes issue #11738, patched by me)
  202
  203 2008-01-23 16:18 +0000 [r99878]  Mark Michelson <[email protected]>
  204
  205 	* channels/chan_sip.c: These flag tests were illogical. They were
  206 	  testing sip_peer flags on a sip_pvt. Thanks to Russell for
  207 	  helping to get this odd problem figured out.
  208
  209 2008-01-23 04:31 +0000 [r99718-99777]  Tilghman Lesher <[email protected]>
  210
  211 	* apps/app_voicemail.c: When we reset the password via an external
  212 	  command, we should also reset the password stored in the
  213 	  in-memory list, too (otherwise it doesn't really take effect).
  214 	  (closes issue #11809) Reported by: davetroy Patches:
  215 	  fix_externpass.diff uploaded by davetroy (license 384)
  216
  217 	* res/res_odbc.c: Oops, should have checked for a NULL obj, here,
  218 	  too
  219
  220 	* main/acl.c: Just confirmed that all current platforms need this
  221 	  header file
  222
  223 2008-01-22 20:56 +0000 [r99652]  Olle Johansson <[email protected]>
  224
  225 	* channels/chan_sip.c: Thanks to Russell's education I realize that
  226 	  BUFSIZ has changed since I learned the C language over 20 years
  227 	  ago... Resetting chan_sip to the size of BUFSIZ that I expected
  228 	  in my old head to avoid to heavy memory allocations on some
  229 	  systems.
  230
  231 2008-01-22 20:34 +0000 [r99643]  Tilghman Lesher <[email protected]>
  232
  233 	* main/acl.c: Fix the defines for OS X (and Solaris, too)
  234
  235 2008-01-22 17:41 +0000 [r99592-99594]  Olle Johansson <[email protected]>
  236
  237 	* channels/chan_local.c, res/res_features.c, channels/chan_agent.c,
  238 	  apps/app_followme.c: Add more dependencies on chan_local and add
  239 	  a note to the description of chan_local so that people don't
  240 	  disable it in menuselect just to clean up.
  241
  242 	* apps/app_dial.c: Add dependency on chan_local to app_dial. Dial
  243 	  still runs without chan_local, but will be missing forwarding
  244 	  functionality.
  245
  246 2008-01-22 16:54 +0000 [r99540]  Tilghman Lesher <[email protected]>
  247
  248 	* main/acl.c: Ensure that we can get an address even when we don't
  249 	  have a default route. (closes issue #9225) Reported by: junky
  250 	  Patches: 20080122__bug9225.diff.txt uploaded by Corydon76
  251 	  (license 14) Tested by: oej, loloski, sergee
  252
  253 2008-01-22 15:08 +0000 [r99501]  Olle Johansson <[email protected]>
  254
  255 	* channels/chan_sip.c: Cleaning up some documentation that led to
  256 	  confusion in a bug report
  257
  258 2008-01-21 23:55 +0000 [r99426]  Mark Michelson <[email protected]>
  259
  260 	* channels/chan_local.c: Fixing an issue wherein monitoring local
  261 	  channels was not possible. During a channel masquerade, the
  262 	  monitors on the two channels involved are swapped. In 99% of the
  263 	  cases this results in the desired effect. However, if monitoring
  264 	  a local channel, this caused the monitor which was on the local
  265 	  channel to get moved onto a channel which is immediately hung up
  266 	  after the masquerade has completed. By swapping the monitors
  267 	  prior to the masquerade, we avoid the problem by tricking the
  268 	  masquerade into placing the monitor back onto the channel where
  269 	  we want it. During the investigation of the issue, the channel's
  270 	  monitor was the only thing that was swapped in such a manner
  271 	  which did not make sense to have done. All other variable
  272 	  swapping made sense.
  273
  274 2008-01-21 18:11 +0000 [r99341]  Tilghman Lesher <[email protected]>
  275
  276 	* res/res_odbc.c, configs/res_odbc.conf.sample,
  277 	  include/asterisk/res_odbc.h: Permit the user to specify number of
  278 	  seconds that a connection may remain idle, which fixes a crash on
  279 	  reconnect with the MyODBC driver. (closes issue #11798) Reported
  280 	  by: Corydon76 Patches: 20080119__res_odbc__idlecheck.diff.txt
  281 	  uploaded by Corydon76 (license 14) Tested by: mvanbaak
  282
  283 2008-01-21 16:01 +0000 [r99301]  Joshua Colp <[email protected]>
  284
  285 	* channels/chan_sip.c: Bump the buffer size for Via headers up to
  286 	  512. There are some exceptionally large Via headers out there.
  287 	  (closes issue #11783) Reported by: ofirroval
  288
  289 2008-01-19 10:05 +0000 [r99187]  Russell Bryant <[email protected]>
  290
  291 	* main/slinfactory.c: Fix a couple of memory leaks with frame
  292 	  handling. Specifically, ast_frame_free() needed to be called on
  293 	  the frame that came from the translator to signed linear.
  294
  295 2008-01-18 22:57 +0000 [r99127]  Joshua Colp <[email protected]>
  296
  297 	* include/asterisk/channel.h: Remove the __ in front of the unused
  298 	  variable. This causes some compilers to freak out.
  299
  300 2008-01-18 21:37 +0000 [r99079-99081]  Russell Bryant <[email protected]>
  301
  302 	* include/asterisk/translate.h, main/frame.c: Revert adding the
  303 	  packed attribute, as it really doesn't make sense why that would
  304 	  do any good. Fix the real bug, which is to do the check to see if
  305 	  the frame came from a translator at the beginning of
  306 	  ast_frame_free(), instead of at the end. This ensures that it
  307 	  always gets checked, even if none of the parts of the frame are
  308 	  malloc'd, and also ensures that we aren't looking at free'd
  309 	  memory in the case that it is a malloc'd frame. (closes issue
  310 	  #11792, reported by explidous, patched by me)
  311
  312 	* include/asterisk/translate.h: Since we're relying on the offset
  313 	  between the frame and the beginning of the translator pvt struct,
  314 	  set the packed attribute to make sure we get to the right place.
  315 	  (potential fix for issue #11792)
  316
  317 2008-01-18 17:13 +0000 [r99032]  Terry Wilson <[email protected]>
  318
  319 	* res/res_features.c: This should at least temporarily fix a
  320 	  problem where the 't' Dial option is incorrectly passed to the
  321 	  transferee when built-in attended transfers are used. There is
  322 	  still a problem with 'T', but better to fix some problems than no
  323 	  problems while we work on it. (closes issue #7904) Reported by:
  324 	  k-egg Patches: transfer-fix-b14-r97657.diff uploaded by sergee
  325 	  (license 138) Tested by: sergee, otherwiseguy
  326
  327 2008-01-17 23:42 +0000 [r99007-99014]  Pari Nannapaneni <[email protected]>
  328
  329 	* configs/cdr.conf.sample: doh! revert a revert of a revert
  330 	  (changed by mistake in 99010)
  331
  332 	* main/manager.c, configs/cdr.conf.sample: missed that one while
  333 	  reverting
  334
  335 	* main/manager.c: reverting 99001 - We need the Max-Age for
  336 	  extending the life of cookie mansession_id
  337
  338 2008-01-17 22:37 +0000 [r99004]  Russell Bryant <[email protected]>
  339
  340 	* main/frame.c, channels/chan_iax2.c, include/asterisk/frame.h:
  341 	  Have IAX2 optimize the codec translation path just like chan_sip
  342 	  does it. If the caller's codec is in our codec list, move it to
  343 	  the top to avoid transcoding. (closes issue #10500) Reported by:
  344 	  stevedavies Patches: iax-prefer-current-codec.patch uploaded by
  345 	  stevedavies (license 184) iax-prefer-current-codec.1.4.patch
  346 	  uploaded by stevedavies (license 184) Tested by: stevedavies, pj,
  347 	  sheldonh
  348
  349 2008-01-17 21:31 +0000 [r99001]  Kevin P. Fleming <[email protected]>
  350
  351 	* main/manager.c: we should only send the Set-Cookie header to the
  352 	  browser on the first response after creating a manager session,
  353 	  not on every response (doing so causes the browser to clear any
  354 	  local cookies it may have associated with the session)
  355
  356 2008-01-17 16:19 +0000 [r98991]  Jason Parker <[email protected]>
  357
  358 	* configs/zapata.conf.sample: Add a clarification about the
  359 	  immediate= option of zapata.conf Issue 11784, patch by klaus3000.
  360
  361 2008-01-16 22:36 +0000 [r98982]  Russell Bryant <[email protected]>
  362
  363 	* .cleancount, include/asterisk/channel.h: Add an unused pointer to
  364 	  the ast_channel struct. This makes the ast_channel structure
  365 	  retain the same size as it had in previous 1.4 releases. Also,
  366 	  all of the offsets for members in the structure are still the
  367 	  same (except for the two pointers that got replaced for the new
  368 	  spy/whisper architecture.)
  369
  370 2008-01-16 20:34 +0000 [r98966-98973]  Joshua Colp <[email protected]>
  371
  372 	* .cleancount: Bump up cleancount due to previous commit that
  373 	  changed the channel structure.
  374
  375 	* apps/app_chanspy.c, apps/app_mixmonitor.c, main/rtp.c,
  376 	  main/channel.c, apps/app_meetme.c, include/asterisk/audiohook.h
  377 	  (added), main/Makefile, include/asterisk/chanspy.h (removed),
  378 	  include/asterisk/channel.h, main/audiohook.c (added): Replace
  379 	  current spy architecture with backport of audiohooks. This should
  380 	  take care of current known spy issues.
  381
  382 	* channels/chan_iax2.c: Add missing NULLs at end of two
  383 	  ast_load_realtimes. (closes issue #11769) Reported by: tequ
  384 	  Patches: chaniax.patch uploaded by dimas (license 88)
  385
  386 2008-01-16 17:20 +0000 [r98964]  Mark Michelson <[email protected]>
  387
  388 	* channels/chan_local.c: Fix a deadlock in chan_local in
  389 	  local_hangup. There was contention because the local_pvt was held
  390 	  and it was attempting to lock a channel, which is the incorrect
  391 	  locking order. (closes issue #11730) Reported by: UDI-Doug
  392 	  Patches: 11730.patch uploaded by putnopvut (license 60) Tested
  393 	  by: UDI-Doug
  394
  395 2008-01-16 15:08 +0000 [r98951-98960]  Joshua Colp <[email protected]>
  396
  397 	* main/dial.c: Introduce a lock into the dialing API that protects
  398 	  it when destroying the structure. (closes issue #11687) Reported
  399 	  by: callguy Patches: 11687.diff uploaded by file (license 11)
  400
  401 	* main/rtp.c: Add two more SDP names for ulaw and alaw. (closes
  402 	  issue #11777) Reported by: tootai
  403
  404 	* channels/chan_sip.c: Don't drop the old record route information
  405 	  when dealing with packets related to a reinvite. (closes issue
  406 	  #11545) Reported by: kebl0155 Patches: reinvite-patch.txt
  407 	  uploaded by kebl0155 (license 356)
  408
  409 	* build_tools/menuselect-deps.in, configure,
  410 	  include/asterisk/autoconfig.h.in, codecs/codec_speex.c,
  411 	  configure.ac, makeopts.in: Add autoconf logic for speexdsp. Later
  412 	  versions use a separate library for some things so we need to use
  413 	  it if present in codec_speex. (closes issue #11693) Reported by:
  414 	  yzg
  415
  416 2008-01-15 23:50 +0000 [r98943-98946]  Russell Bryant <[email protected]>
  417
  418 	* channels/chan_sip.c: Change a buffer in check_auth() to be a
  419 	  thread local dynamically allocated buffer, instead of a massive
  420 	  buffer on the stack. This fixes a crash reported by Qwell due to
  421 	  running out of stack space when building with LOW_MEMORY defined.
  422 	  On a very related note, the usage of BUFSIZ in various places in
  423 	  chan_sip is arbitrary and careless. BUFSIZ is a system specific
  424 	  define. On my machine, it is 8192, but by definition (according
  425 	  to google) could be as small as 256. So, this buffer in
  426 	  check_auth was 16 kB. We don't even support SIP messages larger
  427 	  than 4 kB! Further usage of this define should be avoided, unless
  428 	  it is used in the proper context.
  429
  430 	* main/rtp.c, include/asterisk/translate.h, main/frame.c,
  431 	  main/translate.c, main/abstract_jb.c, channels/chan_iax2.c,
  432 	  codecs/codec_zap.c, include/asterisk/frame.h: Commit a fix for
  433 	  some memory access errors pointed out by the valgrind2.txt output
  434 	  on issue #11698. The issue here is that it is possible for an
  435 	  instance of a translator to get destroyed while the frame
  436 	  allocated as a part of the translator is still being processed.
  437 	  Specifically, this is possible anywhere between a call to
  438 	  ast_read() and ast_frame_free(), which is _a lot_ of places in
  439 	  the code. The reason this happens is that the channel might get
  440 	  masqueraded during this time. During a masquerade, existing
  441 	  translation paths get destroyed. So, this patch fixes the issue
  442 	  in an API and ABI compatible way. (This one is for you,
  443 	  paravoid!) It changes an int in ast_frame to be used as flag
  444 	  bits. The 1 bit is still used to indicate that the frame contains
  445 	  timing information. Also, a second flag has been added to
  446 	  indicate that the frame came from a translator. When a frame with
  447 	  this flag gets released and has this flag, a function is called
  448 	  in translate.c to let it know that this frame is doing being
  449 	  processed. At this point, the flag gets cleared. Also, if the
  450 	  translator was requested to be destroyed while its internal frame
  451 	  still had this flag set, its destruction has been deffered until
  452 	  it finds out that the frame is no longer being processed.
  453 	  Admittedly, this feels like a hack. But, it does fix the issue,
  454 	  and I was not able to think of a better solution ...
  455
  456 2008-01-15 20:08 +0000 [r98894-98934]  Joshua Colp <[email protected]>
  457
  458 	* channels/chan_sip.c: Based on the boundary found move over the
  459 	  correct amount. (closes issue #11750) Reported by: tasker
  460
  461 	* channels/chan_sip.c: Accept "; boundary=" not just ";boundary="
  462 	  in the multipart mixed content type. (closes issue #11750)
  463 	  Reported by: tasker
  464
  465 2008-01-14 20:59 +0000 [r98849]  Mark Michelson <[email protected]>
  466
  467 	* apps/app_voicemail.c: Adding in appropriate unlocks for the locks
  468 	  I added. Thanks to joetester on IRC for pointing this out.
  469
  470 2008-01-14 17:38 +0000 [r98774]  Russell Bryant <[email protected]>
  471
  472 	* main/translate.c: Revert a change that introduces an unacceptable
  473 	  performance hit and is causing memory leaks ... (from rev 97973)
  474
  475 2008-01-14 16:35 +0000 [r98733-98737]  Mark Michelson <[email protected]>
  476
  477 	* apps/app_queue.c: Fixing another compilation error. I'm a bit off
  478 	  today :(
  479
  480 	* apps/app_queue.c: Oops. Last commit had compilation error.
  481
  482 	* apps/app_queue.c: Adding explicit defaults for missing options to
  483 	  init_queue. This is necessary because if a user either removes or
  484 	  comments one of these options and reloads their queues, the
  485 	  option will not reset to its default, instead maintaining the
  486 	  value from prior to the reload. Thanks to John Bigelow for
  487 	  pointing this error out to me.
  488
  489 2008-01-12 00:05 +0000 [r98467]  Tilghman Lesher <[email protected]>
  490
  491 	* res/res_odbc.c: Add a connection timeout attribute, as that was
  492 	  what was intended with the login timeout, but ODBC divides it up
  493 	  into 2 different timeouts. (Closes issue #11745)
  494
  495 2008-01-11 22:46 +0000 [r98390]  Russell Bryant <[email protected]>
  496
  497 	* pbx/pbx_dundi.c: Fix up setting the EID on BSD based systems.
  498 	  (closes issue #11646) Reported by: caio1982 Patches:
  499 	  dundi_osx_eid6.diff.txt uploaded by caio1982 (license 22)
  500 	  dundi_osx_eid6-1.4.diff uploaded by caio1982 (license 22) Tested
  501 	  by: caio1982, mvanbaak
  502
  503 2008-01-11 21:28 +0000 [r98372]  Pari Nannapaneni <[email protected]>
  504
  505 	* main/http.c: Comment explaining how to force browser to always
  506 	  read some html files from server.
  507
  508 2008-01-11 19:51 +0000 [r98317-98325]  Joshua Colp <[email protected]>
  509
  510 	* main/rtp.c: If the incoming RTP stream changes codec force the
  511 	  bridge to break if the other side does not support it. (closes
  512 	  issue #11729) Reported by: tsearle Patches:
  513 	  new_codec_patch_udiff.patch uploaded by tsearle (license 373)
  514
  515 	* res/res_agi.c: If the channel is hungup during RECORD FILE send a
  516 	  result code of -1 to be uniform with everything else. (closes
  517 	  issue #11743) Reported by: davevg Patches: res_agi.diff uploaded
  518 	  by davevg (license 209)
  519
  520 2008-01-11 19:10 +0000 [r98315]  Mark Michelson <[email protected]>
  521
  522 	* main/channel.c: Properly report the hangup cause as no answer
  523 	  when someone does not answer (closes issue #10574, reported by
  524 	  boch, patched by moy)
  525
  526 2008-01-11 18:25 +0000 [r98266]  Tilghman Lesher <[email protected]>
  527
  528 	* codecs/gsm/Makefile: Add another exception (which doesn't work)
  529 	  for -march optimization flag. Reported by: thomasmebes Patch by:
  530 	  tilghman (Closes issue #11563)
  531
  532 2008-01-11 18:25 +0000 [r98265]  Russell Bryant <[email protected]>
  533
  534 	* doc/security.txt, main/asterisk.c, configure,
  535 	  include/asterisk/autoconfig.h.in, main/Makefile, configure.ac,
  536 	  makeopts.in: Backport the ability to set the ToS bits on Linux
  537 	  when not running as root. Normally, we would not backport
  538 	  features into 1.4, but, I was convinced by the justification
  539 	  supplied by the supplier of this patch. He pointed out that this
  540 	  patch removes a requirement for running as root, thus reducing
  541 	  the potential impacts of security issues. (closes issue #11742)
  542 	  Reported by: paravoid Patches: libcap.diff uploaded by paravoid
  543 	  (license 200)
  544
  545 2008-01-11 17:22 +0000 [r98219]  Joshua Colp <[email protected]>
  546
  547 	* apps/app_followme.c: Ensure the return value of ast_bridge_call
  548 	  is passed back up as the application return value. This is needed
  549 	  for transfers to function so the PBX core knows to continue
  550 	  execution. (closes issue #10327) Reported by: kkiely
  551
  552 2008-01-11 15:52 +0000 [r98164]  Tilghman Lesher <[email protected]>
  553
  554 	* channels/chan_sip.c: Back out changes from revision 97077, since
  555 	  it wasn't perfect
  556
  557 2008-01-11 03:39 +0000 [r97976-98082]  Russell Bryant <[email protected]>
  558
  559 	* main/frame.c: Fix samples vs. length calculations for g722
  560
  561 	* main/translate.c: Simplify this code with a suggestion from Luigi
  562 	  on the asterisk-dev list. Instead of using is16kHz(), implement a
  563 	  format_rate() function.
  564
  565 	* main/translate.c: Fix various timing calculations that made
  566 	  assumptions that the audio being processed was at a sample rate
  567 	  of 8 kHz.
  568
  569 2008-01-10 23:08 +0000 [r97973]  Tilghman Lesher <[email protected]>
  570
  571 	* channels/chan_sip.c, main/translate.c: 1) When we get a
  572 	  translated frame out, clone it, because if the translator pvt is
  573 	  freed before we use the frame, bad things happen. 2) Getting a
  574 	  failure from ast_sched_delete means that the schedule ID is
  575 	  currently running. Don't just ignore it. (Closes issue #11698)
  576
  577 2008-01-10 21:57 +0000 [r97925]  Mark Michelson <[email protected]>
  578
  579 	* apps/app_voicemail.c: Let us leave a voicemail for ourself if we
  580 	  have logged into VoiceMailMain and chosen to leave a message.
  581 	  (closes issue #11735, reported and patched by jamessan)
  582
  583 2008-01-10 21:37 +0000 [r97849-97889]  Steve Murphy <[email protected]>
  584
  585 	* pbx/ael/ael_lex.c, pbx/Makefile, pbx/ael/ael.flex: Applied the
  586 	  same fixes for ael.flex as was done in 97849 for ast_expr2.fl;
  587 	  overrode the normally generate yyfree func with our own version
  588 	  that checks the pointer for non-null before passing to free().
  589 	  Also takes care of a little problem with 2.5.33 and the use of
  590 	  the __STDC_VERSION__ macro.
  591
  592 	* main/ast_expr2.fl, main/Makefile, main/ast_expr2f.c: This is a
  593 	  fix for 2 things: a problem Terry was having in OSX with null
  594 	  pointers, which was my fault, as I probably forgot to run the sed
  595 	  script last time I made mods. So, I moved the fix into the flex
  596 	  input itself. Then, I found when I used flex 2.5.33, that it was
  597 	  using __STDC_VERSION__, and that's not real good; so I added back
  598 	  in a DIFFERENT sed script to fix that little mess. Tested
  599 	  everything, a couple different ways. Hope I did no harm, at the
  600 	  least.
  601
  602 2008-01-10 20:12 +0000 [r97847]  Jason Parker <[email protected]>
  603
  604 	* include/asterisk/frame.h: Fix a comment that is no longer true.
  605
  606 2008-01-10 16:19 +0000 [r97734-97753]  Russell Bryant <[email protected]>
  607
  608 	* pbx/pbx_kdeconsole.h (removed), configs/modules.conf.sample,
  609 	  pbx/kdeconsole_main.cc (removed): Remove other remnants of
  610 	  pbx_kdeconsole
  611
  612 	* pbx/pbx_kdeconsole.cc (removed), build_tools/menuselect-deps.in,
  613 	  configure, include/asterisk/autoconfig.h.in, configure.ac,
  614 	  makeopts.in: Remove pbx_kdeconsole from the tree. It hasn't
  615 	  worked in ages, and nobody has complained. (closes issue #11706,
  616 	  reported by caio1982)
  617
  618 2008-01-10 15:07 +0000 [r97697]  Joshua Colp <[email protected]>
  619
  620 	* funcs/func_groupcount.c: Don't try to copy the category from the
  621 	  group if no category exists. (closes issue #11724) Reported by:
  622 	  IgorG Patches: group_count.v1.patch uploaded by IgorG (license
  623 	  20)
  624
  625 2008-01-09 23:01 +0000 [r97640-97645]  Russell Bryant <[email protected]>
  626
  627 	* pbx/pbx_gtkconsole.c: Strip terminal sequences from the verbose
  628 	  messages
  629
  630 	* pbx/pbx_gtkconsole.c: Make pbx_gtkconsole build ... but doesn't
  631 	  actually load on my system still (related to issue #11706)
  632
  633 2008-01-09 20:28 +0000 [r97618-97622]  Jason Parker <[email protected]>
  634
  635 	* main/cli.c: Correctly display a message if a command could not be
  636 	  found. Also fix a comment which may have led to this happening.
  637 	  Issue 11718, reported by kshumard.
  638
  639 	* main/cli.c: Fix some locking and return value funkiness. We
  640 	  really shouldn't be unlocking this lock inside of a function,
  641 	  unless we locked it there too.
  642
  643 2008-01-09 18:48 +0000 [r97575]  Mark Michelson <[email protected]>
  644
  645 	* apps/app_queue.c: Part 2 of app_queue doxygen improvements. Some
  646 	  smaller functions this time
  647
  648 2008-01-09 18:02 +0000 [r97529]  Russell Bryant <[email protected]>
  649
  650 	* res/res_features.c: Fix saying the parking space number to the
  651 	  caller doing the parking ...
  652
  653 2008-01-09 17:21 +0000 [r97491]  Kevin P. Fleming <[email protected]>
  654
  655 	* codecs/codec_zap.c: report the same message whether Zaptel does
  656 	  not have transcoder support loaded or no transcoders were found
  657
  658 2008-01-09 16:44 +0000 [r97489]  Philippe Sultan <[email protected]>
  659
  660 	* channels/chan_gtalk.c: Set the caller id within the gtalk_alloc
  661 	  function. As underlined in issue #10437 by Josh, we need to
  662 	  prevent a possible memory leak. We only set the name part of the
  663 	  caller id, the number part is not relevant when dealing with
  664 	  JIDs. Closes issue #11549.
  665
  666 2008-01-09 16:11 +0000 [r97450]  Joshua Colp <[email protected]>
  667
  668 	* apps/app_meetme.c: Don't do conferencing totally in Zaptel if
  669 	  Monitor is running on the channel. (closes issue #11709) Reported
  670 	  by: BigJimmy Patches: patch-meetmerec uploaded by BigJimmy
  671 	  (license 371)
  672
  673 2008-01-09 15:43 +0000 [r97410-97448]  Kevin P. Fleming <[email protected]>
  674
  675 	* channels/chan_zap.c: pass the right variable to get an error
  676 	  string... oops
  677
  678 	* channels/chan_zap.c: add error number output to ioctl failure
  679 	  messages to help with debugging
  680
  681 2008-01-09 00:44 +0000 [r97350]  Tilghman Lesher <[email protected]>
  682
  683 	* main/cli.c, main/editline/readline.c: Allow filename completion
  684 	  on zero-length modules, remove a memory leak, remove a file
  685 	  descriptor leak, and make filename completion thread-safe.
  686 	  Patched and tested by tilghman. (Closes issue #11681)
  687
  688 2008-01-09 00:17 +0000 [r97206-97308]  Mark Michelson <[email protected]>
  689
  690 	* apps/app_queue.c: use the \retval doxygen command properly
  691
  692 	* apps/app_queue.c: Part 1 of N of adding doxygen comments to
  693 	  app_queue. I picked some of the most common functions used (which
  694 	  also happen to be some the biggest/ugliest functions too) to
  695 	  document first. I'm pretty new to doxygen so criticism is
  696 	  welcome.
  697
  698 	* apps/app_queue.c: Some coding guidelines-related cleanup
  699
  700 2008-01-08 20:48 +0000 [r97195]  Joshua Colp <[email protected]>
  701
  702 	* channels/chan_mgcp.c: Fix various DTMF issues in chan_mgcp.
  703 	  (closes issue #11443) Reported by: eferro Patches:
  704 	  dtmf_control_hybrid-inband-mode.patch uploaded by eferro (license
  705 	  337)
  706
  707 2008-01-08 20:47 +0000 [r97194]  Tilghman Lesher <[email protected]>
  708
  709 	* main/autoservice.c, main/utils.c: Increase constants to where
  710 	  we're less likely to hit them while debugging. (Closes issue
  711 	  #11694)
  712
  713 2008-01-08 20:42 +0000 [r97192]  Mark Michelson <[email protected]>
  714
  715 	* apps/app_voicemail.c: Making some changes designed to not allow
  716 	  for a corrupted mailstream for a vm_state. 1. Add locking to the
  717 	  vm_state retrieval functions so that no linked list corruption
  718 	  occurs. 2. Make sure to always grab the persistent vm_state when
  719 	  mailstream access is necessary. 3. Correct an incorrect return
  720 	  value in the init_mailstream function. (closes issue #11304,
  721 	  reported by dwhite)
  722
  723 2008-01-08 19:53 +0000 [r97093-97152]  Joshua Colp <[email protected]>
  724
  725 	* funcs/func_groupcount.c: If no group has been provided to the
  726 	  GROUP_COUNT dialplan function then use the first one specific to
  727 	  the channel. (closes issue #11077) Reported by: m4him
  728
  729 	* apps/app_queue.c: Make app_queue calls work with directed pickup.
  730 	  (closes issue #11700) Reported by: jbauer
  731
  732 2008-01-08 18:02 +0000 [r97077]  Tilghman Lesher <[email protected]>
  733
  734 	* main/asterisk.c, channels/chan_sip.c: Apply multiple crash fixes,
  735 	  found in issue #11386, but not completely closing that issue.
  736
  737 2008-01-07 20:47 +0000 [r96884-96932]  Russell Bryant <[email protected]>
  738
  739 	* configs/extensions.conf.sample, /: Merged revisions 96931 via
  740 	  svnmerge from
  741 	  https://origsvn.digium.com/svn/asterisk/branches/1.2 ........
  742 	  r96931 | russell | 2008-01-07 14:46:22 -0600 (Mon, 07 Jan 2008) |
  743 	  2 lines Change misery.digium.com to pbx.digium.com ........
  744
  745 	* res/res_smdi.c: Don't crash if something happens when setting up
  746 	  an SMDI interface and it gets destroyed before the SMDI port
  747 	  handling thread gets created.
  748
  749 2008-01-07 14:34 +0000 [r96797-96815]  Philippe Sultan <[email protected]>
  750
  751 	* res/res_jabber.c: Indentation fix, makes the code easier to read
  752
  753 	* res/res_jabber.c: Compute the base64 value over the
  754 	  [authzid]\0authcid\0password string, thus excluding the trailing
  755 	  NULL byte. This change has already been committed to trunk, see
  756 	  #11644.
  757
  758 2008-01-05 02:09 +0000 [r96644]  Russell Bryant <[email protected]>
  759
  760 	* main/devicestate.c: Don't pass an empty string as the device
  761 	  name.
  762
  763 2008-01-04 23:03 +0000 [r96575]  Tilghman Lesher <[email protected]>
  764
  765 	* main/devicestate.c: Fix the problem of notification of a device
  766 	  state change to a device with a '-' in the name. Could probably
  767 	  do with a better fix in trunk, but this bug has been open way too
  768 	  long without a better solution. Reported by: stevedavies Patch
  769 	  by: tilghman (Closes issue #9668)
  770
  771 2008-01-04 22:55 +0000 [r96573]  Jason Parker <[email protected]>
  772
  773 	* res/res_features.c: Properly continue in the dialplan if using
  774 	  PARKINGEXTEN and the slot is full. Issue 11237, patch by me.
  775
  776 2008-01-04 19:27 +0000 [r96525]  Tilghman Lesher <[email protected]>
  777
  778 	* channels/chan_sip.c: If you change the bindaddr in sip.conf to a
  779 	  non-bound address and reload, sip goes kablooie. Reported and
  780 	  patched by: one47 (Closes issue #11535)
  781
  782 2008-01-04 16:19 +0000 [r96394-96449]  Russell Bryant <[email protected]>
  783
  784 	* channels/chan_zap.c: Make use of the temporary channel pointer
  785 	  while the pvt is unlocked. (closes issue #11675) Reported by:
  786 	  flefoll Patches: chan_zap.c.patch-store-owner-before-unlock
  787 	  uploaded by flefoll (license 244)
  788
  789 	* channels/chan_iax2.c: Don't crash if the iax2 pvt structure has
  790 	  been destroyed before we get to this point (closes issue #11672,
  791 	  reported by snuffy, patched by me)
  792
  793 2008-01-03 21:37 +0000 [r96318]  Tilghman Lesher <[email protected]>
  794
  795 	* res/res_config_pgsql.c: Missed initialization caused crash.
  796 	  Reported and fixed by: tiziano (Closes issue #11671)
  797
  798 2008-01-03 12:12 +0000 [r96198-96199]  Christian Richter <[email protected]>
  799
  800 	* channels/chan_misdn.c: make sure frame is completely clean,
  801 	  before we send it to asterisk as DTMF. If we don't make it clean,
  802 	  it happens that one way audio occurs..
  803
  804 	* channels/chan_misdn.c: when overlapdial was used and no number
  805 	  was dialed, the call was dropped, now we just jump into the s
  806 	  extension, which makes a lot more sense.
  807
  808 2008-01-02 23:46 +0000 [r96102]  Mark Michelson <[email protected]>
  809
  810 	* apps/app_queue.c: We need to reset the membername to NULL on each
  811 	  iteration of this loop, otherwise the result is that multiple
  812 	  members can have the same name, since the variable was not reset
  813 	  on each iteration of the loop.
  814
  815 2008-01-02 22:14 +0000 [r96020-96024]  Russell Bryant <[email protected]>
  816
  817 	* pbx/pbx_config.c: Convert locks of the contexts list in
  818 	  pbx_config to the appropriate rdlock or wrlock
  819
  820 	* pbx/pbx_dundi.c: pbx_dundi only needs a rdlock on the contexts
  821 	  list.
  822
  823 	* apps/app_macro.c: app_macro only needs a rdlock on the contexts
  824 	  list.
Nach der Anzahl und der Geschwindigkeit, wie in den vergangenen Tagen 1.4.18-RC-Versionen dieser Asterisk Version veröffentlicht wurden, scheinen die Entwickler ihrem eigenen Produkt nicht mehr zu trauen :rolleyes:
Bevor ich nun ein Update auf 1.4.18 mache, werde ich erstmal auf 1.4.18.1 warten und sehen, was sie bis dahin wieder alles an Murks gefunden haben - es wird ja wohl nicht allzu lange dauern.
Vielleicht wollen sie mit den RCs aber auch eben verhindern, dass sie noch eine Version nachschieben müssen.
Gerade ist 1.4.18 RC4 heraus gekommen. Durchaus ist diese Version also kein Release, auch wenn das im Changelog so steht. Die RC's sind ja eine tolle Idee, aber irgendwie ist das ganze auch etwas verwirrend. Laut Asterisk Developer Mailingliste ist es erst ein Release, wenn auf dem Digium Downloadserver eine entsprechende *.tar.gz Datei vorhanden ist (ohne RC im Namen).
@Netview: Ich sehe in Deiner Signatur Du verwendest Asterisk 1.4.19 mit Bristuff Patch. Bist Du ein Zeitreisender? ;-)
heute kam 1.4.18 nun offiziell.
The Asterisk development team has released Asterisk version 1.4.18.
In response to a community request, in preparation for this release, the
development community held a release candidate period before making the official
release. Multiple people tested it out and reported issues. The release
candidate process was definitely a success for this release, and we will
continue to do it for future Asterisk 1.4 releases.
3cvx
