So wieder fehler, trotz patch
mit dirclean ging es auch nicht!
Letze worte:
output/samples-mipsel-linux-uclibc/level.o \
-L/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjlib/lib -L/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjlib-util/lib -L/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjnath/lib -L/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjmedia/lib -L/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjsip/lib -L/home/daniel/freetz-trunk/source/pjproject-0.8.0/third_party/lib -lpjsua -lpjsip-ua -lpjsip-simple -lpjsip -lpjmedia-codec -lpjmedia -lpjnath -lpjlib-util -lresample -lmilenage -lpj -Wl,-Bdynamic -lnsl -lrt -lm -lpthread
mipsel-linux-gcc -c -DPJ_AUTOCONF=1 -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjlib/include -I/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjlib-util/include -I/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjnath/include -I/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjmedia/include -I/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjsip/include \
-o output/samples-mipsel-linux-uclibc/pjsip-perf.o \
../src/samples/pjsip-perf.c
mipsel-linux-gcc -o ../bin/samples/pjsip-perf-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/playfile.o \
../src/samples/playfile.c
mipsel-linux-gcc -o ../bin/samples/playfile-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/playsine.o \
../src/samples/playsine.c
../src/samples/playsine.c: In function 'create_sine_port':
../src/samples/playsine.c:164: warning: incompatible implicit declaration of built-in function 'sin'
mipsel-linux-gcc -o ../bin/samples/playsine-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/recfile.o \
../src/samples/recfile.c
mipsel-linux-gcc -o ../bin/samples/recfile-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/resampleplay.o \
../src/samples/resampleplay.c
mipsel-linux-gcc -o ../bin/samples/resampleplay-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/simpleua.o \
../src/samples/simpleua.c
mipsel-linux-gcc -o ../bin/samples/simpleua-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/simple_pjsua.o \
../src/samples/simple_pjsua.c
mipsel-linux-gcc -o ../bin/samples/simple_pjsua-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/siprtp.o \
../src/samples/siprtp.c
mipsel-linux-gcc -o ../bin/samples/siprtp-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/sipstateless.o \
../src/samples/sipstateless.c
mipsel-linux-gcc -o ../bin/samples/sipstateless-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/sndinfo.o \
../src/samples/sndinfo.c
mipsel-linux-gcc -o ../bin/samples/sndinfo-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/sndtest.o \
../src/samples/sndtest.c
mipsel-linux-gcc -o ../bin/samples/sndtest-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/stateful_proxy.o \
../src/samples/stateful_proxy.c
mipsel-linux-gcc -o ../bin/samples/stateful_proxy-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/stateless_proxy.o \
../src/samples/stateless_proxy.c
mipsel-linux-gcc -o ../bin/samples/stateless_proxy-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/streamutil.o \
../src/samples/streamutil.c
mipsel-linux-gcc -o ../bin/samples/streamutil-mipsel-linux-uclibc \
-o output/samples-mipsel-linux-uclibc/tonegen.o \
../src/samples/tonegen.c
mipsel-linux-gcc -o ../bin/samples/tonegen-mipsel-linux-uclibc \
rm output/samples-mipsel-linux-uclibc/resampleplay.o output/samples-mipsel-linux-uclibc/sipstateless.o output/samples-mipsel-linux-uclibc/simple_pjsua.o output/samples-mipsel-linux-uclibc/recfile.o output/samples-mipsel-linux-uclibc/siprtp.o output/samples-mipsel-linux-uclibc/stateful_proxy.o output/samples-mipsel-linux-uclibc/level.o output/samples-mipsel-linux-uclibc/pjsip-perf.o output/samples-mipsel-linux-uclibc/streamutil.o output/samples-mipsel-linux-uclibc/playsine.o output/samples-mipsel-linux-uclibc/playfile.o output/samples-mipsel-linux-uclibc/simpleua.o output/samples-mipsel-linux-uclibc/confsample.o output/samples-mipsel-linux-uclibc/sndtest.o output/samples-mipsel-linux-uclibc/stateless_proxy.o output/samples-mipsel-linux-uclibc/sndinfo.o output/samples-mipsel-linux-uclibc/tonegen.o
make[3]: Verlasse Verzeichnis '/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjsip-apps/build'
make[2]: Verlasse Verzeichnis '/home/daniel/freetz-trunk/source/pjproject-0.8.0/pjsip-apps/build'
make[1]: Verlasse Verzeichnis '/home/daniel/freetz-trunk/source/pjproject-0.8.0'
PATH=/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/bin:/bin:/sbin:/usr/bin:/usr/sbin \
make -j2 -C source/pjproject-0.8.0 \
DESTDIR="/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc" \
TARGET_NAME="mipsel-linux-uclibc" \
install
make[1]: Betrete Verzeichnis '/home/daniel/freetz-trunk/source/pjproject-0.8.0'
mkdir -p /home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib
cp -L $(find . -name '*.a') /home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib
mkdir -p /home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include
cp -RL $(find . -name include) /home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./pjnath/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./pjlib/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./pjmedia/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./pjsip/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./pjlib-util/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./third_party/portaudio/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./third_party/resample/include“ nicht möglich.
cp: Überschreiben des Nicht‐Verzeichnisses „/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include“ mit Verzeichnis „./third_party/speex/include“ nicht möglich.
make[1]: *** [install] Fehler 1
make: *** [/home/daniel/freetz-trunk/toolchain/build/gcc-4.2.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libpjsip.a] Fehler 2
daniel@daniel-laptop:~/freetz-trunk$
