fritz box FON DSL modem router problem.. need help..
jivica
24 Jun 2008
Dear community,
HADVARE:
I have friend that gave me fritz box FON DSL version with serial number 2000 1660 (have connectors [dsl] [lan] [usb] [isdn/analog] [fon1] [fon2] (power) )
does not have WLAN!!
serial number is:S415.160.00.002.178
there is no sticker at the back saying it is annex A or B
just: Fritz!Box FON
PROBLEM:
I can not access to it via web... power ligth is on all the time
I am not sure which firmware I should try to recover, and what is exactly the model?...
Think my friend tried to put new firmware but he stopped during process..
I WANT TO GET IT BACK INTO FACORTY DEFAULTS..
I have tried many firmwares from avm but none have worked for me...
I can access via ftp before it boots up and log in as adam2...
here is my env:
HWRevision            58
ProductID             Fritz_Box_FON
SerialNumber          0000000000000000
annex
autoload              yes
bootloaderVersion     0.18.01
bootserport           tty0
bluetooth             00:04:0E:FF:FF:07
cpufrequency          150000000
firstfreeaddress      0x94730938
firmware_version      avm
firmware_info         06.04.01
flashsize             0x00400000
maca                  00:04:0E:81:03:D7
macb                  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
macc                  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
macwlan               ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
macdsl                00:04:0E:81:03:D8
memsize               0x01000000
modetty0              38400,n,8,1,hw
modetty1              38400,n,8,1,hw
mtd0                  0x900C0000,0x903C0000
mtd1                  0x90010000,0x900C0000
mtd2                  0x90000000,0x90010000
mtd3                  0x903C0000,0x903E0000
mtd4                  0x903E0000,0x90400000
my_ipaddress          192.168.178.1
prompt                AVM_Ar7
reserved              00:04:0E:FF:FF:00
req_fullrate_freq     125000000
sysfrequency          125000000
usb_board_mac         00:04:0E:81:03:D9
usb_rndis_mac         00:04:0E:81:03:DA
usb_device_id         0x3A00
usb_revision_id       0x0100
usb_device_name       USB DSL Device
usb_manufacturer_name  AVM
WHEN I TRY TO PUT NEW FIRMWARE here is error message:
FRITZ!Box Fon suchen an: 192.168.178.1
Eine Anlage gefunden! - Ermitteln der aktuellen Version.
Version erfolgreich ermittelt!
Hardware: FRITZ!Box Fon
Urlader: 0
Firmware: 06.04.01
Warnung! Beim Lesen ist ein Timeout aufgetreten (alter Urlader)!
Sie müssen nun die FRITZ!Box Fon vom Stromnetz
entfernen und nach Aufforderung wieder anschliessen.
Recover der Partition mtd2 fehlgeschlagen! WinError 10054
IS THERE A WAY TO MAKE IT WORK??? OR IS IT SOFT DEAD??
I am willing to put even openWRT (have compiled it) if this is gonna bring it to the live...
Thanks in advance!
cheers, Ivica
Hi and welcome to the forum,
it's just the model "Fritz!Box Fon", the good old one.
The easiest way: Connect a telephone and try to reset the box with this telephoncode: #991*15901590*
If that doesn't work, try to recover with Recover version 06.04.15. It's got the same urlader as the version 06.04.01 which is currently installed.
Good luck!
Marsupilami
thanks for help!
here is output from trying to put firmware you told me to:
FRITZ!Box Fon suchen an: 192.168.2.2
Urlader: 0
Firmware: 06.04.01
like it has problem at mtd2 partition?!?!
if I connect phone at fon1 there is nothing like it is dead.. no signal.. (I have it plugged into power but not at the DSL line or telephone line.. should I connect it to normal telephone line??)
Thanks ivica
using help from support of avm
they told me that device is for germany annex B
so I tried to use firmware they told me but still not working!
I am one step further;
now it regenerate mtd2 but after that it stops
( i have tried 6 times and nothing happned .. but now are ALL lights blinking all the time)
here is error message from firmware update:
Flashbereich (mtd2)
Lösche Flashbereich (mtd2)
Restauriere Flashbereich (mtd2)
Urlader: 0
Firmware: 06.04.01
Firmware der FRITZ!Box Fon ist mit der Recover-Firmware inkompatibel
and at the end it said that there is Memoryfailure ?!
Thanks
ivica
Reset via telephonecode:
No need to connect the box to DSL or PSTN.
Most probable reason: Wrong pin out between box and telephone. For german telephones you have to use the TAE adapter. Western connectors normally have a different pinout than the box.
Reset via recover:
Give your PC the 192.168.178.12 and try again. Does that help?
Wh-tele.com
