Hi, ich habe neuerdings das Problem, dass WOL bei mir nicht mehr so funktioniert wie zuvor. Ich arbeite auf dem neuesten stable-branch mit all-in-one firmware für die 7170.
Hat jemand eine Idee?
Tom
Tom
/var/mod/root # sh -x /etc/init.d/rc.wol start
+ export PATH=/sbin:/bin:/usr/sbin:/usr/bin:/mod/sbin:/mo
d/usr/bin
+ export LD_LIBRARY_PATH=/mod/lib
+ DAEMON=httpd-wol
+ _DAEMON=httpd
+ [ ! -r /mod/etc/conf/wol.cfg ]
+ . /mod/etc/conf/wol.cfg
+ export WOL_ENABLED=yes
+ export WOL_PLAIN_PASSWD=
+ export WOL_PORT=82
+ export WOL_USER=
+ start
+ config
+ [ -x /tmp/flash/httpd-wol_conf ]
+ /mod/etc/default.wol/httpd-wol_conf
+ [ -r /tmp/flash/httpd-wol.extra ]
+ echo -n Starting wol webinterface...
Starting wol webinterface...+ webcfg-wol
/etc/init.d/rc.wol: line 1: webcfg-wol: Permission denied
+ exitval=126
+ [ 126 -eq 0 ]
+ rm -f /var/run/httpd-wol.pid
+ echo failed.
failed.
+ exit 126
/var/mod/root #
which webcfg-wol
ls -l /usr/bin/webcfg*
webcfg-wol
/var/mod/root # which webcfg-wol
/var/mod/root # ls -l /usr/bin/webcfg*
-rwxr-xr-x 1 root root 391 Aug 19 14:04 /usr/bin/webcfg
-rw-r--r-- 1 root root 395 Aug 19 14:05 /usr/bin/webcfg-wol
/var/mod/root # webcfg-wol
-sh: webcfg-wol: Permission denied
/var/mod/root #
oliver@ubuntu:/freetz/trunk/packages/wol-cgi-0.6/root/usr/bin# ls -l
insgesamt 8
-rwxr-xr-x 1 oliver oliver 888 2008-05-14 01:02 freetz_wol
-rwxr-xr-x 1 oliver oliver 395 2008-06-21 13:28 webcfg-wol
ls -l make/wol-cgi/files/root/usr/bin/
insgesamt 8
ubuntu@Ubuntu:~/freetz-stable-1.0/packages/wol-cgi-0.6/root/usr/bin$ ls -l
insgesamt 8
-rwxr-xr-x 1 ubuntu ubuntu 888 2008-08-19 14:05 freetz_wol
-rw-r--r-- 1 ubuntu ubuntu 395 2008-08-19 14:05 webcfg-wol
ubuntu@Ubuntu:~/freetz-stable-1.0$ ls -l make/wol-cgi/files/root/usr/bin/
insgesamt 8
ubuntu@Ubuntu:~/freetz-stable-1.0$ make menuconfig
/bin/bash: tools/check_uclibc: Permission denied
Makefile:79: WARNING: uClibc-version changed. Packages, toolchain and some other stuff must be rebuilt. This will take a while
# using defaults found in .config
Your Freetz configuration changes were NOT saved.
Ist hier das "Permission denied" ok?
ls -aln tools/check_uc*
-rwxr-xr-x 1 501 502 631 2008-08-26 12:37 tools/check_uclibc
make wol-cgi-dirclean && svn up && make
