Zitat von
Anleitung
1 RedBoot> ip_address - l local_ip_address [/mask_len]
Sets the IP address and subnet mask of the
Ethernet interface 0/0 which shall be used to
receive the new application image.
mask_len is the length of the network address
(or the number of 1’s within the subnet mask).
See Note below.
2 RedBoot> ip_address -g gateway
Sets the IP address of the default gateway.
3 RedBoot> ping -h tftp-server_ip_address
Tests the connectivity to the TFTP server.
4 RedBoot> load -r -v -h host -b base_address file_name
Downloads an application image into the volatile
memory (RAM) from where the SmartNode
could directly execute it.
host: IP address of the TFTP server
base_address: memory location where to store
the application image. Use the default address
0x1800100
file_name: path and name of the file on the
TFTP server. Note: use the image file that contains
the whole application, not the image
parts.
5 RedBoot> fis delete -n 1
Deletes the first application image.
Reply with ‘y’ to the confirmation request.
6 RedBoot> fis create
Stores the downloaded application image to
the permanent memory (flash:).
7 RedBoot> fis list -l
Checks whether the image has been successfully
stored, whether it is the desired Release
and Build, and whether it is valid.
