Ergebnis 1 bis 15 von 15
Thema: MODEM UMTS USB driver for 7170
  1. #1
    IPPF-Aufsteiger Avatar von skizzo3000
    Registriert seit
    14.07.2006
    Idee MODEM UMTS USB driver for 7170
    Hello,
    i made a working driver for e220, e270 umts modem for 7170 with 2.6.13 kernel.
    It works only if only gsm modem is attached on usb port.
    i made hotplug script for automatic driver install.
    Now the modem is mounted on ttyUSB( 0 1 2 ) serial ports.
    How can i make internet connection ?
    pppd is not in freetz.
    Thanks Sk3
    Angehängte Dateien Angehängte Dateien
  2. #2
    IPPF-Fünfhundert-Club Avatar von Whoopie
    Registriert seit
    19.10.2004
    pppd is part of freetz. But it's only shown when pptp or pptpd is selected because only these packages use pppd.
    As I understood, there's also the "replace kernel" dependency for pppd.
    Best regards,
    Whoopie
    Router: AVM FRITZ!Box Fon WLAN 7390 mit FRITZ!OS 84.05.55-25667 und freetz-devel
    VoIP: Telekom, sipgate
    Anbindung: Telekom Call&Surf Basic IP (DSL 16000 Annex J), Downstream: 13,0 MBit/s, Upstream: 2,3 MBit/s
  3. #3
    Registriert seit
    14.07.2006
    where can i find the pptp option in menuconfig ?
    and kernel replace ?
    EDIT: ok i found it in the newer freetz version.
    Thanks Sk3
    Geändert von skizzo3000 (18.09.2008 um 00:43 Uhr)
  4. #4
    IPPF-Fan
    Registriert seit
    17.10.2006
    Hello.
    I am interested in this solution, too.
    At least for test reasons.
    Currently we are using Internet via satellite. At its best 256 kb/s down and 64 kb/s up, but very slow connection because of the distance.
    skizzo3000, how far are you with this one?
    Is there a special way of how to compile the firmware with freetz?
    Kind regards
    molfi
    AVM Fritz!Box Fon WLAN 7270 V3 avm branding, Firmware 74.05.22-freetz-devel-9286, 128MB Swap, replaced kernel, syslogd, cifsmount, avm-firewall, dropbear, wol, transmission, onlinechanged, LCR, screen, Fritzload, PHP, esniper, es-f, python, heatpumpmonitor, solarview
  5. #5
    Registriert seit
    14.07.2006
    I made:
    usbserial, option drivers
    pppd, chat programs
    a GUI in cgi-bin
    an atserver daemon and atclient to comunicate with modem
    but i had disable iptable freetz GUI
    i made a working test firmware but all in italian.
    Sk3
  6. #6
    IPPF-Fan
    Registriert seit
    17.10.2006
    Hi.
    Sounds great.
    I know that is your work, but could you upload all needed files to this thread?
    And maybe a short manual of how to get it to work.
    Or is there a section on your website that contains all needed things?
    Regards
    molfi
  7. #7
    Registriert seit
    14.07.2006
    Reden
    in these days i'm working on a 'gsm framework' so all user can call the functions without any problem.
    At now is difficult for me post some working files, because they are very alfa test and hard to integrate in firmware.
    In march i think i will complete the framework and i upload it with english guide.
    Features in framework:
    - hotplug usb modem
    - hw test
    - saving conf file in flash
    - internet connection with pppd
    - operator and mode info
    - ppp session info/log
    - firewall/nat on ppp interface
    - parameters configuration in simple GUI
    - sms support: read and send and delete
    - sms gui
    - sim phonebook
    - phonebook gui
    - some example sms script for automations
    - autopin
    - autoconnect (umts)
    - serial driver and daemon for input/output serial borad with rele and i2c bus
    - simple function to create gui (html)
    ALL WRITE IN SHELL SCRIPT !! (so it works on all linux PC and embedded)
    a simple gui preview
    Sk3
    Angehängte Grafiken Angehängte Grafiken
    Geändert von skizzo3000 (01.02.2009 um 14:55 Uhr)
  8. #8
    IPPF-Fan
    Registriert seit
    17.10.2006
    Hi
    Looks good.
    Ok, then I will wait.
    Thanks for your efforts in advance.
    Regards
    molfi
  9. #9
    IPPF-Fünftausend-VIP Avatar von Feuer-Fritz
    Registriert seit
    16.07.2007
    Ort
    50°55′N 6°21′O
    Hi, Skizzo
    How far did your work grow? Any success until now?
  10. #10
    Registriert seit
    14.07.2006
    Hi
    i made a working firmware but without the gsm framework.
    dchp server is disabled and the iptables has a simple configuration, that can be changed only via telnet.
  11. #11
    IPPF-Einsteiger
    Registriert seit
    14.04.2009
    Hello Skizzo,
    maybe you can give some hints to do this on a 3170?
    Maybe you can post the freetz config file. This would be very nice.
    With best regards
    Daniel
  12. #12
    IPPF-Fortgeschrittener
    Registriert seit
    05.10.2006
    nice to hear you are working on that
    did you make any progress lately, i have also an 7170 and a e176 huawei.
    do you have anything new to test?
    i would really appreciate it
  13. #13
    IPPF-Einsteiger
    Registriert seit
    18.05.2009
    Ort
    W´tal
    So many versions of Firmwares
    Hello!
    I was on the download-page to find the firmware and UMTS-Driver, I found the GSM/UMTS-Driver but which of these many firmware can I use in my fritzbox 7170 to try if it accepts my Huawei E172?
    I will even try it with italian firmware, the menu works almost the same and many of the most important words are in english regardless of the language of userinterface...
    Thx
    Greetings
  14. #14
    Registriert seit
    14.07.2006
    hello,
    my firmware is tested with e220/e270 but i think it works with other huawei umts modem.
    A new version on 25 december
    Sk3
  15. #15
    IPPF-Aufsteiger
    Registriert seit
    07.02.2009
    Zitat Zitat von skizzo3000 Beitrag anzeigen
    Hello,
    Thanks Sk3
    Welcome
    I'm at the stage of the firmware modyfukacji FRITZ! Box with the assistance of speed-to-fritz, and similar tools.
    I would like to install the firmware for the 7170 and 7141 (58.04.76)
    GSM modem on USB Hueway E220 E165. I know that you have the drivers for the E220. I have a question?
    Is posiadsz driver for E165?
    Do you have an operative part of the firmware - the menu with support for GSM, as in 7270? Or a script like this to do the same for drivers that do not cater?
    Can this be done by adapting the firmware for the 7170 and 7270 drivers substitution?
    Case Pilana
    very please to assist you as Your server ..
    Xavier
Ähnliche Themen
  1. Fritz!Box 7170 als GSM/UMTS Modem
    Von Brainpool im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 10
    Letzter Beitrag: 09.05.2010, 14:03
  2. Antworten: 10
    Letzter Beitrag: 08.04.2009, 21:46
  3. Antworten: 3
    Letzter Beitrag: 18.03.2009, 21:11
  4. 7140 and 7170 usb driver
    Von Spewk im Forum FRITZ!Box Fon: Modifikationen
    Antworten: 1
    Letzter Beitrag: 17.01.2008, 15:50
  5. 7170 labor fernzugang base avm-vpn-driver
    Von kal10bach im Forum FRITZ!Box tot? Recover, Firmware Up-/ Downgrade
    Antworten: 3
    Letzter Beitrag: 27.09.2007, 00:06
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
