Ok, guckst Du hier:
# asterisk -rvvvvvv
Asterisk 1.6.0.1, Copyright (C) 1999 - 2008 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
== Parsing '/etc/asterisk/asterisk.conf': == Found
== Parsing '/etc/asterisk/extconfig.conf': == Found
Connected to Asterisk 1.6.0.1 currently running on fritz (pid = 877)
No entry for terminal type "vt102";
using dumb terminal settings.
Verbosity was 4 and is now 6
== Using SIP RTP CoS mark 5
fritz*CLI>
oben das Ergebnis mit +49xxx, unten mit 0049xxx
-- Executing [0049xxx@sip7701:1] Set("SIP/7701-0063ea68", "CALLERID(num)=xxxx") in new stack
[Nov 22 13:36:26] WARNING[14344]: ast_expr2.y:1272 op_plus: non-numeric argument
-- Executing [0049xxx@sip7701:2] Set("SIP/7701-0063ea68", "EXTEN2=0049xxx") in new stack
-- Executing [0049xxx@sip7701:3] Dial("SIP/7701-0063ea68", "CAPI/ISDN1/0049xxx,55,Tt/bd") in new stack
-- Called ISDN1/0049xxx
-- CAPI/ISDN1#02/0049xxx-18 is proceeding passing it to SIP/7701-0063ea68
== ISDN1#02: Setting up DTMF detector (PLCI=0x201, flag=1)
-- CAPI/ISDN1#02/0049xxx-18 answered SIP/7701-0063ea68
-- ISDN1#02: Fax detected, but not configured for redirection
== ISDN1#02: CAPI Hangingup for PLCI=0x201 in state 2
== Spawn extension (sip7701, 0049xx, 3) exited non-zero on 'SIP/7701-0063ea68'
fritz*CLI>
Wie schon gesagt, da kommt nicht wirklich was bei raus, wenn die Nummer mit einem Pluszeichen beginnt....
Wolfgang
