Ergebnis 1 bis 4 von 4
Thema: make bricht ab
  1. #1
    make bricht ab
    /usr/lib/libfreetype.so: could not read symbols: File in wrong format
    collect2: ld returned 1 exit status
    make[3]: *** [librrd_th.la] Error 1
    make[3]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/src'
    Making all in doc
    make[3]: Entering directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/doc'
    make[3]: Nothing to be done for `all'.
    make[3]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/doc'
    Making all in examples
    make[3]: Entering directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/examples'
    make[3]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/examples'
    Making all in bindings
    make[3]: Entering directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/bindings'
    make[4]: Entering directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/bindings'
    make[4]: Nothing to be done for `all-am'.
    make[4]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/bindings'
    make[3]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29/bindings'
    make[3]: Entering directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29'
    make[3]: Nothing to be done for `all-am'.
    make[3]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/hec/fritz.box/freetz/freetz-trunk/source/rrdtool-1.2.29'
    make: *** [source/rrdtool-1.2.29/src/.libs/rrdtool] Error 2
    revision 2891
    hat jemand eine idee was da los ist ?
    gruß
    gruß aus dem bayerischen wald
    Bufallo N450 als Acces Point an Ubuntu Gateway per FreeRadius (im Aufbau)
    Fritz!Box Fon WLAN 7390 aktuelle Firmware mit Freetz für Telefonie
    Tel. Anschluß: Vdafone LTE
    Internet: Vdafone LTE 21 Mbit
    FB 7270: als Repeater mit Freetz (aktuell im Urlaub)
    Phone:AVM MT-F (aktuelle Firm.) SpeedPhone 300 (Firm 1.79), Sinus 501, GN 9120 DG GAP. Alle per DECT an FB 7390
    Handy:Samsung Galaxy Note
    USB Umts/EDGE: Huawei E160 mit Tchibo Flat
    USB Umts/EDGE: Huawei E173 mit o2o
    VoIP: Sipgate (zu testzwecken)
    Media:DVB-Viewer Netz, wird zukünftig durch MythTV ersetzt
  2. #2
    IPPF-Fünfhundert-Club Avatar von Whoopie
    Registriert seit
    19.10.2004
    kann das Problem nicht reproduzieren. Hab auch die devel-Packete für mein i386-System installiert und trotzdem wird es ordentlich gegen die für Mipsel kompilierte freetype2 gelinkt.
    Beste Grüße,
    Whoopie
    Router: AVM FRITZ!Box Fon WLAN 7390 mit FRITZ!OS 84.05.55-25188 und freetz-devel
    VoIP: Telekom, sipgate
    Anbindung: Telekom Call&Surf Comfort IP (DSL 16000 Annex J), Downstream: 12,6 MBit/s, Upstream: 2,3 MBit/s
  3. #3
    danke für die info.
    gruß
  4. #4
    Semi-Moderator Avatar von olistudent
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Kannst du mal bitte deine config.log und das Makefile aus source/rrdtool-1.2.29 anhängen?
    MfG Oliver
    Router: Fritz!Box Fon WLAN 7570, 7390, 7320, 7270, 3170
    Anbindung: T-Online DSL 16.000 RAM
    Visit ##fritzbox on Freenode for help
    Spenden für Freetz
Ähnliche Themen
  1. Make bricht mit fehler 1 ab
    Von Black_Beetle im Forum Freetz
    Antworten: 27
    Letzter Beitrag: 09.08.2009, 20:19
  2. Make bricht bei Iptables ab
    Von jenswmeyer im Forum Freetz
    Antworten: 14
    Letzter Beitrag: 28.11.2008, 12:29
  3. Rev.2466 make bricht ab
    Von moosbart im Forum Freetz
    Antworten: 2
    Letzter Beitrag: 24.08.2008, 19:07
  4. Make bricht einfach so ab...
    Von GuruHacker im Forum Freetz
    Antworten: 46
    Letzter Beitrag: 22.06.2008, 02:34
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
