Sat Mar 21 22:16:18 2009 OpenVPN 2.1_rc15e Win32-MSVC++ [SSL] [LZO2] built on Mar 15 2009
Sat Mar 21 22:16:18 2009 MANAGEMENT: TCP Socket listening on 127.0.0.1:10000
Sat Mar 21 22:16:18 2009 Need hold release from management interface, waiting...
Sat Mar 21 22:16:19 2009 MANAGEMENT: Client connected from 127.0.0.1:10000
Sat Mar 21 22:16:19 2009 Using Windows Connection Manager with destination '{097AFAB2-B067-4BB1-90CA-BCA9C553EECF}' resolving to provider guid {097AFAB2-B067-4BB1-90CA-BCA9C553EECF} (exclusive)
Sat Mar 21 22:16:26 2009 Acquisition of Windows Connection Manager provider succeeded...
Sat Mar 21 22:16:26 2009 WARNING: Make sure you understand the semantics of --tls-remote before using it (see the man page).
Sat Mar 21 22:16:26 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sat Mar 21 22:16:26 2009 Control Channel Authentication: using '\Programme\OpenVPN\config\ovpnstatic.key' as a OpenVPN static key file
Sat Mar 21 22:16:26 2009 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:16:26 2009 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:16:26 2009 LZO compression initialized
Sat Mar 21 22:16:26 2009 Control Channel MTU parms [ L:1574 D:166 EF:66 EB:0 ET:0 EL:0 ]
Sat Mar 21 22:16:26 2009 MANAGEMENT: >STATE:1237670186,RESOLVE,,,
Sat Mar 21 22:16:26 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:16:26 2009 Data Channel MTU parms [ L:1574 D:1450 EF:42 EB:135 ET:32 EL:0 AF:3/1 ]
Sat Mar 21 22:16:26 2009 Local Options hash (VER=V4): '13a273ba'
Sat Mar 21 22:16:26 2009 Expected Remote Options hash (VER=V4): '360696c5'
Sat Mar 21 22:16:31 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:16:36 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:16:41 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:16:47 2009 Socket Buffers: R=[32768->32768] S=[16384->16384]
Sat Mar 21 22:16:47 2009 UDPv4 link local (bound): [undef]
Sat Mar 21 22:16:47 2009 UDPv4 link remote: 78.42.159.42:1194
Sat Mar 21 22:16:47 2009 MANAGEMENT: >STATE:1237670207,WAIT,,,
Sat Mar 21 22:16:47 2009 MANAGEMENT: >STATE:1237670207,AUTH,,,
Sat Mar 21 22:16:47 2009 TLS: Initial packet from 78.42.159.42:1194, sid=796ec02f 262435d1
Sat Mar 21 22:16:52 2009 VERIFY OK: depth=1, /C=DE/ST=BW/L=Buehlertann/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=BlackSunSoftwareGmbH-CA/emailAddress=blacksun@directbox.com
Sat Mar 21 22:16:52 2009 VERIFY X509NAME OK: /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:16:52 2009 VERIFY OK: depth=0, /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:16:59 2009 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Mar 21 22:16:59 2009 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:16:59 2009 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Mar 21 22:16:59 2009 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:16:59 2009 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Sat Mar 21 22:16:59 2009 [Eumex] Peer Connection Initiated with 78.42.159.42:1194
Sat Mar 21 22:17:01 2009 MANAGEMENT: >STATE:1237670221,GET_CONFIG,,,
Sat Mar 21 22:17:01 2009 SENT CONTROL [Eumex]: 'PUSH_REQUEST' (status=1)
Sat Mar 21 22:17:01 2009 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway,route-gateway 192.168.3.97,route 192.168.3.0 255.255.255.0'
Sat Mar 21 22:17:01 2009 OPTIONS IMPORT: route options modified
Sat Mar 21 22:17:01 2009 OPTIONS IMPORT: route-related options modified
Sat Mar 21 22:17:01 2009 ROUTE default_gateway=10.129.175.233
Sat Mar 21 22:17:01 2009 TAP-WIN32 device [TAP1:] opened: TAP1:
Sat Mar 21 22:17:01 2009 TAP-Win32 Driver Version 9.4
Sat Mar 21 22:17:01 2009 TAP-Win32 MTU=1500
Sat Mar 21 22:17:01 2009 Successful ARP Flush on interface [3] TAP DEVICE 1
Sat Mar 21 22:17:06 2009 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
Sat Mar 21 22:17:06 2009 Route: Waiting for TUN/TAP interface to come up...
Sat Mar 21 22:17:11 2009 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
Sat Mar 21 22:17:11 2009 Route: Waiting for TUN/TAP interface to come up...
Sat Mar 21 22:17:12 2009 TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
Sat Mar 21 22:17:12 2009 Route: Waiting for TUN/TAP interface to come up...
Sat Mar 21 22:17:13 2009 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Sat Mar 21 22:17:13 2009 C:\WINDOWS\system32\route.exe ADD 78.42.159.42 MASK 255.255.255.255 10.129.175.233
Sat Mar 21 22:17:13 2009 ROUTE: route addition failed using CreateIpForwardEntry: Der Parameter ist ungültig. [status=87 if_index=196612]
Sat Mar 21 22:17:13 2009 Route addition via IPAPI failed [adaptive]
Sat Mar 21 22:17:13 2009 Route addition fallback to route.exe
Sat Mar 21 22:17:13 2009 ERROR: Windows route add command failed [adaptive]: external program did not execute -- returned error code -1
Sat Mar 21 22:17:13 2009 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 10.129.175.233
Sat Mar 21 22:17:13 2009 Route deletion via IPAPI succeeded [adaptive]
Sat Mar 21 22:17:13 2009 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 192.168.3.97
Sat Mar 21 22:17:13 2009 Route addition via IPAPI succeeded [adaptive]
Sat Mar 21 22:17:13 2009 MANAGEMENT: >STATE:1237670233,ADD_ROUTES,,,
Sat Mar 21 22:17:13 2009 RESOLVE: Cannot parse IP address:
Sat Mar 21 22:17:13 2009 WARNING: potential route subnet conflict between local LAN [192.168.3.0/255.255.255.0] and remote VPN [192.168.3.0/255.255.255.0]
Sat Mar 21 22:17:13 2009 C:\WINDOWS\system32\route.exe ADD 192.168.3.0 MASK 255.255.255.0 192.168.3.97
Sat Mar 21 22:17:13 2009 Initialization Sequence Completed
Sat Mar 21 22:17:13 2009 MANAGEMENT: >STATE:1237670233,CONNECTED,SUCCESS,,78.42.159.42
Sat Mar 21 22:17:13 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:14 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:18 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:19 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:20 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:21 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:22 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:24 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:28 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:30 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:36 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:42 2009 write UDPv4: No Route to Host (WSAEHOSTUNREACH) (code=10065)
Sat Mar 21 22:17:46 2009 TCP/UDP: Closing socket
Sat Mar 21 22:17:46 2009 C:\WINDOWS\system32\route.exe DELETE 192.168.3.0 MASK 255.255.255.0 192.168.3.97
Sat Mar 21 22:17:46 2009 Route deletion via IPAPI succeeded [adaptive]
Sat Mar 21 22:17:46 2009 C:\WINDOWS\system32\route.exe DELETE 78.42.159.42 MASK 255.255.255.255 10.129.175.233
Sat Mar 21 22:17:46 2009 ROUTE: route deletion failed using DeleteIpForwardEntry: Der Parameter ist ungültig.
Sat Mar 21 22:17:46 2009 Route deletion via IPAPI failed [adaptive]
Sat Mar 21 22:17:46 2009 Route deletion fallback to route.exe
Sat Mar 21 22:17:46 2009 ERROR: Windows route delete command failed [adaptive]: external program did not execute -- returned error code -1
Sat Mar 21 22:17:46 2009 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 192.168.3.97
Sat Mar 21 22:17:46 2009 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 10.129.175.233
Sat Mar 21 22:17:46 2009 ROUTE: route addition failed using CreateIpForwardEntry: Der Parameter ist ungültig. [status=87 if_index=196612]
Sat Mar 21 22:17:46 2009 Route addition via IPAPI failed [adaptive]
Sat Mar 21 22:17:46 2009 Route addition fallback to route.exe
Sat Mar 21 22:17:46 2009 ERROR: Windows route add command failed [adaptive]: external program did not execute -- returned error code -1
Sat Mar 21 22:17:46 2009 Closing TUN/TAP interface
Sat Mar 21 22:17:46 2009 SIGTERM[hard,] received, process exiting
Sat Mar 21 22:17:46 2009 MANAGEMENT: >STATE:1237670266,EXITING,SIGTERM,,
Sat Mar 21 22:17:46 2009 Releasing Windows Connection Manager provider
ach ja, und so sieht das ganze mit TCP auf Port 443 aus, wo nicht mal eine Verbindung zustande kommt:
Sat Mar 21 22:18:24 2009 OpenVPN 2.1_rc15e Win32-MSVC++ [SSL] [LZO2] built on Mar 15 2009
Sat Mar 21 22:18:24 2009 MANAGEMENT: TCP Socket listening on 127.0.0.1:10000
Sat Mar 21 22:18:24 2009 Need hold release from management interface, waiting...
Sat Mar 21 22:18:24 2009 MANAGEMENT: Client connected from 127.0.0.1:10000
Sat Mar 21 22:18:25 2009 Using Windows Connection Manager with destination '{097AFAB2-B067-4BB1-90CA-BCA9C553EECF}' resolving to provider guid {097AFAB2-B067-4BB1-90CA-BCA9C553EECF} (exclusive)
Sat Mar 21 22:18:30 2009 Acquisition of Windows Connection Manager provider succeeded...
Sat Mar 21 22:18:30 2009 WARNING: Make sure you understand the semantics of --tls-remote before using it (see the man page).
Sat Mar 21 22:18:30 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sat Mar 21 22:18:31 2009 Control Channel Authentication: using '\Programme\OpenVPN\config\ovpnstatic.key' as a OpenVPN static key file
Sat Mar 21 22:18:31 2009 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:18:31 2009 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Mar 21 22:18:31 2009 LZO compression initialized
Sat Mar 21 22:18:31 2009 Control Channel MTU parms [ L:1576 D:168 EF:68 EB:0 ET:0 EL:0 ]
Sat Mar 21 22:18:31 2009 MANAGEMENT: >STATE:1237670311,RESOLVE,,,
Sat Mar 21 22:18:31 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:18:31 2009 Data Channel MTU parms [ L:1576 D:1450 EF:44 EB:135 ET:32 EL:0 AF:3/1 ]
Sat Mar 21 22:18:31 2009 Local Options hash (VER=V4): 'e39a3273'
Sat Mar 21 22:18:31 2009 Expected Remote Options hash (VER=V4): '3c14feac'
Sat Mar 21 22:18:36 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:18:41 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:18:46 2009 RESOLVE: Cannot resolve host address: tauscher.dyndns.org: [HOST_NOT_FOUND] The specified host is unknown.
Sat Mar 21 22:18:52 2009 Attempting to establish TCP connection with 78.42.159.42:443
Sat Mar 21 22:18:52 2009 MANAGEMENT: >STATE:1237670332,TCP_CONNECT,,,
Sat Mar 21 22:18:53 2009 TCP connection established with 78.42.159.42:443
Sat Mar 21 22:18:53 2009 Socket Buffers: R=[32768->32768] S=[16384->16384]
Sat Mar 21 22:18:53 2009 TCPv4_CLIENT link local (bound): [undef]
Sat Mar 21 22:18:53 2009 TCPv4_CLIENT link remote: 78.42.159.42:443
Sat Mar 21 22:18:53 2009 MANAGEMENT: >STATE:1237670333,WAIT,,,
Sat Mar 21 22:18:54 2009 MANAGEMENT: >STATE:1237670334,AUTH,,,
Sat Mar 21 22:18:54 2009 TLS: Initial packet from 78.42.159.42:443, sid=adf86229 0da5e408
Sat Mar 21 22:19:05 2009 VERIFY OK: depth=1, /C=DE/ST=BW/L=Buehlertann/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=BlackSunSoftwareGmbH-CA/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:05 2009 VERIFY X509NAME OK: /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:05 2009 VERIFY OK: depth=0, /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:12 2009 TLS Error: unknown opcode received from 78.42.159.42:443 op=25
Sat Mar 21 22:19:12 2009 Fatal TLS error (check_tls_errors_co), restarting
Sat Mar 21 22:19:12 2009 TCP/UDP: Closing socket
Sat Mar 21 22:19:12 2009 SIGUSR1[soft,tls-error] received, process restarting
Sat Mar 21 22:19:12 2009 MANAGEMENT: >STATE:1237670352,RECONNECTING,tls-error,,
Sat Mar 21 22:19:12 2009 Restart pause, 5 second(s)
Sat Mar 21 22:19:17 2009 WARNING: Make sure you understand the semantics of --tls-remote before using it (see the man page).
Sat Mar 21 22:19:17 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sat Mar 21 22:19:17 2009 Re-using SSL/TLS context
Sat Mar 21 22:19:17 2009 LZO compression initialized
Sat Mar 21 22:19:17 2009 Control Channel MTU parms [ L:1576 D:168 EF:68 EB:0 ET:0 EL:0 ]
Sat Mar 21 22:19:17 2009 MANAGEMENT: >STATE:1237670357,RESOLVE,,,
Sat Mar 21 22:19:17 2009 Data Channel MTU parms [ L:1576 D:1450 EF:44 EB:135 ET:32 EL:0 AF:3/1 ]
Sat Mar 21 22:19:17 2009 Local Options hash (VER=V4): 'e39a3273'
Sat Mar 21 22:19:17 2009 Expected Remote Options hash (VER=V4): '3c14feac'
Sat Mar 21 22:19:17 2009 Attempting to establish TCP connection with 78.42.159.42:443
Sat Mar 21 22:19:17 2009 MANAGEMENT: >STATE:1237670357,TCP_CONNECT,,,
Sat Mar 21 22:19:18 2009 TCP connection established with 78.42.159.42:443
Sat Mar 21 22:19:18 2009 Socket Buffers: R=[32768->32768] S=[16384->16384]
Sat Mar 21 22:19:18 2009 TCPv4_CLIENT link local (bound): [undef]
Sat Mar 21 22:19:18 2009 TCPv4_CLIENT link remote: 78.42.159.42:443
Sat Mar 21 22:19:18 2009 MANAGEMENT: >STATE:1237670358,WAIT,,,
Sat Mar 21 22:19:19 2009 MANAGEMENT: >STATE:1237670359,AUTH,,,
Sat Mar 21 22:19:19 2009 TLS: Initial packet from 78.42.159.42:443, sid=b6c16ddc d0e46bef
Sat Mar 21 22:19:30 2009 VERIFY OK: depth=1, /C=DE/ST=BW/L=Buehlertann/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=BlackSunSoftwareGmbH-CA/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:30 2009 VERIFY X509NAME OK: /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:30 2009 VERIFY OK: depth=0, /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:38 2009 TLS Error: Unroutable control packet received from 78.42.159.42:443 (si=3 op=P_ACK_V1)
Sat Mar 21 22:19:38 2009 Fatal TLS error (check_tls_errors_co), restarting
Sat Mar 21 22:19:38 2009 TCP/UDP: Closing socket
Sat Mar 21 22:19:38 2009 SIGUSR1[soft,tls-error] received, process restarting
Sat Mar 21 22:19:38 2009 MANAGEMENT: >STATE:1237670378,RECONNECTING,tls-error,,
Sat Mar 21 22:19:38 2009 Restart pause, 5 second(s)
Sat Mar 21 22:19:43 2009 WARNING: Make sure you understand the semantics of --tls-remote before using it (see the man page).
Sat Mar 21 22:19:43 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sat Mar 21 22:19:43 2009 Re-using SSL/TLS context
Sat Mar 21 22:19:43 2009 LZO compression initialized
Sat Mar 21 22:19:43 2009 Control Channel MTU parms [ L:1576 D:168 EF:68 EB:0 ET:0 EL:0 ]
Sat Mar 21 22:19:43 2009 MANAGEMENT: >STATE:1237670383,RESOLVE,,,
Sat Mar 21 22:19:43 2009 Data Channel MTU parms [ L:1576 D:1450 EF:44 EB:135 ET:32 EL:0 AF:3/1 ]
Sat Mar 21 22:19:43 2009 Local Options hash (VER=V4): 'e39a3273'
Sat Mar 21 22:19:43 2009 Expected Remote Options hash (VER=V4): '3c14feac'
Sat Mar 21 22:19:43 2009 Attempting to establish TCP connection with 78.42.159.42:443
Sat Mar 21 22:19:43 2009 MANAGEMENT: >STATE:1237670383,TCP_CONNECT,,,
Sat Mar 21 22:19:44 2009 TCP connection established with 78.42.159.42:443
Sat Mar 21 22:19:44 2009 Socket Buffers: R=[32768->32768] S=[16384->16384]
Sat Mar 21 22:19:44 2009 TCPv4_CLIENT link local (bound): [undef]
Sat Mar 21 22:19:44 2009 TCPv4_CLIENT link remote: 78.42.159.42:443
Sat Mar 21 22:19:44 2009 MANAGEMENT: >STATE:1237670384,WAIT,,,
Sat Mar 21 22:19:44 2009 MANAGEMENT: >STATE:1237670384,AUTH,,,
Sat Mar 21 22:19:44 2009 TLS: Initial packet from 78.42.159.42:443, sid=4cb84c12 9a2fc84d
Sat Mar 21 22:19:56 2009 VERIFY OK: depth=1, /C=DE/ST=BW/L=Buehlertann/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=BlackSunSoftwareGmbH-CA/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:56 2009 VERIFY X509NAME OK: /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:19:56 2009 VERIFY OK: depth=0, /C=DE/ST=BW/O=BlackSunSoftwareGmbH/OU=OpenVPN/CN=Eumex/emailAddress=blacksun@directbox.com
Sat Mar 21 22:20:04 2009 TLS Error: unknown opcode received from 78.42.159.42:443 op=20
Sat Mar 21 22:20:04 2009 Fatal TLS error (check_tls_errors_co), restarting
Sat Mar 21 22:20:04 2009 TCP/UDP: Closing socket
Sat Mar 21 22:20:04 2009 SIGUSR1[soft,tls-error] received, process restarting
Sat Mar 21 22:20:04 2009 MANAGEMENT: >STATE:1237670404,RECONNECTING,tls-error,,
Sat Mar 21 22:20:04 2009 Restart pause, 5 second(s)
Sat Mar 21 22:20:06 2009 SIGTERM[hard,init_instance] received, process exiting
Sat Mar 21 22:20:06 2009 MANAGEMENT: >STATE:1237670406,EXITING,init_instance,,
Sat Mar 21 22:20:06 2009 Releasing Windows Connection Manager provider
