Und was mach ich jetzt?
if test -d make/modcgi/files; then tar -c -C make/modcgi/files --exclude=.svn . | tar -x -C packages/modcgi-0.2 ; fi
--2009-06-26 22:45:23-- http://freetz.magenbrot.net/modcgi-0.2.tar.bz2
Auflösen des Hostnamen »freetz.magenbrot.net«.... 212.34.184.253
Verbindungsaufbau zu freetz.magenbrot.net|212.34.184.253|:80... verbunden.
HTTP Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 3873 (3,8K) [application/x-bzip2]
In »dl/modcgi-0.2.tar.bz2« speichern.
100%[===================================================================================>] 3.873 --.-K/s in 0,04s
2009-06-26 22:45:23 (89,6 KB/s) - »dl/modcgi-0.2.tar.bz2« gespeichert [3873/3873]
Download succeeded - http://freetz.magenbrot.net/modcgi-0.2.tar.bz2 -> saved to folder dl
rm -f -r source/modcgi-0.2
tar -C source -xjf dl/modcgi-0.2.tar.bz2
shopt -s nullglob; for i in make/modcgi/patches/*.patch; do tools/freetz_patch source/modcgi-0.2 $i; done
touch source/modcgi-0.2/.unpacked
touch source/modcgi-0.2/.configured
PATH="/home/freetz/freetz-stable-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" \
make -j4 -C source/modcgi-0.2 \
CROSS="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-" \
CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64"
make[1]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.1/source/modcgi-0.2'
cp proccgi/proccgi.c proccgi.c ; \
patch -p0 < patches/proccgi.c.patch ; \
mv proccgi.c modcgi.c
patching file proccgi.c
/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -o modcgi modcgi.c
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/source/modcgi-0.2'
mkdir -p packages/modcgi-0.2/root/usr/bin/
cp source/modcgi-0.2/modcgi packages/modcgi-0.2/root/usr/bin/modcgi
/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/modcgi-0.2/root/usr/bin/modcgi
mkdir -p packages/usbroot-0.2/root
if test -d make/usbroot/files; then tar -c -C make/usbroot/files --exclude=.svn . | tar -x -C packages/usbroot-0.2 ; fi
STEP 0: DOWNLOAD
downloading firmware image
--2009-06-26 22:45:24-- ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch/FRITZ.Box_Fon_WLAN_7270.54.04.70.image
=> `FRITZ.Box_Fon_WLAN_7270.54.04.70.image'
Auflösen des Hostnamen »ftp.avm.de«.... 212.42.244.90
Verbindungsaufbau zu ftp.avm.de|212.42.244.90|:21... verbunden.
Anmelden als anonymous ... Angemeldet!
==> SYST ... fertig. ==> PWD ... fertig.
==> TYPE I ... fertig. ==> CWD /fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch ... fertig.
==> SIZE FRITZ.Box_Fon_WLAN_7270.54.04.70.image ... fertig.
==> PASV ... fertig. ==> RETR FRITZ.Box_Fon_WLAN_7270.54.04.70.image ...
Die Datei »FRITZ.Box_Fon_WLAN_7270.54.04.70.image« gibt es nicht.
ERROR: Could not download Firmwareimage.
make: *** [dl/fw/FRITZ.Box_Fon_WLAN_7270.54.04.70.image] Fehler 3
real 11m8.369s
user 7m34.600s
sys 4m59.480s
freetz@freetz-linux:~/freetz-stable-1.1$
