[gelöst] freetz-devel-3251: USB-Stick gefunden, wird aber nicht gemountet
ao
Aktives Mitglied
15 Aug 2005
mit o.g. FW (7170) habe ich das Problem, dass mein USB-Stick wohl erkannt, aber nicht ordentlich gemountet wird:
Apr 29 07:35:13 fritz user.info kernel: Initializing USB Mass Storage driver...
Apr 29 07:35:13 fritz user.info kernel: USB Mass Storage device (05dc:0330) detected...
Apr 29 07:35:13 fritz user.warn kernel: SLAB: cache with size 352 has lost its name
Apr 29 07:35:13 fritz user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Apr 29 07:35:13 fritz user.debug kernel: usb-storage: device found at 8
Apr 29 07:35:13 fritz user.debug kernel: usb-storage: waiting for device to settle before scanning
Apr 29 07:35:13 fritz user.info kernel: usbcore: registered new driver usb-storage
Apr 29 07:35:13 fritz user.info kernel: USB Mass Storage support registered.
Apr 29 07:35:14 fritz user.warn kernel: SLAB: cache with size 352 has lost its name
Apr 29 07:35:18 fritz user.notice kernel:   Vendor: LEXAR     Model: JD EXPRESSION     Rev: 1.00
Apr 29 07:35:18 fritz user.notice kernel:   Type:   Direct-Access                      ANSI SCSI revision: 01 CCS
Apr 29 07:35:18 fritz user.notice kernel: SCSI device sda: 503808 512-byte hdwr sectors (258 MB)
Apr 29 07:35:18 fritz user.notice kernel: sda: Write Protect is off
Apr 29 07:35:18 fritz user.debug kernel: sda: Mode Sense: 23 00 00 00
Apr 29 07:35:18 fritz user.err kernel: sda: assuming drive cache: write through
Apr 29 07:35:18 fritz user.info kernel:  sda:
Apr 29 07:35:18 fritz user.info kernel:  sda1
Apr 29 07:35:18 fritz user.notice kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Apr 29 07:35:18 fritz user.debug kernel: usb-storage: device scan complete
Apr 29 07:35:58 fritz user.notice kernel: usb_unlink_urb() is deprecated for synchronous unlinks.  Use usb_kill_urb() instead.
Apr 29 07:35:58 fritz user.info kernel: usb 1-1.1: reset full speed USB device using ahci and address 8
Apr 29 07:36:04 fritz user.warn kernel: /proc/tffs: info request: success
Apr 29 07:36:28 fritz user.notice kernel: usb_unlink_urb() is deprecated for synchronous unlinks.  Use usb_kill_urb() instead.
Apr 29 07:36:28 fritz user.info kernel: usb 1-1.1: reset full speed USB device using ahci and address 8
Apr 29 07:36:58 fritz user.notice kernel: usb_unlink_urb() is deprecated for synchronous unlinks.  Use usb_kill_urb() instead.
Lässt sich hieraus die Ursache erkennen? Ich weiß nicht so recht weiter, denn auch ein Reboot und auch Hot-Plugging haben nicht geholfen. Danke für Eure Hilfe!
Ich sehe nur einige seltsame Meldungen, die ich vorher noch nie gesehen habe. Hast du mal einen anderen Stick probiert?
MfG Oliver
Noch nicht, hole ich aber gerne heute Abend nach und poste dann nochmal den Syslog-Output.
Welche Meldungen kommen Dir seltsam vor?
MfG Oliver
es lag am Stick/-Inhalt. Nach Formatierung (ext2) und Neuanlage aller nötigen Konfigurationen und externer Programme klappt es jetzt wieder.
Warum der Stick/-Inhalt hinüber war, weiß ich nicht, aber Sticks sind halt auch fehleranfällig.
Liegt's evtl. am Swappen auf dem Stick?
Ich hab übrigens am Wochenende auch meinen ext3-superblock "verloren". Bei ausführen von "reboot" auf der Box kommen immer ziehmlich viele Fehler vom Stick. Der wird wohl nicht richtig ausgehängt
Hast Du es mit einem anderen Stick versucht, oder mit ext2 statt ext3?
Verwendest Du swap auf dem Stick?
Kein swap. Aber rrdstats loggt darauf. Vielleicht kommen die Fehler daher, dass alle Freetz-Dienste noch laufen
Stimmt, ich habe u.a. auch rrdstats drauf laufen, zzgl. swap.
Aber wenn das ein generelles Problem wäre, würden sich doch sicherlich noch andere melden.
Haben USB-Sticks nicht so ein internes Management, dass defekte Sektoren nicht mehr verwendet werden?
Oder hängt das auch vom Format ab, also ext2/ext3, reiserfs, ntfs o.a.?
Ich meine, in dem Zusammenhang gelesen zu haben, dass man sich keine Gedanken machen müsste, dass ein USB-Stick allzuschnell abraucht.
Was mir noch auffällt: Oben im Log steht was von "SLAB". Bei mir verbrät DigiTemp die slab "size-32" so, dass die Box nicht viel länger als 1 Tag ohne Reboot läuft
Was bedeutet SLAB bzw. slab-size 32 im Zusammenhang mit digitemp? Danke für's Feedback!
Schau mal hier ab Post 52
Ich hoffe dein Memory-Log sieh nicht auch so aus:
Keine Ahnung, was da wie nicht aussehen soll. Meins ist im Anhang und außerdem anbei noch:
/var/mod/root # echo -n " slab size-32: $(((`cat /proc/slabinfo |grep "size-32     "|tr -s " "| cut -d " " -f 2,4|sed 's/ /*/'`)/1048576)) MB, uptime ";upti
me|sed 's/.* up //;s/,.*//'
 slab size-32: 0 MB, uptime 17:45
Leider habe ich kein weiter zurückliegenden Output, und ich bin mir auch nicht sicher, ob in den letzten 24h immer digitemp lief. Aber falls ich das nochmals 100%ig korrekt nachvollziehen kann, mache ich hier (bzw. hier) gerne ein Update.
Was man oben auf dem Screenshot sieht ist, dass die RAM Auslastung auf bis zu 50 MB steigt und die Box dann immer Rebootet :-(
#Kuddel#
