Freetz 1.0.1 u. 7240 Labor 14371 Image Erstellung bricht ab
Eldrik
4 Jul 2007
Mit der neuen Labor 14371 bekomme ich bei der Imageerstellung neuerdings eine Fehlermeldung :(.
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
  created 2865 files
  created 132 directories
  created 314 symlinks
  created 323 devices
  created 0 fifos
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
  applying patches (7240-de)
    applying patch file ./patches/7240/100-webif.sh
  Applying symlinks, deleting additional webinterfaces
    applying patch file ./patches/7240/110-inittab.sh
    applying patch file ./patches/7240/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/120-inittab_console.patch
    patching file etc/inittab
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7240/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7240/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    Hunk #1 succeeded at 217 (offset -692 lines).
    applying patch file ./patches/7240/120-rc.S-dev.patch
    applying patch file ./patches/7240/130-rc.S-logging.patch
    applying patch file ./patches/7240/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1464 (offset 13 lines).
    applying patch file ./patches/7240/290-replace_websrv-remove_igdd.patch
    Hunk #1 FAILED at 57.
    Hunk #2 succeeded at 301 (offset 6 lines).
    1 out of 2 hunks FAILED -- saving rejects to file etc/init.d/rc.net.rej
ERROR: modpatch: Error in patch-file ./patches/7240/290-replace_websrv-remove_igdd.patch
make: *** [firmware-nocompile] Fehler 2
Meine Freetz Version 1.0.1 Revision 3384.
Jemand ne Idee?
Greetings
Eldrik
Ja, die Labor-Firmwares werden nur im Trunk sauber gepflegt, und sind eigentlich in den Releases deaktiviert.
Das heißt jetzt?
Abhilfe möglich?
Edit: alles klar trunk geladen und gudd :)
das ergibt sich doch schon beim lesen! entweder trunk nehmen oder auf labor verzichten!
IPPF im Überblick
