freetz 1.1 + eumex300ip.49FW+ privoxy fehler beim kompilieren
pixide
15 Jan 2005
mipsel-linux-ranlib libopenbsd-compat.a
make[2]: Verlasse Verzeichnis '/home/user001/Desktop/freetz-1.1/source/openntpd-3.9p1/openbsd-compat'
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DUSE_ADJTIMEX -o ntpd ntpd.o buffer.o log.o imsg.o ntp.o ntp_msg.o config.o server.o client.o util.o y.tab.o openbsd-compat/libopenbsd-compat.a
make[1]: Verlasse Verzeichnis '/home/user001/Desktop/freetz-1.1/source/openntpd-3.9p1'
mkdir -p packages/openntpd-3.9p1/root/usr/sbin/
cp source/openntpd-3.9p1/ntpd packages/openntpd-3.9p1/root/usr/sbin/ntpd
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/openntpd-3.9p1/root/usr/sbin/ntpd
PATH="/home/user001/Desktop/freetz-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" \
make -j2 -C source/privoxy-3.0.10-stable
make[1]: Betrete Verzeichnis '/home/user001/Desktop/freetz-1.1/source/privoxy-3.0.10-stable'
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre actions.c -o actions.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre cgi.c -o cgi.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre cgiedit.c -o cgiedit.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre cgisimple.c -o cgisimple.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre deanimate.c -o deanimate.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre encode.c -o encode.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre errlog.c -o errlog.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre filters.c -o filters.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre gateway.c -o gateway.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre jbsockets.c -o jbsockets.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre jcc.c -o jcc.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre list.c -o list.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre loadcfg.c -o loadcfg.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre loaders.c -o loaders.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre miscutil.c -o miscutil.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre parsers.c -o parsers.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre ssplit.c -o ssplit.o
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre urlmatch.c -o urlmatch.o
parsers.c:841:18: error: zlib.h: No such file or directory
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre pcrs.c -o pcrs.o
parsers.c: In function 'decompress_iob':
parsers.c:1138: error: 'z_stream' undeclared (first use in this function)
parsers.c:1138: error: (Each undeclared identifier is reported only once
parsers.c:1138: error: for each function it appears in.)
parsers.c:1138: error: expected ';' before 'zstr'
parsers.c:1175: error: 'Z_DEFLATED' undeclared (first use in this function)
parsers.c:1308: error: 'zstr' undeclared (first use in this function)
parsers.c:1308: error: 'Bytef' undeclared (first use in this function)
parsers.c:1308: error: expected expression before ')' token
parsers.c:1310: error: 'Z_NULL' undeclared (first use in this function)
parsers.c:1318: warning: implicit declaration of function 'inflateInit2'
parsers.c:1318: error: 'MAX_WBITS' undeclared (first use in this function)
parsers.c:1318: error: 'Z_OK' undeclared (first use in this function)
parsers.c:1339: error: expected expression before ')' token
parsers.c:1342: error: 'Z_BUF_ERROR' undeclared (first use in this function)
parsers.c:1342: warning: implicit declaration of function 'inflate'
parsers.c:1342: error: 'Z_FINISH' undeclared (first use in this function)
parsers.c:1396: error: expected expression before ')' token
parsers.c:1410: error: 'Z_STREAM_ERROR' undeclared (first use in this function)
parsers.c:1410: warning: implicit declaration of function 'inflateEnd'
parsers.c:1426: error: 'Z_STREAM_END' undeclared (first use in this function)
/home/user001/Desktop/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -pipe -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Ipcre pcre/get.c -o pcre/get.o
make[1]: *** [parsers.o] Fehler 1
make[1]: *** Warte auf noch nicht beendete Prozesse...
make[1]: Verlasse Verzeichnis '/home/user001/Desktop/freetz-1.1/source/privoxy-3.0.10-stable'
make: *** [source/privoxy-3.0.10-stable/privoxy] Fehler 2
