[EN] Fritz 7270 conversion German to International
Majdan
5 Nov 2006
Hi!
I have Fritz 7270 with old German interface (Annex B).
I tried to upload new Inernational Firmware, but I got error that my box does not support this firmware.
1) Is it possible to run English language in my Fritz?
2) Is it possible to use Annex A or Annex A&B (like in International version)?
With kind regards,
Majdan
Yes, it is possible.
Just to help you understand:
1) To load MultiLanguage FW 54.04.67_en-de-it-es you must only change an environment parameter: "firmware_version" must be set to "avme"
2) To use newest german FW 54.04.76 with AnnexA it is somewhat tricky. You must use freetz or "speed-to-fritz" by Jpascher. I recommend you the latter - it is easier.
The "how to" is described in different threads here in the forum.
Good luck!
@Stiefel:
Your link dedicates to change from AnnexB to AnnexA in general.
With the FB7270 it is a little different.
Stiefel schrieb:
I've already seen it. There's a lot of information about 7170 and I can't find any helpful for me and my FB 7270.
There is also a big mess.
el_valiente,
1) So I should do: ?
i) ftp 192.168.178.1
quote SETENV firmware_version avme
ii) Use recover: http://download.avm.de/fritz.box/fritzbox.fon_wlan_7270/x_misc/english/?
Or do not use recover? (You didn't write about it)
iii) And then upload http://download.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/english/FRITZ.Box_Fon_WLAN_7270.en-de-es-it.54.04.67.image?
2) I didn't clearly expressed myself.
I want to change "FB Annex B German" to "FB Annex A&B English" or "FB Annex A English" (if A&B not possible).
If I change to English (International?), there will be also Annex A&B? Or I need to change Annex in other way?
i) ftp 192.168.178.1; quote SETENV firmware_version avme
That is correct.
The FB will be temporarily not accessible - dont worry!
ii) Use recover: FRITZ.Box_Fon_WLAN_7270.en-de-es-it.54.04.67
That is correct, too
iii) And then upload FRITZ.Box_Fon_WLAN_7270.en-de-es-it.54.04.67
That is not necessary
Yes!
International MultiLanguage FW 54.04.67_en-de-it-es includes MultiAnnex A&B
PauSchmitz
