ERROR: modpatch: Error in patch-file ./patches/7240/290-replace_websrv-remove_igdd.pa
Kalle322
9 Aug 2007
Hallo Community,
habe versucht einige Pakete einzubinden. Bekomme nun aber diese Fehlermeldung
slightly@StinkyLinux:~/freetz-1.1$ make
WARNING: The program intltool-update was not found in path.
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
  3519 inodes (3748 blocks) to write
[=============================================================/] 3748/3748 100%
  created 2882 files
  created 132 directories
  created 314 symlinks
  created 323 devices
  created 0 fifos
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
  applying patches (7240-de)
    applying patch file ./patches/7240/100-webif.sh
  Applying symlinks, deleting additional webinterfaces
    applying patch file ./patches/7240/110-inittab.sh
    applying patch file ./patches/7240/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/120-inittab_console.patch
    patching file etc/inittab
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7240/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7240/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    Hunk #1 succeeded at 217 (offset -730 lines).
    applying patch file ./patches/7240/120-rc.S-dev.patch
    applying patch file ./patches/7240/130-rc.S-logging.patch
    applying patch file ./patches/7240/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1531 (offset 74 lines).
    applying patch file ./patches/7240/290-replace_websrv-remove_igdd.patch
    Hunk #1 FAILED at 57.
    1 out of 2 hunks FAILED -- saving rejects to file etc/init.d/rc.net.rej
ERROR: modpatch: Error in patch-file ./patches/7240/290-replace_websrv-remove_igdd.patch
make: *** [firmware-nocompile] Fehler 2
Wie kann ich ein Outpost machen, von meinen Einstellungen von den Patches/Paketen?
Oder ist es offensichtlich, welchen Fehler ich gemacht habe? Habe schon etwas gegoogelt und hier im Forum gesucht und hab wirklich nur ein passender Thread gefunden:
http://www.ip-phone-forum.de/showthread.php?p=1352881
Aber leider hat dieser mir nicht weitergeholfen... Das "Remove UPnP Daemon" habe ich nicht angewählt...
Über euere Hilfe wär ich sehr dankbar...
Schöner Gruß
Kalle
Offensichtlich ist, dass du vergessen hast zu erwähnen, welche Version von Freetz du nutzt, und welche Firmwareversion du versuchs zu bauen.
Ich rate mal aus deiner Fehler, dass du versucht, die 1.1 zu flashen, aber ob du diese aus dem SVN heraus - also den ausgecheckten Branch - oder per Download hinbekommen hast, ersehe ich daraus nicht. Ich tippe auf den Branch, und ich tippe darauf, dass du versuchst, die Labor Phone zu basteln, aber kann auch vollkommen falsch liegen. Sicher ist, du versuchst was für die 7240 zu basteln, und sicher ist, dass du irgendeine Form der Freetz-1.1-Version nutzt. mehr nicht.
Ich bitte um Entschuldigung.. Das habe ich vergessen.
Nutze die Freetz-Version 1.1 und die Firmware 73.04.76 auf einer 7240.
..., aber ob du diese aus dem SVN heraus - also den ausgecheckten Branch - oder per Download hinbekommen hast, ersehe ich daraus nicht.
Habe "svn co http://svn.freetz.org/tags/freetz-1.1 freetz-1.1" bei Putty (SSH Verbindung) eingegeben. So wie es in dieser Newbe-Einleitung steht
Wollte diese "FRITZ.Box_Fon_WLAN_7240.73.04.76.image" bearbeiten.
Hast du den Imagenamen von Hand geändert? Eigentlich sollte der doch die 04.70 suchen.
Mfg Oliver
Override? Fällt mir dazu so ein.
Jep, hab ich gemacht.. da er die alte Firmware nicht gefunden hat und abgebrochen hat...
Vergiss es und such lieber nach der alten Firmware, oder warte eben, bis es eine 1.1.1 gibt.
Es gibt hier im Forum einen Thread, in dem man solche Requests unterbringen kann.
Ich gehe übrigens mal davon aus, dass du bei der fehlermeldung keinen Blickins Wiki oder die FAQ geworfen hast? Hol das mal bitte nach, die Fehlermeldung ist sogar in den FAQ direkt vorhanden.
Okay habs mit der 73.04.70 ausprobiert und hat einwandfrei funktioniert. Vielen dank für eure Hilfe.. nun nur noch testen, ob es auch läuft ;)
ipeee
