Fehler in Speedport2Fritz nach dem Einfügen von Freetz-Modulen
alligator_asl
20 Sep 2007
wollte heute wiedermal meine Firmware auf den neusten Stand bringen, habe wie immer Speedport2Fritz und Freetz verwendet. Leider lief das Script diesmal nicht bis zum Ende durch, sondern brach vorher ab:
  Invoke 'speed-to-fritz' now? (y/n)?
Be patient ...
Firmware configuration taken from: conf-701-freetz
Speed-to-Fritz version: 17.09.09-multi
Phase 1: Download or check firmware images.
Phase 2: Unpack and extract files from images.
Extracting image files to temporary directories ...
-- Unpacking fw_Speedport_W701V_v33.04.57.image to:
      /home/edvr/download/speed-to-fritz/SPDIR
remove tichksum
splitting kernel image
Extract Filesystem ...
681 inodes (800 blocks) to write
[===============================================================/] 800/800 100%
created 348 files
created 50 directories
created 178 symlinks
created 155 devices
created 0 fifos
unpacking var.tar
-- Unpacking 7170_04.76freetz-develX.de_20090917-181838.image to:
      /home/edvr/download/speed-to-fritz/FBDIR
remove tichksum
2231 inodes (2432 blocks) to write
[=============================================================-] 2432/2432 100%
created 1529 files
created 128 directories
created 377 symlinks
created 324 devices
created 1 fifos
unpacking var.tar
Images extracted... Press 'ENTER' to continue
Verifying version of firmware images ...
-- T-Home firmware version:     33.04.57-0
-- AVM    firmware version:     29.04.76-0
-- T-Home  # Versioninfo:       33.04.57
-- AVM     # Versioninfo:       29.04.76
-- T-Home  # Checkpoint:        r11284
-- AVM     # Checkpoint:        r14789
-- T-Home  # Kernelsize:        7798784
-- AVM     # Kernelsize:        7798784
-- T-Home Kernel version is: 2.6.13.1-ohio
-- AVM  Kernel version is: 2.6.13.1-ohio
-- T-Home  uClib version is: 0.9.28
-- AVM   uClib version is: 0.9.29
WARNING! uClib version of AVM and T-Home firmware differ!
HW Feature      Fritz_Box_SpeedportW701V        Fritz_Box_7170
DECT:           not detected            not detected
ISDN NT:        not detected            detected
ISDN TE:        detected                detected
USB Port:       not detected            1.0 detected
a/b Ports:      2 Port(s)               3 Port(s)
eth Ports:      4 Port(s)               4 Port(s)
Phase 3: Copy sources.
707/////////////////////////////////////////////////////////////////////////////
-- Removed directory: www/1und1
-- Removed directory: www/freenet
-- Moving /www/all to /www/avm ...
-- Removed directory: www/all
Phase 4: Apply changes.
-- Matching Versions: 04.76-0 - 04.57-0
Replacing hardware related files of AVM firmware images ...
-- Copy original T-com module:
      /lib/modules
  -- piglet_width_running=1
  -- piglet_usb_power_bit=-1
  -- piglet_disable_test=1
  -- piglet_cs=5
  -- piglet_reset_bit=-2
  -- piglet_bitfile_offset=0x51
  -- piglet_bitfile_write=-1
  -- piglet_bitfile_revbytes=1
  -- piglet_enable_button2=1
-- copy complete AVM source to destination directory!
Fritz_Box_7170  --->   Fritz_Box_SpeedportW701V
-- Move contents of OEM directory:
      move /etc/default.Fritz_Box_7170 --> /etc/default.Fritz_Box_SpeedportW701V
-- Removing 'internal S0', from setup page ...
-- Removing 'USB' from setup page ...
-- Removing 'internal FON 3', from setup page ...
      /etc/usbclass.tab
      /etc/usbdevice.tab
      /usr/share/ctlmgr/libctlusb.so
      /bin/usbhostchanged
      /sbin/eventadd
      /sbin/hotplug
      /sbin/lsusb
      /sbin/printserv
 -- Removing /usr/www/avm/html/de/menus/menu2_usb.inc
 -- Removing /usr/www/avm/html/de/home/menu2_usb.html
   -- Removing USB Symbol LED from:
      /usr/www/avm/html/de/home/home.html
      /usr/www/avm/html/de/menus/menu2_fon.html
      /usr/www/avm/html/de/menus/menu2_home.html
      /usr/www/avm/html/de/menus/menu2_konfig.html
      /usr/www/avm/html/de/menus/menu2_internet.html
      /usr/www/avm/html/de/menus/menu2_wlan.html
      /usr/www/avm/html/de/menus/menu2_system.html
      /usr/www/avm/html/de/menus/menu2_software.html
      /usr/www/avm/html/de/system/syslog.html
      /usr/www/avm/html/de/system/energy.html
      /usr/www/avm/html/de/system/energy.js
      /usr/www/avm/html/de/wlan/common.html
      /usr/www/avm/html/de/home/sitemap.html
      /usr/www/avm/html/de/fon/tamlist.html
      /usr/www/avm/html/de/home/tamedit.html
      /usr/www/avm/html/de/fon_config/fon_config_3fxi.js
      /usr/www/avm/html/de/fon_config/fon_config_3fxi.html
   -- Removing directory:
      /usr/www/avm/html/de/usb
 -- Remove some 'internal S0' Text in Files ...
      /usr/www/avm/html/de/fon_config/fon_config_Start.html
      /usr/www/avm/html/de/fon_config/fon_config_1.js
      /usr/www/avm/html/de/fon_config/fon_config_2.js
      /usr/www/avm/html/de/fon_config/fon_config_check.html
      /usr/www/avm/html/de/fon_config/fon_config_check.js
      /usr/www/avm/html/de/fon_config/fon_config_End.html
      /usr/www/avm/html/de/fon_config/fon_config_End.js
      /usr/www/avm/html/de/fon_config/fon_config_IsdnSwitch.html
      /usr/www/avm/html/de/fon_config/fon_config_IsdnSwitch.js
      /usr/www/avm/html/de/fon_config/fon_config_msn.html
      /usr/www/avm/html/de/fon_config/fon_config_test.html
      /usr/www/avm/html/de/fon_config/fon_config_test.js
      /usr/www/avm/html/de/home/dial.js
      /usr/www/avm/html/de/home/fon1Dect.js
      /usr/www/avm/html/de/home/fon1isdn.html
      /usr/www/avm/html/de/home/fon1isdn.js
      /usr/www/avm/html/de/home/fon1.js
      /usr/www/avm/html/de/home/fon1Mini.js
      /usr/www/avm/html/de/home/fonbuch.js
      /usr/www/avm/html/de/home/foncalls.js
      /usr/www/avm/html/de/home/fondevices.js
      /usr/www/avm/html/de/home/fondevlist.js
      /usr/www/avm/html/de/home/home.js
      /usr/www/avm/html/de/home/isdn.html
      /usr/www/avm/html/de/home/isdn.js
      /usr/www/avm/html/de/home/isdnoptionen.html
      /usr/www/avm/html/de/home/isdnoptionen.js
      /usr/www/avm/html/de/home/merkmale_mini.html
      /usr/www/avm/html/de/home/msn.html
      /usr/www/avm/html/de/home/msn.js
      /usr/www/avm/html/de/home/ppFonbuch.html
-- Adjusting config parms in:
      /etc/init.d/rc.conf
-- Changing product to Fritz_Box_SpeedportW701V
      /usr/www/kids
-- Bugfix for home.js
-- Adding 'Info' button and display of mod related data ...
-- Adding Header ...
      /usr/www/avm/html/de/images/fw_header980.gif
-- Add support menu-item...
-- Adding DSL expert pages ...
applying patch file /home/edvr/download/speed-to-fritz/alien/patches/add_dsl_expert_de_ut8.patch
patching file internet/labor_dsl.frm
patching file internet/labor_dsl.html
patching file internet/labor_dsl.js
  /usr/www/avm/html/de/internet/adsl.html
  /usr/www/avm/html/de/internet/atm.html
  /usr/www/avm/html/de/internet/bits.html
  /usr/www/avm/html/de/internet/overview.html
  /usr/www/avm/html/de/internet/feedback.html
-- Replace menu-item assistent...
-- Set Expertansicht ...
  'in file: /default.Fritz_Box_SpeedportW701V/avm/ar7.cfg
  'in file: /default.Fritz_Box_SpeedportW701V/1und1/ar7.cfg
  'in file: /default.Fritz_Box_SpeedportW701V/tcom/ar7.cfg
  'in file: /default.Fritz_Box_SpeedportW701V/freenet/ar7.cfg
-- Added MAC settings to page:
  /usr/www/avm/html/de/internet/internet_expert.js
-- Make links...
     /usr/www/1und1
     /usr/www/freenet
     /usr/www/tcom
-- Applying 'check signature' patch ...
-- Patching file:
      /usr/www/html/de/home/home.js ...
-- Signature removed in avm/html/de/home/home.js
-- Patching install webpages ...
      patch update page (de) avm/html/tools/downgrade.html...
      patch update page (de) avm/html/tools/flash.html...
      patch update page (de) avm/html/tools/flash2.html...
      patch update page (de) avm/html/tools/update_not_signed.html...
      patch update page (de) avm/html/tools/update_not_signed_no_password.html...
      patch update page (de) avm/html/restart.html...
      patch update page (de) avm/html/tools/update_result.html...
Phase 9: Patch install.
Path: /home/edvr/download/speed-to-fritz/FBDIR
applying patch file /home/edvr/download/speed-to-fritz/alien/patches/add_var-install.patch
patching file var/install
Phase 10: Pack and deliver.
Settings:
Script version               : 17.09.09-multi
Firmware for update via GUI  : fw_C_Speedport_W701V_33.04.57-0_Fritz_Box_SpeedportW701V_29.04.76-0-freetz-3668M-sp2fr-09.09.17-r-552M_OEM-avm_annexB_de.image
Firmware for update via FTP  : kernel.image
Output directory             : /home/edvr/download/speed-to-fritz/Firmware.new
for Speedport model          : W701V
Branding set to              : avm
AVM source is                : Fritz_Box_7170
AVM source firmware mod is   : 7170
Ready for packing... Press 'ENTER' to continue...
/home/edvr/download/speed-to-fritz/tools/tar: unrecognized option `--owner=0'
BusyBox v1.15.0 (2009-09-16 22:56:01 CEST) multi-call binary
Usage: tar -[caxtvO] [-X FILE] [-f TARFILE] [-C DIR] [FILE(s)]...
ERROR OCCURED !!! - Push 'Q' to get back.
(END)
Habe ich hier was falsch gemacht oder hat sich hier vielleicht ein Fehler im Script eingeschlichen?
Hat jemand eine Ahnung, wo das Problem liegt?
Danke!
MfG
alligator_asl
Ich kann das so leider nicht nachstellen, hier läuft speed-to-fritz und das anschliessende Freetz durch. Ein Unterschied wäre allerdings: ich habe die aktuelle speed-to-fritz-Revision #553 verwendet, bei dir war es noch #552. Auch Freetz ist zwei Revisionen weiter (mittlerweile #3670). Aber bei dir scheint es ein anderer Fehler zu sein, etwas stimmt mit dem "Tar" nicht.
mfg
Keine Ahnunug warum, du hast auf jeden Fall nicht den richtigen tar im Toolsverzeichnis, bei dir ist der Link auf die busybox aktiv. Könnte sein, dass das erst neu auftritt aber erklärn kann ich mir das momentan nicht.
habe das ganze nochmal probiert, Spedport2fritz und Freetz weggelöscht und neu aus dem Netz geladen. Leider ohne Erfiolg. Auch eine andere Linix-Version brachte das selbe Ergebnis. Install-tools hatte ich auch vorher durchgeführt.
Schätze es liegt an meiner Auswahl in Spedport2fritz und in Freetz.
alligator-asl
Kommt der selbe fehler wieder ?
Freetz lauft ja probelmlos durch bei dir.
Es ist nur das Probelem mit den tar.
Habe es auch probiert, hatte keine Probelme.
ja, der selbe Fehler. Trotz verschienener LINUX-Versionen und trotz neuem Download der aktuellen Version.
Gehe dem nach was ich geschriebn habe.
Hast du eine gepackte version von speed-to-fritz in Verwendung oder verwenderst du das SVN? (download_speed-to-fritz.sh)
also nachdem ich heute, nach der Methode wie sie hier "Speedport2Fritz und Freetz - neue Anleitungen (geändert 28.06.2009)" von Ernest015 beschrieben ist, versucht habe ein neues Image zu erstellen, erhielt ich die gleiche Warnung wie alligator_asl
"-- T-Home uClib version is: 0.9.28
WARNING! uClib version of AVM and T-Home firmware differ!".
Nach kurzer Verweildauer lief das Skript dann weiter.
Ein schwerer Dämpfer für mein aufflammendes Selbstbewusstsein. Erst im August habe ich für mich und meinen Kollegen jeweils ein Image für den W 900V und den W 920V erstellt ohne mindestens zwei Kilo Ausgeschwitztes zu verlieren. Momentan hängt das Skript bei "Creating Filesystem Image, be patient...". Sollte da noch ein Image bei rauskommen, werde ich es sicherheitshalber nicht nutzen und abwarten was die Spezialisten hier herausbekommen.:)
bis dann.
Ist ja nur eine Warnung und kein Fehler.
Es könnte somit gewisse Einschränkungen geben aber bisher hat niemand von ernsten Problemen berichtet.
Das ist nicht tragisch. Die uClibC ist nur eine "abgespeckte" Bibliothek für den Compiler, ursprünglich wurde sie mal für Mikrocontroller entwickelt, daher das uC im Namen. Bei der AVM-Firmware ist die Version halt etwas neuer, Unterschiede in der Funktion haben sich aber bislang nicht herausgestellt. Bei alligator_asl liegt der Fehler woanders. Entweder ist seine "tar"-Version (ein Paket, welches zum Packen/entpacken von Dateien benutzt wird) zu alt oder das Script findet auf seinem Linux nicht die Version, die es eigentlich benutzen soll.
Wir hatten et gestern ausprobiert, ein Image mit seiner Konfiguration und den gewünschten Freetz-Paketen wird hier mit Ubuntu 9.04 einwandfrei erstellt.
mfg
Freetz Fehler
obwohl alles neu erstellt wurde, (aktuelles "speed-to-fritz" (SVN) und aktueller trunk von "freetz", nach Anleitung erstellt) läuft freetz nicht durch; siehe Fehlermeldung:
"STEP 2: MODIFY
  Applying symlinks, deleting additional webinterfaces
applying patches
  applying patches (7270-de)
    applying patch file ./patches/7270/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7270/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7270/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    Hunk #1 succeeded at 217 (offset -730 lines).
    applying patch file ./patches/7270/120-rc.S-dev.patch
    applying patch file ./patches/7270/130-rc.S-logging.patch
    applying patch file ./patches/7270/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1554 (offset 74 lines).
    applying patch file ./patches/7270/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/7270/de/190-webmenu.patch
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2_konfig.html
    applying patch file ./patches/7270/de/200-sperre1.patch
    patching file usr/www/avm/html/de/fon/sperre1.js
    applying patch file ./patches/7270/de/210-notmountable.patch
    patching file usr/www/all/html/de/home/home.js
    Hunk #1 FAILED at 797.
    1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/home/home.js.rej
ERROR: modpatch: Error in patch-file ./patches/7270/de/210-notmountable.patch
make: *** [firmware-nocompile] Fehler 2
modimage=
_______________________________________________________________________________________________________________
Something went wrong, Freetzfirmware not found!
If Firmware was created, you may copy the freetz image yourself to:
/home/jh/Desktop/speed-to-fritz/Firmware.orig
Then start speed-to-fretz setup (./start) again and select freetz image as AVM LABOR source
All done .... Press 'ENTER' to return to the calling shell."
Hat jemand 'nen Tip was ich machen soll?
odeon
Edit Ernest105: Ausgabetext in Code-Tags gesetzt
@odeon
Welche Firmware-Versionen wurden denn zur Erstellung verwendet? Und evtl. auch noch von Interesse: welche Linux-Version?
mfg
Freetz Fehler
@Ernest015
Danke für die Rückmeldung.
Ich nutze Ubuntu 8.04 installiert auf Festplatte. Alle Updates wurden nach Deiner Anleitung für die VM eingespielt.
Als Firmware-Versionen habe ich das Script von gestern unverändert übernommen. Ich glaube jdeoch das ich mit den Vinax-Treibern aus der 7570 evtl. keine Verbindung zustande bring wegen DPBO. Sollte ich eine andere Firmware-Kombination nehmen? (Über DPBO finde ich weing Infos).
Wie setze ich den Ausgabetext in "Code-Tags"?
odeon
Willst du wirklich die firmware mit freetz bearbeiten?
Speedport W 920V, Firmware-Version: fw_C_Speedport_W920V_65.04.71-0_Fritz_Box_DECT_W920V_54.04.70-13486-freetz-3100M-sp2fr-09.06.08-r-324M_OEM-avm_annexB.image
Für diese muss im Speed-to-fritz auch eine alte Revisionsnummer für freetz gewählt werden.
Nimm doch die Voreingestellte die funktioniert doch nun bei allen.
@Jpascher
ich brauche Samba, WOL, Dropbear, openVPN, und ssh-Server.
Kann ich dieses Features anders realisieren?
Gibt es Erfahrungen (ich habe beim durchforsten der Treads nichts gefunden), mit dem aktuellen Script ohne Änderungen mit DPBO DSLAM?
mfg
odeon
@ernest015, Jpascher
ich habe nochmals alle Ordner gelöscht, neu heruntergeladen und mit den eingestellten Werten speed2fritz und freetz durchlaufen lassen.
Bei freetz, obwohl lt. Empfehlung von Jpascher nichts geändert, die gleiche Fehlermeldung:
STEP 2: MODIFY
applying patches
    Hunk #1 succeeded at 1554 with fuzz 2 (offset -72 lines).
modimage=
Was stimmt da nicht?
odeon
@Edit: ich bin zu blöd die Code-Tags zu setzten!
Edit Ernest015: War schon soweit richtig, nur wurde beim zweiten "code" nach dem Text der Schrägstrich davor vergessen:
[ code ] ...eingebundener Text .... [ /code ] (ohne Leerzeichen in den eckigen Klammern, das ist nur wegen der Darstellung)
Poste bitte deine Firmware.conf.tar dann probiere ich es damit aus.
@Jpascher
vielen Dank für Dein Angebot - wie immer hilfsbereit - .
ich habe deine Firmware.conf aus Post #1123 (Speedport W920V zu Fritzbox 7270 flashen?! Teil 3) genommen und stufenweise, zuerst ohne Änderungen in freetz gestartet, dann nach und nach Elemente hinzugefügt.
Es hat alles funktioniert. Das Ergebnis ist folgende Firmware: fw_C_Speedport_W920V_75.04.94-14621_Fritz_Box_DECT_W920V_54.04.98-15220-freetz-3690M-sp2fr-09.09.19-r-560M_OEM-avm
Intergriert mit Freetz: Bftp, dropbear,HD-Idle, OpenSSH sshd, WOL, OpenVPN, Samba, Disk Spindown.
Die Box ist online. Zugangsdaten mussten neu erfasst werden. Inwieweit alle Module funktionieren habe ich noch nicht getestet, - heute wird es wohl nichts mehr - falls was nicht funktioniert melde ich mich.
Warum das ganze mit dem aktuellen Script nicht funktioniert, weiß ich nicht. Bei Bedarf kann ich alles nochmals mit dem aktuellen Script durchlaufen lassen und die "Firmware.conf.tar" zur Verfügung stellen.
An dieser Stelle möchte ich mich besonders bei Jpascher, ernest015 und bei allen anderen Mitwirkenden herzlich bedanken. Es ist eine super Leistung die hier eingebracht wird und vor allem kommt die Hilfe prompt und selbstlos.
Als Anhang meine Firmware.conf.tar
mfg
odeon
  • Firmware.conf.tar
Problem tritt nicht mehr auf
habe heute den Speedport2fritz / freetz-Durchlauf nochmals mit aktuellen svn-Versionen wiederholt, diesmal lief alles ohne Fehlermeldung durch.
Dank an alle, die geholfen haben
alligator-asl
broekar
IPPF im Überblick
