tar: cannot create directory './etc/ppp': No such file or directory
SystemR89
20 Feb 2009
I do a fresh setup of freetz but on the last step it fail with this error..
  bluez-utils-2.25
tar: cannot create directory './etc/ppp/': No such file or directory
tar: can't open './etc/ppp/peers/dun': No such file or directory
make: *** [firmware-nocompile] Error 1
How I can fix it?
Hi.
Here is the ticket in german language regarding this issue:
http://trac.freetz.org/ticket/579
It has not been solved yet. Do you need bluez-utils support? I suppose you choosed it?
Regards,
Oliver
I would set up a bluetooth AP, however deselecting bluez-utils I can compile the firmware successfully!
I hope that it can be fixed soon...
Thank You!
Michele
with the latest svn I get the same error:
  bluez-utils-2.25
Did you execute "make bluez-utils-dirclean" before?
ok, now the error is different because the package cannot be compiled anymore.
if /home/michele/bin/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I. -I..     -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_FORTIFY_SOURCE=2 -MT dun.o -MD -MP -MF ".deps/dun.Tpo" \
	  -c -o dun.o `test -f 'dun.c' || echo './'`dun.c; \
	then mv -f ".deps/dun.Tpo" ".deps/dun.Po"; \
	else rm -f ".deps/dun.Tpo"; exit 1; \
	fi
main.c:85: error: initializer element is not constant
make[3]: *** [main.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory `/home/michele/bin/freetz-trunk/source/bluez-utils-2.25/dund'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/michele/bin/freetz-trunk/source/bluez-utils-2.25'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/michele/bin/freetz-trunk/source/bluez-utils-2.25'
make: *** [source/bluez-utils-2.25/hcid/hcid] Error 2
I've tested it again with a fresh trunk, no error's here.
Another compile error...
if /home/michele/bin/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I. -I..     -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_FORTIFY_SOURCE=2 -MT sdp.o -MD -MP -MF ".deps/sdp.Tpo" \
	  -c -o sdp.o `test -f 'sdp.c' || echo './'`sdp.c; \
	then mv -f ".deps/sdp.Tpo" ".deps/sdp.Po"; \
	else rm -f ".deps/sdp.Tpo"; exit 1; \
	fi
It's the same error like above. Did you do a fresh checkout? Which build system are you using?
Regards,
Oliver
MXDNRT
