PHP Version 5.3.6-6~dotdeb.1
System Linux web1.php-friends.de 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64
Build Date Apr 3 2011 16:19:21
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php5/apache2
Loaded Configuration File /etc/php5/apache2/php.ini
Scan this dir for additional .ini files /etc/php5/apache2/conf.d
Additional .ini files parsed /etc/php5/apache2/conf.d/includes.ini
PHP API 20090626
PHP Extension 20090626
Zend Extension 220090626
Zend Extension Build API220090626,NTS
PHP Extension Build API20090626,NTS
Debug Build no
Thread Safety disabled
Zend Memory Manager enabled
Zend Multibyte Support disabled
IPv6 Support enabled
Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, zip, phar
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Registered Stream Filters zlib.*, bzip2.*, convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, mcrypt.*, mdecrypt.*
This server is protected with the Suhosin Patch 0.9.10
Copyright (c) 2006-2007 Hardened-PHP Project Copyright (c) 2007-2009 SektionEins GmbH
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.3.0, Copyright (c) 1998-2011 Zend Technologies
with the ionCube PHP Loader v4.0.9, Copyright (c) 2002-2011, by ionCube Ltd.
with Suhosin v0.9.32.1, Copyright (c) 2007-2010, by SektionEins GmbH
This program was built by Dotdeb.
Configuration
apache2handler
Apache Version Apache/2.2.16 (Debian)
Apache API Version 20051115
Server Administrator
Hostname:Port infoframe.pf-control.de:0
User/Group www-data(33)/33
Max Requests Per Child: 10000 - Keep Alive: off - Max Per Connection: 100
Timeouts Connection: 30 - Keep-Alive: 15
Virtual Server Yes
Server Root /etc/apache2
Loaded Modules core mod_log_config mod_logio itk http_core mod_so mod_actions mod_alias mod_auth_basic mod_authn_file mod_authz_default mod_authz_groupfile mod_authz_host mod_authz_user mod_autoindex mod_dir mod_env mod_expires mod_headers mod_mime mod_security2 mod_negotiation mod_php5 mod_rewrite mod_rpaf mod_setenvif mod_status mod_unique_id
Directive Local Value Master Value
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
UNIQUE_ID Tjh8ZVVygasAAD9yEDwAAAAA
HTTP_HOST infoframe.pf-control.de
HTTP_X_REAL_IP 92.230.240.24
HTTP_X_FORWARDED_FOR 92.230.240.24
HTTP_CONNECTION close
HTTP_USER_AGENT Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/535.1 (KHTML, like Gecko) Chrome/13.0.782.107 Safari/535.1
HTTP_ACCEPT text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
HTTP_ACCEPT_ENCODING gzip,deflate,sdch
HTTP_ACCEPT_LANGUAGE de-DE,de;q=0.8,en-US;q=0.6,en;q=0.4
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.3
PATH /usr/local/bin:/usr/bin:/bin
SERVER_SIGNATURE <address>Apache/2.2.16 (Debian) Server at infoframe.pf-control.de Port 80</address>
SERVER_SOFTWARE Apache/2.2.16 (Debian)
SERVER_NAME infoframe.pf-control.de
SERVER_ADDR 85.114.129.171
SERVER_PORT 80
REMOTE_ADDR 92.230.240.24
DOCUMENT_ROOT /var/customers/webs/infoframe/
SERVER_ADMIN micky2k@gmx.de
SCRIPT_FILENAME /var/customers/webs/infoframe/Infoframe-web/infoframe/phpinfo.php
REMOTE_PORT 52773
REMOTE_USER markus
AUTH_TYPE Basic
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.0
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /Infoframe-web/infoframe/phpinfo.php
SCRIPT_NAME /Infoframe-web/infoframe/phpinfo.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /Infoframe-web/infoframe/phpinfo.php HTTP/1.0
Host infoframe.pf-control.de
X-Real-IP 92.230.240.24
X-Forwarded-For 92.230.240.24
Connection close
Authorization Basic bWFya3VzOnJkMTVrbQ==
User-Agent Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/535.1 (KHTML, like Gecko) Chrome/13.0.782.107 Safari/535.1
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Encoding gzip,deflate,sdch
Accept-Language de-DE,de;q=0.8,en-US;q=0.6,en;q=0.4
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.3
HTTP Response Headers
Connection close
Content-Type text/html
apc
APC Support enabled
Version 3.1.9
APC Debugging Disabled
MMAP Support Enabled
MMAP File Mask no value
Locking type pthread mutex Locks
Serialization Support php
Revision $Revision: 308812 $
Build Date Jul 9 2011 13:46:54
apc.cache_by_default On On
apc.canonicalize On On
apc.coredump_unmap Off Off
apc.enable_cli Off Off
apc.enabled On On
apc.file_md5 Off Off
apc.file_update_protection 1 1
apc.filters no value no value
apc.gc_ttl 3600 3600
apc.include_once_override Off Off
apc.lazy_classes Off Off
apc.lazy_functions Off Off
apc.max_file_size 1M 1M
apc.mmap_file_mask no value no value
apc.num_files_hint 1000 1000
apc.preload_path no value no value
apc.report_autofilter Off Off
apc.rfc1867 Off Off
apc.rfc1867_freq 0 0
apc.rfc1867_name APC_UPLOAD_PROGRESS APC_UPLOAD_PROGRESS
apc.rfc1867_prefix upload_ upload_
apc.rfc1867_ttl 3600 3600
apc.serializer default default
apc.shm_segments 1 1
apc.shm_size 32M 32M
apc.slam_defense On On
apc.stat On On
apc.stat_ctime Off Off
apc.ttl 0 0
apc.use_request_time On On
apc.user_entries_hint 4096 4096
apc.user_ttl 0 0
apc.write_lock On On
bcmath
BCMath support enabled
bcmath.scale 0 0
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.5, 10-Dec-2007
calendar
Calendar support enabled
Core
allow_call_time_pass_reference Off Off
allow_url_fopen Off Off
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions exec,passthru,shell_exec,system,proc_close,proc_get_status,proc_nice,proc_open,proc_terminate,disk_total_space,posix_getpwuid,posix_getpwnam,diskfreespace,popen,posix_mkfifo,pfsockopen,set_time_limit,set_memory_limit exec,passthru,shell_exec,system,proc_close,proc_get_status,proc_nice,proc_open,proc_terminate,disk_total_space,posix_getpwuid,posix_getpwnam,diskfreespace,popen,posix_mkfifo,pfsockopen,set_time_limit,set_memory_limit
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 22519 22519
exit_on_timeout Off Off
expose_php Off Off
extension_dir /usr/lib/php5/20090626 /usr/lib/php5/20090626
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors Off Off
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/share/php5/:/usr/share/php/PEAR/:/usr/share/php/ .:/usr/share/php5/:/usr/share/php/PEAR/:/usr/share/php/
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.add_x_header Off Off
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 60 60
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 10 10
memory_limit 128M 128M
open_basedir /var/customers/webs/infoframe/:/var/customers/tmp/infoframe/:/usr/share/php/:/usr/share/php5/:/usr/share/php/PEAR/ no value
output_buffering 4096 4096
output_handler no value no value
post_max_size 101M 101M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
register_globals Off Off
register_long_arrays On On
report_memleaks On On
report_zend_debug On On
request_order no value no value
safe_mode Off Off
safe_mode_exec_dir /usr/lib/php5/libexec /usr/lib/php5/libexec
safe_mode_gid Off Off
safe_mode_include_dir /usr/share/php5/:/usr/share/php/ /usr/share/php5/:/usr/share/php/
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -f micky2k@gmx.de /usr/sbin/sendmail -t
serialize_precision 17 17
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 101M 101M
upload_tmp_dir /var/customers/tmp/infoframe/ /var/customers/tmp/
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.enable_gc On On
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.21.0
Age 3
Features
AsynchDNS No
Debug No
GSS-Negotiate Yes
IDN Yes
IPv6 Yes
Largefile Yes
NTLM Yes
SPNEGO No
SSL Yes
SSPI No
krb4 No
libz Yes
CharConv No
Protocols dict, file, ftp, ftps, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp
Host x86_64-pc-linux-gnu
SSL Version OpenSSL/0.9.8o
ZLib Version 1.2.3.4
libSSH Version libssh2/1.2.6
date
date/time support enabled
"Olson" Timezone Database Version 2011.4
Timezone Database internal
Default timezone Europe/Berlin
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone Europe/Berlin Europe/Berlin
dba
DBA support enabled
Supported handlers cdb cdb_make db4 inifile flatfile qdbm
dba.default_handler flatfile flatfile
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.8
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
ereg
Regex Library Bundled library enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: exif.c 308362 2011-02-15 14:02:26Z pajoye $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
version 1.0.5-dev
filter
Input Validation and Filtering enabled
Revision $Revision: 306939 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
gd
GD Support enabled
GD Version bundled (2.0.34 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.4.2
T1Lib Support enabled
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.2.44
WBMP Support enabled
XPM Support enabled
XBM Support enabled
gd.jpeg_ignore_warning 0 0
gettext
GetText Support enabled
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost adler32 crc32 crc32b salsa10 salsa20 haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.11.2
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
imap
IMAP c-Client Version 2007e
SSL Support enabled
Kerberos Support enabled
intl
Internationalization support enabled
version 1.1.0
ICU version 4.4.1
intl.default_locale no value no value
intl.error_level 0 0
json
json support enabled
json version 1.2.1
libxml
libXML support active
libXML Compiled Version 2.7.8
libXML Loaded Version 20708
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 5.9.1
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input pass pass
mbstring.http_output pass pass
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
mcrypt support enabled
mcrypt_filter support enabled
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mhash
MHASH support Enabled
MHASH API Version Emulated Support
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version mysqlnd 5.0.8-dev - 20102224 - $Revision: 308673 $
mysql.allow_local_infile On On
mysql.allow_persistent On On
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket /var/run/mysqld/mysqld.sock /var/run/mysqld/mysqld.sock
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
mysqli
MysqlI Support enabled
Client API library version mysqlnd 5.0.8-dev - 20102224 - $Revision: 308673 $
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infile On On
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket /var/run/mysqld/mysqld.sock /var/run/mysqld/mysqld.sock
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.8-dev - 20102224 - $Revision: 308673 $
Compression not supported
SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 31536000
Collecting statistics Yes
Collecting memory statistics No
Tracing n/a
Client statistics
bytes_sent 0
bytes_received 0
packets_sent 0
packets_received 0
protocol_overhead_in 0
protocol_overhead_out 0
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 0
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 0
bytes_received_prepare_response_packet 0
bytes_received_change_user_packet 0
packets_sent_command 0
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 0
packets_received_rset_field_meta 0
packets_received_rset_row 0
packets_received_prepare_response 0
packets_received_change_user 0
result_set_queries 0
non_result_set_queries 0
no_index_used 0
bad_index_used 0
slow_queries 0
buffered_sets 0
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 0
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 0
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 0
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_affected_normal 0
rows_affected_ps 0
rows_skipped_normal 0
rows_skipped_ps 0
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 0
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 0
active_connections 0
active_persistent_connections 0
explicit_close 0
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 0
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_amount 0
mem_ecalloc_count 0
mem_ecalloc_amount 0
mem_erealloc_count 0
mem_erealloc_amount 0
mem_efree_count 0
mem_efree_amount 0
mem_malloc_count 0
mem_malloc_amount 0
mem_calloc_count 0
mem_calloc_amount 0
mem_realloc_count 0
mem_realloc_amount 0
mem_free_count 0
mem_free_amount 0
mem_estrndup_count 0
mem_strndup_count 0
mem_estndup_count 0
mem_strdup_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 0
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 0
proto_text_fetched_bigint 0
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 0
proto_text_fetched_timestamp 0
proto_text_fetched_string 0
proto_text_fetched_blob 0
proto_text_fetched_enum 0
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
init_command_executed_count 0
init_command_failed_count 0
com_quit 0
com_init_db 0
com_query 0
com_field_list 0
com_create_db 0
com_drop_db 0
com_refresh 0
com_shutdown 0
com_statistics 0
com_process_info 0
com_connect 0
com_process_kill 0
com_debug 0
com_ping 0
com_time 0
com_delayed_insert 0
com_change_user 0
com_binlog_dump 0
com_table_dump 0
com_connect_out 0
com_register_slave 0
com_stmt_prepare 0
com_stmt_execute 0
com_stmt_send_long_data 0
com_stmt_close 0
com_stmt_reset 0
com_stmt_set_option 0
com_stmt_fetch 0
com_deamon 0
bytes_received_real_data_normal 0
bytes_received_real_data_ps 0
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 0.9.8o 01 Jun 2010
OpenSSL Header Version OpenSSL 0.9.8o 01 Jun 2010
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 8.11 2010-12-10
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql, sqlite, sqlite2
pdo_mysql
PDO Driver for MySQL enabled
pdo_mysql.default_socket /var/run/mysqld/mysqld.sock /var/run/mysqld/mysqld.sock
pdo_sqlite
PDO Driver for SQLite 3.x enabled
SQLite Library 3.7.3
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.1
Phar API version 1.1.1
SVN revision $Revision: 307915 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
Reflection
Reflection enabled
Version $Revision: 307971 $
session
Session Support enabled
Registered save handlers files user sqlite
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 Off Off
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file /dev/urandom /dev/urandom
session.entropy_length 16 16
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 4 4
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/customers/tmp/infoframe/ /var/customers/tmp/
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies On On
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Revision: 308262 $
Schema support enabled
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
SQLite
SQLite support enabled
PECL Module version 2.0-dev $Id: sqlite.c 306939 2011-01-01 02:19:59Z felipe $
SQLite Library 2.8.17
SQLite Encoding UTF-8
sqlite.assoc_case 0 0
sqlite3
SQLite3 support enabled
SQLite3 module version 0.7-dev
sqlite3.extension_dir no value no value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -f micky2k@gmx.de
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,form=,fieldset= a=href,area=href,frame=src,form=,fieldset=
user_agent no value no value
suhosin
This server is protected with the Suhosin Extension 0.9.32.1
Copyright (c) 2007-2010 SektionEins GmbH
suhosin.apc_bug_workaround Off Off
suhosin.cookie.checkraddr 0 0
suhosin.cookie.cryptdocroot On On
suhosin.cookie.cryptkey [ protected ] [ protected ]
suhosin.cookie.cryptlist no value no value
suhosin.cookie.cryptraddr 0 0
suhosin.cookie.cryptua On On
suhosin.cookie.disallow_nul 1 1
suhosin.cookie.disallow_ws 1 1
suhosin.cookie.encrypt Off Off
suhosin.cookie.max_array_depth 50 50
suhosin.cookie.max_array_index_length 64 64
suhosin.cookie.max_name_length 64 64
suhosin.cookie.max_totalname_length 256 256
suhosin.cookie.max_value_length 10000 10000
suhosin.cookie.max_vars 100 100
suhosin.cookie.plainlist no value no value
suhosin.coredump Off Off
suhosin.disable.display_errors Off Off
suhosin.executor.allow_symlink Off Off
suhosin.executor.disable_emodifier Off Off
suhosin.executor.disable_eval Off Off
suhosin.executor.eval.blacklist no value no value
suhosin.executor.eval.whitelist no value no value
suhosin.executor.func.blacklist no value no value
suhosin.executor.func.whitelist no value no value
suhosin.executor.include.allow_writable_files On On
suhosin.executor.include.blacklist no value no value
suhosin.executor.include.max_traversal 0 0
suhosin.executor.include.whitelist phar phar
suhosin.executor.max_depth 0 0
suhosin.filter.action no value no value
suhosin.get.disallow_nul 1 1
suhosin.get.disallow_ws 0 0
suhosin.get.max_array_depth 50 50
suhosin.get.max_array_index_length 64 64
suhosin.get.max_name_length 64 64
suhosin.get.max_totalname_length 256 256
suhosin.get.max_value_length 512 512
suhosin.get.max_vars 100 100
suhosin.log.file 0 0
suhosin.log.file.name no value no value
suhosin.log.phpscript 0 0
suhosin.log.phpscript.is_safe Off Off
suhosin.log.phpscript.name no value no value
suhosin.log.sapi 0 0
suhosin.log.script 0 0
suhosin.log.script.name no value no value
suhosin.log.syslog no value no value
suhosin.log.syslog.facility no value no value
suhosin.log.syslog.priority no value no value
suhosin.log.use-x-forwarded-for Off Off
suhosin.mail.protect 1 1
suhosin.memory_limit 0 0
suhosin.mt_srand.ignore On On
suhosin.multiheader Off Off
suhosin.perdir 0 0
suhosin.post.disallow_nul 1 1
suhosin.post.disallow_ws 0 0
suhosin.post.max_array_depth 50 50
suhosin.post.max_array_index_length 64 64
suhosin.post.max_name_length 64 64
suhosin.post.max_totalname_length 256 256
suhosin.post.max_value_length 1000000 1000000
suhosin.post.max_vars 1000 1000
suhosin.protectkey On On
suhosin.request.disallow_nul 1 1
suhosin.request.disallow_ws 0 0
suhosin.request.max_array_depth 50 50
suhosin.request.max_array_index_length 64 64
suhosin.request.max_totalname_length 256 256
suhosin.request.max_value_length 1000000 1000000
suhosin.request.max_varname_length 64 64
suhosin.request.max_vars 1000 1000
suhosin.server.encode On On
suhosin.server.strip On On
suhosin.session.checkraddr 0 0
suhosin.session.cryptdocroot On On
suhosin.session.cryptkey [ protected ] [ protected ]
suhosin.session.cryptraddr 0 0
suhosin.session.cryptua Off Off
suhosin.session.encrypt Off Off
suhosin.session.max_id_length 128 128
suhosin.simulation Off Off
suhosin.sql.bailout_on_error Off Off
suhosin.sql.comment 0 0
suhosin.sql.multiselect 0 0
suhosin.sql.opencomment 0 0
suhosin.sql.union 0 0
suhosin.sql.user_postfix no value no value
suhosin.sql.user_prefix no value no value
suhosin.srand.ignore On On
suhosin.stealth On On
suhosin.upload.disallow_binary 0 0
suhosin.upload.disallow_elf 1 1
suhosin.upload.max_uploads 25 25
suhosin.upload.remove_binary 0 0
suhosin.upload.verification_script no value no value
sysvmsg
sysvmsg support enabled
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.8
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
zip
Zip enabled
Extension Version $Id: php_zip.c 308107 2011-02-07 16:20:16Z pajoye $
Zip version 1.9.1
Libzip version 0.9.0
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.1.1
Linked Version 1.2.3.4
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
ionCube Loader
sysvsem
sysvshm
Environment
Variable Value
APACHE_RUN_DIR /var/run/apache2
APACHE_PID_FILE /var/run/apache2.pid
APACHE_LOCK_DIR /var/lock/apache2
LANG C
APACHE_RUN_GROUP www-data
APACHE_RUN_USER www-data
APACHE_LOG_DIR /var/log/apache2
PWD /
PHP Variables
Variable Value
_SERVER["UNIQUE_ID"] Tjh8ZVVygasAAD9yEDwAAAAA
_SERVER["HTTP_HOST"] infoframe.pf-control.de
_SERVER["HTTP_X_REAL_IP"] 92.230.240.24
_SERVER["HTTP_X_FORWARDED_FOR"] 92.230.240.24
_SERVER["HTTP_CONNECTION"] close
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/535.1 (KHTML, like Gecko) Chrome/13.0.782.107 Safari/535.1
_SERVER["HTTP_ACCEPT"] text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate,sdch
_SERVER["HTTP_ACCEPT_LANGUAGE"] de-DE,de;q=0.8,en-US;q=0.6,en;q=0.4
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.3
_SERVER["PATH"] /usr/local/bin:/usr/bin:/bin
_SERVER["SERVER_SIGNATURE"] <address>Apache/2.2.16 (Debian) Server at infoframe.pf-control.de Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache/2.2.16 (Debian)
_SERVER["SERVER_NAME"] infoframe.pf-control.de
_SERVER["SERVER_ADDR"] 85.114.129.171
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 92.230.240.24
_SERVER["DOCUMENT_ROOT"] /var/customers/webs/infoframe/
_SERVER["SERVER_ADMIN"] micky2k@gmx.de
_SERVER["SCRIPT_FILENAME"] /var/customers/webs/infoframe/Infoframe-web/infoframe/phpinfo.php
_SERVER["REMOTE_PORT"] 52773
_SERVER["REMOTE_USER"] markus
_SERVER["AUTH_TYPE"] Basic
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.0
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /Infoframe-web/infoframe/phpinfo.php
_SERVER["SCRIPT_NAME"] /Infoframe-web/infoframe/phpinfo.php
_SERVER["PHP_SELF"] /Infoframe-web/infoframe/phpinfo.php
_SERVER["PHP_AUTH_USER"] markus
_SERVER["PHP_AUTH_PW"] rd15km
_SERVER["REQUEST_TIME"] 1312324709
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
