Wenn ich OpenVPN starte, funktioniert dies nicht, mit der Fehlermeldung kann ich nichts anfangen und die Suche ist auch nicht erfolgreich.
Das sagt syslogd:
Meine Freetz-Config:Code:Feb 6 23:35:14 fritz daemon.notice openvpn[10543]: OpenVPN 2.1.1 mipsel-linux [SSL] [LZO2] [EPOLL] [MH] [PF_INET6] built on Feb 4 2010 Feb 6 23:35:14 fritz daemon.warn openvpn[10543]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Feb 6 23:35:14 fritz daemon.err openvpn[10543]: Insufficient key material or header text not found found in file '/tmp/flash/static.key' (0/128/256 bytes found/min/max) Feb 6 23:35:14 fritz daemon.notice openvpn[10543]: Exiting
Kann mir jemand weiterhelfen?Code:FREETZ_HAVE_DOT_CONFIG=y FREETZ_AVM_VERSION_7270_04_80=y FREETZ_TYPE_FON_WLAN_7270=y FREETZ_TYPE_FON_WLAN_7270_16MB=y FREETZ_AVM_VERSION_STRING="7270_04.80" FREETZ_TYPE_LANG_DE=y FREETZ_TYPE_LANG_STRING="de" FREETZ_TYPE_STRING="7270" FREETZ_INSTALL_BASE=y FREETZ_REPLACE_BUSYBOX=y FREETZ_REPLACE_KERNEL_AVAILABLE=y FREETZ_REPLACE_KERNEL=y FREETZ_SHOW_ADVANCED=y FREETZ_TARGET_IPV6_SUPPORT=y FREETZ_TARGET_REF="8mb_26" FREETZ_KERNEL_REF="8mb_26" FREETZ_KERNEL_LAYOUT="ur8" FREETZ_KERNEL_MTD_SIZE=246 FREETZ_HAS_PHONE=y FREETZ_HAS_TAM=y FREETZ_HAS_WLAN=y FREETZ_HAS_USB_HOST=y FREETZ_HAS_AVM_INETD=y FREETZ_HAS_LIBSSL=y FREETZ_LANG_DE=y FREETZ_LANG_STRING="de" FREETZ_REMOVE_TR069=y FREETZ_REMOVE_CHRONYD=y FREETZ_PATCH_SIGNED=y FREETZ_PATCH_RCFTPD=y FREETZ_PATCH_FREETZMOUNT=y FREETZ_USBSTORAGE_AUTOMOUNT=y FREETZ_AUTOMOUNT_EXT3=y FREETZ_REMOVE_FTPD=y FREETZ_REMOVE_CAPIOVERTCP=y FREETZ_REMOVE_DTRACE=y FREETZ_PACKAGE_BRIDGE_UTILS=y FREETZ_PACKAGE_CIFSMOUNT=y FREETZ_PACKAGE_DNSMASQ=y FREETZ_PACKAGE_DROPBEAR=y FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y FREETZ_PACKAGE_FORTUNE=y FREETZ_PACKAGE_OPENNTPD=y FREETZ_PACKAGE_OPENVPN=y FREETZ_PACKAGE_OPENVPN_STATIC=y FREETZ_PACKAGE_OPENVPN_WITH_LZO=y FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y FREETZ_PACKAGE_SAMBA=y FREETZ_PACKAGE_NMBD=y FREETZ_PACKAGE_VSFTPD=y FREETZ_PACKAGE_VSFTPD_WITH_SSL=y FREETZ_PACKAGE_VSFTPD_STATIC=y FREETZ_PACKAGE_AUTHORIZED_KEYS=y FREETZ_PACKAGE_AVM_FIREWALL=y FREETZ_PACKAGE_SYSLOGD_CGI=y FREETZ_PACKAGE_E2FSPROGS=y FREETZ_PACKAGE_E2FSPROGS_STATIC=y FREETZ_PACKAGE_E2FSPROGS_BLKID=y FREETZ_PACKAGE_FSTYP=y FREETZ_PACKAGE_PPPD=y FREETZ_PACKAGE_PPTP=y FREETZ_SHOW_UNSTABLE_PACKAGES=y FREETZ_PACKAGE_RADVD=y FREETZ_PACKAGE_GW6=y FREETZ_PACKAGE_HASERL=y FREETZ_PACKAGE_MODCGI=y FREETZ_DL_KERNEL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7270/x_misc/opensrc" FREETZ_DL_KERNEL_SOURCE="fritzbox7270-source-files-04.80.tar.gz" FREETZ_DL_KERNEL_SOURCE_MD5="bcd49b28a54293e1481b8170b07245e0" FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch" FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270.54.04.80.image" FREETZ_DL_SOURCE_MD5="4ea997dce6bbf72202ae80cb572ab1fe" FREETZ_MOD_DL_NUM_SITES="5" FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de" FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info" FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net" FREETZ_MOD_DL_SITE_4="" FREETZ_MOD_DL_SITE_5="" FREETZ_SECURITY_LEVEL=1 FREETZ_VERBOSITY_LEVEL=2 FREETZ_FAVICON_NONE=y FREETZ_FAVICON_STRING="none" FREETZ_SUBVERSION_STRING=y FREETZ_DEVELOPER_VERSION_STRING=y FREETZ_STYLE_COLORED=y FREETZ_STYLE="colored" FREETZ_USER_DEFINED_COMMENT="" FREETZ_AVMPLUGINS_ENABLED=y FREETZ_AVMPLUGINS_MEDIASRV=y FREETZ_AVMPLUGINS_MINI=y FREETZ_AVMPLUGINS_NTFS=y FREETZ_AVMPLUGINS_ONLINEPB=y FREETZ_AVMPLUGINS_SAMBA=y FREETZ_AVMPLUGINS_TAM=y FREETZ_AVMPLUGINS_WEBDAV=y FREETZ_SQUASHFS_BLOCKSIZE_65536=y FREETZ_BUSYBOX_INETD=y FREETZ_BUSYBOX_IP=y FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y FREETZ_BUSYBOX_REALPATH=y FREETZ_BUSYBOX_WGET=y FREETZ_BUSYBOX_MD5SUM=y FREETZ_MODULE_crypto_algapi=y FREETZ_MODULE_arc4=y FREETZ_MODULE_sha1=y FREETZ_MODULE_ppp_async=y FREETZ_MODULE_ppp_deflate=y FREETZ_MODULE_ppp_generic=y FREETZ_MODULE_ppp_mppe_mppc=y FREETZ_MODULE_slhc=y FREETZ_MODULE_cifs=y FREETZ_MODULE_ext3=y FREETZ_MODULE_fuse=y FREETZ_MODULE_jbd=y FREETZ_MODULE_nls_cp437=y FREETZ_MODULE_nls_iso8859_1=y FREETZ_MODULE_mbcache=y FREETZ_MODULE_crc_ccitt=y FREETZ_MODULE_ipv6=y FREETZ_LIB_libcrypto=y FREETZ_LIB_libssl=y FREETZ_LIB_libz=y FREETZ_LIB_ld_uClibc=y FREETZ_LIB_libcrypt=y FREETZ_LIB_libdl=y FREETZ_LIB_libm=y FREETZ_LIB_libnsl=y FREETZ_LIB_libpthread=y FREETZ_LIB_librt=y FREETZ_LIB_libuClibc=y FREETZ_LIB_libutil=y FREETZ_LIB_libuClibc__=y FREETZ_LIB_libgcc_s=y FREETZ_LIB_libfreetz=y FREETZ_BUILD_TOOLCHAIN=y FREETZ_TARGET_CROSS="mipsel-linux-uclibc-" FREETZ_TARGET_MAKE_PATH="toolchain/target/bin" FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap" FREETZ_JLEVEL=2 FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-" FREETZ_KERNEL_MAKE_PATH="toolchain/kernel/bin" FREETZ_KERNEL_VERSION_2_6_19_2=y FREETZ_KERNEL_VERSION="2.6.19.2" FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_29=y FREETZ_TARGET_GCC_VERSION="4.2.4" FREETZ_TARGET_UCLIBC_VERSION="0.9.29" FREETZ_TARGET_BINUTILS_VERSION="2.18" FREETZ_TARGET_UCLIBC_CONFIG_MOD=y FREETZ_TARGET_UCLIBC_REF="mod" FREETZ_TARGET_GXX=y FREETZ_TARGET_CCACHE=y FREETZ_TARGET_LFS=y FREETZ_KERNEL_COMPILER_GCC_3_4_6=y FREETZ_KERNEL_GCC_VERSION="3.4.6" FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
Danke für´s lesen.
Octomax
Zitieren
