EDIT: make distclean hat geholfen....
ich hab mal ein svn up auf die neueste trunk version gemacht und nun scheitert der Compiler an der uclibc Übersetzung:
Hat sich daran irgend was geändert?Code:cando@CANDO1:/data/freetz-new$ make cmd() { PATH="/data/freetz-new/toolchain/target/bin:/data/freetz-new/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2 \ ARCH_CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" \ CROSS="mipsel-linux-uclibc-" \ all mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory make[1]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2' for dir in bin include src ; do \ make -C $dir all; \ done mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory make[2]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/bin' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/bin' mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory make[2]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/include' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/include' mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory make[2]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src' make -C abi/libgcc_eh all make -C abi/libsupc all mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory mipsel-linux-uclibc-gcc: No such file or directory make[3]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src/abi/libgcc_eh' mipsel-linux-uclibc-ar x Usage: mipsel-linux-uclibc-ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV] [member-name] [count] archive-file file... mipsel-linux-uclibc-ar -M [<mri-script] commands: d - delete file(s) from the archive m[ab] - move file(s) in the archive p - print file(s) found in the archive q[f] - quick append file(s) to the archive r[ab][f][u] - replace existing or insert new file(s) into the archive t - display contents of archive x[o] - extract file(s) from the archive command specific modifiers: [a] - put file(s) after [member-name] [b] - put file(s) before [member-name] (same as [i]) [N] - use instance [count] of name [f] - truncate inserted file names [P] - use full path names when matching [o] - preserve original dates [u] - only replace files that are newer than current archive contents generic modifiers: [c] - do not warn if the library had to be created [s] - create an archive index (cf. ranlib) [S] - do not build a symbol table [v] - be verbose [V] - display the version number @<file> - read options from <file> emulation options: No emulation specific options mipsel-linux-uclibc-ar: supported targets: elf32-tradlittlemips elf32-tradbigmips ecoff-littlemips ecoff-bigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-ntradbigmips elf64-tradbigmips elf64-little elf64-big elf32-little elf32-big srec symbolsrec tekhex binary ihex make[3]: *** [unwind-c.o] Error 1 make[3]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src/abi/libgcc_eh' mipsel-linux-uclibc-gcc: No such file or directory make[2]: *** [libgcc_eh] Error 2 make[2]: *** Waiting for unfinished jobs.... make[3]: Entering directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src/abi/libsupc' mipsel-linux-uclibc-ar x Usage: mipsel-linux-uclibc-ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV] [member-name] [count] archive-file file... mipsel-linux-uclibc-ar -M [<mri-script] commands: d - delete file(s) from the archive m[ab] - move file(s) in the archive p - print file(s) found in the archive q[f] - quick append file(s) to the archive r[ab][f][u] - replace existing or insert new file(s) into the archive t - display contents of archive x[o] - extract file(s) from the archive command specific modifiers: [a] - put file(s) after [member-name] [b] - put file(s) before [member-name] (same as [i]) [N] - use instance [count] of name [f] - truncate inserted file names [P] - use full path names when matching [o] - preserve original dates [u] - only replace files that are newer than current archive contents generic modifiers: [c] - do not warn if the library had to be created [s] - create an archive index (cf. ranlib) [S] - do not build a symbol table [v] - be verbose [V] - display the version number @<file> - read options from <file> emulation options: No emulation specific options mipsel-linux-uclibc-ar: supported targets: elf32-tradlittlemips elf32-tradbigmips ecoff-littlemips ecoff-bigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-ntradbigmips elf64-tradbigmips elf64-little elf64-big elf32-little elf32-big srec symbolsrec tekhex binary ihex make[3]: *** [libsupc] Error 1 make[3]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src/abi/libsupc' make[2]: *** [libsupc] Error 2 make[2]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src' make[1]: *** [all] Error 2 make[1]: Leaving directory `/data/freetz-new/source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2' ERROR: Build failed. make: *** [source/target-mipsel_uClibc-0.9.29/uClibc++-0.2.2/src/libuClibc++-0.2.2.so] Error 1 cando@CANDO1:/data/freetz-new$
Hier meine .config:
Code:# # Automatically generated make config: don't edit # FREETZ_HAVE_DOT_CONFIG=y # # General -------------------------------- # FREETZ_AVM_VERSION_7270_04_80=y # FREETZ_TYPE_300IP_AS_FON is not set # FREETZ_TYPE_2170 is not set # FREETZ_TYPE_FON is not set # FREETZ_TYPE_FON_5010 is not set # FREETZ_TYPE_FON_5050 is not set # FREETZ_TYPE_FON_5140 is not set # FREETZ_TYPE_FON_WLAN is not set # FREETZ_TYPE_FON_WLAN_7050 is not set # FREETZ_TYPE_FON_WLAN_7112 is not set # FREETZ_TYPE_FON_WLAN_7113 is not set # FREETZ_TYPE_FON_WLAN_7140 is not set # FREETZ_TYPE_FON_WLAN_7141 is not set # FREETZ_TYPE_FON_7150 is not set # FREETZ_TYPE_FON_WLAN_7170 is not set # FREETZ_TYPE_FON_WLAN_7240 is not set FREETZ_TYPE_FON_WLAN_7270=y # FREETZ_TYPE_FON_WLAN_7270_V3 is not set # FREETZ_TYPE_WLAN_3020 is not set # FREETZ_TYPE_WLAN_3030 is not set # FREETZ_TYPE_WLAN_3130 is not set # FREETZ_TYPE_WLAN_3131 is not set # FREETZ_TYPE_WLAN_3170 is not set # FREETZ_TYPE_WLAN_3270 is not set # FREETZ_TYPE_WLAN_3270_V3 is not set # FREETZ_TYPE_SPEEDPORT_W501V is not set # FREETZ_TYPE_CUSTOM is not set FREETZ_TYPE_FON_WLAN_7270_16MB=y # FREETZ_TYPE_LABOR is not set # FREETZ_TYPE_ALIEN_HARDWARE is not set FREETZ_AVM_VERSION_STRING="7270_04.80" FREETZ_TYPE_LANG_DE=y # FREETZ_TYPE_LANG_A_CH is not set # FREETZ_TYPE_LANG_EN is not set FREETZ_TYPE_LANG_STRING="de" FREETZ_TYPE_STRING="7270" FREETZ_INSTALL_BASE=y FREETZ_REPLACE_BUSYBOX=y FREETZ_SHOW_ADVANCED=y FREETZ_REPLACE_KERNEL_AVAILABLE=y FREETZ_REPLACE_KERNEL=y # FREETZ_TARGET_IPV6_SUPPORT is not set FREETZ_TARGET_REF="8mb_26" FREETZ_KERNEL_REF="8mb_26" FREETZ_KERNEL_LAYOUT="ur8" FREETZ_KERNEL_MTD_SIZE=246 FREETZ_HAS_PHONE=y FREETZ_HAS_TAM=y FREETZ_HAS_WLAN=y # FREETZ_HAS_USB_CLIENT is not set FREETZ_HAS_USB_HOST=y FREETZ_HAS_AVM_INETD=y FREETZ_HAS_LIBSSL=y # # Mod ------------------------------------ # FREETZ_LANG_DE=y # FREETZ_LANG_EN is not set FREETZ_LANG_STRING="de" # # Patches # # # Web menu patches ------------------------ # FREETZ_PATCH_DSL_EXPERT=y FREETZ_ADD_REGEXT_GUI=y # FREETZ_PATCH_ALARMCLOCK is not set FREETZ_PATCH_SIGNED=y # # USB mounting ---------------------------- # # FREETZ_PATCH_FREETZMOUNT is not set # FREETZ_PATCH_RCFTPD is not set FREETZ_PATCH_USBSTORAGE=y FREETZ_USBSTORAGE_AUTOMOUNT=y FREETZ_AUTOMOUNT_EXT2=y FREETZ_AUTOMOUNT_EXT3=y FREETZ_AUTOMOUNT_NTFS=y # FREETZ_AUTOMOUNT_REISER_FS is not set # FREETZ_AUTORUN_AUTOEND is not set # FREETZ_PATCH_MAXDEVCOUNT is not set # # Removings ------------------------------- # # FREETZ_REMOVE_ANNEX_B_FIRMWARE is not set FREETZ_REMOVE_ASSISTANT=y FREETZ_REMOVE_AURA_USB=y FREETZ_REMOVE_AVM_VPN=y # # Remove brandings # # FREETZ_REMOVE_BRANDING_1und1 is not set # FREETZ_REMOVE_BRANDING_avm is not set # FREETZ_REMOVE_CAPIOVERTCP is not set # FREETZ_REMOVE_CHRONYD is not set # FREETZ_REMOVE_DECT is not set # FREETZ_REMOVE_DSLD is not set FREETZ_REMOVE_DTRACE=y # FREETZ_REMOVE_FTPD is not set FREETZ_REMOVE_HELP=y FREETZ_REMOVE_SUPPORT=y FREETZ_REMOVE_TR069=y FREETZ_REMOVE_TR069_FWUPDATE=y # FREETZ_REMOVE_UPNP is not set FREETZ_REMOVE_USERMAN=y # FREETZ_REMOVE_VOIPD is not set # FREETZ_REMOVE_VOIP_ISDN is not set # FREETZ_REMOVE_WLAN is not set # # Adds ----------------------------------- # # FREETZ_ADD_ANNEX_A_FIRMWARE is not set # # Other stuff ----------------------------- # # FREETZ_PATCH_GETCONS is not set # # Package selection # # # Standard packages # # FREETZ_PACKAGE_BFTPD is not set # FREETZ_PACKAGE_BIRD is not set FREETZ_PACKAGE_BRIDGE_UTILS=y # FREETZ_PACKAGE_CALLMONITOR is not set # FREETZ_PACKAGE_CHECKMAILD is not set # FREETZ_PACKAGE_CIFSMOUNT is not set FREETZ_PACKAGE_CPMACCFG=y # FREETZ_PACKAGE_CURL is not set # FREETZ_PACKAGE_DECO is not set # FREETZ_PACKAGE_DNSMASQ is not set # FREETZ_PACKAGE_DROPBEAR is not set # FREETZ_PACKAGE_DTMFBOX is not set # FREETZ_PACKAGE_ESPEAK is not set # FREETZ_PACKAGE_FORTUNE is not set # FREETZ_PACKAGE_FUSE is not set # FREETZ_PACKAGE_INETD is not set # FREETZ_PACKAGE_KNOCK is not set FREETZ_PACKAGE_MC=y FREETZ_PACKAGE_MC_INTERNAL_EDITOR=y # FREETZ_PACKAGE_MC_SUBSHELL is not set FREETZ_PACKAGE_MC_ONLINE_HELP=y # FREETZ_PACKAGE_MC_WITH_NCURSES is not set # FREETZ_PACKAGE_MC_FORCE_GLIB12 is not set # FREETZ_PACKAGE_MINI_FO is not set # FREETZ_PACKAGE_MTR is not set FREETZ_PACKAGE_NANO=y # # Nano additional features # FREETZ_PACKAGE_NANO_TINY=y # FREETZ_PACKAGE_NETCAT is not set # FREETZ_PACKAGE_NETSNMP is not set FREETZ_PACKAGE_NTFS=y # FREETZ_PACKAGE_OPENNTPD is not set # FREETZ_PACKAGE_OPENVPN is not set # FREETZ_PACKAGE_PINGTUNNEL is not set # FREETZ_PACKAGE_PRIVOXY is not set # FREETZ_PACKAGE_RCAPID is not set # FREETZ_PACKAGE_SAMBA is not set # FREETZ_PACKAGE_SCREEN is not set # FREETZ_PACKAGE_STUNNEL is not set # FREETZ_PACKAGE_TCPDUMP is not set # FREETZ_PACKAGE_TOR is not set # FREETZ_PACKAGE_VPNC is not set # FREETZ_PACKAGE_VSFTPD is not set # # Web interfaces # FREETZ_PACKAGE_AVM_FIREWALL=y # FREETZ_PACKAGE_CPMACCFG_CGI is not set # FREETZ_PACKAGE_DOWNLOADER is not set FREETZ_PACKAGE_AUTHORIZED_KEYS=y # FREETZ_PACKAGE_NFSD_CGI is not set FREETZ_PACKAGE_NHIPT=y FREETZ_PACKAGE_IPTABLES=y FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y # # Select kernel modules (IPv4) # FREETZ_MODULE_ip_conntrack=y FREETZ_MODULE_ip_conntrack_ftp=y FREETZ_MODULE_ip_conntrack_h323=y FREETZ_MODULE_ip_conntrack_irc=y FREETZ_MODULE_ip_conntrack_pptp=y FREETZ_MODULE_ip_conntrack_tftp=y FREETZ_MODULE_ip_nat=y FREETZ_MODULE_ip_nat_ftp=y FREETZ_MODULE_ip_nat_h323=y FREETZ_MODULE_ip_nat_irc=y FREETZ_MODULE_ip_nat_pptp=y FREETZ_MODULE_ip_nat_tftp=y FREETZ_MODULE_iptable_filter=y FREETZ_MODULE_iptable_mangle=y FREETZ_MODULE_iptable_nat=y FREETZ_MODULE_iptable_raw=y FREETZ_MODULE_ip_tables=y FREETZ_MODULE_ipt_iprange=y FREETZ_MODULE_ipt_layer7=y FREETZ_MODULE_ipt_ipp2p=y FREETZ_MODULE_ipt_LOG=y FREETZ_MODULE_ipt_comment=y FREETZ_MODULE_ipt_MASQUERADE=y FREETZ_MODULE_ipt_REDIRECT=y FREETZ_MODULE_ipt_REJECT=y FREETZ_MODULE_ipt_TCPMSS=y FREETZ_MODULE_ipt_tos=y FREETZ_MODULE_ipt_TOS=y FREETZ_MODULE_ipt_ttl=y # # x_tables (both IPv4 and IPv6) # FREETZ_MODULE_x_tables=y FREETZ_MODULE_xt_helper=y FREETZ_MODULE_xt_CLASSIFY=y FREETZ_MODULE_xt_comment=y FREETZ_MODULE_xt_conntrack=y FREETZ_MODULE_xt_esp=y FREETZ_MODULE_xt_length=y FREETZ_MODULE_xt_limit=y FREETZ_MODULE_xt_mac=y FREETZ_MODULE_xt_multiport=y FREETZ_MODULE_xt_mark=y FREETZ_MODULE_xt_MARK=y FREETZ_MODULE_xt_NFQUEUE=y FREETZ_MODULE_xt_NOTRACK=y FREETZ_MODULE_xt_pkttype=y FREETZ_MODULE_xt_physdev=y FREETZ_MODULE_xt_quota=y FREETZ_MODULE_xt_realm=y FREETZ_MODULE_xt_state=y FREETZ_MODULE_xt_statistic=y FREETZ_MODULE_xt_string=y FREETZ_MODULE_xt_tcpudp=y FREETZ_MODULE_xt_tcpmss=y FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y # # Select shared libraries (IPv4) # FREETZ_LIB_libipt_addrtype=y FREETZ_LIB_libipt_ah=y FREETZ_LIB_libipt_CLUSTERIP=y FREETZ_LIB_libipt_DNAT=y FREETZ_LIB_libipt_ecn=y FREETZ_LIB_libipt_ECN=y FREETZ_LIB_libipt_icmp=y FREETZ_LIB_libipt_ipp2p=y FREETZ_LIB_libipt_LOG=y FREETZ_LIB_libipt_MASQUERADE=y FREETZ_LIB_libipt_MIRROR=y FREETZ_LIB_libipt_NETMAP=y FREETZ_LIB_libipt_policy=y FREETZ_LIB_libipt_realm=y FREETZ_LIB_libipt_REDIRECT=y FREETZ_LIB_libipt_REJECT=y FREETZ_LIB_libipt_SAME=y FREETZ_LIB_libipt_set=y FREETZ_LIB_libipt_SET=y FREETZ_LIB_libipt_SNAT=y FREETZ_LIB_libipt_ttl=y FREETZ_LIB_libipt_TTL=y FREETZ_LIB_libipt_ULOG=y FREETZ_LIB_libipt_unclean=y # # Select shared libraries (both IPv4 and IPv6) # FREETZ_LIB_libxt_CLASSIFY=y FREETZ_LIB_libxt_comment=y FREETZ_LIB_libxt_connbytes=y FREETZ_LIB_libxt_connmark=y FREETZ_LIB_libxt_CONNMARK=y FREETZ_LIB_libxt_CONNSECMARK=y FREETZ_LIB_libxt_conntrack=y FREETZ_LIB_libxt_dscp=y FREETZ_LIB_libxt_DSCP=y FREETZ_LIB_libxt_esp=y FREETZ_LIB_libxt_hashlimit=y FREETZ_LIB_libxt_helper=y FREETZ_LIB_libxt_iprange=y FREETZ_LIB_libxt_length=y FREETZ_LIB_libxt_limit=y FREETZ_LIB_libxt_mac=y FREETZ_LIB_libxt_mark=y FREETZ_LIB_libxt_MARK=y FREETZ_LIB_libxt_multiport=y FREETZ_LIB_libxt_NFLOG=y FREETZ_LIB_libxt_NFQUEUE=y FREETZ_LIB_libxt_NOTRACK=y FREETZ_LIB_libxt_owner=y FREETZ_LIB_libxt_physdev=y FREETZ_LIB_libxt_pkttype=y FREETZ_LIB_libxt_quota=y FREETZ_LIB_libxt_rateest=y FREETZ_LIB_libxt_RATEEST=y FREETZ_LIB_libxt_sctp=y FREETZ_LIB_libxt_SECMARK=y FREETZ_LIB_libxt_standard=y FREETZ_LIB_libxt_state=y FREETZ_LIB_libxt_statistic=y FREETZ_LIB_libxt_string=y FREETZ_LIB_libxt_tcpmss=y FREETZ_LIB_libxt_TCPMSS=y FREETZ_LIB_libxt_tcp=y FREETZ_LIB_libxt_time=y FREETZ_LIB_libxt_tos=y FREETZ_LIB_libxt_TOS=y FREETZ_LIB_libxt_TRACE=y FREETZ_LIB_libxt_u32=y FREETZ_LIB_libxt_udp=y # FREETZ_PACKAGE_ONLINECHANGED_CGI is not set # FREETZ_PACKAGE_PHPXMAIL is not set # FREETZ_PACKAGE_PPP_CGI is not set FREETZ_PACKAGE_RRDSTATS=y # FREETZ_PACKAGE_SPINDOWN_CGI is not set FREETZ_PACKAGE_SYSLOGD_CGI=y # FREETZ_PACKAGE_TRANSMISSION_CGI is not set # FREETZ_PACKAGE_VIRTUALIP_CGI is not set FREETZ_PACKAGE_VNSTAT_CGI=y # FREETZ_PACKAGE_WOL_CGI is not set # # Debug helpers # FREETZ_PACKAGE_LDD=y FREETZ_PACKAGE_LSOF=y FREETZ_PACKAGE_LTRACE=y FREETZ_PACKAGE_NANO_SHELL=y FREETZ_PACKAGE_PCIUTILS=y FREETZ_PACKAGE_PCIUTILS_IDS=y FREETZ_PACKAGE_STRACE=y FREETZ_PACKAGE_USBUTILS=y FREETZ_PACKAGE_USBUTILS_IDS=y # # Testing # # FREETZ_PACKAGE_APACHE is not set # FREETZ_PACKAGE_BASH is not set # FREETZ_PACKAGE_BFUSB is not set # FREETZ_PACKAGE_BIP is not set # FREETZ_PACKAGE_BITTWIST is not set # FREETZ_PACKAGE_BLUEZ_UTILS is not set # FREETZ_PACKAGE_BR2684CTL is not set # FREETZ_PACKAGE_CRYPTSETUP is not set # FREETZ_PACKAGE_CTORRENT is not set # FREETZ_PACKAGE_DAVFS2 is not set # FREETZ_PACKAGE_DEBOOTSTRAP is not set # FREETZ_PACKAGE_DIGITEMP is not set # FREETZ_PACKAGE_DNS2TCP is not set # FREETZ_PACKAGE_DOSFSTOOLS is not set # FREETZ_PACKAGE_DTACH is not set # FREETZ_PACKAGE_E2FSPROGS is not set # FREETZ_PACKAGE_EMPTY is not set FREETZ_PACKAGE_FSTYP=y # FREETZ_PACKAGE_GNU_MAKE is not set # FREETZ_PACKAGE_GNUTLS is not set # FREETZ_PACKAGE_GOCR is not set # FREETZ_PACKAGE_HD_IDLE is not set # FREETZ_PACKAGE_HTOP is not set # FREETZ_PACKAGE_HTTPRY is not set # FREETZ_PACKAGE_HTTPTUNNEL is not set # FREETZ_PACKAGE_IGMPPROXY is not set # FREETZ_PACKAGE_INADYN_MT is not set # FREETZ_PACKAGE_INOTIFY_TOOLS is not set # FREETZ_PACKAGE_IODINE is not set # FREETZ_PACKAGE_IPTRAF is not set # FREETZ_PACKAGE_IRSSI is not set # FREETZ_PACKAGE_JAMVM is not set # FREETZ_PACKAGE_LFTP is not set # FREETZ_PACKAGE_LIGHTTPD is not set # FREETZ_PACKAGE_LYNX is not set # FREETZ_PACKAGE_LUA is not set # FREETZ_PACKAGE_MADPLAY is not set # FREETZ_PACKAGE_MATRIXTUNNEL is not set # FREETZ_PACKAGE_MCABBER is not set # FREETZ_PACKAGE_MICROPERL is not set # FREETZ_PACKAGE_MINICOM is not set # FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set # FREETZ_PACKAGE_NAGIOS is not set # FREETZ_PACKAGE_NCFTP is not set # FREETZ_PACKAGE_NETPBM is not set # FREETZ_PACKAGE_NOIP is not set # FREETZ_PACKAGE_NDAS is not set # FREETZ_PACKAGE_NFS_UTILS is not set # FREETZ_PACKAGE_NFSROOT is not set # FREETZ_PACKAGE_NGIRCD is not set # FREETZ_PACKAGE_NMAP is not set # FREETZ_PACKAGE_OBEXFTP is not set # # OpenSSH # # FREETZ_PACKAGE_OPENSSH_SSHD is not set # FREETZ_PACKAGE_OPENSSH_CLIENT is not set # FREETZ_PACKAGE_OPENSSH_SCP is not set # FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set # FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set # FREETZ_PACKAGE_OPENSSH_SFTPCLIENT is not set # FREETZ_PACKAGE_OPENSSH_SFTP is not set # FREETZ_PACKAGE_OWFS is not set # FREETZ_PACKAGE_PHP is not set # FREETZ_PACKAGE_PORTMAP is not set # FREETZ_PACKAGE_POLIPO is not set # FREETZ_PACKAGE_PPPD_CHAT is not set # FREETZ_PACKAGE_PPTP is not set # FREETZ_PACKAGE_PPTPD is not set # FREETZ_PACKAGE_QUAGGA is not set FREETZ_PACKAGE_RRDTOOL=y # FREETZ_PACKAGE_RSYNC is not set # FREETZ_PACKAGE_RUBY is not set # FREETZ_PACKAGE_SABLEVM_SDK is not set # FREETZ_PACKAGE_SER2NET is not set # FREETZ_PACKAGE_SISPMCTL is not set # FREETZ_PACKAGE_SLURM is not set # FREETZ_PACKAGE_SOCAT is not set # FREETZ_PACKAGE_SPAWN_FCGI is not set # FREETZ_PACKAGE_SQLITE is not set # FREETZ_PACKAGE_SQUID is not set # FREETZ_PACKAGE_STREAMRIPPER is not set # FREETZ_PACKAGE_SUBVERSION is not set # FREETZ_PACKAGE_SYNCE_DCCM is not set # FREETZ_PACKAGE_SYNCE_SERIAL is not set # FREETZ_PACKAGE_TCP_WRAPPERS is not set # FREETZ_PACKAGE_TCPPROXY is not set # FREETZ_PACKAGE_TINYPROXY is not set # FREETZ_PACKAGE_TRANSMISSION is not set # FREETZ_PACKAGE_TREE is not set # FREETZ_PACKAGE_TRICKLE is not set # FREETZ_PACKAGE_TMUX is not set # FREETZ_PACKAGE_UMURMUR is not set # FREETZ_PACKAGE_UNRAR is not set # FREETZ_PACKAGE_USBROOT is not set # FREETZ_PACKAGE_VIM is not set FREETZ_PACKAGE_VNSTAT=y FREETZ_PACKAGE_VNSTAT_DAEMON=y FREETZ_PACKAGE_VNSTAT_IMAGE=y # FREETZ_PACKAGE_VTUN is not set # FREETZ_PACKAGE_WGET is not set # FREETZ_PACKAGE_WOL is not set # FREETZ_PACKAGE_WPUT is not set # FREETZ_PACKAGE_XMAIL is not set # FREETZ_PACKAGE_XPDF is not set # FREETZ_PACKAGE_XRELAYD is not set # FREETZ_PACKAGE_XSLTPROC is not set FREETZ_SHOW_UNSTABLE_PACKAGES=y # # Unstable packages # # FREETZ_PACKAGE_COLLECTD is not set # FREETZ_PACKAGE_HP_UTILS is not set # FREETZ_PACKAGE_HPLIP is not set # FREETZ_PACKAGE_IPTABLES_CGI is not set # # Select kernel modules (IPv4) # # FREETZ_MODULE_ip_conntrack_rtsp is not set # FREETZ_MODULE_ip_nat_rtsp is not set # # x_tables (both IPv4 and IPv6) # # # Select shared libraries (IPv4) # # # Select shared libraries (both IPv4 and IPv6) # # FREETZ_PACKAGE_MDEV is not set # # SANE # # FREETZ_PACKAGE_SANE_BACKENDS is not set # FREETZ_PACKAGE_TINC is not set # FREETZ_PACKAGE_USBIP is not set # FREETZ_PACKAGE_UTIL_LINUX_NG is not set FREETZ_PACKAGE_HASERL=y FREETZ_PACKAGE_MODCGI=y # # Advanced options # # FREETZ_DL_OVERRIDE is not set FREETZ_DL_KERNEL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7270/x_misc/opensrc" FREETZ_DL_KERNEL_SOURCE="fritzbox7270-source-files-04.80.tar.gz" FREETZ_DL_KERNEL_SOURCE_MD5="bcd49b28a54293e1481b8170b07245e0" FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch" FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270.54.04.80.image" FREETZ_DL_SOURCE_MD5="4ea997dce6bbf72202ae80cb572ab1fe" # # Freetz package download sites # FREETZ_MOD_DL_NUM_SITES="5" # # Download site #1 - default: http://freetz.3dfxatwork.de # FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de" # # Download site #2 - default: http://freetz.wirsind.info # FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info" # # Download site #3 - default: http://freetz.magenbrot.net # FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net" # # Download site #4 - default: empty (reserved for later use) # FREETZ_MOD_DL_SITE_4="" # # Download site #5 - user-defined # FREETZ_MOD_DL_SITE_5="" FREETZ_SECURITY_LEVEL=0 FREETZ_VERBOSITY_LEVEL=2 FREETZ_FAVICON_NONE=y # FREETZ_FAVICON_ATOMPHIL is not set # FREETZ_FAVICON_CUMA is not set # FREETZ_FAVICON_DSL123 is not set # FREETZ_FAVICON_HANSOLO is not set # FREETZ_BACKUP_CONFIG_CACHE is not set FREETZ_CHECK_CHANGED=y FREETZ_FAVICON_STRING="none" FREETZ_SUBVERSION_STRING=y FREETZ_DEVELOPER_VERSION_STRING=y # FREETZ_STYLE_COLORED is not set FREETZ_STYLE_GREY=y FREETZ_STYLE="grey" FREETZ_USER_DEFINED_COMMENT="" # FREETZ_CUSTOM_IMAGE_NAME is not set # # Info pages # # FREETZ_REMOVE_BOX_INFO is not set # FREETZ_REMOVE_FREETZ_INFO is not set # FREETZ_REMOVE_DOT_CONFIG is not set FREETZ_AVMPLUGINS_ENABLED=y # # Plugin selection # # # Select plugin(s) for insertion # # FREETZ_AVMPLUGINS_MEDIASRV is not set # FREETZ_AVMPLUGINS_MINI is not set FREETZ_AVMPLUGINS_NTFS=y # FREETZ_AVMPLUGINS_ONLINEPB is not set FREETZ_AVMPLUGINS_SAMBA=y FREETZ_AVMPLUGINS_TAM=y # FREETZ_AVMPLUGINS_WEBDAV is not set # # External # # EXTERNAL_ENABLED is not set # FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set # FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set # FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set FREETZ_SQUASHFS_BLOCKSIZE_65536=y # FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set # FREETZ_REPLACE_SSL_LIBS is not set # # BusyBox options # # FREETZ_BUSYBOX_AR is not set FREETZ_BUSYBOX_BRCTL=y FREETZ_BUSYBOX_BRCTL_FANCY=y # FREETZ_BUSYBOX_BZIP2 is not set # FREETZ_BUSYBOX_CHGRP is not set # FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set FREETZ_BUSYBOX_DIFF=y # FREETZ_BUSYBOX_DOS2UNIX is not set # FREETZ_BUSYBOX_ETHER_WAKE is not set # FREETZ_BUSYBOX_FANCY_KEYS is not set # FREETZ_BUSYBOX_FUSER is not set FREETZ_BUSYBOX_INETD=y FREETZ_BUSYBOX_IP=y FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y FREETZ_BUSYBOX_FEATURE_IP_LINK=y FREETZ_BUSYBOX_FEATURE_IP_RULE=y FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y FREETZ_BUSYBOX_LESS=y FREETZ_BUSYBOX_LONG_OPTS=y FREETZ_BUSYBOX_LS_COLOR=y FREETZ_BUSYBOX_MD5SUM=y # FREETZ_BUSYBOX_MDEV is not set # FREETZ_BUSYBOX_MOUNT_HELPERS is not set # FREETZ_BUSYBOX_MOUNT_LABEL is not set FREETZ_BUSYBOX_NICE=y # FREETZ_BUSYBOX_PATCH is not set FREETZ_BUSYBOX_PSCAN=y FREETZ_BUSYBOX_REALPATH=y # FREETZ_BUSYBOX_SEQ is not set # FREETZ_BUSYBOX_SHA1SUM is not set # FREETZ_BUSYBOX_SPLIT is not set FREETZ_BUSYBOX_START_STOP_DAEMON=y # FREETZ_BUSYBOX_TAC is not set # FREETZ_BUSYBOX_UDHCPC is not set # FREETZ_BUSYBOX_UDHCPD is not set # FREETZ_BUSYBOX_UNIX2DOS is not set # FREETZ_BUSYBOX_UNZIP is not set # FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set # FREETZ_BUSYBOX_VOLUMEID is not set FREETZ_BUSYBOX_WGET=y # FREETZ_BUSYBOX_WHOAMI is not set # # Kernel modules # # FREETZ_MODULES_ALL is not set # # block # # FREETZ_MODULE_ramzswap is not set # FREETZ_MODULE_xvmalloc is not set # # crypto # # FREETZ_MODULE_crypto_algapi is not set # FREETZ_MODULE_arc4 is not set # FREETZ_MODULE_blkcipher is not set # FREETZ_MODULE_cbc is not set # FREETZ_MODULE_cryptomgr is not set # FREETZ_MODULE_sha1 is not set # FREETZ_MODULE_sha256 is not set # # drivers # # FREETZ_MODULE_loop is not set # FREETZ_MODULE_nbd is not set # FREETZ_MODULE_cdrom is not set # FREETZ_MODULE_capiconn is not set # FREETZ_MODULE_nand is not set # FREETZ_MODULE_ohio_nand is not set # FREETZ_MODULE_dummy is not set # FREETZ_MODULE_ppp_async is not set # FREETZ_MODULE_ppp_deflate is not set # FREETZ_MODULE_ppp_generic is not set # FREETZ_MODULE_pppoe is not set # FREETZ_MODULE_pppox is not set # FREETZ_MODULE_ppp_mppe_mppc is not set # FREETZ_MODULE_scsi_mod is not set # FREETZ_MODULE_sd_mod is not set # FREETZ_MODULE_sg is not set # FREETZ_MODULE_sr_mod is not set # FREETZ_MODULE_slhc is not set # FREETZ_MODULE_musb_hdrc is not set # FREETZ_MODULE_usblp is not set # FREETZ_MODULE_usb_storage is not set # FREETZ_MODULE_usbmon is not set # FREETZ_MODULE_usbcore is not set # FREETZ_MODULE_usbip is not set # FREETZ_MODULE_usbip_common_mod is not set # FREETZ_MODULE_usbserial is not set # FREETZ_MODULE_ipaq is not set # FREETZ_MODULE_pl2303 is not set # FREETZ_MODULE_ftdi_sio is not set # FREETZ_MODULE_hci_usb is not set # FREETZ_MODULE_bfusb is not set # FREETZ_MODULE_firmware_class is not set # FREETZ_MODULE_dm_mod is not set # FREETZ_MODULE_dm_crypt is not set # FREETZ_MODULE_option is not set # # fs # # FREETZ_MODULE_cifs is not set # FREETZ_MODULE_coda is not set FREETZ_MODULE_ext3=y FREETZ_MODULE_ext2=y # FREETZ_MODULE_fat is not set # FREETZ_MODULE_hfs is not set # FREETZ_MODULE_hfsplus is not set FREETZ_MODULE_fuse=y FREETZ_MODULE_jbd=y # FREETZ_MODULE_lockd is not set # FREETZ_MODULE_mini_fo is not set # FREETZ_MODULE_minix is not set # # ndas # # FREETZ_MODULE_ndas_block is not set # FREETZ_MODULE_ndas_core is not set # FREETZ_MODULE_ndas_sal is not set # FREETZ_MODULE_nfsd is not set # FREETZ_MODULE_exportfs is not set # FREETZ_MODULE_nfs is not set # FREETZ_MODULE_nls_cp437 is not set # FREETZ_MODULE_nls_cp852 is not set # FREETZ_MODULE_nls_iso8859_15 is not set # FREETZ_MODULE_nls_iso8859_1 is not set # FREETZ_MODULE_nls_utf8 is not set # FREETZ_MODULE_ntfs is not set # FREETZ_MODULE_reiserfs is not set # FREETZ_MODULE_smbfs is not set # FREETZ_MODULE_udf is not set # FREETZ_MODULE_unionfs is not set # FREETZ_MODULE_vfat is not set # FREETZ_MODULE_msdods is not set # FREETZ_MODULE_jffs2 is not set FREETZ_MODULE_mbcache=y # # lib # # FREETZ_MODULE_crc_ccitt is not set # FREETZ_MODULE_lzo_compress is not set # FREETZ_MODULE_lzo_decompress is not set # # net # # FREETZ_MODULE_bluetooth is not set # FREETZ_MODULE_bnep is not set # FREETZ_MODULE_l2cap is not set # FREETZ_MODULE_rfcomm is not set # FREETZ_MODULE_sunrpc is not set # # Shared libraries # # FREETZ_STRIP_LIBRARIES is not set # # Libraries ------------------------------- # # FREETZ_LIB_libapr is not set # FREETZ_LIB_libaprutil is not set # FREETZ_LIB_libatm is not set # FREETZ_LIB_libconfig is not set # FREETZ_LIB_libdb is not set # FREETZ_LIB_libbluetooth is not set # FREETZ_LIB_libopenobex is not set # # Crypto & SSL # # # GMP ------------------------------------ # # FREETZ_LIB_libgmp is not set # # GnuPG ---------------------------------- # # FREETZ_LIB_libgpg_error is not set # FREETZ_LIB_libgcrypt is not set # # SSL ------------------------------------ # # FREETZ_LIB_libcyassl is not set # FREETZ_LIB_libmatrixssl is not set # FREETZ_LIB_libpolarssl is not set # FREETZ_LIB_libcrypto is not set # # GnuTLS --------------------------------- # # FREETZ_LIB_libgnutls is not set # FREETZ_LIB_libtasn1 is not set # # Data compression # # FREETZ_LIB_liblzo2 is not set FREETZ_LIB_libz=y # # e2fsprogs libraries # # FREETZ_LIB_libblkid is not set # FREETZ_LIB_libcom_err is not set # FREETZ_LIB_libe2p is not set # FREETZ_LIB_libext2fs is not set # FREETZ_LIB_libss is not set # FREETZ_LIB_libuuid is not set # FREETZ_LIB_libfuse is not set # # Graphics & fonts # FREETZ_LIB_libfreetype=y FREETZ_LIB_libart_lgpl_2=y FREETZ_LIB_libjpeg=y FREETZ_LIB_libpng12=y FREETZ_LIB_libgd=y # # uClibc # FREETZ_LIB_ld_uClibc=y FREETZ_LIB_libcrypt=y FREETZ_LIB_libdl=y FREETZ_LIB_libm=y FREETZ_LIB_libnsl=y FREETZ_LIB_libpthread=y # FREETZ_LIB_libresolv is not set FREETZ_LIB_librt=y # FREETZ_LIB_libthread_db is not set FREETZ_LIB_libuClibc=y # FREETZ_LIB_libutil is not set # FREETZ_LIB_libuClibc__ is not set FREETZ_LIB_libgcc_s=y # FREETZ_LIB_libglib_1 is not set # # GLib2 # FREETZ_LIB_libglib_2=y # FREETZ_LIB_libgio_2 is not set # FREETZ_LIB_libgobject_2 is not set # FREETZ_LIB_libgmodule_2 is not set # FREETZ_LIB_libgthread_2 is not set # # ncurses # FREETZ_LIB_libncurses=y # # terminfo database # # # Select terminfo database entries to install (see help of 'Show all items') # FREETZ_SHARE_terminfo=y # FREETZ_SHARE_terminfo_showall is not set FREETZ_SHARE_terminfo_ansi=y FREETZ_SHARE_terminfo_gnome=y FREETZ_SHARE_terminfo_konsole=y FREETZ_SHARE_terminfo_linux=y FREETZ_SHARE_terminfo_putty=y FREETZ_SHARE_terminfo_rxvt=y FREETZ_SHARE_terminfo_screen=y FREETZ_SHARE_terminfo_screenMINUSw=y FREETZ_SHARE_terminfo_sun=y FREETZ_SHARE_terminfo_vt100=y FREETZ_SHARE_terminfo_vt102=y FREETZ_SHARE_terminfo_vt102MINUSnsgr=y FREETZ_SHARE_terminfo_vt102MINUSw=y FREETZ_SHARE_terminfo_vt200=y FREETZ_SHARE_terminfo_vt220=y FREETZ_SHARE_terminfo_vt52=y FREETZ_SHARE_terminfo_xterm=y FREETZ_SHARE_terminfo_xtermMINUScolor=y FREETZ_SHARE_terminfo_xtermMINUSxfree86=y # FREETZ_LIB_libform is not set # FREETZ_LIB_libmenu is not set # FREETZ_LIB_libpanel is not set # FREETZ_LIB_libcapi20 is not set # FREETZ_LIB_libcurl is not set # FREETZ_LIB_libevent is not set # FREETZ_LIB_libexpat is not set # FREETZ_LIB_libid3tag is not set # FREETZ_LIB_libltdl is not set # FREETZ_LIB_liblua is not set # FREETZ_LIB_libmad is not set # FREETZ_LIB_libneon is not set # FREETZ_LIB_libnetpbm is not set # # Ogg/Vorbis # # FREETZ_LIB_libogg is not set # FREETZ_LIB_libvorbis is not set # FREETZ_LIB_libvorbisenc is not set # FREETZ_LIB_libvorbisfile is not set # FREETZ_LIB_libpcap is not set # FREETZ_LIB_libdnet is not set # # Readline # # FREETZ_LIB_libreadline is not set # FREETZ_LIB_libhistory is not set # FREETZ_LIB_libsqlite3 is not set FREETZ_LIB_libusb=y FREETZ_LIB_libelf=y FREETZ_LIB_libintl=y # FREETZ_LIB_libiconv is not set # FREETZ_LIB_libftdi is not set # FREETZ_LIB_libsynce is not set # FREETZ_LIB_libsysfs is not set # FREETZ_LIB_libpopt is not set # FREETZ_LIB_libdevmapper is not set FREETZ_LIB_libfreetz=y FREETZ_LIB_libpcre=y # FREETZ_LIB_libpcreposix is not set # # XML/XSLT # # FREETZ_LIB_libxml2 is not set # FREETZ_LIB_libxslt is not set # FREETZ_LIB_libexslt is not set # # Compiler options # FREETZ_DOWNLOAD_TOOLCHAIN=y # FREETZ_BUILD_TOOLCHAIN is not set FREETZ_TARGET_ARCH="mipsel" FREETZ_TARGET_CROSS="mipsel-linux-uclibc-" FREETZ_TARGET_MAKE_PATH="toolchain/target/bin" FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap" FREETZ_JLEVEL=2 FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-" FREETZ_KERNEL_MAKE_PATH="toolchain/kernel/bin" # FREETZ_KERNEL_VERSION_2_6_13_1 is not set FREETZ_KERNEL_VERSION_2_6_19_2=y FREETZ_KERNEL_VERSION="2.6.19.2" # FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y # FREETZ_TARGET_UCLIBC_VERSION_0_9_30 is not set # FREETZ_TARGET_COMPILER_GCC_4_1_2_UCLIBC_0_9_28 is not set # FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_28 is not set FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_29=y # FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_29 is not set # FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_30 is not set FREETZ_TARGET_GCC_VERSION="4.2.4" FREETZ_TARGET_UCLIBC_VERSION="0.9.29" FREETZ_TARGET_BINUTILS_VERSION="2.18" FREETZ_TARGET_UCLIBC_REF="mod" # FREETZ_STATIC_TOOLCHAIN is not set FREETZ_TARGET_GXX=y FREETZ_TARGET_CCACHE=y # FREETZ_TARGET_NLS is not set FREETZ_TARGET_LFS=y FREETZ_KERNEL_GCC_VERSION="3.4.6" FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17" # FREETZ_TARGET_TOOLCHAIN is not set # # GNU debugger (gdb) # # FREETZ_PACKAGE_GDB is not set # FREETZ_PACKAGE_GDB_SERVER is not set # FREETZ_PACKAGE_GDB_HOST is not set
Yes, we can!
Zitieren
