Seite 1 von 2 12 LetzteLetzte
Ergebnis 1 bis 20 von 27
Thema: tcpdump compile error
  1. #1
    IPPF-Fan
    Registriert seit
    24.02.2006
    7270 16MB and i get this err:
    applying patch file make/tcpdump/patches/02-shared_pcap.patch
    patching file aclocal.m4
    touch source/tcpdump-3.9.8/.unpacked
    ( cd source/tcpdump-3.9.8; rm -f config.{cache,status} ; autoconf --force ; source /home/freetz/freetz-stable-1.1/make/config.mipsel ; PATH="/home/freetz/freetz-stable-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" CC="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc" CXX="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" GLOBAL_LIBDIR=/home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib BUILD_CC="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc" HOSTCC="gcc" td_cv_buggygetaddrinfo="no" ./configure --cache-file=/home/freetz/freetz-stable-1.1/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --disable-ipv6 --without-crypto )
    configure.in:15: warning: AC_REQUIRE: `AC_PROG_CC' was expanded before it was required
    ../../lib/autoconf/c.m4:433: AC_LANG_COMPILER(C) is expanded from...
    ../../lib/autoconf/lang.m4:315: AC_LANG_COMPILER_REQUIRE is expanded from...
    ../../lib/autoconf/general.m4:2593: AC_COMPILE_IFELSE is expanded from...
    ../../lib/autoconf/general.m4:2601: AC_TRY_COMPILE is expanded from...
    aclocal.m4:45: AC_LBL_C_INIT is expanded from...
    configure.in:15: the top level
    configure: WARNING: unrecognized options: --with-gnu-ld, --disable-nls
    configure: loading cache /home/freetz/freetz-stable-1.1/make/config.cache
    checking build system type... (cached) i386-pc-linux-gnu
    checking host system type... (cached) mipsel-unknown-linux-gnu
    ./configure: line 2548: syntax error near unexpected token `newline'
    ./configure: line 2548: `yes:'
    make: *** [source/tcpdump-3.9.8/.configured] Fehler 2
    VoIP- und DSL-Hardware:
    FRITZ!Box Fon WLAN 7170 Version 29.04.80
    FRITZ!Box Fon WLAN 7270 Firmware version 54.04.81
  2. #2
    IPPF-Fan
    Registriert seit
    24.02.2006
    i get next error:
    checking whether we are using the GNU C++ compiler... (cached) yes
    checking whether /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc accepts -g... (cached) yes
    checking dependency style of /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc... (cached) gcc3
    checking for mipsel-linux-gcc... (cached) /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc
    checking whether we are using the GNU C compiler... (cached) yes
    checking whether /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc accepts -g... (cached) yes
    checking for /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc option to accept ISO C89... (cached) none needed
    checking dependency style of /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc... (cached) gcc3
    checking whether /home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc and cc understand -c and -o together... (cached) yes
    checking for a BSD-compatible install... /usr/bin/install -c
    checking for special C compiler options needed for large files... (cached) no
    checking for _FILE_OFFSET_BITS value needed for large files... (cached) no
    checking for pkg-config... (cached) /usr/bin/pkg-config
    checking for gawk... (cached) gawk
    checking for perl5... no
    checking for perl... perl
    checking for indent... no
    checking for perl... /usr/bin/perl
    checking for a Python interpreter with version >= 2.4... python
    checking for python... /usr/bin/python
    checking for python version... 2.6
    checking for python platform... linux2
    checking for python script directory... ${prefix}/lib/python2.6/site-packages
    checking for python extension module directory... ${exec_prefix}/lib/python2.6/site-packages
    checking for libiconv_open in -liconv... yes
    checking for grep that handles long lines and -e... (cached) /bin/grep
    checking for egrep... (cached) /bin/grep -E
    checking whether we are using the GNU C Library 2.1 or newer... (cached) yes
    checking Whether to cache iconv descriptors... no
    checking for ANSI C header files... (cached) yes
    checking for sys/types.h... (cached) yes
    checking for sys/stat.h... (cached) yes
    checking for stdlib.h... (cached) yes
    checking for string.h... (cached) yes
    checking for memory.h... (cached) yes
    checking for strings.h... (cached) yes
    checking for inttypes.h... (cached) yes
    checking for stdint.h... (cached) yes
    checking for unistd.h... (cached) yes
    checking for locale.h... (cached) yes
    checking for LC_MESSAGES... (cached) yes
    checking for libintl.h... (cached) no
    configure: error:
    *** You must have either have gettext support in your C library, or use the
    *** GNU gettext library. (http://www.gnu.org/software/gettext/gettext.html
    make: *** [source/glib-2.18.2/.configured] Fehler 1
  3. #3
    IPPF-Urgestein
    Registriert seit
    22.04.2007
    There's probably something wrong with your build system.
  4. #4
    IPPF-Fan
    Registriert seit
    24.02.2006
    i compile some images, but i try to change optionsm then this is 100% my bug?
    next error:
    if [ -f ./lib/libc.so -a -f /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/lib/libc.so.0 ] ; then \
    rm -f /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/lib/libc.so; \
    sed -e 's:uclibc_nonshared.a:/usr/lib/uclibc_nonshared.a:' \
    -e 's:libc.so.0:/lib/libc.so.0:' \
    -e 's:ld-uClibc.so.0:/lib/ld-uClibc.so.0:' \
    ./lib/libc.so > /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/lib/libc.so; \
    fi
    ln -sf ../../lib/libthread_db.so.1 \
    /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/lib/libthread_db.so
    if [ -d lib ] ; then \
    for i in `find lib/ -type f -name 'lib*.a' | sed -e 's/lib\///'` ; do \
    ln -sf $i /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/lib/`echo $i \
    | sed -e 's/\.a$/_pic.a/'`; \
    done ; \
    fi
    make[1]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/source/toolchain/target/uClibc-0.9.29'
    # Install the kernel headers to the target dir if necessary
    if [ ! -f /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/include/linux/version.h ]; then \
    cp -pLR /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/include/* \
    /home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/include/; \
    fi
    cp: Kopieren von zyklischer symbolischer VerknĂźpfung â/home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/include/include/includeâ nicht mĂśglich
    make: *** [/home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/target-utils/usr/lib/libc.a] Fehler 1
    ps: is possible build image for 5050 (4MB only)? I not fit into limitsize, i get out some components but not fit too
  5. #5
    IPPF-Fan
    Registriert seit
    20.12.2005
    tcpdump error is not your fault, but also not ours. It's a combination of tcpdump error and your build system (automake 2.64?). The problem is not fixed in stable branch, there is however a patch somewhere here in forum. Use SuFu...
    gettext error is definitely your fault, RTFM...
    uClibc-error: no clue whose fault it is, but what's the reason you build uClibc yourself, use precompiled aka download toolchain...
  6. #6
    IPPF-Fan
    Registriert seit
    24.02.2006
    rm -f -r source/dtmfbox-0.5.0_svn-src
    tar -C source -xjf dl/dtmfbox-0.5.0_svn-src.tar.bz2
    set -e; shopt -s nullglob; for i in make/dtmfbox/patches/*.patch; do tools/freetz_patch source/dtmfbox-0.5.0_svn-src $i; done
    touch source/dtmfbox-0.5.0_svn-src/.unpacked
    ( cd source/dtmfbox-0.5.0_svn-src; rm -f config.{cache,status} ; cd ../../; rm -Rf source/dtmfbox-0.5.0_svn-src; svn co http://svn.v3v.de/svn/dtmfbox/trunk source/dtmfbox-0.5.0_svn-src; cd source/dtmfbox-0.5.0_svn-src; touch .unpacked; source /home/freetz/freetz-stable-1.1/make/config.mipsel ; PATH="/home/freetz/freetz-stable-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" CC="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc" CXX="/home/freetz/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" ./configure --cache-file=/home/freetz/freetz-stable-1.1/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --with-pjsip-version=9 --with-pjsip-path=/home/freetz/freetz-stable-1.1/source/pjproject-1.0.1 --prefix=/home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc --exec-prefix=/home/freetz/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc --disable-sound --disable-template )
    svn: OPTIONS of 'http://svn.v3v.de/svn/dtmfbox/trunk': Could not resolve hostname `svn.v3v.de': Host nicht gefunden (http://svn.v3v.de)
    /bin/bash: Zeile 0: cd: source/dtmfbox-0.5.0_svn-src: No such file or directory
    /bin/bash: ./configure: No such file or directory
    make: *** [source/dtmfbox-0.5.0_svn-src/.configured] Fehler 127
    i load freetz live image again (fresh!) and after 2 hours compiling i get this error... Omg, i not sure where is bug?
    is here anyone developer for confirm and/or repair these bugs above please? !!!
    Geändert von vpe (05.06.2010 um 05:03 Uhr)
  7. #7
    IPPF-Fünftausend-VIP
    Registriert seit
    03.08.2007
    Ort
    BI
    Give the stable version of dtmfbox a try, not the trunk. THis is of course one of the errors, every trunk user should be able to fix by his own...
    Geändert von Silent-Tears (05.06.2010 um 12:46 Uhr)
    Boxen: 7240, 7170, W900V, W701V jeweils mit mehr oder minder aktuellem Freetz-Trunk und irgendwelchen Modifizierungen.
    Aus aktuellem Anlaß: Support gehört ins Forum, IRC oder Trac-System, nicht in mein Postfach oder meine Messenger-Accounts.
    ICQ und andere Kontaktinformationen ab nun nur noch per PN.
  8. #8
    IPPF-Fan
    Registriert seit
    24.02.2006
    i make from begin and now okay.. but i get this:
    STEP 3: PACK
    packing var.tar
    creating filesystem image
    merging kernel image
    ERROR: kernel image is 1379072 bytes too big. See http://trac.freetz.org/wiki/FAQ#Filesystemimagetoobig for details
    make: *** [firmware-nocompile] Fehler 1
    i have 16MB... and 1,3MB for kernel is much? How i use all space? How i disable (must?) Answeringmachine?
    And finally - is possible get ast. pbx into flash?
  9. #9
    Semi-Moderator Avatar von olistudent
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Your image is 1,3 MB too big. You have to remove (or use external) some packages to save this 1,3 MB.
    Regards
    Oliver
    Router: Fritz!Box Fon WLAN 7570, 7390, 7320, 7270, 3170
    Anbindung: T-Online DSL 16.000 RAM
    Visit ##fritzbox on Freenode for help
    Spenden für Freetz
  10. #10
    IPPF-Fan
    Registriert seit
    24.02.2006
    oh, thx. i get this by self try and false method -
    now i have
    ERROR: kernel image is 64256 bytes too big.
    better is if any package show size i n menuconfig
    and this is my sole last Err msg:
    WARNING: Library libneon_WITH_SSL selected, but no files found
  11. #11
    Registriert seit
    03.08.2007
    Ort
    BI
    The error message with libneon doesn't matter, but your image is still too big. Please deselect some packages to get the correct size, use external to put some files to usb-devices or use some more remove-patches...
  12. #12
    IPPF-Fan
    Registriert seit
    24.02.2006
    i know, this is little bug report and here is next:
    Download succeeded - http://www.tcpdump.org/release/tcpdump-3.9.8.tar.gz -> saved to folder dl
    rm -f -r source/tcpdump-3.9.8
    tar -C source -xzf dl/tcpdump-3.9.8.tar.gz
    set -e; shopt -s nullglob; for i in make/tcpdump/patches/*.patch; do tools/freetz_patch source/tcpdump-3.9.8 $i; done
    ( cd source/tcpdump-3.9.8; rm -f config.{cache,status} ; autoconf --force ; source /home/freetz/freetz-stable-1.1/freetz-stable-1.1/make/config.mipsel ; PATH="/home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" CC="/home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc" CXX="/home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" GLOBAL_LIBDIR=/home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib BUILD_CC="/home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc" HOSTCC="gcc" td_cv_buggygetaddrinfo="no" ./configure --cache-file=/home/freetz/freetz-stable-1.1/freetz-stable-1.1/make/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --disable-ipv6 --without-crypto )
    configure: loading cache /home/freetz/freetz-stable-1.1/freetz-stable-1.1/make/config.cache
    i muss deselect tcpdump and i ask why is error
  13. #13
    IPPF-Fünfhundert-Club Avatar von Whoopie
    Registriert seit
    19.10.2004
    tcpdump compile error fixed in the freetz-stable-1.1 branch, see here.
    Router: AVM FRITZ!Box Fon WLAN 7390 mit FRITZ!OS 84.05.55-25188 und freetz-devel
    VoIP: Telekom, sipgate
    Anbindung: Telekom Call&Surf Comfort IP (DSL 16000 Annex J), Downstream: 12,6 MBit/s, Upstream: 2,3 MBit/s
  14. #14
    IPPF-Fan
    Registriert seit
    20.12.2005
    @Whoopie: you were 6 minutes faster than me
  15. #15
    IPPF-Fan
    Registriert seit
    24.02.2006
    after i make clean and get new svn, then this error after make menuconfig and make:
    CFLAGS="-g -O2 -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -pedantic -Wno-long-long " \
    CONFIG_H="tconfig.h /home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6/gcc/../include/ansidecl.h" \
    MAKEOVERRIDES= \
    -f libgcc.mk install
    make[3]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6-build/gcc'
    for d in libgcc; do \
    if [ -d $d ]; then true; else /bin/sh /home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6/gcc/mkinstalldirs $d; fi; \
    done
    if [ -f stmp-dirs ]; then true; else touch stmp-dirs; fi
    /usr/bin/install -c -m 644 ./libgcc.a /home/freetz/freetz-stable-1.1/toolchain/build/gcc-3.4.6/mipsel-unknown-linux-gnu/lib/gcc/mipsel-unknown-linux-gnu/3.4.6/
    mipsel-unknown-linux-gnu-ranlib /home/freetz/freetz-stable-1.1/toolchain/build/gcc-3.4.6/mipsel-unknown-linux-gnu/lib/gcc/mipsel-unknown-linux-gnu/3.4.6/libgcc.a
    make[3]: mipsel-unknown-linux-gnu-ranlib: Kommando nicht gefunden
    make[3]: *** [install] Fehler 127
    make[3]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6-build/gcc'
    make[2]: *** [install-libgcc] Fehler 2
    make[2]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6-build/gcc'
    make[1]: *** [install-gcc] Fehler 2
    make[1]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/source/toolchain/kernel/gcc-3.4.6-build'
    make: *** [/home/freetz/freetz-stable-1.1/toolchain/build/gcc-3.4.6/mipsel-unknown-linux-gnu/bin/mipsel-unknown-linux-gnu-gcc] Fehler 2
  16. #16
    IPPF-Fan
    Registriert seit
    24.02.2006
    same error....
  17. #17
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Did anybody write that the error was fixed in the stable branch!? Although it has nothing to do with tcpdump.
    Regards
    Oliver
    Spenden für Freetz
  18. #18
    IPPF-Fan
    Registriert seit
    24.02.2006
    i think not fixed...
    how component i must deselect to compile without error please?
  19. #19
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    In r5268 I merged some Changesets concerning toolchain fixes. Please do svn up, make dirclean and start from the beginning. Is your problem solved?
    Regards
    Oliver
    Spenden für Freetz
  20. #20
    IPPF-Fan
    Registriert seit
    24.02.2006
    Checked out revision 5274.
    make clean;make menuconfig;make
    i get
    /home/freetz/freetz-stable-1.1/freetz-stable-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -shared -o ../../.ext/mipsel-linux/curses.so curses.o -L. -L../.. -L. -rdynamic -Wl,-export-dynamic -lruby -lncurses -lrt -ldl -lcrypt -lm -lc
    make[2]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/freetz-stable-1.1/source/ruby-1.8.6-p368/ext/curses'
    compiling dbm
    make[2]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.1/freetz-stable-1.1/source/ruby-1.8.6-p368/ext/dbm'
    make[2]: *** Keine Targets. Schluss.
    make[2]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/freetz-stable-1.1/source/ruby-1.8.6-p368/ext/dbm'
    make[1]: *** [all] Fehler 1
    make[1]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.1/freetz-stable-1.1/source/ruby-1.8.6-p368'
    make: *** [source/ruby-1.8.6-p368/ruby] Fehler 2
    maybe after dirclean worl i must check
    Geändert von vpe (20.07.2010 um 13:41 Uhr)
Ähnliche Themen
  1. Freetz stable tcpdump error
    Von mcblack im Forum Freetz
    Antworten: 16
    Letzter Beitrag: 21.06.2010, 12:19
  2. Compile Error: OpenSSL (trunk 3710)
    Von danage im Forum Freetz
    Antworten: 22
    Letzter Beitrag: 07.10.2009, 11:39
  3. quagga compile error ?!
    Von markusbab im Forum Freetz
    Antworten: 3
    Letzter Beitrag: 11.03.2009, 12:16
  4. [gelöst] Zaptel Compile Error mit OpenSuse 10.3
    Von hamuch im Forum Asterisk ISDN mit Bristuff (hfc, zaptel)
    Antworten: 3
    Letzter Beitrag: 11.11.2007, 17:22
  5. compile error ?
    Von reiner_hohn im Forum Asterisk Allgemein
    Antworten: 1
    Letzter Beitrag: 16.10.2006, 07:05
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
