Dies ist der log über adb logcat, wenn ich versuche mich über das Mobile Internet zu verbinden:
D/VPN_Connections( 5054): vpnc still trying to connect. Will check again in 500
milliseconds
D/VPN_Connections( 5054): Read vpnc process line as root 5347 5346 1272
660 c00d48d4 afe0d7fc S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 5054): Read vpnc process id as 5347
milliseconds
664 c00d48d4 afe0d7fc S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
D/dalvikvm( 5054): GC freed 8778 objects / 552576 bytes in 50ms
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
I/power ( 1287): *** set_screen_state 0
D/SurfaceFlinger( 1287): About to give-up screen, flinger = 0x126400
D/Sensors ( 1287): using accelerometer (name=accelerometer)
W/SSM ( 1061): no ack
D/VPN_Connections( 5054): Monitoring will not start
D/ThumbnailIntentReceiver( 3791): received Intent android.intent.action.SCREEN_O
FF, mGalleryRunning is false
D/ViewFlipper( 1368): updateRunning() mVisible=false, mStarted=true, mUserPresen
t=false, mRunning=false
milliseconds
milliseconds
milliseconds
milliseconds
milliseconds
D/VPN_Connections( 5054): process stderr: no response from target
D/VPN_Connections( 5054): Read vpnc process line as null
D/VPN_Connections( 5054): Attempt to read vpnc process id did not return anythin
g
D/VPN_Connections( 5054): process had died, return as failed connection
Dies ist der Code, wenn ich über mein WLAN versuche VPN aufzubauen:
[D/VPN_Connections( 5054): long press handler, handling the choice
D/VPN_Connections( 5054): NetworkDatabase:singleNetwork - Start
D/dalvikvm( 3797): GC freed 2549 objects / 139032 bytes in 264ms
D/VPN_Connections( 5054): Enter IPSec gateway address:
D/VPN_Connections( 5054): IP .dyndns.org
D/VPN_Connections( 5054): Enter IPSec ID for .dyndns.org:
D/VPN_Connections( 5054): group id: benutzer@firma
D/VPN_Connections( 5054): Enter IPSec secret for
D/VPN_Connections( 5054): group pwd
D/VPN_Connections( 5054): Enter username for .dyndns.org:
D/VPN_Connections( 5054): user
D/VPN_Connections( 5054): Enter password for s.dyndns.org:
D/VPN_Connections( 5054): password **************
D/VPN_Connections( 5054): done interacting with vpnc
D/VPN_Connections( 5054): Read vpnc process line as root 5695 5694 1328
516 c00d48d4 afe0cb24 S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 5054): Read vpnc process id as 5695
milliseconds
D/VPN_Connections( 5054): Read vpnc process line as root 5695 5694 1268
604 c00d48d4 afe0d7fc S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
milliseconds
D/VPN_Connections( 5054): Read vpnc process line as root 5695 5694 1272
656 c00d48d4 afe0d7fc S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
milliseconds
milliseconds
milliseconds
milliseconds
D/VPN_Connections( 5054): process stdout: backing up dns settings
D/VPN_Connections( 5054): vpnc-script ran to completion
D/VPN_Connections( 5054): process stderr: /data/data/org.codeandroid.vpnc_fronte
nd/files/vpnc-script: cannot create /sys/devices/platform/leds-microp/leds/blue/
brightness: directory nonexistent
D/VPN_Connections( 5054): ip: invalid argument 'wifi' to 'table ID'
D/VPN_Connections( 5054): ip: invalid argument 'gprs' to 'table ID'
D/VPN_Connections( 5054): vpnc[5695]: can't open pidfile /var/run/vpnc/pid for w
riting
D/VPN_Connections( 5054): Connect string detected!
I/global ( 5054): Default buffer size used in BufferedReader constructor. It wo
uld be better to be explicit if an 8k-char buffer is required.
D/VPN_Connections( 5054): Monitoring is enabled and we should be connected to vp
n connection #1
D/VPN_Connections( 5054): Will connect to service
D/VPN_Connections( 5054): MonitorServiceImpl.CTR()
D/VPN_Connections( 5054): MonitorServiceImpl.onCreate()
D/VPN_Connections( 5054): MonitorService.startMonitor called
D/VPN_Connections( 5054): Found a vpn id, will monitor it
D/VPN_Connections( 5054): MonitorServiceImpl.onStart()
D/VPN_Connections( 5054): onBind called on MonitorService for intent with action
of org.codeandroid.vpnc_frontend.MonitorServiceImpl
D/VPN_Connections( 5054): Connected to monitor service
W/InputManagerService( 1287): Window already focused, ignoring focus gain of: co
m.android.internal.view.IInputMethodClient$Stub$Proxy@4505c6c8
704 c00d48d4 afe0cb24 S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 5054): Monitor service: We're still connected
Also ich habe immer dieser Fehler dort stehen. Kann mir jemand sagen, woran das liegt?
