[v0.7.4.1] [bug 0000361]Monitor Verbindung weg nach suspend to RAM
RSchnauzer
11 Apr 2006
bei mir ist die Monitor Verbindung (rot) weg, obwohl die Verbindung zur FB (grün) aktiv ist Das Ganze scheint nach Fehlern beim suspend to RAM zu passieren. Anbei der Ausschnitt aus der debug.log
(26.11.10 14:25:54): STANDBY or SUSPEND TO RAM detected
java.net.NoRouteToHostException: No route to host: connect
    at java.net.PlainSocketImpl.socketConnect(Native Method)
    at java.net.PlainSocketImpl.doConnect(Unknown Source)
    at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
    at java.net.PlainSocketImpl.connect(Unknown Source)
    at java.net.SocksSocketImpl.connect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at sun.net.NetworkClient.doConnect(Unknown Source)
    at sun.net.www.http.HttpClient.openServer(Unknown Source)
    at sun.net.www.http.HttpClient.<init>(Unknown Source)
    at sun.net.www.http.HttpClient.New(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
    at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
    at de.moonflower.jfritz.utils.JFritzUtils.fetchDataFromURLToVector(JFritzUtils.java:192)
    at de.moonflower.jfritz.box.fritzbox.FritzBox.getQueryNew(FritzBox.java:525)
    at de.moonflower.jfritz.box.fritzbox.FritzBox.getQuery(FritzBox.java:288)
    at de.moonflower.jfritz.box.fritzbox.FritzBox.getCallerListFromBox(FritzBox.java:1006)
    at de.moonflower.jfritz.box.fritzbox.FritzBox.getCallerList(FritzBox.java:991)
    at de.moonflower.jfritz.box.BoxCommunication.getCallerList(BoxCommunication.java:110)
    at de.moonflower.jfritz.JFritzWindow$6.construct(JFritzWindow.java:844)
    at de.moonflower.jfritz.utils.SwingWorker$2.run(SwingWorker.java:112)
    at java.lang.Thread.run(Unknown Source)
(26.11.10 15:35:36): STANDBY or SUSPEND TO RAM detected
(26.11.10 15:35:56): Saving to file C:\WINNT\Profiles\xxxx\Application Data\JFritz\jfritz.calls.xml
Exception in thread "FBoxThread" java.lang.NullPointerException
    at de.moonflower.jfritz.struct.Call.equals(Call.java:105)
    at de.moonflower.jfritz.monitoring.CurrentCallsTable.endOfCall(CurrentCallsTable.java:113)
    at de.moonflower.jfritz.callmonitor.CallMonitorList.invokeDisconnectCall(CallMonitorList.java:248)
    at de.moonflower.jfritz.callmonitor.CallMonitorList.removeCall(CallMonitorList.java:121)
    at de.moonflower.jfritz.callmonitor.FBoxCallMonitorV3.parseOutput(FBoxCallMonitorV3.java:168)
    at de.moonflower.jfritz.callmonitor.FBoxCallMonitorV3.parseOutput(FBoxCallMonitorV3.java:43)
    at de.moonflower.jfritz.callmonitor.FBoxCallMonitor.readOutput(FBoxCallMonitor.java:135)
    at de.moonflower.jfritz.callmonitor.FBoxCallMonitorV3.run(FBoxCallMonitorV3.java:38)
(26.11.10 15:55:56): Saving to file C:\WINNT\Profiles\xxxx\Application Data\JFritz\jfritz.calls.xml
(26.11.10 17:34:55): Saving to file C:\WINNT\Profiles\xxxx\Application Data\JFritz\jfritz.calls.xml
Nach jfritz.exe process kill mit Taskmonitor und Restart ist alles wieder aktiv (grün)
Bug ist bisher untergegangen, habe ihn nun im Bugtracker eingetragen und werde es mir demnächst genauer anschauen.
Vielen Dank für die Meldung!
