Danke für den Hinweis!! Dann hier mal meine cfg Dateien
diese cfg ist im programm fritz fernzugang auf meinen laptop
* C:\Users\Elbor\AppData\Roaming\AVM\FRITZ!Fernzugang\meine_dyndns_org\meine_gmx_net\vpnuser_meine_gmx_net.cfg
* Sun Dec 12 08:56:56 2010
version {
revision = "$Revision: 1.30 $";
creatversion = "1.1";
pwcheck {
datapipecfg {
security = dpsec_quiet;
icmp {
ignore_echo_requests = no;
destunreach_rate {
burstfactor = 6;
timeout = 1;
timeexceeded_rate {
burstfactor = 6;
timeout = 1;
echoreply_rate {
burstfactor = 6;
timeout = 1;
masqtimeouts {
tcp = 15m;
tcp_fin = 2m;
tcp_rst = 3s;
udp = 5m;
icmp = 30s;
got_icmp_error = 15s;
any = 5m;
tcp_connect = 6m;
tcp_listen = 2m;
ipfwlow {
input {
output {
ipfwhigh {
input {
output {
NAT_T_keepalive_interval = 20;
targets {
policies {
name = "meine.dyndns.org";
connect_on_channelup = no;
always_renew = no;
reject_not_encrypted = no;
dont_filter_netbios = yes;
localip = 0.0.0.0;
virtualip = 192.168.177.199;
remoteip = 0.0.0.0;
remotehostname = "meine.dyndns.org";
localid {
user_fqdn = "meine@gmx.net";
mode = mode_aggressive;
phase1ss = "all/all/all";
keytype = keytype_pre_shared;
key = "97ece0=Z14o7ec7c0I93bee3fc&afa2217";
cert_do_server_auth = no;
use_nat_t = yes;
use_xauth = no;
use_cfgmode = no;
phase2localid {
ipaddr = 192.168.177.199;
phase2remoteid {
ipnet {
ipaddr = 192.168.177.1;
mask = 255.255.255.255;
phase2ss = "esp-all-all/ah-none/comp-all/pfs";
accesslist = "permit ip any 192.168.177.1 255.255.255.255";
wakeupremote = no;
policybindings {
// EOF
hier die cfg auf der FB
* C:\Users\Elbor\AppData\Roaming\AVM\FRITZ!Fernzugang\meine_dyndns_org\fritzbox_meine_dyndns_org.cfg
vpncfg {
connections {
enabled = yes;
conn_type = conntype_user;
name = "meine@gmx.net";
always_renew = no;
localip = 0.0.0.0;
local_virtualip = 0.0.0.0;
remoteip = 0.0.0.0;
remote_virtualip = 192.168.177.199;
remoteid {
mode = phase1_mode_aggressive;
keytype = connkeytype_pre_shared;
use_nat_t = yes;
use_xauth = no;
use_cfgmode = no;
phase2localid {
ipnet {
phase2remoteid {
accesslist =
"permit ip 192.168.177.1 255.255.255.255 192.168.177.199 255.255.255.255";
ike_forward_rules = "udp 0.0.0.0:500 0.0.0.0:500",
"udp 0.0.0.0:4500 0.0.0.0:4500";
// EOF
