Ergebnis 1 bis 10 von 10
Thema: Installing Freetz trunk (7635) on 7170, no Freetz webinterface
  1. #1
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    Hi Experts,
    These are my first steps with Freetz.
    I’m trying to create an image for my 7170, a test router not connected to my ADSL line.
    I used the following commands:
    svn co http://svn.freetz.org/trunk/ freetz-trunk
    mv freetz-trunk/ freetz-trunk-7635
    cd freetz-trunk-7635
    make menuconfig > selected “Fon WLAN 7170”, “Firmware language (en - international)” and “Annex (A)”
    make
    Which resulted in: -rw-r--r-- 1 user users 7499776 2011-09-17 22:07 7170_04.84freetz-devel-7635.en_20110917-220645.image
    I uploaded this image via the webinterface which seem to be successful (blinking Info for ~30 sec followed by a reset).
    The normal Fritz!box webinterface (http://fritz.box) is normally working, but the Freetz webinterface (http://fritz.box:81) is not.
    Any idea what I’m missing here? Can I verify if my image is successfully installed (e.g. via telnet)?
    Below the output of ps and dmesg:
    # ps
      PID  Uid        VSZ Stat Command
        1 root       1308 S   init
        2 root            SWN [ksoftirqd/0]
        3 root            SW< [events/0]
        4 root            SW< [khelper]
        5 root            SW< [kthread]
        6 root            SW< [kblockd/0]
       23 root            SW< [pdflush]
       24 root            SW< [pdflush]
       26 root            SW< [aio/0]
       25 root            SW  [kswapd0]
       62 root            SW  [pm_info]
       66 root            SW< [CPMAC]
       70 root            SW  [mtdblockd]
       96 root            SW  [tffsd_mtd_0]
      215 root            SWN [jffs2_gcd_mtd6]
      243 root            SW< [capi_oslib]
      244 root            SW< [capi_oslib]
      245 root            SW  [capitransp]
      267 root            SW< [khubd]
      321 root       8616 S N ctlmgr
      347 root       1968 S   wpa_authenticator
      352 root       8616 S N ctlmgr
      353 root       8616 R N ctlmgr
      354 root       8616 S N ctlmgr
      355 root       8616 S N ctlmgr
      356 root       8616 S N ctlmgr
      390 root       4540 S   upnpd
      396 root       3236 S   multid
      400 root       3540 S   dsld -i -n
      405 root       2640 S   usermand
      415 root       1312 S   telnetd -l /sbin/ar7login
      416 root       5388 S   telefon a127.0.0.1
      420 root       4748 S < voipd
      425 root       2900 S   pbd
      428 root       2900 S   pbd
      431 root       2900 S   pbd
      432 root       2900 S   pbd
      435 root        860 S   /bin/run_clock -c /dev/tffs -d
      444 root       1308 S   init
      445 root       3236 S   multid
      450 root       4540 S   upnpd
      451 root       4540 S   upnpd
      452 root       4540 S   upnpd
      453 root       1328 S   -sh
      662 root       1312 R   ps
    # dmesg
    Linux version 2.6.13.1-ohio (2953) (gcc-Version 3.4.6) #1 Mon Feb 7 10:19:51 CET 2011
    memsize=32 MByte
    flashsize=8 MByte
    &_end=0x94247784 PFN_ALIGN(&_end)=0x94248000 CPHYSADDR(PFN_ALIGN(&_end))=0x14248000 memsize=0x2000000
    CPU revision is: 00018448
    [ohio_gpio_init]
    Determined physical RAM map:
     memory: 00248000 @ 14000000 (reserved)
     memory: 01db8000 @ 14248000 (usable)
    On node 0 totalpages: 8192
    [alloc_node_mem_map] reduce size from 2883616 Bytes to  262176 Bytes
    [alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x9424b000-0x9428b020
    [alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fcb000-0x9428b020
    zone=0 zone_size[j]=0x90112
    realsize=8192
      DMA zone: 8192 pages, LIFO batch:3
    zone=1 zone_size[j]=0x0
    realsize=0
      Normal zone: 0 pages, LIFO batch:1
    zone=2 zone_size[j]=0x0
    realsize=0
      HighMem zone: 0 pages, LIFO batch:1
    Built 1 zonelists
    Kernel command line:  console=ttyS0,38400n8r
    [ld_mmu_r4xx0] memcpy((void *)(CAC_BASE   + 0x100), &except_vec2_generic, 0x30)
    Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
    Primary data cache 8kB, 4-way, linesize 16 bytes.
    Synthesized TLB refill handler (20 instructions). Base=0x9420a8ac
    TLB synthesizer field overflow (simm)
    Synthesized TLB load handler fastpath (34 instructions) Base=0x9420e620.
    Synthesized TLB store handler fastpath (34 instructions) Base=0x9420e820.
    Synthesized TLB modify handler fastpath (33 instructions) Base=0x9420ea20.
    PID hash table entries: 256 (order: 8, 4096 bytes)
    CPU frequency 211.97 MHz
    Using 105.984 MHz high precision timer.
    [setup_irq]: irq 255 irqaction->handler 0x940430e0 (no_action+0x0/0x8 )
    [register_console] enable commandline console 0
    Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Memory: 30080k/30432k available (1593k kernel code, 320k reserved, 387k data, 116k init, 0k highmem)
    totalram_pages= 7528
    Calibrating delay loop... 211.35 BogoMIPS (lpj=1056768)
    loops_per_jiffy=1056768
    Mount-cache hash table entries: 512
    Checking for 'wait' instruction...  available.
    Calling initcall 0x941fe27c: helper_init+0x0/0x30()
    Calling initcall 0x941fe53c: ksysfs_init+0x0/0x3c()
    Calling initcall 0x94200468: filelock_init+0x0/0x48()
    Calling initcall 0x94200d88: init_script_binfmt+0x0/0xc()
    Calling initcall 0x94200d94: init_elf_binfmt+0x0/0xc()
    Calling initcall 0x94205c70: netlink_proto_init+0x0/0x2ac()
    NET: Registered protocol family 16
    Calling initcall 0x9420161c: kobject_uevent_init+0x0/0x50()
    Calling initcall 0x942018a4: tty_class_init+0x0/0x34()
    Calling initcall 0x941f52c4: frame_info_init+0x0/0xb4()
    Can't analyze prologue code at 9418caa4
    Calling initcall 0x94200158: init_bio+0x0/0x17c()
    Calling initcall 0x94201f50: misc_init+0x0/0xc0()
    Calling initcall 0x94203b18: genhd_device_init+0x0/0x44()
    Calling initcall 0x94204230: init_mtd+0x0/0x48()
    Calling initcall 0x94204e40: input_init+0x0/0x1e0()
    Calling initcall 0x94205378: proto_init+0x0/0x48()
    Calling initcall 0x9420553c: net_dev_init+0x0/0x1dc()
    Calling initcall 0x94205b68: pktsched_init+0x0/0xc8()
    Calling initcall 0x94205c3c: tc_filter_init+0x0/0x34()
    Calling initcall 0x942003bc: init_pipe_fs+0x0/0x6c()
    Calling initcall 0x94201734: chr_dev_init+0x0/0xb4()
    Calling initcall 0x941fd8a4: create_proc_profile+0x0/0x64()
    Calling initcall 0x941fd984: ioresources_init+0x0/0xc4()
    Calling initcall 0x941fdb90: uid_cache_init+0x0/0x88()
    Calling initcall 0x941fdf6c: param_sysfs_init+0x0/0x208()
    Calling initcall 0x941fe174: init_posix_timers+0x0/0x108()
    Calling initcall 0x941fe2ac: init_posix_cpu_timers+0x0/0xd4()
    Calling initcall 0x941fe4fc: kallsyms_init+0x0/0x40()
    Calling initcall 0x941ff7b4: init_per_zone_pages_min+0x0/0x64()
    Calling initcall 0x941ffbf8: pdflush_init+0x0/0x28()
    Calling initcall 0x941ffc20: cpucache_init+0x0/0x20()
    Calling initcall 0x941fff6c: kswapd_init+0x0/0x70()
    Calling initcall 0x94200020: procswaps_init+0x0/0x40()
    Calling initcall 0x94200060: init_tmpfs+0x0/0x3c()
    Calling initcall 0x94200428: fasync_init+0x0/0x40()
    Calling initcall 0x94200b2c: aio_setup+0x0/0x8c()
    Calling initcall 0x94200bb8: inotify_setup+0x0/0xf4()
    Calling initcall 0x94200cac: eventpoll_init+0x0/0xdc()
    Calling initcall 0x942012e4: init_devpts_fs+0x0/0x48()
    Calling initcall 0x9420132c: init_squashfs_fs+0x0/0xe4()
    Squashfs 2.2-r2b (released 2006/02/23) (C) 2002-2005 Phillip Lougher
    Calling initcall 0x94201410: init_ramfs_fs+0x0/0xc()
    Calling initcall 0x94201428: ipc_init+0x0/0x30()
    Calling initcall 0x942017e8: rand_initialize+0x0/0x3c()
    Calling initcall 0x942018d8: tty_init+0x0/0x184()
    Calling initcall 0x94201a5c: pty_init+0x0/0x4f4()
    Calling initcall 0x94202010: avm_net_trace_init+0x0/0x80()
    avm_net_trace: Up and running.
    Calling initcall 0x94202090: avm_power_init+0x0/0x190()
    [avm_power]Ohio250 detected -> overclocking possible
    Calling initcall 0x94202220: avm_sammel_init+0x0/0x158()
    [avm] configured: watchdog eventled enable shift register enable direct gpio
            gpio usage: reset=12 clock=13 store=10 data=9
    AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Feb  7 2011 10:17:13)
    Calling initcall 0x94203168: serial8250_init+0x0/0x10c()
    Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
    [uart_add_one_port]
    ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
    [uart_add_one_port] dont register console port->type = 16
    port->cons = 0x941ce340 port->cons->flags = 0x7
    [uart_add_one_port] success
    Calling initcall 0x94203b5c: noop_init+0x0/0xc()
    io scheduler noop registered
    Calling initcall 0x94203b68: cpphy_entry_probe+0x0/0x440()
    [cpmac] Version: 1.128  -  Revision 790:974  -  Mo   7.02.2011  10:18:34
    [avm_event_source_trigger]: not registered
    [cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
    Calling initcall 0x94204038: net_olddevs_init+0x0/0x100()
    Calling initcall 0x942041a0: tun_init+0x0/0x90()
    tun: Universal TUN/TAP device driver, 1.6
    tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    Calling initcall 0x94204278: cmdline_parser_init+0x0/0xc()
    Calling initcall 0x94204284: init_mtdchar+0x0/0xc0()
    Calling initcall 0x94204344: init_mtdblock+0x0/0xc()
    Calling initcall 0x94204350: cfi_probe_init+0x0/0x24()
    Calling initcall 0x94204374: cfi_amdstd_init+0x0/0x30()
    Calling initcall 0x942043a4: cfi_intelext_init+0x0/0x4c()
    Calling initcall 0x942043f0: jedec_probe_init+0x0/0x24()
    Calling initcall 0x94204414: map_ram_init+0x0/0x24()
    Calling initcall 0x94204438: init_physmap+0x0/0x170()
    physmap flash device: 400000 at 10000000
    phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
     Amd/Fujitsu Extended Query Table at 0x0040
    phys_mapped_flash: Swapping erase regions for broken CFI table.
    number of CFI chips: 1
    RedBoot partition parsing not available
    Calling initcall 0x942045a8: platram_init+0x0/0x30()
    Generic platform RAM MTD, (c) 2004 Simtec Electronics
    Calling initcall 0x942045d8: init_ohio_flash+0x0/0x868()
    Ohio flash driver (size->0x400000 mem->0x10000000)
    flash_size=0x800000
    flash_mask=0xffffff
    Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
    [genprobe_ident_chips] 4 i 0 j 0
    [genprobe_ident_chips] 5 i 0 j 1
    Ohio flash memory: Swapping erase regions for broken CFI table.
    [mtd]: jffs2_size = 16 * 64KByte (0x100000 Bytes)
    [ohio_find_hidden_filesystem]: super block found: bytes_used: 0x5c1a26/6036006
    [init_ohio_flash] find hidden filesystem size=0x6c7d00 offset=0xb8300
    [mtd] configure jffs2 partition
    [mtd] fs_size=0x670000 max=0x100000 is=0x100000 max jffs2_size value 16
    [mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=0x10000000 size=0x800000
    Creating 7 MTD partitions on "Ohio flash memory":
    0x000b8300-0x00780000 : "filesystem"
            'nor-flash'
            'Bits can be cleared (flash)'
            'Has an erase function'
    mtd: partition "filesystem" doesn't start on an erase block boundary -- force read-only
    0x00010000-0x00780000 : "kernel"
            'nor-flash'
    0x00000000-0x00010000 : "bootloader"
            'nor-flash'
    0x00780000-0x007c0000 : "tffs (1)"
            'nor-flash'
    0x007c0000-0x00800000 : "tffs (2)"
            'nor-flash'
    0x00680000-0x00780000 : "jffs2"
            'nor-flash'
    0x00010000-0x00680000 : "Kernel without jffs2"
            'nor-flash'
    partition_info[0]: name=filesystem offset=b8300 size=6c7d00
    partition_info[0]: 0xb00b8300: 0x73717368 0x8b5
    partition_info[1]: name=kernel offset=10000 size=770000
    partition_info[1]: 0xb0010000: 0xfeed1281 0xa8271
    partition_info[2]: name=bootloader offset=0 size=10000
    partition_info[2]: 0xb0000000: 0x40809000 0x40809800
    partition_info[3]: name=tffs (1) offset=780000 size=40000
    partition_info[3]: 0xb0780000: 0x40001 0x89fbffff
    partition_info[4]: name=tffs (2) offset=7c0000 size=40000
    partition_info[4]: 0xb07c0000: 0x40001 0x88fbffff
    partition_info[5]: name=jffs2 offset=680000 size=100000
    partition_info[5]: 0xb0680000: 0x20031985 0xc
    partition_info[6]: name=Kernel without jffs2 offset=10000 size=670000
    partition_info[6]: 0xb0010000: 0xfeed1281 0xa8271
    Calling initcall 0x94205020: kcapi_init+0x0/0x9c()
    Calling initcall 0x94205164: capi_oslib_init+0x0/0x8()
    Calling initcall 0x94205c30: blackhole_module_init+0x0/0xc()
    Calling initcall 0x94206920: inet_init+0x0/0x504()
    NET: Registered protocol family 2
    IP route cache hash table entries: 512 (order: -1, 2048 bytes)
    TCP established hash table entries: 2048 (order: 2, 16384 bytes)
    TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
    TCP: Hash tables configured (established 2048 bind 2048)
    TCP reno registered
    Calling initcall 0x94209338: init+0x0/0x8()
    Calling initcall 0x94209340: bictcp_register+0x0/0xc()
    TCP bic registered
    Calling initcall 0x9420934c: mcfw_init_module+0x0/0x2c()
    mcfw: IGMPv3 fast forwarding
    Calling initcall 0x94209378: af_unix_init+0x0/0xa0()
    Calling initcall 0x94209418: packet_init+0x0/0x80()
    NET: Registered protocol family 17
    Calling initcall 0x94209498: br_init+0x0/0x68()
    Calling initcall 0x94209554: atm_init+0x0/0xec()
    NET: Registered protocol family 8
    NET: Registered protocol family 20
    Calling initcall 0x942096f8: br2684_init+0x0/0x54()
    Calling initcall 0x941f4024: ohio_install_dummy_irq_functions+0x0/0x58()
    [setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
    [setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
    Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
    [ohio_late_init]
    Calling initcall 0x941f4160: ohio_clk_switch_init+0x0/0x60()
    Calling initcall 0x941f43dc: speedup_init+0x0/0x3c()
    Calling initcall 0x94201824: seqgen_init+0x0/0x20()
    Calling initcall 0x940cef50: avm_event_push_button_init+0x0/0x130()
    [avm_new] push_button_gpio=8 value=1 enabled
    Calling initcall 0x942029dc: tffs_init+0x0/0x224()
    TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
          mount on mtd4 and mtd5 (double buffering)
    Adam2 environment variables API installed.
    Calling initcall 0x9420382c: early_uart_console_switch+0x0/0xb4()
    Calling initcall 0x9412c148: net_random_reseed+0x0/0x34()
    Calling initcall 0x94207e40: ip_auto_config+0x0/0x1120()
    [prepare_namespace] new mount root /dev/mtdblock1
    use lzma compression
    VFS: Mounted root (squashfs filesystem) readonly.
    Freeing prom memory: 0kb freed
    Freeing unused kernel memory: 116k freed (7557 free)
    [setup_irq]: irq 15 irqaction->handler 0x940db17c (serial8250_interrupt+0x0/0x13c )
    AR7WDT: System Init UEberwachung 240 Sekunden
    TFFS Name Table G
    Piglet: module license '
    (C) Copyright 2005 by AVM
    ' taints kernel.
    EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
    [piglet]McSP: rFS: 8000 Hz rCLK:2048215 Hz
    [avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=5250 key=button_key_2
    JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
    registered device TI Avalanche SAR
    tiatm driver (patch_annex=0xc00e42ec)
    [tiatm] Set StrictPriority=0
    DSP binary filesize = 389522 bytes
    [dsl_ur8] dsl serial number successfully set to "465249545a21426f78466f6e574c414e37313730303031463346414530344143"
    [tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
    [avm_power]#### boostVoltage: DSP Core voltage set to 1,5 V ####
    [setup_irq]: irq 23 irqaction->handler 0xc00ca208 (tn7atm_sar_irq+0x0/0x50 [tiatm] )
    [setup_irq]: irq 31 irqaction->handler 0xc00ca258 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
    [tiatm]: Powermanagment (States => 1,3,10) supported!
    [tiatm] AvmInterface length: 44
    [avm_power]#### boostVoltage: DSP Core voltage set to 1,65 V ####
    Texas Instruments ATM driver: version:[4.08.02.01]
    ubik2 driver (ubik2 - 0x10=0xc003efd4)
    atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc002cbfc
    atm_dsp_register_ubik2: dsp mem pointer 0xa1c1644c
    ubik2_init_interface: DSP-Link Version v3 8480
    [ubik2_debug] eof_sync =1
  2. #2
    Semi-Moderator Avatar von olistudent
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Flashing your new image did not succeed. The output of ps doesn't show anything different from an original AVM firmware.
    Regards
    Oliver
    Router: Fritz!Box Fon WLAN 7570, 7390, 7320, 7270, 3170
    Anbindung: T-Online DSL 16.000 RAM
    Visit ##fritzbox on Freenode for help
    Spenden für Freetz
  3. #3
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    Oliver,
    Thanks for your reply.
    I verified the md5 outcome of the image in ./freetz-trunk-7635/images/ and the one I used for flashing, they are the same.
    So I have to look further...I didn't see errors during make. Below Step 1 to 3 of make.
    Can I see from the LED behavior to get a better understanding what goes wrong?
    I ordered a Data cable that probably arrives in a week or two, which hopefully gives more info what happens during flashing.
    STEP 1: UNPACK
    unpacking firmware image
    splitting kernel image
    unpacking filesystem image
        2110 inodes (2288 blocks) to write
        created 1553 files
        created 119 directories
        created 247 symlinks
        created 310 devices
        created 0 fifos
    unpacking var.tar
    done.
    STEP 2: MODIFY
    applying symlinks, deleting additional webinterfaces in: usr/www
    applying patches
      applying patches (7170-en)
        applying patch file ./patches/110-multid-wait.patch
        patching file etc/init.d/rc.net
        Hunk #1 succeeded at 66 with fuzz 1 (offset -2 lines).
        applying patch file ./patches/110-system_status.patch
        patching file usr/bin/system_status
        applying patch file ./patches/7170/110-rc.S-mknod.patch
        patching file etc/init.d/rc.S
        Hunk #1 succeeded at 195 (offset -23 lines).
        applying patch file ./patches/7170/120-rc.S-dev.patch
        applying patch file ./patches/7170/130-rc.S-logging.patch
        applying patch file ./patches/7170/140-rc.S-no_avm_exit.patch
        Hunk #1 succeeded at 1578 (offset -416 lines).
        applying patch file ./patches/7170/290-replace_websrv-remove_igdd.patch
        Hunk #1 succeeded at 52 (offset -2 lines).
        Hunk #2 succeeded at 298 (offset -13 lines).
        applying patch file ./patches/7170/301-remove_smbd.patch
        Hunk #1 succeeded at 66 (offset -2 lines).
        Hunk #2 succeeded at 311 (offset -16 lines).
        applying patch file ./patches/7170/en/190-webmenu.patch
        patching file usr/www/all/html/de/menus/menu2_homehome.html
        patching file usr/www/all/html/de/menus/menu2_konfig.html
        applying patch file ./patches/7170/en/200-sperre1.patch
        patching file usr/www/all/html/de/fon/sperre1.js
      creating symlinks /tmp, /mod and /home
      creating /mnt and /opt
      setting freetz-version 'freetz-devel-7635'
      setting subversion 'freetz-devel-7635'
        applying patch file ./patches/100-3170_7170.sh
        applying patch file ./patches/100-7112_7170.sh
        applying patch file ./patches/100-7113_7170.sh
        applying patch file ./patches/100-7140_7170.sh
        applying patch file ./patches/100-7141_7170.sh
        applying patch file ./patches/100-7240_7270.sh
        applying patch file ./patches/100-7270v1_7270.sh
        applying patch file ./patches/100-7570_IAD.sh
        applying patch file ./patches/100-W920_7570.sh
        applying patch file ./patches/100-enforce-urlader-settings.sh
        applying patch file ./patches/100-w701v_7170.sh
        applying patch file ./patches/100-w900v_7170.sh
        applying patch file ./patches/100_iad3331_7170.sh
        applying patch file ./patches/101-ctlmgr_wrapper.sh
        applying patch file ./patches/105-onlinechanged.sh
      patching /bin/onlinechanged
        applying patch file ./patches/109-rc.net-multid-wrapper.sh
      replacing multid by a wrapper
        patching build/modified/filesystem/etc/init.d/rc.net
        applying patch file ./patches/110-inittab.sh
        applying patch file ./patches/115-rc.S.sh
        applying patch file ./patches/116-usbroot_S46-usb.sh
        applying patch file ./patches/120-dev_led.sh
      applying /dev/led patch
        patching build/modified/filesystem/bin/update_led_on
        patching build/modified/filesystem/bin/update_led_off
        applying patch file ./patches/130-fstab.sh
        applying patch file ./patches/140-remove-uClibc.sh
        applying patch file ./patches/170-rename_ar7login.sh
      renaming ar7login to make way for wrapper script
        applying patch file ./patches/180-printk.sh
      applying printk patch
        patching build/modified/filesystem/etc/init.d/rc.S
        applying patch file ./patches/191-webmenu_wol.sh
        applying patch file ./patches/195-webmenu_signed.sh
        applying patch file ./patches/197-freetzmount.sh
      applying FREETZMOUNT patch
        patching build/modified/filesystem/etc/hotplug/storage
        patching build/modified/filesystem/etc/hotplug/run_mount
        patching run_mount script
        patching /etc/hotplug/storage
        applying patch file ./patches/198-usbroot.sh
        applying patch file ./patches/200-vcc.sh
        applying patch file ./patches/210-ata.sh
        applying patch file ./patches/210-enum.sh
        applying patch file ./patches/210-international.sh
        applying patch file ./patches/220-assistant.sh
        applying patch file ./patches/220-cdrom-iso.sh
        applying patch file ./patches/220-chronyd.sh
        applying patch file ./patches/220-help.sh
        applying patch file ./patches/220-remove-nas.sh
        applying patch file ./patches/230-openssl.sh
        applying patch file ./patches/240-add-dsl-expert-pages.sh
        applying patch file ./patches/250-remove_avm_inetd.sh
      removing AVM inetd
        rm build/modified/filesystem/bin/inetdctl
        rm build/modified/filesystem/etc/inetd.conf
        applying patch file ./patches/260-remove_tr069.sh
        applying patch file ./patches/270-remove_usb_module.sh
        applying patch file ./patches/275-multiple_printers.sh
        applying patch file ./patches/290-replace_websrv-remove_igdd.sh
        applying patch file ./patches/300-remove-smbd.sh
        applying patch file ./patches/310-remove_userman.sh
        applying patch file ./patches/320-remove-dsld.sh
        applying patch file ./patches/320-remove_capiotcp.sh
        applying patch file ./patches/330-remove-voip-isdn.sh
        applying patch file ./patches/331-remove-voipd.sh
        applying patch file ./patches/340-remove_dect_update.sh
        applying patch file ./patches/350-add_remove_annex_file.sh
        applying patch file ./patches/360-remove-wlan.sh
        applying patch file ./patches/370-remove_dtrace.sh
      removing dtrace file
        rm build/modified/filesystem/usr/bin/dtrace
        applying patch file ./patches/380-remove-umtsd.sh
        applying patch file ./patches/385-remove-ntfs.sh
        applying patch file ./patches/390-remove_util_linux.sh
        applying patch file ./patches/400-remove-inetdctl.sh
        applying patch file ./patches/401-remove_ftpd.sh
        applying patch file ./patches/410-remove_piglet.sh
        applying patch file ./patches/420-remove_printserv.sh
        applying patch file ./patches/460-MAXDEVCOUNT.sh
        applying patch file ./patches/470-volumecounter.sh
        applying patch file ./patches/480-alarmclock.sh
        applying patch file ./patches/500-remove-mediasrv.sh
        applying patch file ./patches/510-remove_aura_usb.sh
        applying patch file ./patches/510-remove_avm_vpn.sh
        applying patch file ./patches/510-remove_minid.sh
        applying patch file ./patches/520-remove_dect.sh
        applying patch file ./patches/530-remove_support.sh
        applying patch file ./patches/540-remove_webdav.sh
        applying patch file ./patches/550-add_reg_external_in_gui.sh
        applying patch file ./patches/560-remove_lsof.sh
        applying patch file ./patches/570-remove_strace.sh
        applying patch file ./patches/600-replace_mdev.sh
        applying patch file ./patches/700-add_bash_to_etc_shells.sh
        applying patch file ./patches/900-add_options_cfg.sh
      creating options.cfg
        by symlinking it to .config
        applying patch file ./patches/999-remove_run_clock.sh
      removing oem: none
    installing mod base
      installing libs
        ld_uClibc
        libcrypt
        libdl
        libfreetz
        libgcc_s
        libm
        libnsl
        libpthread
        librt
        libuClibc
    replacing busybox
      replacing busybox-8mb
      installing symlinks
    installing modules
      generating modules.dep
    installing packages
      syslogd-cgi-0.2.3
      inetd-0.2
      haserl-0.9.29
      mod-1.0
      modcgi-0.3
    invoking custom script
    processing mod base options
      setting colored style as default
      patching security level
      rc.external was not integrated into image
      integrating stripped .config file into image
    stripping leftover unstripped binaries
        build/modified/filesystem/lib/libled2.so.2.2.0
        build/modified/filesystem/lib/libpthread-0.9.29.so
        build/modified/filesystem/lib/libusbcfg.so.1.0.0
        build/modified/filesystem/lib/libacgenusb.so.1.0.0
        build/modified/filesystem/lib/libupnpdevusb.so.1.0.0
        build/modified/filesystem/usr/share/ctlmgr/libctlusb.so
    done.
    STEP 3: PACK
      checking for left over Subversion directories
      integrate freetz info file into image
    packing var.tar
    creating filesystem image
      squashfs blocksize: 65536
    merging kernel image
      kernel image size: 6718208 (max: 7798784, free: 1080576)
      Aproximately free time for the answering machine: 419s (6min 59s)
    packing 7170_04.84freetz-devel-7635.en_20110917-220645.image
    Image files can be found in the ./images/ subfolder
    done.
    FINISHED
  4. #4
    IPPF-Urgestein
    Registriert seit
    22.04.2007
    What did you do to flash the image into to box?
  5. #5
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    RalfFriedl,
    Thanks for your interest.
    Here the steps I used:
    Settings > System > Firmware Update > Firmware File
    Step 1: Save Settings
    Step 2: Selected firmware “7170_04.84freetz-devel-7635.en_20110917-220645.image” via the Browse button
    Step 3: Start Update button.
    After about 50 seconds get message “Attention! The specified file does not contain firmware released for this device by AVM. …..” >
    Selected “Continue Update” button
    Info blinking for about 30 seconds followed by all LEDs on for 1 second that all LEDs off followed by a reboot.
    I tried it a few times with each time the same result.
  6. #6
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    I installed freetz-linux under VirtualBox and re-build the image for my 7170 with the same selections (exept now with 7662), inside freetz-linux and this installed fine.
    Looks that I have to look more carefull at my first build environment...but guess I will use freetz-linux for now.
  7. #7
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    After receiving de Data cable I again tried to load the failed image, but I didn't recognize the error.
    Below the startup messages from the 7170. I did make a note when I got the request to continue with the not AVM released firmware.
    But I don't see where it goes wrong. The router did again came back online with the old existing image. I expected more details about the reason of the failure.
    But if someone sees where it goes wrong than please let me know.
      PID USER       VSZ STAT COMMAND
        1 root      1140 S    init
        2 root         0 SWN  [ksoftirqd/0]
        3 root         0 SW<  [events/0]
        4 root         0 SW<  [khelper]
        5 root         0 SW<  [kthread]
        6 root         0 SW<  [kblockd/0]
       23 root         0 SW<  [pdflush]
       24 root         0 SW<  [pdflush]
       26 root         0 SW<  [aio/0]
       25 root         0 SW   [kswapd0]
       62 root         0 SW   [pm_info]
       66 root         0 SW<  [CPMAC]
       70 root         0 SW   [mtdblockd]
       98 root         0 SW   [tffsd_mtd_0]
      334 root         0 SWN  [jffs2_gcd_mtd6]
      357 root         0 SW<  [capi_oslib]
      358 root         0 SW<  [capi_oslib]
      359 root         0 SW   [capitransp]
      380 root         0 SW<  [khubd]
      447 root      8776 S N  /usr/bin/ctlmgr.bin
      538 root      3056 S    multid
      581 root      1132 S    telnetd -l /sbin/ar7login
      582 root      5204 S    telefon a127.0.0.1
      595 root      2748 S    pbd
      596 root      2748 S    pbd
      601 root      2748 S    pbd
      602 root      2748 S    pbd
      605 root       696 S    /bin/run_clock -c /dev/tffs -d
      628 root      3056 S    multid
      766 root      1132 S    httpd-webcfg -P /var/run/webcfg.pid -p 81 -c /mod/et
      847 root      1132 S    inetd
      949 root      8776 S N  /usr/bin/ctlmgr.bin
      950 root      8776 S N  /usr/bin/ctlmgr.bin
      951 root      8776 S N  /usr/bin/ctlmgr.bin
      952 root      8776 S N  /usr/bin/ctlmgr.bin
      953 root      8776 S N  /usr/bin/ctlmgr.bin
     1021 root      2660 S    usermand
     1054 root       828 S    radvd -C /mod/etc/radvd.conf
     1245 root      1148 S    -/bin/sh
     1293 root      3908 S N  /cgi-bin/firmwarecfg
     1294 root      2748 S    pbd
     1295 root      1156 S N  /bin/sh /bin/prepare_fwupgrade start
     1297 root      1136 R N  ps
    Sat Jan  1 01:03:40 CET 2000
    /etc/hotplug/storage: line 250: led-ctrl: not found
    killall: ftpd: no process killed
    killall: smbd: no process killed
    rmmod: can't unload 'vfat': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'fat': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'nls_cp437': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'nls_iso8859_1': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'sd_mod': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'usb_storage': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'scsi_mod': unknown symbol in module, or unknown parameter
    AVM USB 1.1 Host stopped
    Sat Jan  1 01:03:47 CET 2000
        1 root      1140 S    init
      595 root      2752 S    pbd
      596 root      2752 S    pbd
      601 root      2752 S    pbd
      602 root      2752 S    pbd
     1294 root      2752 S    pbd
     1417 root      1136 R N  ps
    Sat Jan  1 01:03:48 CET 2000
    TERMINATING capiotcp_server pbd faxd telefon dtrace printserv smbd mailer
    Jan  1 01:03:48 pbd[595]: received signal: Terminated.
    Jan  1 01:03:48 pbd[595]: terminating.
    Jan  1 01:03:48 telefon[582]: SIGTERM received!
    Jan  1 01:03:48 telefon[582]: wdt release failed
    Sat Jan  1 01:03:51 CET 2000
    TERMINATING audiod pictured feedd playerd
    Sat Jan  1 01:03:52 CET 2000
    TERMINATING configd
    TERMINATING maild voipd usermand upnpd mediasrv avmlogd tr069discover avmike dsld
    Sat Jan  1 01:03:54 CET 2000
    Sat Jan  1 01:03:55 CET 2000
    root@fritz:/var/mod/root# Get window with: File_not_released_by_AVM_continue_?
    -/bin/sh: File_not_released_by_AVM_continue_: not found
    root@fritz:/var/mod/root#   PID USER       VSZ STAT COMMAND
        1 root      1140 S    init
      447 root      8728 S N  /usr/bin/ctlmgr.bin
      538 root      3048 S    multid
      628 root      3048 S    multid
      949 root      8728 S N  /usr/bin/ctlmgr.bin
      950 root      8728 S N  /usr/bin/ctlmgr.bin
      951 root      8728 S N  /usr/bin/ctlmgr.bin
      952 root      8728 S N  /usr/bin/ctlmgr.bin
      953 root      8728 S N  /usr/bin/ctlmgr.bin
     1625 root      3948 S N  /cgi-bin/firmwarecfg
     1626 root      1156 S N  /bin/sh /bin/prepare_fwupgrade end
     1628 root      1136 R N  ps
    Sat Jan  1 01:05:45 CET 2000
    sh: /proc/bus/usb: unknown operand
    cat: can't open '/var/USB-proc-bus-*': No such file or directory
    rmmod: can't unload 'usbahcicore': unknown symbol in module, or unknown parameter
    Sat Jan  1 01:05:51 CET 2000
    SHUTDOWN: initiated
    SHUTDOWN: executing /etc/init.d/rc.mod stop
    Stopping all packages:
    inetd: Stopping inetd ... done.
    authorized-keys:
    dropbear: Stopping dropbear SSH server ... not running.
    dnsmasq: Stopping dnsmasq ... not running.
    aiccu: Stopping aiccu ... not running.
    radvd: Stopping radvd ... done.
    crond: Stopping crond ... not running.
    telnetd: AVM telnetd is started by phone, failed.
    webcfg: Stopping Freetz webinterface ... done.
    dsld: Stopping AVM dsld ... not running.
    ftpd: Stopping AVM ftpd ... not running.
    multid: Stopping AVM multid ... not running.
    Stopping all packages finished.
    SHUTDOWN: executing /var/post_install
    unload dsl and dependend driver ..
    rmmod: can't unload 'rfcntl': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'isdn_fbox_fon5': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'isdn_fbox_fon3': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'isdn_fbox_fon2': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'isdn_fbox_fon': unknown symbol in module, or unknown parameter
    rmmod: can't unload 'userman': unknown symbol in module, or unknown parameter
        1 root      1140 S    init
      447 root      8708 S N  /usr/bin/ctlmgr.bin
      949 root      8708 S N  /usr/bin/ctlmgr.bin
      950 root      8708 R N  /usr/bin/ctlmgr.bin
      951 root      8708 S N  /usr/bin/ctlmgr.bin
      952 root      8708 S N  /usr/bin/ctlmgr.bin
      953 root      8708 S N  /usr/bin/ctlmgr.bin
     1842 root      1132 S    /bin/sh -c /etc/inittab.shutdown
     1843 root      1136 S    /bin/sh /etc/inittab.shutdown
     2013 root      1132 S    /bin/sh /var/post_install
     2014 root      1160 S    /bin/sh /etc/init.d/rc.dsl.sh stop
     2047 root      1132 R    ps
    Module                  Size  Used by    Tainted: P
    ipv6                  273280  6
    usbcore               113328  1
    jffs2                 108800  1
    Piglet                 10656  0
    system is going down ..
    /var/post_install: start
    skip deleting language from env
    still running:
        1 root      1140 S    init
      447 root      8708 R N  /usr/bin/ctlmgr.bin
     2058 root      1132 R    ps
    ipv6                  273280  6
    usbcore               113328  1
    jffs2                 108800  1
    Piglet                 10656  0
    SHUTDOWN: unmounting
    SysRq : Emergency Sync
    SysRq : Emergency Remount R/O
    SHUTDOWN: unmounting 'usbfs' on '/proc/bus/usb'
    SHUTDOWN: unmounting 'jffs2' on '/data'
    SHUTDOWN: unmounting 'sysfs' on '/sys'
    SHUTDOWN: unmounting 'devpts' on '/dev/pts'
    SHUTDOWN: umount rootfs (on /) failed, trying to remount readonly...
    SHUTDOWN: still rw mounted: rootfs (on /)
    SHUTDOWN: still ro mounted: /dev/root (on /)
    SHUTDOWN: still rw mounted: dev (on /dev)
    SHUTDOWN: still rw mounted: proc (on /proc)
    SHUTDOWN: still rw mounted: tmpfs (on /var)
    SHUTDOWN: finished
    Th[avm_power]pm_ressourceinfo_thread: exit
    e system is going down NOW!
    Sent SIGTERM to all processes
    Sent Restarting system.
    (AVM) EVA Revision: 1.347 Version: 1347
    (C) Copyright 2005 AVM Date: Sep 20 2007 Time: 11:14:07 (3) 2 0x0-0x41F
    [FLASH:] SPANSION Top-MirrorBit-Flash 8MB 32 Bytes WriteBuffer
    [FLASH:](Eraseregion [0] 127 sectors a 64kB)
    [FLASH:](Eraseregion [1] 8 sectors a 8kB)
    [SYSTEM:] OHIO on 211MHz/125MHz
    Eva_AVM >AVM decompress Kernel:
    ...................executeProgram on 0x94209000
    [ohio_pre_init] System Clk = 62500000 Hz
    LINUX started...
    Linux version 2.6.13.1-ohio () (gcc version 3.4.6) #2 Thu Sep 29 21:22:40 CEST 2011
    memsize=32 MByte
    flashsize=8 MByte
    &_end=0x94264f84 PFN_ALIGN(&_end)=0x94265000 CPHYSADDR(PFN_ALIGN(&_end))=0x14265000 memsize=0x2000000
    [ohio_gpio_init]
     memory: 00265000 @ 14000000 (reserved)
     memory: 01d9b000 @ 14265000 (usable)
    [alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x94268000-0x942a8020
    [alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fe8000-0x942a8020
    realsize=8192
    realsize=0
    realsize=0
    Built 1 zonelists
    Synthesized TLB refill handler (20 instructions). Base=0x94224244
    Synthesized TLB load handler fastpath (34 instructions) Base=0x94227620.
    Synthesized TLB store handler fastpath (34 instructions) Base=0x94227820.
    Synthesized TLB modify handler fastpath (33 instructions) Base=0x94227a20.
    [setup_irq]: irq 255 irqaction->handler 0x94043a60 (no_action+0x0/0x8 )
    Memory: 29952k/30316k available (1683k kernel code, 320k reserved, 397k data, 116k init, 0k highmem)
    totalram_pages= 7499
    Can't analyze prologue code at 941a333c
    squashfs: version 3.3 (2007/10/31) Phillip Lougher
    Initializing Cryptographic API
    AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Sep 29 2011 21:21:18)
    [uart_add_one_port]
    port->cons = 0x941e64e0 port->cons->flags = 0x7
    [cpmac] Version: 1.124  -  Revision 538:916  -  Mi   9.12.2009  14:07:43
    flash_size=0x800000
    flash_mask=0xffffff
    [mtd]: jffs2_size = 6 * 64KByte (0x60000 Bytes)
    [ohio_find_hidden_filesystem]: super block found: bytes_used: 0x0/6677749
    [init_ohio_flash] find hidden filesystem size=0x6c2c00 offset=0xbd400
    [mtd] fs_size=0x710000 max=0x60000 is=0x60000 max jffs2_size value 6
    0x000bd400-0x00780000 : "filesystem"
            'nor-flash'
            'nor-flash'
            'nor-flash'
            'nor-flash'
            'nor-flash'
    0x00720000-0x00780000 : "jffs2"
            'nor-flash'
    0x00010000-0x00720000 : "Kernel without jffs2"
            'nor-flash'
    partition_info[0]: name=filesystem offset=bd400 size=6c2c00
    partition_info[0]: 0xb00bd400: 0x73717368 0xa47
    partition_info[1]: 0xb0010000: 0xfeed1281 0xad3ab
    partition_info[3]: 0xb0780000: 0x40001 0x87fbffff
    partition_info[5]: name=jffs2 offset=720000 size=60000
    partition_info[5]: 0xb0720000: 0x20031985 0xc
    partition_info[6]: name=Kernel without jffs2 offset=10000 size=710000
    partition_info[6]: 0xb0010000: 0xfeed1281 0xad3ab
    TCP reno registered
    TCP bic registered
    802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    [ohio_late_init]
    NumProbs = 7990 / 2 -> 15980
    Freeing unused kernel memory: 116k freed (7528 free)
    [setup_irq]: irq 15 irqaction->handler 0x940e346c (serial8250_interrupt+0x0/0x13c )
    init started: BusyBox v1.18.5 (2011-09-29 20:45:41 CEST)
    rootdir=/
    table='/etc/device.table'
    TFFS Name Table G
    HWRevision      127.1.1.0
    ProductID       Fritz_Box_7170_AnnexA
    SerialNumber    0000000000000000
    annex   A
    autoload        yes
    bootloaderVersion       1.347
    bootserport     tty0
    country 031
    cpufrequency    211968000
    firstfreeaddress        0x946C0D14
    firmware_version        avme
    firmware_info   58.04.84
    flashsize       0x00800000
    jffs2_size      6
    maca    00:1F:3F:AE:04:AA
    macb    00:1F:3F:AE:04:AB
    macwlan 00:1F:3F:A0:91:0A
    macdsl  00:1F:3F:AE:04:AC
    memsize 0x02000000
    modetty0        38400,n,8,1,hw
    modetty1        38400,n,8,1,hw
    mtd0    0x90000000,0x90000000
    mtd1    0x90010000,0x90780000
    mtd2    0x90000000,0x90010000
    mtd3    0x90780000,0x907C0000
    mtd4    0x907C0000,0x90800000
    my_ipaddress    192.168.178.1
    prompt  Eva_AVM
    ptest
    req_fullrate_freq       125000000
    sysfrequency    125000000
    urlader-version 1347
    usb_board_mac   00:1F:3F:AE:04:AD
    usb_rndis_mac   00:1F:3F:AE:04:AE
    usb_device_id   0x3D00
    usb_revision_id 0x0200
    usb_device_name USB DSL Device
    usb_manufacturer_name   AVM
    wlan_key        5130695660030532
    wlan_cal        001E,03BD,0022,00DA,010A,00DB,010A,0313,0303
    mknod: /var/flash/ar7.cfg: File exists
    Loading /var/flash/freetz ... done.
    Loading users, groups and passwords ... done.
    Loading hosts ... done.
    Loading config ... done.
    Loading modules ... done.
    P-Defaults: do nothing
    [avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=6250 key=button_key_3
    checkempty: : No such file or directory
    ' taints kernel.
    [piglet]McSP: rFS: 8000 Hz rCLK:2048225 Hz
    [jffs2] xx=mtd6: 00060000 00010000 "jffs2"
    [jffs2] i=mtd6:
    [jffs2] jffs2_pat=6
    [jffs2] i=00060000
    [jffs2] jffs2_size=6
    [jffs2] i=00010000
    [jffs2] i="jffs2"
    [jffs2] load jffs2 module
    [jffs2] mount jffs
    [jffs2] write env variable jffs2_size to 6
    TAM: create JFFS2 directory /data/tam
    attempting to load DSL Firmware '/lib/modules/microvoip-dsl.bin'
    **** ANNEX: 'A'
    setting DSL Firmware to Annex A
    EOC info: product_name='FRITZ!BoxFonWLAN7170AnnexA'
    tiatm driver (patch_annex=0xc013e2ec)
    [setup_irq]: irq 23 irqaction->handler 0xc0124208 (tn7atm_sar_irq+0x0/0x50 [tiatm] )
    [setup_irq]: irq 31 irqaction->handler 0xc0124258 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
    ubik2 driver (ubik2 - 0x10=0xc0098fd4)
    atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc0086bfc
    driver params overwritten io_addr=0x0 irq_num=0
    [setup_irq]: irq 28 irqaction->handler 0xc0091af0 (soft_interrupt_handler+0x0/0x30 [ubik2] )
    capicodec_init()
    [capi_codec] support fax
    [capi_codec] support Codecs
    usbcore: registered new driver usbfs
    usbcore: registered new driver hub
            AHCI RevisionID = 0x02, RamSize = 16384, NumPorts= 1
    [setup_irq]: irq 9 irqaction->handler 0xc0119490 (ahci_irq+0x0/0x880 [usbahcicore] )
    ahci : new USB bus registered, assigned bus number 1
    AVM USB 1.1 Host started
    kdsldmod: init start (Apr  4 2011 16:27:39) sizeof(struct sk_buff)=176
    kdsldmod: init done
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    MAC WLAN:       00:1F:3F:A0:91:0A
    WLAN is not enabled
    ifconfig: SIOCGIFFLAGS: No such device
    /etc/init.d/rc.net: line 408: websrv: not found
    AVMMULTID: dnsmasq is disabled.
    [tiatm]: error getting DSL parametrization interface for read operation!
    [avm_power] : ethernet port 0 status 2
    [avm_power] : ethernet port 1 status 1
    [avm_power] : ethernet port 2 status 1
    [avm_power] : ethernet port 3 status 1
    [setup_irq]: irq 27 irqaction->handler 0x940f41cc (cpmac_main_isr+0x0/0x78 )
    [cpmac] [cpmac_main_ioctl] unknown ioctl 35142
    device cpmac0 entered promiscuous mode
    device eth0 entered promiscuous mode
    device wan entered promiscuous mode
    Jan  1 01:00:31 multid[538]: DEBUG: upnpdev_start_usb
    AVMMULTID: Starting AVM multid ... done.
    lan: port 1(eth0) entering learning state
    lan: topology change detected, propagating
    lan: port 1(eth0) entering forwarding state
    Jan  1 01:00:31 dsld[572]: voip: ppptarget voip disabled, ignored
    Jan  1 01:00:31 dsld[572]: get_queueindex: none: not found
    Jan  1 01:00:32 telefon[576]: use clock_gettime(CLOCK_MONOTONIC)!
    Jan  1 01:00:32 telefon[576]: SIGC[capi_oslib] capi_installed -1811764080
    HLD received!
    Jan  1 01:00:33 telefon[576]: SIGCHLD received!
    [capi_oslib] capi_installed -1811531940
    create sema UPNPAPI_DATA_phonebook
    /etc/init.d/rc.S: line 1523: /etc/init.d/rc.media: not found
    run_clock demAR7WDT: System Init UEberwachung abgeschlossen (207710 ms noch verfuegbar)
    on started
    SysRq : Changing Loglevel
    Loglevel set to 4
    rc.mod version freetz-devel-7662M
    crond is disabled.
    Starting Freetz webinterface ... done.
    swap is disabled.
    syslogd is disabled.
    Starting inetd ... done.
    Setting up SSH authorized_keys for root ... done.
    dropbear SSH server is disabled.
    Jan  1 01:00:47 ctlmgr[450]: my_wlan_init
    Starting aiccu ... failed.
    Starting radvd ... done.
    rc.mod finished.
    Please press Enter to activate this console.
    BusyBox v1.18.5 (2011-09-29 20:45:41 CEST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
  8. #8
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    Perhaps you can try to execute "sh -x /var/install" manually when it stops with this webinterface message and post the output of "cat /var/post_install". Is the file /var/tmp/kernel.image created?
    Regards
    Oliver
    Spenden für Freetz
  9. #9
    IPPF-Einsteiger
    Registriert seit
    29.08.2011
    Oliver,
    Thanks for pointing me to locations that provide additional infomation during uploading an image.
    Yes the file is created, with an expected timestamp (file name on disk:7170_04.84freetz-devel-7635.en_20110917-220645.image). The size is smaller than on my harddisk (7499776bytes). I understand from the flash layout that kernel.image contains both kernel and root files system. I only don't understand the difference of 781560bytes.
    root@fritz:/var/mod/root# ls -la /var/tmp/kernel.image
    -rw-r--r--    1 root     root       6718216 Sep 17 22:07 /var/tmp/kernel.image
    Here the output of sh -x /var/install:
    root@fritz:/var/mod/root# sh -x /var/install
    + kernel_update_start=0
    + kernel_update_len=0
    + name_list=
    + export INSTALL_SUCCESS_NO_REBOOT=0
    + export INSTALL_SUCCESS_REBOOT=1
    + export INSTALL_WRONG_HARDWARE=2
    + export INSTALL_KERNEL_CHECKSUM=3
    + export INSTALL_FILESYSTEM_CHECKSUM=4
    + export INSTALL_URLADER_CHECKSUM=5
    + export INSTALL_OTHER_ERROR=6
    + export INSTALL_FIRMWARE_VERSION=7
    + export INSTALL_DOWNGRADE_NEEDED=8
    + force_update=n
    + uname -r
    + echo install: have Kernel 2.6
    + kversion=26
    + echo install: check and install new firmware ...
    + need_reboot=0
    + korrekt_version=0
    + /bin/update_led_on
    /bin/update_led_on: line 2: can't create /dev/led: No such device or address
    + [ 26 = 24 ]
    + echo OEM=avme
    OEM=avme
    + [ 26 = 24 ]
    + export CONFIG_ENVIRONMENT_PATH=/proc/sys/urlader
    + cat /proc/sys/urlader/annex
    + export ANNEX=A
    + [ -z A ]
    + echo ANNEX=A
    ANNEX=A
    + [ -z  ]
    + echo testing acceptance for device Fritz_Box_7170_AnnexA ...
    + /etc/version --install=ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
    korrekt install type: ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
    + echo device has installtype ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
    + accept_annex=A
    + echo assumed ANNEX A -- found ANNEX A
    + [ A = A ]
    + echo device has ANNEX A
    device has ANNEX A
    + [ ! -z avme ]
    + oem_found=0
    + [ avme = avme ]
    + echo OK - OEM avme is supported
    + oem_found=1
    + break
    + [ 1 = 0 ]
    + echo OK - accept this update for device Fritz_Box_7170_AnnexA ...
    + korrekt_version=1
    + echo testing acceptance for device Fritz_Box_7170_AnnexA done
    + kernel_start=0x90010000
    + kernel_size=7798784
    + filesystem_start=0x90000000
    + filesystem_size=0
    + urlader_start=0x90000000
    + urlader_size=65536
    + newFWver=04.84
    + [ 1 = 0 ]
    + /etc/version -v
    + currFWver=58.04.84
    + echo curr: 58.04.84  new: xx.04.84
    + major_currFWver=58
    + middle_currFWver=58.04
    + middle_currFWver=04
    + minor_currFWver=84
    + echo debug: curr: 58.04.84
    + middle_newFWver=04
    + minor_newFWver=84
    + echo debug: new: "XX.04.84"
    + middle_currFWver=4
    + major_newFWver=
    + middle_newFWver=4
    + minor_newFWver=84
    + echo major_currFWver=58
    major_currFWver=58
    + echo middle_currFWver=4
    middle_currFWver=4
    + echo minor_currFWver=84
    minor_currFWver=84
    + echo middle_newFWver=4
    middle_newFWver=4
    + echo minor_newFWver=84
    minor_newFWver=84
    + [ -z 4 ]
    + [ -z 84 ]
    + [ -z 4 ]
    + [ -z 84 ]
    + [ n = y ]
    + echo check Firmware Version: xx.04.84
    + [ 4 -lt 4 ]
    + echo DEBUG: 4 >= 4
    DEBUG: 4 >= 4
    + [ 4 -eq 4 ]
    + [ 84 -gt 89 ]
    + [ 84 -lt 84 ]
    + echo DEBUG: 84 >= 84
    DEBUG: 84 >= 84
    + echo Accept Firmware Version: xx.04.84
    + echo install: 26 check files...
    + [ -f /var/tmp/filesystem.image ]
    + [ 0 -ne 0 ]
    + [ -f /var/tmp/kernel.image ]
    + /var/chksum /var/tmp/kernel.image
    File already contains the checksum, verifying
    Calculated checksum is A715B6E3
    Saved checksum is A715B6E3
    Checksum validation successful!
    + echo chksum for file /var/tmp/kernel.image ok
    + [ ! -f /var/post_install ]
    + echo echo $0: start
    + echo sleep 1
    + echo killall run_clock
    + echo if ps | grep -v grep | grep -q telefon ; then killall telefon ; fi
    + echo if ps | grep -v grep | grep -q telnetd ; then killall telnetd ; fi
    + [ 26 = 24 ]
    + echo echo skip deleting language from env
    + echo echo MODE=update > /dev/avm_power
    + [ -e /dev/watchdog ]
    + echo echo "disable" > /dev/watchdog
    + echo echo still running:
    + echo ps
    + echo lsmod
    + echo sleep 1
    + [ 26 = 24 ]
    + echo install: 26 getting mtd to install...
    + echo install: -----------------------------------------------------
    + ls -l /var/tmp/kernel.image
    + sed -e s/[^0-9]/#/g
    + sed -e s/#\+[0-9]\+#\+\([0-9]\+\).*/\1/
    + kernel_image_size=6718216
    + get_kernel_mtd 6718216 7798784
    + kernel_mtd_size=7798784
    + cat /proc/mtd
    + grep urlader
    + sed -n -e s/mtd[0-9].*: \([^ ]*\) \([^ ]*\) .*/\1/p
    + tmp_size=
    + [ -z  ]
    + cat /proc/mtd
    + grep bootloader
    + tmp_size=00010000
    + [ -z 00010000 ]
    + bootloader_size=0x00010000
    + cat /proc/mtd
    + grep "jffs2"
    + grep -v Kernel
    + tmp_size=00060000
    + [ -z 00060000 ]
    + jffs2_size=0x00060000
    + Kernel_without_jffs2_size=7405568
    + kernel_update_start=268500992
    + echo bootloader_size 0x00010000
    + echo jffs2_size 0x00060000
    + echo Kernel_without_jffs2_size 7405568
    + echo kernel_image_size 6718216
    + echo kernel_mtd_size 7798784
    + echo Kernel_Start_Add=268500992
    + echo Kernel_End_Addr=275219208
    + echo Kernel_without_jffs2_End_Addr=275906560
    + [ 6718216 -le 7405568 ]
    + kernel_update_len=7405568
    + return 0
    + echo install: kernel_size=7798784
    + echo install: kernel_update_start=268500992
    + echo install: kernel_update_len=7405568
    + [ 268500992 = 0 ]
    + echo install: 26 setting files to install...
    + crc_param=1
    + echo install: /var/tmp/kernel.image to start(268500992) size(7405568)
    + echo update_parameter=flash_update_file0="/var/tmp/kernel.image,268500992,7405568,crc=1"
    + need_reboot=1
    + ls -l /var/tmp/filesystem.image
    + act_fs_size=0
    + [ 0 -ne 0 ]
    + [ 1 -eq 1 ]
    + echo insmod /var/flash_update.ko $update_parameter
    + echo exit 0
    + chmod +x /var/post_install
    + [ 1 -eq 1 ]
    + echo install: check for old settings ...
    + OLD_SETTINGS_FILE=#! /bin/sh major=`grep tffs /proc/devices` tffs_major=${major%%tffs} telnetd -l /sbin/ar7login killall capiotcp_server sleep 5 /usr/bin/capiotcp_server -p5031 -m3 &
    + [ -f /var/rc.user ]
    + [ -x /var/regelex ]
    + [ -e /var/flash/fx_lcr ]
    + [ -n  ]
    + echo clear_id 95
    + echo clear_id 96
    + [ 1 -eq 1 ]
    + echo set INFO led to blink (modul=7, state=4)
    + exit 1
    And the output of cat /var/post_install:
    root@fritz:/var/mod/root# cat /var/post_install
    # ! /bin/sh
    if [ -x /etc/hotplug/usb.pandu -a -f /proc/bus/usb/devices ] ; then
        echo "stopping USB-Subsystem .."
        /etc/hotplug/usb.pandu stop
    fi
    if [ -x /etc/init.d/rc.dsl.sh ] ; then
        echo "unload dsl and dependend driver .."
    fi
    echo "system is going down .."
    # UBIK2 Nutzer freigeben
    # if lsmod | grep -q ubik2 ; then
    #     echo "stopping applications using ubik2 .."
    #     if ps | grep -v grep | grep -q capiotcp_server ; then killall capiotcp_server ; fi
    #     if ps | grep -v grep | grep -q telefon ; then killall telefon ; fi
    #     if ps | grep -v grep | grep -q voipd ; then voipd -s ; fi
    #     sleep 2
    #     if ps | grep -v grep | grep -q voipd ; then killall voipd ; fi
    #     sleep 3
    #     if lsmod | grep -q isdn_fbox ; then rmmod isdn_fbox ; fi
    #     sleep 3
    #     if lsmod | grep -q ubik2 ; then rmmod ubik2 ; fi
    # fi
    # return 0
  10. #10
    Registriert seit
    19.10.2004
    Ort
    Kaiserslautern
    I don't know what is going on there. The piece of code in /var/install is:
    if [ $need_reboot -eq $INSTALL_SUCCESS_REBOOT ] ; then
        echo "insmod /var/flash_update.ko \$update_parameter" >>/var/post_install
    fi
    # due to append sequence add exit to prevent accidently second run.
    echo "exit 0" >>/var/post_install
    But the instructions don't appear in your post_install!?
    Regards
    Oliver
    Spenden für Freetz
Ähnliche Themen
  1. [Problem] 3170 keine AVM Webinterface mehr nach freetz-trunk
    Von HarryHase im Forum Freetz
    Antworten: 6
    Letzter Beitrag: 21.06.2011, 20:14
  2. Problem Freetz-Trunk Annex A auf FB 7170
    Von Elsi29 im Forum Freetz
    Antworten: 6
    Letzter Beitrag: 03.01.2010, 04:12
  3. [SOLVED]Help for installing freetz!!!
    Von flame23 im Forum Freetz
    Antworten: 95
    Letzter Beitrag: 15.11.2009, 17:47
  4. Antworten: 4
    Letzter Beitrag: 22.07.2008, 23:49
  5. Antworten: 3
    Letzter Beitrag: 19.05.2008, 11:36
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
