Sende Verbindungsaufbau ...
Wed Jul 11 17:27:23 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:27:23 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:27:23 2012 LZO compression initialized
Wed Jul 11 17:27:23 2012 Control Channel MTU parms [ L:1541 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:27:23 2012 TLS: Initial packet from 88.73.174.142:1194, sid=bee4c1ca b73956b7
Wed Jul 11 17:27:24 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:27:24 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:27:24 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:27:25 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:27:25 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:27:25 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:27:25 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:27:25 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:27:25 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:27:27 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:27:27 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:27:27 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:27:27 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:27:27 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:27:27 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:27:27 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:27:27 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:27:27 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:27:27 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:27:27 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:27:27 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:27:27 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:27:29 2012 TEST ROUTES: 2/2 succeeded len=2 ret=1 a=0 u/d=up
Wed Jul 11 17:27:29 2012 C:\WINDOWS\system32\route.exe ADD 10.10.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:27:30 2012 C:\WINDOWS\system32\route.exe ADD 10.8.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:27:30 2012 Initialization Sequence Completed
ERROR:Application Exiting!
Wed Jul 11 17:27:37 2012 Assertion failed at ../openvpn-2.1.1/crypto.c:162
Wed Jul 11 17:27:37 2012 Exiting
Wed Jul 11 17:29:28 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:29:28 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:29:28 2012 LZO compression initialized
Wed Jul 11 17:29:28 2012 Control Channel MTU parms [ L:1541 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:29:28 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:29:28 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:29:28 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:29:28 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:29:28 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:29:28 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:29:28 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:29:28 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:29:28 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:29:31 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:29:31 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:29:31 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:29:31 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:29:31 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:29:31 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:29:31 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:29:31 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:29:31 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:29:31 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:29:31 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:29:31 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:29:31 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:29:33 2012 TEST ROUTES: 2/2 succeeded len=2 ret=1 a=0 u/d=up
Wed Jul 11 17:29:33 2012 C:\WINDOWS\system32\route.exe ADD 10.10.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:29:33 2012 C:\WINDOWS\system32\route.exe ADD 10.8.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:29:33 2012 Initialization Sequence Completed
Wed Jul 11 17:29:41 2012 Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3991321559 / time = (360808257) Mon Jun 08 02:30:57 1981 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Wed Jul 11 17:29:41 2012 Fatal decryption error (process_incoming_link), restarting
Wed Jul 11 17:29:41 2012 TCP/UDP: Closing socket
Wed Jul 11 17:29:41 2012 SIGUSR1[soft,decryption-error] received, process restarting
Wed Jul 11 17:29:41 2012 Restart pause, 5 second(s)
RESTART:ACTION
Neustart erhalten.
Wed Jul 11 17:29:46 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:29:46 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:29:46 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:29:46 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:29:46 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:29:46 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:29:46 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:29:46 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:29:46 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:29:48 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:29:48 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:29:48 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:29:48 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:29:48 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:29:48 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:29:48 2012 Preserving previous TUN/TAP instance: LAN-Verbindung 2
Wed Jul 11 17:29:48 2012 Initialization Sequence Completed
Wed Jul 11 17:29:58 2012 Assertion failed at ../openvpn-2.1.1/crypto.c:162
Wed Jul 11 17:29:58 2012 Exiting
Wed Jul 11 17:32:51 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:32:51 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:32:51 2012 LZO compression initialized
Wed Jul 11 17:32:51 2012 Control Channel MTU parms [ L:1541 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:32:51 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:32:51 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:32:51 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:32:51 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:32:51 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:32:51 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:32:51 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:32:51 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:32:51 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:32:53 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:32:53 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,redirect-gateway,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:32:53 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:32:53 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:32:53 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:32:53 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:32:53 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:32:53 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:32:53 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:32:53 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:32:53 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:32:53 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:32:53 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:32:54 2012 Assertion failed at ../openvpn-2.1.1/crypto.c:162
Wed Jul 11 17:32:54 2012 Exiting
Wed Jul 11 17:32:55 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:32:55 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:32:55 2012 LZO compression initialized
Wed Jul 11 17:32:55 2012 Control Channel MTU parms [ L:1541 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:32:55 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:32:55 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:32:55 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:32:55 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:32:55 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:32:55 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:32:55 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:32:55 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:32:55 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:32:57 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:32:57 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,redirect-gateway,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:32:57 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:32:57 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:32:57 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:32:57 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:32:57 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:32:57 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:32:57 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:32:57 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:32:57 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:32:57 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:32:57 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:32:58 2012 Assertion failed at ../openvpn-2.1.1/crypto.c:162
Wed Jul 11 17:32:58 2012 Exiting
Wed Jul 11 17:35:38 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:35:38 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:35:38 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:35:38 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:35:38 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:35:38 2012 Data Channel Encrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:35:38 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:35:38 2012 Data Channel Decrypt: Cipher 'DES-CFB' initialized with 64 bit key
Wed Jul 11 17:35:38 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:35:38 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:35:38 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:35:40 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:35:40 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,redirect-gateway,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:35:40 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:35:40 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:35:40 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:35:40 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:35:40 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:35:40 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:35:40 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:35:40 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:35:40 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:35:40 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:35:40 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:35:40 2012 Assertion failed at ../openvpn-2.1.1/crypto.c:162
Wed Jul 11 17:35:40 2012 Exiting
Wed Jul 11 17:37:05 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Benutzername wird angefordert.
Sende Benutzernamen ...
ERROR:Auth username is empty
Wed Jul 11 17:37:07 2012 ERROR: Auth username is empty
Wed Jul 11 17:37:07 2012 Exiting
Wed Jul 11 17:37:17 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:37:17 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:37:17 2012 LZO compression initialized
Wed Jul 11 17:37:17 2012 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Sende Trennen ...
Wed Jul 11 17:37:53 2012 TCP/UDP: Closing socket
Wed Jul 11 17:37:53 2012 SIGTERM[hard,] received, process exiting
Wed Jul 11 17:38:03 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:38:03 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:38:03 2012 LZO compression initialized
Wed Jul 11 17:38:03 2012 Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:38:03 2012 Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:135 ET:0 EL:0 AF:3/1 ]
Wed Jul 11 17:38:03 2012 Local Options hash (VER=V4): '69109d17'
Wed Jul 11 17:38:03 2012 Expected Remote Options hash (VER=V4): 'c0103fa8'
Wed Jul 11 17:38:03 2012 Attempting to establish TCP connection with 88.73.174.142:1194
Wed Jul 11 17:38:04 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:38:04 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:38:04 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:38:04 2012 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Jul 11 17:38:04 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:38:04 2012 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Jul 11 17:38:04 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:38:04 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:38:04 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:38:06 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:38:06 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,redirect-gateway,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:38:06 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:38:06 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:38:06 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:38:06 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:38:06 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:38:06 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:38:06 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:38:06 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:38:06 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:38:06 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:38:06 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:38:08 2012 TEST ROUTES: 3/3 succeeded len=2 ret=1 a=0 u/d=up
Wed Jul 11 17:38:08 2012 C:\WINDOWS\system32\route.exe ADD 88.73.174.142 MASK 255.255.255.255 10.211.55.1
Wed Jul 11 17:38:08 2012 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 10.211.55.1
Wed Jul 11 17:38:08 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 10.8.0.1
Wed Jul 11 17:38:08 2012 C:\WINDOWS\system32\route.exe ADD 10.10.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:08 2012 WARNING: potential route subnet conflict between local LAN [10.8.0.0/255.255.255.0] and remote VPN [10.8.0.0/255.255.255.0]
Wed Jul 11 17:38:08 2012 C:\WINDOWS\system32\route.exe ADD 10.8.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:08 2012 Initialization Sequence Completed
Sende Trennen ...
Wed Jul 11 17:38:30 2012 TCP/UDP: Closing socket
Wed Jul 11 17:38:30 2012 C:\WINDOWS\system32\route.exe DELETE 10.8.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:30 2012 C:\WINDOWS\system32\route.exe DELETE 10.10.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:30 2012 C:\WINDOWS\system32\route.exe DELETE 88.73.174.142 MASK 255.255.255.255 10.211.55.1
Wed Jul 11 17:38:30 2012 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 10.8.0.1
Wed Jul 11 17:38:30 2012 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 10.211.55.1
Wed Jul 11 17:38:30 2012 Closing TUN/TAP interface
Wed Jul 11 17:38:30 2012 SIGTERM[hard,] received, process exiting
Wed Jul 11 17:38:42 2012 OpenVPN 2.1.1 i386-pc-mingw32 [SSL] [LZO2] built on Apr 14 2010
Wed Jul 11 17:38:42 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Jul 11 17:38:42 2012 LZO compression initialized
Wed Jul 11 17:38:42 2012 Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Wed Jul 11 17:38:42 2012 VERIFY OK: depth=1, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=Meinekraft_CA/
[email protected]
Wed Jul 11 17:38:42 2012 VERIFY OK: nsCertType=SERVER
Wed Jul 11 17:38:42 2012 VERIFY OK: depth=0, /C=DE/ST=B/L=Berlin/O=Meinekraft/CN=server/
[email protected]
Wed Jul 11 17:38:43 2012 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Jul 11 17:38:43 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:38:43 2012 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Jul 11 17:38:43 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Jul 11 17:38:43 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Wed Jul 11 17:38:43 2012 [server] Peer Connection Initiated with 88.73.174.142:1194
Wed Jul 11 17:38:45 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Wed Jul 11 17:38:45 2012 PUSH: Received control message: 'PUSH_REPLY,route-gateway 10.8.0.1,topology subnet,route 10.10.0.0 255.255.255.0,route 10.8.0.0 255.255.255.0,ping 10,ping-restart 120,ifconfig 10.8.0.100 255.255.255.0'
Wed Jul 11 17:38:45 2012 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 11 17:38:45 2012 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 11 17:38:45 2012 OPTIONS IMPORT: route options modified
Wed Jul 11 17:38:45 2012 OPTIONS IMPORT: route-related options modified
Wed Jul 11 17:38:45 2012 ROUTE default_gateway=10.211.55.1
Wed Jul 11 17:38:45 2012 TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{1C700A2D-44EF-461C-8305-5F5F6C456B04}.tap
Wed Jul 11 17:38:45 2012 TAP-Win32 Driver Version 9.6
Wed Jul 11 17:38:45 2012 TAP-Win32 MTU=1500
Wed Jul 11 17:38:45 2012 Set TAP-Win32 TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.100/255.255.255.0 [SUCCEEDED]
Wed Jul 11 17:38:45 2012 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.8.0.100/255.255.255.0 on interface {1C700A2D-44EF-461C-8305-5F5F6C456B04} [DHCP-serv: 10.8.0.254, lease-time: 31536000]
Wed Jul 11 17:38:45 2012 Successful ARP Flush on interface [19] {1C700A2D-44EF-461C-8305-5F5F6C456B04}
Wed Jul 11 17:38:47 2012 TEST ROUTES: 2/2 succeeded len=2 ret=1 a=0 u/d=up
Wed Jul 11 17:38:47 2012 C:\WINDOWS\system32\route.exe ADD 10.10.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:47 2012 C:\WINDOWS\system32\route.exe ADD 10.8.0.0 MASK 255.255.255.0 10.8.0.1
Wed Jul 11 17:38:47 2012 Initialization Sequence Completed
