anscheinend wird alle 2 Minuten ein Re-Start durchgeführt. Ist das OK ?
Nun die gleichen Einträge alle 2 MinutenCode:Jul 16 16:36:52 fritz daemon.warn openvpn[14551]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: Re-using pre-shared static key Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: LZO compression initialized Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: Socket Buffers: R=[178176->131072] S=[178176->131072] Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: Preserving previous TUN/TAP instance: tun0 Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: Data Channel MTU parms [ L:1545 D:1450 EF:45 EB:135 ET:0 EL:0 AF:3/1 ] Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: UDPv4 link local (bound): [undef] Jul 16 16:36:52 fritz daemon.notice openvpn[14551]: UDPv4 link remote: [undef] Jul 16 16:38:52 fritz daemon.notice openvpn[14551]: Inactivity timeout (--ping-restart), restarting Jul 16 16:38:52 fritz daemon.notice openvpn[14551]: TCP/UDP: Closing socket Jul 16 16:38:52 fritz daemon.notice openvpn[14551]: SIGUSR1[soft,ping-restart] received, process restarting Jul 16 16:38:52 fritz daemon.notice openvpn[14551]: Restart pause, 2 second(s)
Zitieren
