Ergebnis 1 bis 8 von 8
Thema: Custom package does not show up in build
  1. #1
    IPPF-Einsteiger
    Registriert seit
    20.07.2012
    Hello,
    I'm creating a custom package "from scratch"
    I copied the debootstrap package in the make-dir because this is the only packing with .c src files (all others download them from sites), and called the new dir [barcodereader].
    The package shows up in make menuconfig.
    The package compiles during make and the folder with all the right contents shows up in: packages\target-mipsel_uClibc-0.9.29\barcodereader-1.0.28
    including a dir packages\target-mipsel_uClibc-0.9.29\barcodereader-1.0.28\root\usr\lib\barcodereader
    but the directory root\usr\lib\barcodereader wont show in de build directory, and is not available in the image.
    What to do? What im a doing wrong.
    I also noticed that after my build, there is no barcodereader -entry in the .packes files in de freetz-dir , but there is a debootstrap entry in that file
    Here are the contents of package my files:
    Config.in:
    config FREETZ_PACKAGE_BARECODEREADER
    	bool "Barcodereader 1.0.28"
    	default n
    	help
    		Barcodereader is used to read from a barcode scanner and post its values online
    Makefile.in
    ifeq ($(strip $(FREETZ_PACKAGE_BARECODEREADER)),y)
    PACKAGES+=barcodereader
    endif
    barcodereader.mk:
    $(call PKG_INIT_BIN, 1.0.28)
    $(PKG)_BINARY_SOURCE:=$($(PKG)_MAKE_DIR)/src/blink2.c
    $(PKG)_BINARY:=$($(PKG)_DIR)/blink2
    $(PKG)_TARGET_BINARY:=$($(PKG)_DEST_DIR)/usr/lib/barcodereader/blink2
    #$(PKG_LOCALSOURCE_PACKAGE)
    $(PKG_UNPACKED)
    $(PKG_CONFIGURED_NOP)
    $($(PKG)_BINARY): $($(PKG)_BINARY_SOURCE) $($(PKG)_DIR)/.configured
    	mkdir -p $(BARCODEREADER_DIR)
    	echo $(BARCODEREADER_DIR)
    	cp -a $< $(BARCODEREADER_DIR)
    	cd $(BARCODEREADER_DIR) && $(TARGET_CONFIGURE_ENV) \
    		$(TARGET_CC) $(TARGET_CFLAGS) -lusb -o blink2 blink2.c
    $($(PKG)_TARGET_BINARY): $($(PKG)_BINARY)
    	$(INSTALL_BINARY_STRIP)
    $(pkg):
    $(pkg)-precompiled: $($(PKG)_TARGET_BINARY)
    $(pkg)-clean:
    	-$(SUBMAKE) -C $(BARCODEREADER_DIR) clean
    $(pkg)-uninstall:
    	$(RM) $(BARCODEREADER_TARGET_BINARY)
    $(PKG_FINISH)
    Geändert von Qemme (04.08.2012 um 23:36 Uhr)
  2. #2
    IPPF-Urgestein
    Registriert seit
    22.04.2007
    Please add CODE-tags to the relevant sections of your post.
    The /usr/lib directory is special, it is not copied from the packages directory to the the image.
    Maybe the simplest solution would be to add commands to fwmod_custom to copy the files to the desired place.
  3. #3
    IPPF-Einsteiger
    Registriert seit
    20.07.2012
    Ok, but if I change:
    Into
    $(PKG)_TARGET_BINARY:=$($(PKG)_DEST_DIR)/usr/bin/blink2
    It doesnt work either. So how does it work for all the other packages? And why does it work for the debootstrap package.
    (thanxs for the CODE-tag-tip)
  4. #4
    IPPF-Urgestein
    Registriert seit
    22.04.2007
    Maybe you have to do
    make barcodereader-dirclean; make
  5. #5
    IPPF-Einsteiger
    Registriert seit
    20.07.2012
    Does not help. But I think you're right: My package must have gone FUBAR somewhere.
    I just deleted the barcodereader package and simplye started modifying the debootstrap package until it does what I want it to do, and that works.
    So.. Who needs a debootstrapper package anyway?
  6. #6
    IPPF-Fan
    Registriert seit
    20.12.2005
    You commented out
    That's the reason it doesn't work. You partially reimplemented the part needed to compile the package but omitted everything else needed to copy the files into the image. Simply put a proper Makefile along with your .c file under src-directory and rename DEBOOTSTRAP to BARCODEREADER, that is everything you need. Don't add something like $(PKG)_SOURCE_BINARY and don't rewrite the $($(PKG)_BINARY) rule. A proper Makefile means a Makefile which can be used to compile your package also for host (by entering the src-directory and calling make).
  7. #7
    IPPF-Einsteiger
    Registriert seit
    20.07.2012
    Ok, that would be strange,
    I didnt modify that line, so it would be wrong in the orginal debootstrap to!
    It comes from:
    http://svn.freetz.org/branches/freet...debootstrap.mk
    Other question then, i have good communications with a USB device, but i'd like to register by C program as a USB-driver, as mentioned here:
    http://www.linuxjournal.com/article/7353?page=0,1
    Therefor I need to include module.h :
    #include <linux/module.h>
    Gives lots and lots of compiler errors.. What to do?
    (Or should I start a new topic?)
  8. #8
    IPPF-Urgestein
    Registriert seit
    22.04.2007
    If you want to write a kernel module, you should look for other places that create kernel modules (like fuse or ndas).
    You need the kernel compiler and the include path o the kernel modules. The best way is to write a makefile that calls the kernel makefile.
Ähnliche Themen
  1. Antworten: 9
    Letzter Beitrag: 04.07.2011, 10:59
  2. Can't build my custom freetz
    Von SystemR89 im Forum Freetz
    Antworten: 44
    Letzter Beitrag: 01.03.2009, 17:18
  3. Zaptel build ***** FAILED: ***** No zaptel.ko file found after build. Terminating scr
    Von Vincent2004 im Forum FreePBX, TrixBox (Asterisk@Home)
    Antworten: 0
    Letzter Beitrag: 25.04.2008, 08:10
  4. sip show peers
    Von schneemie im Forum FreePBX, TrixBox (Asterisk@Home)
    Antworten: 2
    Letzter Beitrag: 17.09.2006, 22:36
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
