Fritz!Box Fon WLAN 7390 - [tot, dead, bricked]* - Repair possible?
angrybb
27 Nov 2011
Sorry for writting in english, aber mein deutsch ist nicht sehr gut. Nur Stufe A1.
I got 7390 from ebay as defekt. When i connect power on it no LEDs blinks at all. Computer also dont register device when i connect the LAN cabel. Checked some points on the device board with voltmeter and i got readings on main electrolyte capacitors, but nothing on LED, ETHERNET ports and USB ports. Board looks like new, no burnt marks, bad caps. or some visible damage. After some time i can feel on main processor heatsink small amount of heat.
Is there a way for me to repair the unit?
Can i use ejtag?
I found something on the net about (e)jtag but i am not sure where to get custom.bin for fritz!box 7390. Does anyone have it?
Any suggestions?
Thanks!
did you test the power supply? Some times it make problems.
greetings
It looks like you have bought a box with a lightning strike damage.
My first 7390 gets an lightning with the same abnormal behavior then yours: Heatsink gets some heat, but box will not boot.
Can you hear some electrical noise from the mainboard?
No noise at all. Have you repaired your box?
I never saw a device that got striked by the lightning but i guess man could see some burnt components or marks on the board.
Could You dump mtd2 for me? Can i use that dump for jtag or i need mtd2 in some other format?
Thanks!
EDIT: Wait, i checked again and now i hear some constant noise, like a quiet piezo or something like that.
... now i hear some constant noise, like a quiet piezo or something like that.
This seems to me, that this box has the same defect than my box.
No. I havn't repaired this box, I've sold it on "Flohmarkt" here in Forum to someone who needs an casing of this box. Perhaps you bought my defective box on Ebay from that guy? Is there an label on the bottom of the box? (I've removed the label from my box when I sold it.)
I buy it, if you can not repair it. I want to make a wlan mod and need a chase for that.
greetings
Ok. I will try with jtag.
Could somebody give me mtd2 dump for Fritz!Box Fon WLAN 7390?
Or point out where i can get one.
New info folks.
I managed to revive my precious FB 7390!!! And that by pure accident. A friend of mine found where the beeping come from, it was one "coil"(red circle on picture below). When we applied pressure on it, it beeped with higher tone. He than took voltmeter and tried to measure voltage on that coil. It was low, 0.6V or something. While trying to move voltmeter probes, he accidently shortcuted component near that coil(yellow circle on picture below). We got a spark, and power led started blinking!!! There was signal on lan ports, but i could not get ip address from fritz as it restarted after half a minute or so, in a loop. I also got heat on biggest chip.
After couple of tries to get ip and failed, i started recovery and hoped for the best. It detected and recovered fritz and i can now use web gui.
Lan ports seems to work, lan1 so far, didn't tried others.
Usb is working, it sees my usb flash disk.
I cant get dsl connection, but maybe because i need annex A, i am now compiling freetz with EN interface and hope it will work.
Wlan is strange, it says in gui it is on, and led flashes for some time but i cant find it on my phone nor on my desktop. After some time wlan led goes off but in gui still says that wlan is on.
Phone rings on fon1 when i configure it, but cant get dial tone to call outside nor it rings if i call my home number from cell phone.
Is the y-cable for 7170 same as for 7390?
I compiled freetz while i was writting this post and it says it is not for my hardware. I guess i will need to change my HWRevision from ADAM2 ftp.
I am sleepy. See you tomorrow!
I flashed international multi-anex version of firmware with rukerneltool, still no dsl or phone signal. Looks like phone part may be damaged. While testing, another coil started beeping and getting hot for couple of minutes, then it stoped beeping but heat is still there. Will look into that later.
No change for wlan also, it say its on, led flashes, atheros chips get a little bit warm, but i see no signal on other devices. Wlan button working as it should, regarding to wlan led.
Lan2 port works.
Is it normal to have bootloader version 1.947 on 7390? I found this out while i was trying to put international firmware on 7390. On wehavemorefun wiki it says that 1947 is for fritz 7340 and that 7390 should have bootloader version 1819.
I didn't touched the bootloader, it was in device after i revive it and used recovery image to bring it to life.
Can this (bootloader) make problems? If so, where can i get 1819 version for download?
Thanks!
More info :)
I found after looking again at wiki that bootloader is ok.
I made serial (rs-232) connection to the router and this is the log from booting:
(AVM) EVA Revision: 1.947 Version: 1947
(C) Copyright 2005 AVM Date: Jun 30 2010 Time: 17:28:10 (8) 2 0x0-0x340D
[FLASH:] MACRONIX Uniform-Flash 16MB 64 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 128 sectors a 128kB)
[SYSTEM:] IKANOS on 500MHz/166MHz
[RESERVED:] 0x6000000 - 0x6800000
Eva_AVM >...................................Linux version 2.6.28.10 (jpluschke@EmbeddedVM) (gcc version 4.6.1 (Buildroot 2011.08) ) #1 Fri Apr 20 12:19:44 CEST 2012
argc 6 arg gocommand env HWRevision
[prom_init] 0x810202b0
[prom_init] 0x810102b0 [0]
[prom_init] 0x810102f0 [1]
[prom_init] 0x81010330 [2]
[prom_init] switch to ram location
[prom_init] envp[0]= "HWRevision"="156"
[prom_init] envp[2]= "HWSubRevision"="3"
[prom_init] envp[4]= "ProductID"="Fritz_Box_7390"
[prom_init] envp[6]= "SerialNumber"="0000000000000000"
[prom_init] envp[8]= "annex"="B"
[prom_init] envp[10]= "autoload"="yes"
[prom_init] envp[12]= "bootloaderVersion"="1.947"
[prom_init] envp[14]= "bootserport"="tty0"
[prom_init] envp[16]= "country"="99"
[prom_init] envp[18]= "cpufrequency"="500000000"
[prom_init] envp[20]= "firstfreeaddress"="0x810C9834"
[prom_init] envp[22]= "firmware_info"="84.05.22"
[prom_init] envp[24]= "firmware_version"="avme"
[prom_init] envp[26]= "flashsize"="0x01000000"
[prom_init] envp[28]= "kernel_args"="annex=A"
[prom_init] envp[30]= "language"="en"
[prom_init] envp[32]= "maca"="C0:25:06:xx:xx:xx"
[prom_init] envp[34]= "macb"="C0:25:06:xx:xx:xx"
[prom_init] envp[36]= "macwlan"="C0:25:06:xx:xx:xx"
[prom_init] envp[38]= "macwlan2"="C0:25:06:xx:xx:xx"
[prom_init] envp[40]= "macdsl"="C0:25:06:xx:xx:xx"
[prom_init] envp[42]= "memsize"="0x08000000"
[prom_init] envp[44]= "modetty0"="38400,n,8,1,hw"
[prom_init] envp[46]= "modetty1"="38400,n,8,1,hw"
[prom_init] envp[48]= "mtd1"="0x9F020000,0x9FF00000"
[prom_init] envp[50]= "mtd2"="0x9F000000,0x9F020000"
[prom_init] envp[52]= "mtd3"="0x9FF00000,0x9FF80000"
[prom_init] envp[54]= "mtd4"="0x9FF80000,0xA0000000"
[prom_init] envp[56]= "my_ipaddress"="192.168.178.1"
[prom_init] envp[58]= "prompt"="Eva_AVM"
[prom_init] envp[60]= "req_fullrate_freq"="166666666"
[prom_init] envp[62]= "sysfrequency"="166666666"
[prom_init] envp[64]= "tr069_passphrase"="xxx"
[prom_init] envp[66]= "tr069_serial"="xxx"
[prom_init] envp[68]= "urlader-version"="1947"
[prom_init] envp[70]= "usb_board_mac"="C0:25:06:xx:xx:xx"
[prom_init] envp[72]= "usb_device_id"="0x0000"
[prom_init] envp[74]= "usb_manufacturer_name"="AVM"
[prom_init] envp[76]= "usb_revision_id"="0x0000"
[prom_init] envp[78]= "usb_rndis_mac"="C0:25:06:xx:xx:xx"
[prom_init] envp[80]= "wlan_key"="xxxxxxx"
memsize  board_memsize = 134217728
psb_value = 0x0600007f memsize = 0x08000000 xtensa_mem_start = 0x06000000 xtensa_mem_size 0x00800000
wlan_mem_start = 0x05f2c000
arg[1] annex=A
arg[2] memsize=128
arg[3] flash_start=0xBF000000
arg[4] flash_size=16
arg[5] console=ttyS0,115200n8r
board_flash_size 0x01000000
CPU revision is: 0001964c (MIPS 24Kc)
Determined physical RAM map:
 memory: 05f2c000 @ 00000000 (usable)
 memory: 01800000 @ 06800000 (usable)
nid=0 start=0 map=5f9 end=8000 mapsize=1000 mode_bootmen_map=805f9000
Zone PFN ranges:
  Normal   0x00000000 -> 0x00008000
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000000 -> 0x00005f2c
    0: 0x00006800 -> 0x00008000
[request_resource] Kernel code: start 0x10000 < root->start 0x6800000
[request_resource] Kernel data: start 0x388418 < root->start 0x6800000
entering build_all_zonelists()
return from set_zonelist_order()
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 30252
Kernel command line: annex=A memsize=128 flash_start=0xBF000000 flash_size=16 console=ttyS0,115200n8r nor_size=16777216 nand_size=512MB
[0:parse_mtd_size/749] '16777216'
[0:mtdnor_setup/844] nor_size = 0x1000000
[0:mtdnor_setup/851] mtd2 = 0x9F000000,0x9F020000
[0:mtdnor_setup/879] mtd1 = 0x9F020000,0x9FF00000
[0:mtdnor_setup/891] mtd3 = 0x9FF00000,0x9FF80000
[0:mtdnor_setup/903] mtd4 = 0x9FF80000,0xA0000000
[FUSIV] add physmap-flash to the platform device list
[0:parse_mtd_size/749] '512MB'
[0:mtdnand_setup/814] nand_size = 0x20000000
[FUSIV] add direct-avm-nand to the platform device list
[trap_init] cpu_has_ejtag
[trap_init] cpu_has_watch
[trap_init] cpu_has_divec
[trap_init] cpu_has_mcheck
[trap_init] cpu_has_4kex
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00040003
Readback ErrCtl register=00040003
[mips_nmi_setup] setup NMI vector to base 0x80000380
PID hash table entries: 512 (order: 9, 2048 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
ïemory: 114600k/122032k available (3553k kernel code, 7248k reserved, 1356k data, 152k init, 0k highmem)
Calibrating delay loop... 330.75 BogoMIPS (lpj=661504)
Mount-cache hash table entries: 512
kernel_init: started
kernel_init: kernel locked
net_namespace: 636 bytes
NET: Registered protocol family 16
[ikan_gpio_init]
[cpmac] Version: 1.108.1.101 - Revision 811:1778 - Fr 20.04.2012 12:19:40
Fusiv PCI: starting...
registering PCI controller with io_map_base unset
[FUSIV] register 2 platform device(s)
[find_nmi_vector] nmi vector found. Firmware length 0xe8c946 bytes (erase block align 0xe90000) vector gap size 0x100 bytes.
[find_nmi_vector] add 'urlader' size 0x20000 to length
NET: Registered protocol family 8
NET: Registered protocol family 20
ÎET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
ûsimple_profiling] 0 entries 50 min
squashfs: version 3.4 (2008/08/26) Phillip Lougher
Installing knfsd (copyright (C) 1996 [email][email protected][/email]).
æuse init (API version 7.10)
msgmni has been set to 224
alg: No test for stdrng (krng)
io scheduler noop registered (default)
[avm_membench_init]
avm_net_trace: Up and running.
[avm] configured: watchdog event debug
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Apr 20 2012 12:19:09)
[simple-profiling]: 2 performance counters implemented
Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[avm]: AVM Simple Profiling enabled.
[gpio 13]: VX180_GPIO_POLAR: active low
[gpio 13]: GPIO_EDGE_SENSITIVE
[loadcontrol] set auto - scale=1
Serial: 8250/16550 driver1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0xb90a0000 (irq = 29) is a 16450
PPP generic driver version 2.4.2
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[physmap_flash_probe] line=93, doing probes
physmap platform flash device: 01000001 at 1f000000
physmap-flash: Found 1 x16 devices at 0x0 in 16-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
[parse_mtd_partitions] types=cmdlinepart
[parse_mtd_partitions] types=RedBoot
redBoot partition parsing not available
[parse_mtd_partitions] types=find_jffs2
[fusiv_jffs2_parser_function] mtd_info->name physmap-flash mtd_info->index 0 param=0 p_mtd_pat=0x878dac68
[fusiv_jffs2_parser_function] try partition kernel (offset 0x20000 len 15597568)
[parse_mtd_partitions] types=find_squashfs
[fusiv_squashfs_parser_function] mtd_info->name physmap-flash mtd_info->index 0 param=0 p_mtd_pat=0x878dac68
[fusiv_squashfs_parser_function] *p_mtd_pat->name filesystem
[fusiv_squashfs_parser_function] try partition kernel (offset 0x20000 len 15597568 blocksize=20000)
[fusiv_squashfs_parser_function] magic found @pos 0x16e200
[fusiv_squashfs_parser_function]: not enough space for JFFS2!
6 find_squashfs partitions found on MTD device physmap-flash
Creating 6 MTD partitions on "physmap-flash":
0x0016e200-0x00f00000 : "rootfs" (master-size:16777216)
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
[0:fusiv_mtd_add_notifier/624] name rootfs
[0:fusiv_mtd_add_notifier/628] found rootfs
[0:fusiv_mtd_add_notifier/635] use rootfs
[0:fusiv_mtd_add_notifier/639] root device: /dev/mtdblock0 (rootfs)
0x00020000-0x0016e200 : "kernel" (master-size:16777216)
mtd: partition "kernel" doesn't end on an erase block -- force read-only
[0:fusiv_mtd_add_notifier/624] name kernel
[0:fusiv_mtd_add_notifier/668] skip kernel
0x00000000-0x00020000 : "urlader" (master-size:16777216)
[0:fusiv_mtd_add_notifier/624] name urlader
[0:fusiv_mtd_add_notifier/649] set fusiv_urlader_mtd
0x00f00000-0x00f80000 : "tffs (1)" (master-size:16777216)
û0:fusiv_mtd_add_notifier/624] name tffs (1)
[0:fusiv_mtd_add_notifier/657] tffs (1) on Index 3
0x00f80000-0x01000000 : "tffs (2)" (master-size:16777216)
[0:fusiv_mtd_add_notifier/624] name tffs (2)
[0:fusiv_mtd_add_notifier/664] tffs (2) on Index 4
0x00000000-0x01000000 : "reserved" (master-size:16777216)
[0:fusiv_mtd_add_notifier/624] name reserved
[0:fusiv_mtd_add_notifier/668] skip reserved
Generic platform RAM MTD, (c) 2004 Simtec Electronics
AVM Direct NAND driver, © 2008 AVM Berlin
[direct_avm_nand_probe] error output
[NAND] direct NAND: GPIO usage: 16: /CE0 17: /CE1: 20 /WP 18: CLE 19: ALE (0x3)
[direct_avm_nand_probe] irq init
[gpio 21]: VX180_GPIO_POLAR: active high
[gpio 21]: GPIO_EDGE_SENSITIVE
[gpio 7]: VX180_GPIO_POLAR: active high
[gpio 7]: GPIO_EDGE_SENSITIVE
[NAND] !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[NAND] !! MT29F4 erkannt, konnte aber den Hardware-ECC nicht aktivieren -> nutze SW-ECC  !!
[NAND] !!   -Fallback-Layout wird genutzt, welches ein Lesen der Daten erlaubt           !!
[NAND] !!   -YAFFS wird trotzdem massenhaft Warnungen auswerfen -> ECC stimmt halt nicht !!
NAND device: Manufacturer ID: 0x20, Chip ID: 0xdc (ST Micro NAND 512MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 254 at 0x01fc0000
âad eraseblock 288 at 0x02400000
Bad eraseblock 289 at 0x02420000
Bad eraseblock 1312 at 0x0a400000
Bad eraseblock 1313 at 0x0a420000
Bad eraseblock 2336 at 0x12400000
Bad eraseblock 2337 at 0x12420000
Bad eraseblock 3360 at 0x1a400000
Bad eraseblock 3361 at 0x1a420000
Creating 1 MTD partitions on "NAND 512MiB 3,3V 8-bit":
0x00000000-0x20000000 : "nand-filesystem" (master-size:536870912)
[0:fusiv_mtd_add_notifier/624] name nand-filesystem
[0:fusiv_mtd_add_notifier/668] skip nand-filesystem
CAPI Subsystem Rev 1.1.2.8
AVM PA 2.7.4 2012-03-29
AVM PA skb pktinfo at offset 200 size 188
[loadcontrol]module avm_pa registered
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Bridge firewalling registered
Ebtables v2.0 registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
      mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
kernel_init: basic setup done
[squashfs] use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 4dc000: 152k freed
trying /sbin/init
starting pid 28, tty '/dev/ttyS0': '/etc/init.d/rc.S'
tar: removing leading '/' from member names
source files in group 0 ...
/etc/init.d/S00-signal    /etc/init.d/S05-watchdog  /etc/init.d/S09-rtc
/etc/init.d/S01-head      /etc/init.d/S08-tffs
/etc/init.d/S02-led       /etc/init.d/S09-config
TFFS Name Table H
led_modul_Fritz_Box_7390: module license 'unspecified' taints kernel.
Ûled_system_init] Warning: No GPIOs defined for hardware sub-revision 3 (choosing config for sub-revison 0)
[gpio 31]: VX180_GPIO_POLAR: active low
[gpio 31]: GPIO_BOTH_EDGES_SENSITIVE
[gpio 29]: VX180_GPIO_POLAR: active low
[gpio 29]: GPIO_BOTH_EDGES_SENSITIVE
[button_init] name button_both, virtual multipush button
[LED] "wyatt_earp_turn_off_leds" (0x805caec8) loaded
aVM_WATCHDOG: System Init UEberwachung 240 Sekunden
mknod: /var/flash/ar7.cfg: File exists
P-Defaults: do nothing
overwrite annex
rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[avm-rtc]: avm_rtc_probe: register: ret=0x87a1c800
[avm-rtc]: avm_rtc_probe: success
exceute files in group 0 ...
/etc/init.d/E05-basemodules
fusiv library initializing...
Buffer Copy Through DMA is enabled
fusiv library initialized SUCCESSFULLY...
AP2AP fastpath initialized SUCCESSFULLY
 Buffer Manager is initializing...
BMU GIGE clock
Slave Mem Alloc: Req size 32   Ptr2Block 0x191f0000
Load into BM APU Successful !!!
Timers are getting initalized
Timers are initilized SUCCESSFULLY...
periApDriverInit: doneSlave Mem Alloc: Req size 32   Ptr2Block 0x191f0020
 *******LOAD firmware to AP:PERI_ID result:0Load into PERI_AP APU Successful !!!
cpmac0: Netpro Sierra Ethernet found at 0xb9110000, irq 14
GIGE 1 clock dev->baseAddr b9110000
Setting unknown egress to SPA
Slave Mem Alloc: Req size 32   Ptr2Block 0x191f0040
Ethernet Driver is initialized SUCCESSFULLY
 ACL-AP is initializing...
ACL major allocated is 201
Slave Mem Alloc: Req size 32   Ptr2Block 0x191f0060
Configuring host ACL Layer-2 ruleset (128/4 Rules/Intf)
Intf	Addr
0	07a84000
1	07a84e00
2	07a85c00
3	07a86a00
Configuring host ACL Layer-3 ruleset (128/4 Rules/Intf)
Intf	Addr
0	07a88000
1	07a88e00
2	07a89c00
3	07a8aa00
Load into ACL_AP APU Successful !!!
Need to run mknod ...
bmedrv_init: Registered BME device with Major number 247
Request Region 0xa6000000 - 0xa67fffff
bmedrv_init: Region 0xa6000000 - 0xa67fffff allocated successfully
BME Driver has been loaded SUCCESSFULLY
group 0 done ...
source files in group 1 ...
/etc/init.d/S10-html        /etc/init.d/S15-filesys
/etc/init.d/S10-vm          /etc/init.d/S17-isdn
/etc/init.d/S11-config_def  /etc/init.d/S17-tam
/etc/init.d/S12-default
checkempty: : No such file or directory
modprobe: module nand not found in modules.dep
[yaffs] driver is loaded
[yaffs] nand-mtd: mtd6: 20000000 00020000 "nand-filesystem"
yaffs: dev is 32505862 name is "mtdblock6" rw
yaffs: passed flags ""
[yaffs] Internal Memory assigned @ /var/media/ftp
[Internal Memory] is NOT empty
æRITZ
[Internal Memory] initially filling skipped
mknod: /dev/
[avm_debug]redirect kernel-messages (/dev/debug)
capi20: File exists
[piglet]use gpio-settings for 156
patch_dectfw: C13BE000, totallen = 70047(1119F)
patch_dectfw: patch_adress: F1038 max_len: 26 with Version 2 Len: 17
dect_loader: fast-bootmode
ª
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' successfull
[piglet]bitfile '/lib/modules/bitfile.bit'
[piglet] try to preload in progress-context: /lib/modules/bitfile.bit
øBIT_End:DONE didn't went high
[piglet] Failed: write data im fastmode - retry slow
system-load 6 curr: modprobe runnable: 4
[piglet] bitfile 169309 bytes done
[piglet] "wyatt_earp_unload_xilinx" loaded
[pcmlink]svn: 1552
[4294896650][isdn]svn:2937
driver params overwritten io_addr=0x0 irq_num=0
[pcmlink]chrony-support
[adsp_load] file loaded svnVersion 34
[4294896652]PCMLINK-Version(Fusiv): 6.1552 - dsp: 34 time 12:19:21 date Apr 20 2012
[4294896664]PCMLINK: Version 6.552 Codecslots=13 Slics=2 Pots=1 TE=2 NT=2 DECT=4 (IA3222)  DSP-EC: 0
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
[4294897065][DECTDRV_ERR] avm_dect driver init
[4294897065][DECTDRV_ERR] [avm_dect]avm_dect_thread: start
dect_uicp_from_dect, ignore 8 bytes, dect_manager not up: 2F 7B
dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: F6 14
TAM: create directory /data/tam
exceute files in group 1 ...
/etc/init.d/E15-device
mknod led c 249
mknod tffs c 250
mknod avm_power c 251
mknod debug c 252
mknod avm_event c 253
mknod capi_oslib c 68
mknod dect_io c 227
group 1 done ...
source files in group 2 ...
/etc/init.d/S21-udev
exceute files in group 2 ...
group 2 done ...
source files in group 3 ...
/etc/init.d/S30-ledcfg
exceute files in group 3 ...
group 3 done ...
source files in group 4 ...
/etc/init.d/S40-swap.sh   /etc/init.d/S44-hostname  /etc/init.d/S48-configd
/etc/init.d/S42-ptest     /etc/init.d/S46-usb
Jan  1 01:00:19 udevd[280]: specified group 'tty' unknown
Jan  1 01:00:19 udevd[280]: specified group 'dialout' unknown
Jan  1 01:00:19 udevd[280]: specified group 'kmem' unknown
Jan  1 01:00:19 udevd[280]: specified group 'video' unknown
Jan  1 01:00:19 udevd[280]: specified group 'audio' unknown
Jan  1 01:00:19 udevd[280]: specified group 'lp' unknown
Jan  1 01:00:19 udevd[280]: specified group 'disk' unknown
Jan  1 01:00:19 udevd[280]: specified group 'floppy' unknown
Jan  1 01:00:19 udevd[280]: specified group 'cdrom' unknown
Jan  1 01:00:19 udevd[280]: specified group 'tape' unknown
ramzswap: /dev/ramzswap0 initialized: disksize_kb=16384/etc/init.d/rc.S: /etc/init.d/S40-swap.sh: line 10: /sbin/rzscontrol: not found
Adding 16376k swap on /dev/ramzswap0.  Priority:-1 extents:1 across:16376k
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ïount: mounting sysfs on /sys failed: Device or resource busy
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: Ikanos On-Chip EHCI Host Controller
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: new USB bus registered, assigned bus number 1
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: irq 35, io mem 0x19230000
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
avm_net_trace: New net trace device 'usb1' registered with minor 161.
EHCI USB 2.0 Host started
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
drivers/usb/host/ohci-ikf68xx.c: Probing USB OHCI
drivers/usb/host/ohci-ikf68xx.c: starting IKF68XX OHCI USB Host Controller
drivers/usb/host/ohci-ikf68xx.c: Clock to USB host has been enabled
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: Ikanos On-Chip OHCI Host Controller
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: new USB bus registered, assigned bus number 2
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: irq 35, io mem 0x19240800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
avm_net_trace: New net trace device 'usb2' registered with minor 162.
OHCI USB 1.1 Host started
exceute files in group 4 ...
/etc/init.d/E40-dsl   /etc/init.d/E46-net   /etc/init.d/E47-voip
system-load 9 curr: capi_oslib/0 runnable: 8
ûtart_xdsl: DSLMODE=0 ANNEX=A DIAGNOSE=no
[dsl_ikanos] starting vdsld
[dsl_ikanos] dsldiag is not enabled
[dsl_ikanos] CPE start address is a6000000
[dsl_ikanos] Initializing BME 0
[dsl_ikanos] Initializing BME 1
ipos system initialized
[dsl_ikanos] avm_ATA_handle. Mode 0 not supported
[dsl_ikanos] BME 1 is coming up
[dsl_ikanos] b1p0  iposBmeStartBlk cmdtag 0 status: IN PROGRESS
cpe> [dsl_ikanos] Transfer of NON COMPRESSED /var/dsl/dspfw/Vx180Code.bin to SDRAM Successful. Transferred bytes = 1525842
ûdsl_ikanos] BmeHw: Downloading BME 1 software.....
[4294898249][pcmlink]error: trigger too late 331288 usec (CBA1363B D090FA6A D0916F50)
[4294898249]avm_DebugSignal: 0 kernel info: 0
[4294898249][avmdebug] push supportdata
[4294898249][avmdebug]push_mail: failed with ret=-2
[dsl_ikanos] BmeHw: Bme 1 software code downloaded successfully
[dsl_ikanos] deleting /var/dsl/dspfw/Vx180Code.bin[dsl_ikanos] b1p0  iposBmeStartBlk cmdtag 0 status: COMPLETE
cpe> dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: F6 14
[dsl_ikanos] AVM msg received: header addr 0x40168e04, size 16 expected struct size = 16
[dsl_ikanos] avmMsgBoxHandleTrigger entryPtr=0x402df50c OUR rdPos=0 BME rdPos=0 wrPos=36 bufLen=16384
[dsl_ikanos] AVM MsgBox: diagFileBuf = (nil) diagCurrPos = (nil) !!!
[dsl_ikanos] avm_MsgBox disabled
 alm freq 20
 status freq 30
[dsl_ikanos] b1p0  iposPeriodicReportEnable cmdtag 99 status: IN PROGRESS
cpe> kdsldmod: init start (Apr 20 2012 12:45:53) sizeof(struct sk_buff)=536
kdsldmod: init done
[dsl_ikanos] b1p0  iposPeriodicReportEnable cmdtag 99 status: COMPLETE
cpe> /var/dsl/config/dslSavedConfig.conf file not found
[dsl_ikanos] isBBBHw = 1
OamOptionMask Set to 3
 taskUi: profileNum = 2 Sizeof ipos_port_profile=144
[dsl_ikanos] dsl_params_get_handle invoked
[dsl_ikanos] DSL STATS structure from BME len=5376 from KERNEL len=5376
[dsl_ikanos] CPE Vendor Serial Number = C025061BA341 F!Box7390 84.05.22
[dsl_ikanos] dsl_config_set_handle invoked, config type=1 len=64
14
eth: port 0 status 2 throttle 0
eth: port 1 status 1 throttle 1
eth: port 2 status 1 throttle 1
eth: port 3 status 1 throttle 1
rc.wlan: Start WLAN...
13
WLAND:[00638]:01:00.29:Build = Apr 20 2012 12:55:14
Jan  1 01:00:30 ctlmgr[618]: WLANLIB: my_wlan_init:513: svn revision 1123
12
Jan  1 01:00:30 ctlmgr[618]: [PLC ERROR] homeplugnet open failed with -1
[dsl_ikanos] avm_ATA_handle 10
ADDRCONF(NETDEV_UP): eth0: link is not ready
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
ADDRCONF(NETDEV_UP): wan: link is not ready
device wan entered promiscuous mode
Jan  1 01:00:31 multid[629]: DHCPD on lan:0 skipped, is virtual interface
Jan  1 01:00:31 dsld[660]: voip: ppptarget voip disabled, ignored
Jan  1 01:00:31 multid[629]: call pupnpdev_start_onlinestore
11
Jan  1 01:00:31 multid[629]: call pupnpdev_start_usb
Jan  1 01:00:31 multid[629]: DEBUG: upnpdev_start_usb
Jan  1 01:00:32 telefon[675]: use clock_gettime(CLOCK_MONOTONIC)!
Please enter console password:
Supervisor mode
      BME Reference board API Menu
Ikanos Communications Copyright 2000-2008
             Version 9.1.0.10IKF6850
    2) Initiate Reset BME command
    3) Configure System Provision (default values)
    4) Configure Port Provision
    5) Initiate Port Start command
    7) Initiate Port Stop command
    9) Start Loopback Test
   10) Request Brief Port Status
   11) Request Extended Port Status
   12) Display Performance Counters
   13) Get Near End SNR Margin and Attenuation
   15) Display User Logs
   16) Clear User Logs
   20) Display this menu
   21) Modify Port Provision
   31) INI CRC Threshold
   41) Port Error Count Management
   42) Event Log Management
   55) Board Configuration Management
   56) OAM Options Mask Setting
   57) Performance Management Parameter Configuration
   58) Trigger PM Failures
   59) Bitloading Per Tone
   62) GPIO Test
   70) Maintenance Mode
   72) VDSL2 Double Ended Loop Testing (DELT)
   73) Freeze Mode
   90) BME Firmware versions
   91) EFM Pre-emption
   99) Log off/ Go to auto mode
  114) Clear Performance Counters
  127) System training LED blink rate
  131) VDSL CRC Threshold
  140) Internal EOC Commands
  141) Overhead Message Commands
  143) Remote Ethernet Status Report
  150) Bit Swap Commands
  212) Display All Performance Counters
  820) AVM turn off AutoStart
  821) AVM turn on AutoStart
cpe>
*******BME 1 debug monitor*******
Enter opcode for (BME:1) or ? for help: system-load 100 % curr: inetdctl runnable: 5
Jan  1 01:00:32 telefon[675]: NoOldMSNNames
telefon: SIGCHLD PID 695 received!
Jan  1 01:00:33 telefon[675]: WARNING No config file '/var/flash/fx_def' !
Jan  1 01:00:33 telefon[675]: epoll_add failed: File exists
telefon: SIGCHLD PID 708 received!
group 4 done ...
source files in group 5 ...
exceute files in group 5 ...
group 5 done ...
source files in group 6 ...
exceute files in group 6 ...
group 6 done ...
source files in group 7 ...
/etc/init.d/S73-capitcp  /etc/init.d/S75-inetd    /etc/init.d/S76-media
/etc/init.d/rc.S: /etc/init.d/S76-media: line 6: /etc/init.d/rc.media: not found
exceute files in group 7 ...
group 7 done ...
source files in group 8 ...
/etc/init.d/S85-apps
FHEM not found
exceute files in group 8 ...
group 8 done ...
source files in group 9 ...
/etc/init.d/S99-tail
[4294901014][DECTDRV_ERR] API_FP_MAC_START_STOP_REQ 255 -> 0
[4294901015][DECTDRV_ERR] EepromReadExtRecord, record 0 not found (no records)
rdIdx=0   wrIdx=4e   iSize=8004
iP1 0x0  iP2 0x5  iP3 0x3000000  iP4 0x0
writeAfeReg: reg 0x5  data 0x3000000
cpe>
Exiting VDSL client application
run_clock demon started
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (522280 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=3500 NormP=3500 mW -> SumNormP=3500 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1500 NormP=1500 mW -> SumNormP=5000 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=5273 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=8193 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8293 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8393 mW
[avm_power] pm_ressourceinfo_scriptparser not up: F6 14
kdsldmod: init done
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=vdsld_sig_handler: caught signal 1 inside task main
vdsld_sig_handler called with SIGHUP => ignored...
vdsld_sig_handler: caught signal 1 inside task tRestartTask
Changing port profile #2 BAND_PLAN=0x1 PTM MODE=0x0
OamoptionMask 3
optionMask 8[dsl_ikanos] b1p0  iposBmeProvision cmdtag 0 status: IN PROGRESS
cpe> vdsld_sig_handler: caught signal 1 inside task TimerTask
vdsld_sig_handler: caught signal 1 inside task tBmeRcver
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=9333 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=12083 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=14833 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=15239 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=16739 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=160 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=17256 mW
SysRq : Changing Loglevel
Loglevel set to 4
---> reanimated debugbuffer: read=0 write=5992, written=5992 <---
cat: read error: Broken pipe
telefon: SIGHUP received!
vdsld_sig_handler: caught signal 1 inside task OampTask1
vdsld_sig_handler: caught signal 1 inside task OampTask0
vdsld_sig_handler: caught signal 1 inside task tOneSecTask
vdsld_sig_handler*called with SIGHUP => ignored...
vdsld_sig_handler: caught signal 1 inside task tUiTask
Could not open Client TTY device
Please press Enter to activate this console. Jan  1 01:00:35 pbd[676]: received signal: Hangup.
Jan  1 01:00:35 pbd[674]: received signal: Hangup.
Jan  1 01:00:35 pbd[673]: received signal: Hangup.
Jan  1 01:00:35 pbd[670]: received signal: Hangup.
[dsl_ikanos] b1p0  iposBmeProvision cmdtag 0 status: COMPLETE
cpe> [dsl_ikanos] b1p1  iposPmConfig cmdtag 0 status: IN PROGRESS
cpe> [dsl_ikanos] b1p1  iposPmConfig cmdtag 0 status: COMPLETE
cpe> Jan  1 01:00:35 telefon[703]: Stop DECT
[dsl_ikanos] b1p1  iposPortProvision cmdtag 0 status: IN PROGRESS
cpe> Supervisor mode
[dsl_ikanos] b1p1  iposPortStart cmdtag 0 status: IN PROGRESS
cpe>
cpe>
ipos idx: 3 present 36s start 36s diff 0s[dsl_ikanos] b1p1  iposPortStart cmdtag 0 status: FAILED error= 0x82
cpe> [dsl_ikanos] b1p1  iposPortProvision cmdtag 0 status: COMPLETE
cpe> [dsl_ikanos] b1p1  iposPortStart cmdtag 0 status: IN PROGRESS
cpe> telefon: SIGCHLD PID 710 received!
telefon: SIGCHLD PID 779 received!
Anything unusual or interesting?
Still no wifi, ADSL and phone. It looks like it doesen't detect wireles. Is there some comand to list devices, like lspci?
This are loaded modules:
# lsmod
Module                  Size  Used by    Tainted: P
kdsldmod             1223280  4
ohci_hcd               21648  0
ehci_hcd               38928  0
usbcore               150656  3 ohci_hcd,ehci_hcd
ramzswap               20128  1
lzo_decompress          2592  1 ramzswap
lzo_compress            2304  1 ramzswap
dect_io                13472  0
avm_dect              282336  1 dect_io
capi_codec            477664  0
isdn_fbox_fon5        904160  5
pcmlink               314496  3 avm_dect,capi_codec,isdn_fbox_fon5
Piglet_noemif          35120  0
bmedrv                  5712  0
opensrc_lkm             2080  1 bmedrv
aclap_driver_lkm       23696  0
sysKCode_lkm           16608  0
ethdriver_lkm          46560  1 aclap_driver_lkm
periap_driver_lkm      15904  1 ethdriver_lkm
timers_lkm              6416  0
bmdriver_lkm           14944  0
ap2ap_lkm              25984  5 kdsldmod,aclap_driver_lkm,sysKCode_lkm,ethdriver_lkm,bmdriver_lkm
fusivlib_lkm           57376  8 kdsldmod,bmedrv,aclap_driver_lkm,sysKCode_lkm,ethdriver_lkm,periap_driver_lkm,bmdriver_lkm,ap2ap_lkm
rtc_avm                 6288  1 pcmlink
rtc_core               16720  1 rtc_avm
led_modul_Fritz_Box_7390    99472  2
What is the name of wifi module, maybe i could try to manualy load it? Or is it build-in in kernel?
Some advices what to do next?
Danke schon!
New info folks.
This worked perfectly in my case.
There was a spark and now the Fritzbox is alive again :D
sanahosseini8
