[Gigaset Pro] Neue Firmware 02.00.04 für DE900/DE700 IP PRO
jogiwer
9 Sep 2009
Es gibt mal wieder Neuigkeiten unter
http://gigaset.com/pro/hq/en/product/GIGASETDE900IPPRO.html?tab=downloads
Sieht ja so aus, als wenn die Features bei Gigaset quartalsweise erzeugt werden ...
Viele Grüße,
Jogi
Gigaset DE900 IP PRO, DE 700 IP PRO - Firmware update 11/2012 (Version 02.00.04)
Problems fixed:
1. After being retrieved from hold, SRTP voice becomes destroyed
2. When using Internet Radio DUT reboots after a sequence of softkey presses
3. Autoprovisining: No SIP registration after checksync
4. Analog clock screensaver not working
5. Device inactive after pressing programmable key with invalid XML-content
6. Phone sends DHCP release when rebooting (configured at static IP)
7. One digit is deleted in Next Call anonymous
8. Lack of Dial SK in LDAP directory entry
9. Issues with Call transfer on particular provider platform, bad audio quality when connected to 2nd person
10. Sipgate interop problem solved with Hold, Transfer & Conference by DTMF codes
11. Call transfer to PSTN number doesn't work with particular provider
12. Problem with static IP while using STUN server of particular provider
13. Request for dynamic IP address even if configured to static IP
14. Improved translation when editing contact
15. If call waiting account 1 deactivated, also on account 2 no calls can be received
16. Call transfer problem within particular provider environment
#Kuddel#
