Bad behavior of transmission with cifsmount drives
e-r-a-n
4 Okt 2012
I have in my network the (partially) following config:
1. tv
2. raspberry pi
3. fritz 7390
4. 2 x 3.5" 1TB hard drives
1+2 connected with hdmi
2+3 with ethernet
2+4 with usb
the raspberry pi shares the hdds over the network under username/password
the fritzbox 7390 is running freetz-trunk 10772 84.05.51 rev25072
fritzbox is running, among other packages, transmission & cifsmount
Using cifsmount, I defined share1 as //[RPI-IP]/devices with user/pass and its mounted to /var/media/ftp/raspbmc/
using transmission, i defined base directory to be somewhere in /var/media/ftp/raspbmc (downloading directly to the smb shared drive)
every short time (like few minutes) I get a connection timeout from transmission remote and every torrent says "Unable to save resume file: No such file or directory"
I suspect that it disconnects & connects randomly, yet not sure if its truly whats happening.
can anyone suggests a way to fix it?
tdxchris92
