Mit dieselben konfiguration und selber .config habe ich verschiedene Probleme....
Ich denke das die NAS nicht funktioniert beim 7390 6.03 weil ich kein Kernel Replace machen kann.
Hier sind die änderungen im .config
freetz@freetz:~/trunk$ diff .config .config.original
- 7390 5.51 - (Kernel Replace) Alles funktioniert aber SIP war gehacked und traue firmware nicht mehr
- 7390 6.03 - (Kein Kernel Replace) NAS funktioniert nicht
- 7490 6.04 - (Kernel Replace) WiFi stopt eine Weile
10c10
< # FREETZ_USER_LEVEL_BEGINNER is not set
> FREETZ_USER_LEVEL_BEGINNER=y
12,14c12
< FREETZ_USER_LEVEL_EXPERT=y
< FREETZ_SHOW_ADVANCED=y
< FREETZ_SHOW_EXPERT=y
> # FREETZ_USER_LEVEL_EXPERT is not set
81,87c79,80
< # Custom
< # FREETZ_TYPE_CUSTOM is not set
< # FREETZ_TYPE_LANG_DE is not set
< FREETZ_TYPE_LANG_EN=y
> FREETZ_TYPE_LANG_DE=y
> # FREETZ_TYPE_LANG_EN is not set
91d83
< # FREETZ_TYPE_FIRMWARE_EWE_05_5X is not set
93,94c85
< FREETZ_TYPE_LANGUAGE="en"
< # FREETZ_TYPE_ALIEN_HARDWARE is not set
> FREETZ_TYPE_LANGUAGE="de"
100,107d90
< # Replace kernel (not available, no sources by AVM)
< # SquashFS options
125,126c108,109
< FREETZ_REMOVE_AHA=y
< FREETZ_REMOVE_AURA_USB=y
> # FREETZ_REMOVE_AHA is not set
> # FREETZ_REMOVE_AURA_USB is not set
130,131c113,114
< FREETZ_REMOVE_FHEM=y
< FREETZ_REMOVE_AVM_VPN=y
> # FREETZ_REMOVE_FHEM is not set
> # FREETZ_REMOVE_AVM_VPN is not set
136c119,120
< # FREETZ_REMOVE_BRANDING_avme is not set
> # FREETZ_REMOVE_BRANDING_1und1 is not set
> # FREETZ_REMOVE_BRANDING_avm is not set
154,157c138
< FREETZ_REMOVE_TR069=y
< FREETZ_REMOVE_TR069_FWUPDATE=y
< FREETZ_REMOVE_TR069_HTTPSDL=y
< # FREETZ_REMOVE_TR069_PROVIDERS is not set
> # FREETZ_REMOVE_TR069 is not set
160c141
< FREETZ_REMOVE_KIDS=y
> # FREETZ_REMOVE_KIDS is not set
166d146
< # FREETZ_REMOVE_WLAN is not set
175c155,157
< FREETZ_PATCH_ATA=y
> # FREETZ_PATCH_VCC is not set
> # FREETZ_PATCH_ATA is not set
> # FREETZ_ADD_REGEXT_GUI is not set
201,204d182
< # Replace OpenSSL libraries (not available, requires openssl-0.9.8)
206d183
< # FREETZ_REPLACE_ONLINECHANGED is not set
212d188
< # FREETZ_ENFORCE_URLADER_SETTINGS is not set
225c201
< FREETZ_AVMDAEMON_DISABLE_TR069=y
> # FREETZ_AVMDAEMON_DISABLE_TR069 is not set
237,241d212
< # *** not all packages support selected language ***
< # FREETZ_SELECTED_LANG_ONLY is not set
296,304c267
< FREETZ_PACKAGE_DROPBEAR=y
< # FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER is not set
< # FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
< FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
< FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
< # FREETZ_PACKAGE_DROPBEAR_UTMP is not set
< # FREETZ_PACKAGE_DROPBEAR_WTMP is not set
< # FREETZ_PACKAGE_DROPBEAR_STATIC is not set
< # FREETZ_PACKAGE_DROPBEAR_NONFREETZ is not set
> # FREETZ_PACKAGE_DROPBEAR is not set
378c341
< FREETZ_PACKAGE_NETCAT=y
> # FREETZ_PACKAGE_NETCAT is not set
385,388c348
< # nfs-utils (not available, no sources by AVM)
> # FREETZ_PACKAGE_NFS_UTILS is not set
402,409c362,363
< # Build OpenSSH client (ssh) (not available, provided by dropbear)
< # Build OpenSSH secure copy utility (scp) (not available, provided by dropbear)
> # FREETZ_PACKAGE_OPENSSH_ssh is not set
> # FREETZ_PACKAGE_OPENSSH_scp is not set
424,427d377
< # Point-to-Point (not available, no sources by AVM)
462c412
< FREETZ_PACKAGE_SUDO=y
> # FREETZ_PACKAGE_SUDO is not set
465,466c415
< FREETZ_PACKAGE_TCPDUMP=y
< FREETZ_PACKAGE_TCPDUMP_MINI=y
> # FREETZ_PACKAGE_TCPDUMP is not set
494,495c443
< FREETZ_PACKAGE_WGET=y
< # FREETZ_PACKAGE_WGET_WITH_SSL is not set
> # FREETZ_PACKAGE_WGET is not set
530,538c478
< # FREETZ_PACKAGE_VIRTUALIP_CGI is not set
< FREETZ_PACKAGE_ZABBIX=y
< FREETZ_PACKAGE_ZABBIX_agentd=y
< FREETZ_PACKAGE_ZABBIX_AGENTD_CGI=y
< FREETZ_PACKAGE_ZABBIX_AGENTD_SUPPORT=y
< # FREETZ_PACKAGE_ZABBIX_server is not set
< # FREETZ_PACKAGE_ZABBIX_proxy is not set
< # FREETZ_PACKAGE_ZABBIX_sender is not set
< # FREETZ_PACKAGE_ZABBIX_get is not set
> # FREETZ_PACKAGE_ZABBIX is not set
543,544c483,484
< FREETZ_PACKAGE_AUTHORIZED_KEYS=y
< FREETZ_PACKAGE_AVM_FORWARDING=y
> # FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
> # FREETZ_PACKAGE_AVM_FORWARDING is not set
547,551c487,488
< # NFSD CGI (not available, no sources by AVM)
< FREETZ_PACKAGE_ONLINECHANGED_CGI=y
> # FREETZ_PACKAGE_NFSD_CGI is not set
> # FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
561,564d497
< # Shared libraries
585c518
< FREETZ_LIB_libuClibc__=y
> # FREETZ_LIB_libuClibc__ is not set
667c600
< FREETZ_LIB_libz=y
> # FREETZ_LIB_libz is not set
689c622
< FREETZ_LIB_libntfs=y
> # FREETZ_LIB_libntfs is not set
772c705
< FREETZ_LIB_libncurses=y
> # FREETZ_LIB_libncurses is not set
781,802c714
< FREETZ_SHARE_terminfo=y
< # FREETZ_SHARE_terminfo_showall is not set
< FREETZ_SHARE_terminfo_ansi=y
< FREETZ_SHARE_terminfo_gnome=y
< FREETZ_SHARE_terminfo_konsole=y
< FREETZ_SHARE_terminfo_linux=y
< FREETZ_SHARE_terminfo_putty=y
< FREETZ_SHARE_terminfo_rxvt=y
< FREETZ_SHARE_terminfo_screen=y
< FREETZ_SHARE_terminfo_screenMINUSw=y
< FREETZ_SHARE_terminfo_sun=y
< FREETZ_SHARE_terminfo_vt100=y
< FREETZ_SHARE_terminfo_vt102=y
< FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
< FREETZ_SHARE_terminfo_vt102MINUSw=y
< FREETZ_SHARE_terminfo_vt200=y
< FREETZ_SHARE_terminfo_vt220=y
< FREETZ_SHARE_terminfo_vt52=y
< FREETZ_SHARE_terminfo_xterm=y
< FREETZ_SHARE_terminfo_xtermMINUS256color=y
< FREETZ_SHARE_terminfo_xtermMINUScolor=y
< FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
> # FREETZ_SHARE_terminfo is not set
830c742
< FREETZ_LIB_libdnet=y
> # FREETZ_LIB_libdnet is not set
833c745
< FREETZ_LIB_libpcap=y
> # FREETZ_LIB_libpcap is not set
872c784
< FREETZ_LIB_libpcre=y
> # FREETZ_LIB_libpcre is not set
887c799
< FREETZ_LIB_libutil=y
> # FREETZ_LIB_libutil is not set
928c840
< FREETZ_LIB_liblua=y
> # FREETZ_LIB_liblua is not set
960c872
< # Kernel modules (not available, no sources by AVM)
> # block
961a874
> # FREETZ_MODULE_block2mtd is not set
964c877
< # Busybox applets
> # ndas
965a879,984
> # FREETZ_MODULE_ndas_block is not set
> # FREETZ_MODULE_ndas_core is not set
> # FREETZ_MODULE_ndas_sal is not set
> # crypto
> # FREETZ_MODULE_crypto_blkcipher is not set
> # FREETZ_MODULE_crypto_hash is not set
> # FREETZ_MODULE_arc4 is not set
> # FREETZ_MODULE_sha256_generic is not set
> # drivers
> # FREETZ_MODULE_loop is not set
> # FREETZ_MODULE_nbd is not set
> # FREETZ_MODULE_cdrom is not set
> # FREETZ_MODULE_capiconn is not set
> # FREETZ_MODULE_nand is not set
> # FREETZ_MODULE_ohio_nand is not set
> # FREETZ_MODULE_dummy is not set
> # FREETZ_MODULE_ppp_deflate is not set
> # FREETZ_MODULE_pppoe is not set
> # FREETZ_MODULE_pppox is not set
> # FREETZ_MODULE_ppp_mppe_mppc is not set
> # FREETZ_MODULE_scsi_mod is not set
> # FREETZ_MODULE_sd_mod is not set
> # FREETZ_MODULE_sg is not set
> # FREETZ_MODULE_sr_mod is not set
> # FREETZ_MODULE_usblp is not set
> # FREETZ_MODULE_usb_storage is not set
> # FREETZ_MODULE_usbmon is not set
> # FREETZ_MODULE_usbip is not set
> # FREETZ_MODULE_usbip_common_mod is not set
> # FREETZ_MODULE_usbserial is not set
> # FREETZ_MODULE_ipaq is not set
> # FREETZ_MODULE_cp2101 is not set
> # FREETZ_MODULE_pl2303 is not set
> # FREETZ_MODULE_ftdi_sio is not set
> # FREETZ_MODULE_bfusb is not set
> # FREETZ_MODULE_btusb is not set
> # FREETZ_MODULE_firmware_class is not set
> # FREETZ_MODULE_dm_mod is not set
> # FREETZ_MODULE_dm_crypt is not set
> # FREETZ_MODULE_option is not set
> # fs
> # FREETZ_MODULE_autofs4 is not set
> # FREETZ_MODULE_cifs is not set
> # FREETZ_MODULE_coda is not set
> # FREETZ_MODULE_ext2 is not set
> # FREETZ_MODULE_ext4 is not set
> # FREETZ_MODULE_fat is not set
> # FREETZ_MODULE_hfs is not set
> # FREETZ_MODULE_hfsplus is not set
> # FREETZ_MODULE_fuse is not set
> # FREETZ_MODULE_iso9660 is not set
> # FREETZ_MODULE_jbd2 is not set
> # FREETZ_MODULE_lockd is not set
> # FREETZ_MODULE_mini_fo is not set
> # FREETZ_MODULE_minix is not set
> # FREETZ_MODULE_nfsd is not set
> # FREETZ_MODULE_exportfs is not set
> # FREETZ_MODULE_nfs is not set
> # FREETZ_MODULE_nls_cp437 is not set
> # FREETZ_MODULE_nls_cp852 is not set
> # FREETZ_MODULE_nls_iso8859_15 is not set
> # FREETZ_MODULE_nls_iso8859_1 is not set
> # FREETZ_MODULE_nls_utf8 is not set
> # FREETZ_MODULE_reiserfs is not set
> # FREETZ_MODULE_udf is not set
> # FREETZ_MODULE_unionfs is not set
> # FREETZ_MODULE_vfat is not set
> # FREETZ_MODULE_msdos is not set
> # FREETZ_MODULE_jffs2 is not set
> # FREETZ_MODULE_mbcache is not set
> # lib
> # FREETZ_MODULE_crc16 is not set
> # FREETZ_MODULE_crc_ccitt is not set
> # FREETZ_MODULE_lzo_compress is not set
> # FREETZ_MODULE_lzo_decompress is not set
> # net
> # FREETZ_MODULE_bluetooth is not set
> # FREETZ_MODULE_bnep is not set
> # FREETZ_MODULE_cls_u32 is not set
> # FREETZ_MODULE_l2cap is not set
> # network scheduler
> # FREETZ_MODULE_sch_cbq is not set
> # FREETZ_MODULE_sch_htb is not set
> # FREETZ_MODULE_sch_llq is not set
> # FREETZ_MODULE_sch_sfq is not set
> # FREETZ_MODULE_sch_tbf is not set
> # FREETZ_MODULE_rfcomm is not set
> # FREETZ_MODULE_sunrpc is not set
1004,1005c1023
< FREETZ_BUSYBOX_FEATURE_UTMP=y
< FREETZ_BUSYBOX_FEATURE_WTMP=y
> # FREETZ_BUSYBOX_FEATURE_UTMP is not set
1120c1138
< FREETZ_BUSYBOX_FEATURE_DATE_NANO=y
> # FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
1134,1135d1151
< FREETZ_BUSYBOX_WHO=y
< # FREETZ_BUSYBOX_USERS is not set
1270c1286
< FREETZ_BUSYBOX_MKTEMP=y
> # FREETZ_BUSYBOX_MKTEMP is not set
1283,1284c1299
< FREETZ_BUSYBOX_DIFF=y
< # FREETZ_BUSYBOX_FEATURE_DIFF_DIR is not set
> # FREETZ_BUSYBOX_DIFF is not set
1386,1388c1401
< FREETZ_BUSYBOX_SU=y
< FREETZ_BUSYBOX_FEATURE_SU_SYSLOG=y
< FREETZ_BUSYBOX_FEATURE_SU_CHECKS_SHELLS=y
> # FREETZ_BUSYBOX_SU is not set
1458c1471
< FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID=y
> # FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
1531d1543
< # FREETZ_BUSYBOX_WALL is not set
1554d1565
< # FREETZ_BUSYBOX_LAST is not set
1565d1575
< # FREETZ_BUSYBOX_RUNLEVEL is not set
1568c1578
< FREETZ_BUSYBOX_STRINGS=y
> # FREETZ_BUSYBOX_STRINGS is not set
1651c1661
< FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE=y
> # FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
1659,1661c1669
< FREETZ_BUSYBOX_TELNET=y
< # FREETZ_BUSYBOX_FEATURE_TELNET_TTYPE is not set
< # FREETZ_BUSYBOX_FEATURE_TELNET_AUTOLOGIN is not set
> # FREETZ_BUSYBOX_TELNET is not set
1685a1694,1697
> FREETZ_BUSYBOX_WGET=y
> FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
> FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
> FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
1723d1734
< # FREETZ_BUSYBOX_FEATURE_UPTIME_UTMP_SUPPORT is not set
1816,1819c1827,1830
< # FREETZ_LANG_DE is not set
< FREETZ_LANG_EN=y
< FREETZ_LANG_STRING="en"
< FREETZ_SECURITY_LEVEL=0
> FREETZ_LANG_DE=y
> # FREETZ_LANG_EN is not set
> FREETZ_LANG_STRING="de"
> FREETZ_SECURITY_LEVEL=1
1839,1842d1849
< # Additional image/box information
1845c1852
< FREETZ_MODIFY_AVM_VERSION=y
> # FREETZ_MODIFY_AVM_VERSION is not set
1847,1857d1853
< # FREETZ_CUSTOM_IMAGE_NAME is not set
< FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
< # FREETZ_REMOVE_DOT_CONFIG is not set
< # Build system ---------------------------
< # Toolchain options
1865d1860
< # FREETZ_KERNEL_GCC_4_6 is not set
1873d1867
< # FREETZ_TARGET_UCLIBC_0_9_32 is not set
1878d1871
< # FREETZ_TARGET_GCC_4_6 is not set
1899,1902d1891
< # Build system options
1909,1912d1897
< # Firmware packaging (fwmod) options
1919,1922d1903
< # Strip options
1924,1927d1904
< # FREETZ_STRIP_LIBRARIES is not set
< # FREETZ_STRIP_MODULES_NONE is not set
< FREETZ_STRIP_MODULES_FREETZ=y
< # FREETZ_STRIP_MODULES_ALL is not set
1929,1932d1905
< # Override options
1945,1946c1918,1919
< FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7390/firmware/english"
< FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.06.03.image"
> FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7390/firmware/deutsch,@1&1/7390"
> FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7390.AnnexB.84.06.03.image"
1949,1950c1922,1925
< FREETZ_DL_SOURCE_MD5="48ac9789ba6052ee335e7cfd37ec3455"
< # FREETZ_AVM_HAS_LABOR is not set
> FREETZ_DL_SOURCE_MD5="c87c11dd6a27619b656f728fc18dcfd5"
> FREETZ_REPLACE_KERNEL_AVAILABLE=y
> FREETZ_REPLACE_MODULE_AVAILABLE=y
> FREETZ_AVM_HAS_LABOR=y
1956c1931
< FREETZ_AVM_HAS_FWEWE_05_5X=y
> # FREETZ_AVM_HAS_FWEWE_05_5X is not set
1974,1975c1949,1950
< # FREETZ_NFS_SUPPORT_AVAILABLE is not set
< # FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE is not set
> FREETZ_NFS_SUPPORT_AVAILABLE=y
> FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE=y
