[Info] Neue Firmware für DE410 IP PRO, DE310 IP PRO
Info
Release 2.00.12
Bugfixes
•Redialling on the headset not possible
•Invite is rejected, is not rejected by other Gigaset devices
•Bad voice quality
•Prefix "0" before Redial is not dialled when handset is off hook
•DHCP BAD_ADDRESS
•Device does not recognise new DNS values without reboot
•ÄÖÜ are not displayed correctly
Release Candidate 02.00.13
DE310/410 IP PRO 02.00.13 (Release Candidate)
Date: July 2015
Bugfixes
•Changing volume from call to call
•Volume of the remote side’s speech is 0 for a short time
•Sometimes the first up to two seconds of a call are missing
•Problem with DTMF event generation when Silence Suppression is enabled
•Entries in the system phonebook are not sorted
•Broadsoft: XSI login via https doesn't work
•TCP BLF not working plus reset of the phone after 3 minutes
•DE_xxx voice is cut for a moment when phone receives INVITE in-dialog
•Stability improvement during incoming call and call forwarding
https://teamwork.gigaset.com/gigawiki/pages/viewpage.action?pageId=312049684
Firmware Release DE310/410 IP PRO 02.00.13
Bugfixes
• Changing volume from call to call
• Volume of the remote side’s speech is 0 for a short time
• Sometimes the first up to two seconds of a call are missing
• Problem with DTMF event generation when Silence Suppression is enabled
• Entries in the system phonebook are not sorted
• Broadsoft: XSI login via https doesn't work
• TCP BLF not working plus reset of the phone after 3 minutes
• DE_xxx voice is cut for a moment when phone receives INVITE in-dialog
• Stability improvement during incoming call and call forwarding
Firmware Beta DE310/410 IP PRO 02.00.14
https://teamwork.gigaset.com/gigawiki/pages/viewpage.action?pageId=341934340
Bugfixes
• Headset volume does not stay on adjusted setting
• DNS SRV Lookup Bug
• Phone doesn't hang up with standard BYE SIP message
• After provisioning, LDAP doesn't work
• Wrong cgi script uses during search contact
• Toggling via consultation key not possible
Firmware Release DE310/410 IP PRO 02.01.00
https://teamwork.gigaset.com/gigawiki/pages/viewpage.action?pageId=372408420
Bugfixes
•Headset volume does not stay on adjusted setting
•DNS SRV Lookup Bug
•Phone doesn't hang up with standard BYE SIP message
•After provisioning, LDAP doesn't work
•Wrong cgi script uses during search contact
•Toggling via consultation key not possible
•Uploaded Menu.xml causes reboot
•Instability during incoming call
•After 15-minutes call connection was broken / additionally reboot appears
•Device frozen after incoming call
•Door inter-phone when call waiting is on
•"System recovery" on display
•XML Dir: Scrolling through search results is not possible
•Device freezes
•[DND]Incoming call blocks some keys on HW
#Kuddel#
