[Frage] vnstat datenbank auf usb datenträger speichern?
Cataclysm_177
4 Okt 2013
Hallo erst mal. Ich hab mich in das Programm vnstat eingearbeitet und wollte die Datenbank(en) auf einen USB Datenträger Speichern.
Im freetz Webinterface hab ich als Speicherort "/var/media/ftp/UStor11/vnstatd/" eingetragen, vnstat legt zwar die Dateinen an aber alle DAtein sind 2784 B gross und bleiben es auch.
Muss ich was umstellen?
# vnStat 1.10 config file
# default interface
Interface "eth0"
### The DatabaseDir should NOT be changed here, use the Freetz-Webinterface!
# location of the database directory
DatabaseDir "/var/lib/vnstat"
# locale (LC_ALL) ("-" = use system locale)
Locale "-"
# on which day should months change
MonthRotate 1
# date output formats for -d, -m, -t and -w
# see 'man date' for control codes
DayFormat    "%x"
MonthFormat  "%b '%y"
TopFormat    "%x"
# characters used for visuals
RXCharacter       "%"
TXCharacter       ":"
RXHourCharacter   "r"
TXHourCharacter   "t"
# how units are prefixed when traffic is shown
# 0 = IEC standard prefixes (KiB/MiB/GiB/TiB)
# 1 = old style binary prefixes (KB/MB/GB/TB)
UnitMode 1
# output style
# 0 = minimal & narrow, 1 = bar column visible
# 2 = same as 1 except rate in summary and weekly
# 3 = rate column visible
OutputStyle 3
# used rate unit (0 = bytes, 1 = bits)
RateUnit 1
# maximum bandwidth (Mbit) for all interfaces, 0 = disable feature
# (unless interface specific limit is given)
MaxBandwidth 13
# interface specific limits
#  example 8Mbit limit for eth0 (remove # to activate):
#MaxBWeth0 8
# how many seconds should sampling for -tr take by default
Sampletime 5
# default query mode
# 0 = normal, 1 = days, 2 = months, 3 = top10
# 4 = dumpdb, 5 = short, 6 = weeks, 7 = hours
QueryMode 0
### You have to set CheckDiskSpace to 0 if you would like to save your databases to /tmp/!
# filesystem disk space check (1 = enabled, 0 = disabled)
CheckDiskSpace 1
# database file locking (1 = enabled, 0 = disabled)
UseFileLocking 1
# how much the boot time can variate between updates (seconds)
BootVariation 15
# log days without traffic to daily list (1 = enabled, 0 = disabled)
TrafficlessDays 1
# vnstatd
# how often (in seconds) interface data is updated
UpdateInterval 60
# how often (in seconds) interface status changes are checked
PollInterval 30
# how often (in minutes) data is saved to file
SaveInterval 2
# how often (in minutes) data is saved when all interface are offline
OfflineSaveInterval 2
# force data save when interface status changes (1 = enabled, 0 = disabled)
SaveOnStatusChange 1
# enable / disable logging (0 = disabled, 1 = logfile, 2 = syslog)
UseLogging 1
# file used for logging if UseLogging is set to 1
LogFile "/var/media/ftp/UStor11/vnstat.log"
# file used as daemon pid / lock file
PidFile "/var/run/vnstatd.pid"
# vnstati
# title timestamp format
HeaderFormat "%x %H:%M"
# show hours with rate (1 = enabled, 0 = disabled)
HourlyRate 1
# show rate in summary (1 = enabled, 0 = disabled)
SummaryRate 1
# layout of summary (1 = with monthly, 0 = without monthly)
SummaryLayout 1
# transparent background (1 = enabled, 0 = disabled)
TransparentBg 0
# image colors
CBackground     "FFFFFF"
CEdge           "AEAEAE"
CHeader         "606060"
CHeaderTitle    "FFFFFF"
CHeaderDate     "FFFFFF"
CText           "000000"
CLine           "B0B0B0"
CLineL          "-"
CRx             "92CF00"
CTx             "606060"
CRxD            "-"
CTxD            "-"
