[Info] FRITZ!Box 6810 LTE FRITZ!OS 06.20 international vom 12.12.2014
S
SF1975
Guest
 Product            : FRITZ!Box 6810 LTE
 Version               : FRITZ!OS 6.20
 Language              : English, French, Italian, Spanish
New with FRITZ!OS 6.20:
LTE: added support for LTE roaming (disabled by default)
LTE: added support for PPP authentication (PAP)
LTE: Interop improvements
Home net: display of MIMO standard in the detailed information about powerline devices
Home net: use of fixed IP addresses via DHCP server improved
Home net: change parental controls profile in the detailed settings for every network device
Internet: VPN connection to Android devices no longer disconnected after one hour
Internet: online counter now able to display higher bandwidths
Internet: when activating MyFRITZ! a random port for https will be selected
Internet: fixes a possibility to circumvent parental controls via guest access
Internet: added Diffie Hellmann Group 5, 14 and 15 for VPN
Internet: TR-069 connection request port is now closed once TR-069 has been deactivated
Internet: BPjM filter only active when country is set to Germany
Security: enhanced security area in wireless LAN settings
Security: assistance in choosing safe passwords
Security: push mails are now sent using SSL encryption by default
Security: import and export the SSL certificate used by your FRITZ!Box
Smart Home: use FRITZ!DECT Repeaters as temperature sensors
Smart Home: display the current temperature in FRITZ!Box GUI and MyFRITZ!App
Smart Home: configure push mail to inform you whenever FRITZ!DECT 200 is switched on or off
Smart Home: send a push mail when the connection to FRITZ!DECT 200 is lost
Smart Home: select individual power consumption value to enable standby
System: notification for important FRITZ!OS updates
System: crashes when using the new push services fixed
System: enables password to be set for the saved settings before an update
System: new FRITZ!OS Updates can be installed automatically (default setting)*
System: several improvements for the update process
System: improved scheduled switching for tablets and smartphones.
Telephony: change to oauth2 for authentication with Google contacts
Telephony: forced speed dial for phonebook entries fixed
Telephony: prefix "**8" is displayed when using Vanity Codes
Telephony: plausibility test for the entry of landline numbers fixed
Telephony: sporadic reboots when using IP telephones fixed
Telephony: improved voice quality in case of parallel data transfer (wireless LAN<->LAN)
Telephony/DECT: for mail reception, encrypted transmission via port 995 is always tried first
Telephony/DECT: improved functionality for Gigaset handsets
Telephony/DECT: ability to set and delete custom ringtones for online contacts
Telephony/DECT: display of current temperature on FRITZ!DECT handsets
Telephony/DECT: improved playback of web radio on FRITZ!DECT handsets
Telephony/DECT: improved sound quality for web radio/podcast/media player
Telephony/DECT: improved update of RSS feeds
Telephony/DECT: FRITZ!Fon C4 - improved automatic brightness adjustment**
Telephony/DECT: support for the new call list with voice messages**
Telephony/DECT: permanent signaling of e-mail on the handset fixed
WLAN: Wireless LAN auto channel can be updated over the user interface
WLAN: initial setup extended for wireless LAN information and setup
WLAN: list of access points in the wireless environment sorted by signal strength
WLAN: WPS for the wireless LAN guest access / private hotspot can be started via FRITZ!Box user interface
WLAN: detailed information about connected wireless devices (Rx/Tx data rate, RSSI value, wireless standard etc.)
WLAN: faster activation of changed wireless LAN settings
WLAN: improved display of the wireless guest access on the main page of the user interface
WLAN: improved printer view
WLAN: direct link to the wireless guest access on the main page
WLAN: MAC address filter moved to WLAN/Security
WLAN: connection by QR code enabled for main AP
* FRITZ!Box can periodically search for a new FRITZ!OS version and automatically update (usually at night); you can change the default setting at System/Update.
** Update of the FRITZ!Fon handset to at least version 3.29 required
Notice:
When updating from a version older than 06.20 the SSL certificate of FRITZ!Box will change. If you are using an app or a program that uses the certificate, there might an error message.
Important: during the update of FRITZ!OS, services like telephony and IPTV will be disconnected temporarily.
Download: >>>klick<<<
