ich habe nach
http://www.fritzmod.net/de/modification/apache/installation/
das Paket apache2_v2.4.6_php_v5.5.14.mipsel.tar auf einem USB-Stick unter /Apache gespeichert und wie beschrieben die config geändert (ja, Ordner Apache mit großem A)
auf der Konsole per putty
gestartet aber per ps keinen Prozes gefunden
im error.log
... hat jemand eine Idee?
Dank vorab
ich habe nach
PHP:
/var/media/ftp/Memorex-CoolDriveB-01/Apache/bin/apache -f /var/media/ftp/Memorex-CoolDriveB-01/Apache/conf/apache.conf
im error.log
PHP:
[Sat Jan 01 01:17:17 2000] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 01 01:17:17 2000] [notice] Digest: done
[Sat Jan 01 01:17:17 2000] [notice] Apache/2.2.17 (Unix) DAV/2 configured -- resuming normal operations
[Sat Jan 01 01:17:34 2000] [error] [client 192.168.178.44] Directory index forbidden by Options directive: /var/tmp/apache/htdocs/
[Sat Jan 01 01:17:34 2000] [error] [client 192.168.178.44] File does not exist: /var/tmp/apache/htdocs/favicon.ico
[Sat Jan 01 01:17:37 2000] [error] [client 192.168.178.44] File does not exist: /var/tmp/apache/htdocs/favicon.ico
[Sat Jan 01 01:28:43 2000] [notice] caught SIGTERM, shutting down
[Sat Jan 01 01:31:02 2000] [notice] Digest: generating secret for digest authentication ...
[Sat Jan 01 01:31:02 2000] [notice] Digest: done
[Sat Jan 01 01:31:02 2000] [notice] Apache/2.2.17 (Unix) DAV/2 configured -- resuming normal operations
[Tue Mar 24 20:13:02.105399 2015] [auth_digest:notice] [pid 2106:tid 1024] AH01757: generating secret for digest authentication ...
[Tue Mar 24 20:13:02.121677 2015] [auth_digest:error] [pid 2106:tid 1024] (2)No such file or directory: AH01762: Failed to create shared memory segment on file /var/apache2/logs/authdigest_shm.2106
[Tue Mar 24 20:13:02.122122 2015] [auth_digest:error] [pid 2106:tid 1024] (2)No such file or directory: AH01760: failed to initialize shm - all nonce-count checking, one-time nonces, and MD5-sess algorithm disabled
[Tue Mar 24 20:13:02.122377 2015] [:emerg] [pid 2106:tid 1024] AH00020: Configuration Failed, exiting
[Tue Mar 24 20:15:21.118859 2015] [auth_digest:notice] [pid 2108:tid 1024] AH01757: generating secret for digest authentication ...
[Tue Mar 24 20:15:21.120636 2015] [auth_digest:error] [pid 2108:tid 1024] (2)No such file or directory: AH01762: Failed to create shared memory segment on file /var/apache2/logs/authdigest_shm.2108
[Tue Mar 24 20:15:21.121070 2015] [auth_digest:error] [pid 2108:tid 1024] (2)No such file or directory: AH01760: failed to initialize shm - all nonce-count checking, one-time nonces, and MD5-sess algorithm disabled
[Tue Mar 24 20:15:21.121359 2015] [:emerg] [pid 2108:tid 1024] AH00020: Configuration Failed, exiting
[Tue Mar 24 20:30:17.102113 2015] [auth_digest:notice] [pid 2119:tid 1024] AH01757: generating secret for digest authentication ...
[Tue Mar 24 20:30:17.104793 2015] [auth_digest:error] [pid 2119:tid 1024] (2)No such file or directory: AH01762: Failed to create shared memory segment on file /var/apache2/logs/authdigest_shm.2119
[Tue Mar 24 20:30:17.105250 2015] [auth_digest:error] [pid 2119:tid 1024] (2)No such file or directory: AH01760: failed to initialize shm - all nonce-count checking, one-time nonces, and MD5-sess algorithm disabled
[Tue Mar 24 20:30:17.105528 2015] [:emerg] [pid 2119:tid 1024] AH00020: Configuration Failed, exiting
[Tue Mar 24 20:31:00.094817 2015] [auth_digest:notice] [pid 2123:tid 1024] AH01757: generating secret for digest authentication ...
[Tue Mar 24 20:31:00.096126 2015] [auth_digest:error] [pid 2123:tid 1024] (2)No such file or directory: AH01762: Failed to create shared memory segment on file /var/apache2/logs/authdigest_shm.2123
[Tue Mar 24 20:31:00.096577 2015] [auth_digest:error] [pid 2123:tid 1024] (2)No such file or directory: AH01760: failed to initialize shm - all nonce-count checking, one-time nonces, and MD5-sess algorithm disabled
[Tue Mar 24 20:31:00.096830 2015] [:emerg] [pid 2123:tid 1024] AH00020: Configuration Failed, exiting
[Tue Mar 24 20:34:49.111814 2015] [auth_digest:notice] [pid 2131:tid 1024] AH01757: generating secret for digest authentication ...
[Tue Mar 24 20:34:49.113138 2015] [auth_digest:error] [pid 2131:tid 1024] (2)No such file or directory: AH01762: Failed to create shared memory segment on file /var/apache2/logs/authdigest_shm.2131
[Tue Mar 24 20:34:49.115408 2015] [auth_digest:error] [pid 2131:tid 1024] (2)No such file or directory: AH01760: failed to initialize shm - all nonce-count checking, one-time nonces, and MD5-sess algorithm disabled
[Tue Mar 24 20:34:49.115672 2015] [:emerg] [pid 2131:tid 1024] AH00020: Configuration Failed, exiting
Dank vorab
