make funktioniert seit dem 26.01.2015 nicht mehr
JokerGermany
7 Aug 2007
Heute freetz-devel geupdatet (svn up) und folgenden Fehler bekommen:
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/array_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/atexit_arm.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/atexit_thread.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/bad_alloc.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/bad_cast.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/bad_typeid.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/class_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/dyncast.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_arm.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_aux_runtime.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_call.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_catch.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_exception.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_personality.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_ptr.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_term_handler.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_terminate.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_tm.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_throw.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_type.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/eh_unex_handler.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/enum_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/function_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/fundamental_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/guard.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/guard_error.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/hash_bytes.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/nested_exception.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/pbase_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/pmem_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/pointer_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/si_class_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/tinfo.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/tinfo2.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/vec.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/vmi_class_type_info.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/vterminate.o: No such file or directory
mips-linux-uclibc-g++: error: src/abi/libsupc/./src/abi/libsupc/cp-demangle.o: No such file or directory
make[1]: *** [src/libuClibc++.so] Fehler 1
make[1]: *** Auf noch nicht beendete Prozesse wird gewartet …
mips-linux-uclibc-ar: src/abi/libsupc/./src/abi/libsupc/array_type_info.o: No such file or directory
make[1]: *** [src/libuClibc++.a] Fehler 1
make[1]: Verzeichnis »/home/henry/Downloads/freetz-devel/source/target-mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/uClibc++-7c90261eb9e5cff4ea3a4e5580e4f2bc7543cb21« wird verlassen
ERROR: Build failed.
make: *** [/home/henry/Downloads/freetz-devel/toolchain/build/mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib/libuClibc++.so.0.2.5] Fehler 1
bei einem neuen Anlauf:
WARNING: The program composite was not found in path.
WARNING: The header file readline/readline.h was not found in /usr/(local/)include.
cmd() { PATH="/home/henry/Downloads/freetz-devel/toolchain/build/mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin:/home/henry/Downloads/freetz-devel/toolchain/build/mips_gcc-4.8.4/mips-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" LD_RUN_PATH="/usr/lib/freetz" make  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/uClibc++-7c90261eb9e5cff4ea3a4e5580e4f2bc7543cb21 CPU_CFLAGS="-march=24kc -mtune=24kc -msoft-float -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CROSS_COMPILE="mips-linux-uclibc-" V=2
make[1]: Verzeichnis »/home/henry/Downloads/freetz-devel/source/target-mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/uClibc++-7c90261eb9e5cff4ea3a4e5580e4f2bc7543cb21« wird betreten
rm -f src/libuClibc++.a
mips-linux-uclibc-ar cr src/libuClibc++.a src/algorithm.o src/associative_base.o src/bitset.o src/char_traits.o src/complex.o src/del_op.o src/del_opnt.o src/del_opv.o src/del_opvnt.o src/deque.o src/eh_alloc.o src/eh_globals.o src/exception.o src/fstream.o src/func_exception.o src/iomanip.o src/ios.o src/iostream.o src/istream.o src/iterator.o src/limits.o src/list.o src/locale.o src/map.o src/new_handler.o src/new_op.o src/new_opnt.o src/new_opv.o src/new_opvnt.o src/numeric.o src/ostream.o src/queue.o src/set.o src/sstream.o src/stack.o src/stdexcept.o src/streambuf.o src/string.o src/utility.o src/valarray.o src/vector.o src/abi/abi.o src/abi/libsupc/./src/abi/libsupc/array_type_info.o src/abi/libsupc/./src/abi/libsupc/atexit_arm.o src/abi/libsupc/./src/abi/libsupc/atexit_thread.o src/abi/libsupc/./src/abi/libsupc/bad_alloc.o src/abi/libsupc/./src/abi/libsupc/bad_cast.o src/abi/libsupc/./src/abi/libsupc/bad_typeid.o src/abi/libsupc/./src/abi/libsupc/class_type_info.o src/abi/libsupc/./src/abi/libsupc/dyncast.o src/abi/libsupc/./src/abi/libsupc/eh_arm.o src/abi/libsupc/./src/abi/libsupc/eh_aux_runtime.o src/abi/libsupc/./src/abi/libsupc/eh_call.o src/abi/libsupc/./src/abi/libsupc/eh_catch.o src/abi/libsupc/./src/abi/libsupc/eh_exception.o src/abi/libsupc/./src/abi/libsupc/eh_personality.o src/abi/libsupc/./src/abi/libsupc/eh_ptr.o src/abi/libsupc/./src/abi/libsupc/eh_term_handler.o src/abi/libsupc/./src/abi/libsupc/eh_terminate.o src/abi/libsupc/./src/abi/libsupc/eh_tm.o src/abi/libsupc/./src/abi/libsupc/eh_throw.o src/abi/libsupc/./src/abi/libsupc/eh_type.o src/abi/libsupc/./src/abi/libsupc/eh_unex_handler.o src/abi/libsupc/./src/abi/libsupc/enum_type_info.o src/abi/libsupc/./src/abi/libsupc/function_type_info.o src/abi/libsupc/./src/abi/libsupc/fundamental_type_info.o src/abi/libsupc/./src/abi/libsupc/guard.o src/abi/libsupc/./src/abi/libsupc/guard_error.o src/abi/libsupc/./src/abi/libsupc/hash_bytes.o src/abi/libsupc/./src/abi/libsupc/nested_exception.o src/abi/libsupc/./src/abi/libsupc/pbase_type_info.o src/abi/libsupc/./src/abi/libsupc/pmem_type_info.o src/abi/libsupc/./src/abi/libsupc/pointer_type_info.o src/abi/libsupc/./src/abi/libsupc/si_class_type_info.o src/abi/libsupc/./src/abi/libsupc/tinfo.o src/abi/libsupc/./src/abi/libsupc/tinfo2.o src/abi/libsupc/./src/abi/libsupc/vec.o src/abi/libsupc/./src/abi/libsupc/vmi_class_type_info.o src/abi/libsupc/./src/abi/libsupc/vterminate.o src/abi/libsupc/./src/abi/libsupc/cp-demangle.o
FB7490
@PeterPawn: auch wenn ich Dein Engagement wirklich sehr bewundere, würde ich doch vorschlagen, solche Posts zu ignorieren. Nur so werden wir es vielleicht schaffen, dass die Leute wieder selbständig werden und sich nicht dauernd bedienen lassen.
Einverstanden, wobei es kürzer (und damit noch weniger "wohlwollend") wohl nicht zu beantworten war ... es ist halt ein schmaler Grat.
Ich werde mich also zurückhalten. :)
löst leider das problem nicht
make: *** [source/target-mips_gcc-4.8.4_uClibc-0.9.33.2-nptl/uClibc++-7c90261eb9e5cff4ea3a4e5580e4f2bc7543cb21/src/libuClibc++.so.0.2.5] Fehler 1
*schieb*
Keine Ahnung wonach ich googlen soll...
Danach habe ich auch nicht gegooglet, weil es nur eine Warnung ist und mein Problem nicht lösen wird....
Der Fehler steht doch im log:
Das System sucht nach der libuClibc++.so.0.2.5
