[Frage] FRITZ!OS 06.20 or freetz with DYMO LabelWriter 450
dolphs
26 Sep 2008
Dear FRITZ!Box users,
I owe an int. f7390, which operates with FRITZ!OS 06.20 and freetz devel-13097 ( from trunk ).
Under " USB Devices " I do see the USB device got indentified as " DYMO DYMO LabelWriter 450 - USB printers Status: Ready ".
So in theory I should be able to use the label writer as a network device ...
Unfortunately I cannot find the " printer " in the network, neither smb ( stipped from OS6 onwards ) or direct TCP/IP ( fritz.box ) on my win8.1 laptop.
Enabling the USB Remote connection for printers gives troubles downloading the software ( javascript not enabled? )
It would be great if the " DYMO Printer utility " can find the labelwriter.
So that let me believe something can be done using freetz, my best guess is to compile in samba 3.6.x and share the printer in the network: any suggestions to make this work in freetz sharing the printer through smb?
for now I found a " workaround ", after restarting the fritzbox it appears " something " is running on 9100; this something is " LPR - RAW Printing " .
root@fritz7390:/var/mod/root# ps |grep lp0
6 root 0 SW< [khelper]
6546 root 872 S N /sbin/printserv -d /dev/usblp0 -p 9100 -c /dev/console
6548 root 880 S N /sbin/printserv -d /dev/usblp0 -p 9100 -c /dev/console
6549 root 872 S N /sbin/printserv -d /dev/usblp0 -p 9100 -c /dev/console
6550 root 876 S N /sbin/printserv -d /dev/usblp0 -p 9100 -c /dev/console
Knowning this I installed the dymo software on my win8.1 pc and next steps:
1/ added printer manually ( the printer I want it not listed )
2/ add a printer using a TCP/IP address or hostname
3/ hostname: fritz.box, port name: dymo (optinal: Query printer and automatically select driver to use )
-- till here it is indeed documented at avm's website --
4/ As printer is not listed and correct driver must be installed, choose " Custom " and click " Settings "
5/ In the Port Settings window check if protocol is " Raw ", port number is set to 9100. Click " OK " and " Next "
6/ Yet Select " DYMO " as Manufacturer, printer " Dymo LabelWriter 450 " as driver and click " Next "
After installing, open DYMO Label software and you should be able to print labels through the fritzbox
Yet if might be a nice have to do this smoother through samba in freetz
Hello
Did you tried...
"http://fritz.box/usb/usb_remote_settings.lua"
Help button on this Page
...already?
Brainbanger
