[Info] Freetz - "AVM/cuma's WebIF tagging" seit FritzOS 6.2x ohne Funktion, Edit: seit 6.50
qwertz.asdfgh
IPPF-Promi
18 Feb 2011
Edit: Lösung s.h. #4.
Edit: Vorschlag für FritzOS Ver. >=6.50 s.h. #6.
mir ist soeben aufgefallen das seit FritzOS 6.2x
FREETZ_TAGGING_CUMA=y
FREETZ_TAGGING_STRING="cuma"
bzw. http://freetz.org/ticket/1470 scheinbar keine Funktion mehr hat.
Build-Umgebungen:
ArchLinux und Ubuntu 14.04.2 LTS, composite (Packet 'ImageMagick') ist jeweils vorhanden.
Es taucht bei processing mod base options > tagging avm webif auch keine Fehlermeldung auf:
STEP 1: UNPACK
unpacking firmware image
Skipping 0 Bytes garbage...removing AVM SquashFS junk bytes
Junk header found, inspecting ...
Junk header found at V1 offset 0xBE0000
Image size encoded in junk block matches real file size, removing junk bytes ... done.
splitting kernel image
unpacking filesystem image
    Reading a different endian SQUASHFS filesystem on build/original/kernel/kernelsquashfs.raw
    6259 inodes (6679 blocks) to write
    created 5567 files
    created 330 directories
    created 605 symlinks
    created 87 devices
    created 0 fifos
unpacking var.tar
done.
detected firmware 7390_de 84.06.23 rev29808 (22.01.2015 14:30:14)
STEP 2: MODIFY
  setting colored style as default
  adding favicon(s) (atomphil)
  patching security level (0)
  integrated FREETZMOUNT
  integrated Box-Info
  integrated FREETZ-Info
  integrated .config (stripped)
  [highlight]tagging avm webif (tag by cuma)[/highlight]
stripping leftover unstripped binaries
    build/modified/filesystem/usr/share/ctlmgr/libwlan.so
    build/modified/filesystem/usr/share/ctlmgr/libplcctlmgr.so
    build/modified/filesystem/bin/wlancfgctl
    build/modified/filesystem/bin/wlancfgconv
    build/modified/filesystem/lib/libdl-0.9.33.2.so
    build/modified/filesystem/lib/libluadsl.so.1.0.0
    build/modified/filesystem/lib/libutil-0.9.33.2.so
    build/modified/filesystem/lib/libcrypt-0.9.33.2.so
    build/modified/filesystem/lib/libluaplc.so
    build/modified/filesystem/lib/libuClibc-0.9.33.2.so
    build/modified/filesystem/lib/libwlancsi.so
    build/modified/filesystem/lib/libwlanparams.so
    build/modified/filesystem/lib/libpthread-0.9.33.2.so
    build/modified/filesystem/lib/librt-0.9.33.2.so
    build/modified/filesystem/lib/ld-uClibc-0.9.33.2.so
    build/modified/filesystem/lib/libdslsmiface.so.0.0.0
    build/modified/filesystem/lib/libm-0.9.33.2.so
done.
STEP 3: PACK
  checking for left over Subversion directories
  integrate freetz info file into image
packing var.tar
creating filesystem image
  SquashFS block size: 64 kB (65536 bytes)
merging kernel image
  kernel image size: 14.6 MB, max 14.9 MB, free 0.3 MB (282368 bytes)
  WARNING: Not enough free flash space for answering machine!
packing images/7390_06.23-freetz-devel-13116.de_20150522-225646.image
  image file size: 15.3 MB
done.
FINISHED
Ergebnis "»»/build/modified/filesystem/usr/www/all/css/default/images/kopfbalken_links.gif" mit Freetz-trunk (13116) für 84.06.04 (7390):
Ergebnis "»»/build/modified/filesystem/usr/www/all/css/default/images/kopfbalken_links.png" mit Freetz-trunk (13116) für 84.06.23 (7390):
Neben dem neuen Aufbau bzw. der geänderten Integration des AVM-Logo in den Kopfbalken ab FritzOS 6.2x fällt das geänderte Bildformat des AVM Logo auf (PNG anstatt GIF). Die Größe des Logo selbst (jedoch nicht des Bildes "kopfbalken_links.*") ist geblieben (98px*77px) aber horizontal müsste das tagging für "kopfbalken_links.png" (>=6.20) neu ausgerichtet werden (-33px) wenn man die Option "center" beim tagging nicht verwenden kann.
Ausschnitt »»/fwmod:
        # logo tagging
        if [ "$FREETZ_TAGGING_STRING" != "none" ]; then
            tagging() {
                [ $# -lt 3 ] && return
                local tagging_geo="$1"
                shift
                local tagging_pos="$1"
                shift
                local tagging_arg="$*"
                local tagging_pic="${TAGGING_DIR}/${FREETZ_TAGGING_STRING}.png"
                for tagging_file in $tagging_arg; do
                    echo2 "${tagging_file}"
                    composite -dissolve 100% -gravity $tagging_pos -geometry $tagging_geo -quality 100 $tagging_pic $tagging_file $tagging_file
                    [ $? -ne 0 ] && error 1 "tagging failed while processing ${tagging_file#${FILESYSTEM_MOD_DIR}/}"
                done
            echo1 "tagging avm webif (tag by ${FREETZ_TAGGING_STRING})"
            # newest lua (small logo @left, eg 7270 04.88)
            tagging "+0+0" "center" $(find ${HTML_MOD_DIR} -name kopfbalken_links.gif)
            # newer html (big header @top, eg 7320 05.29)
            tagging "-20+0" "west" $(find ${HTML_MOD_DIR} -name kopfbalken.gif)
            # older (big header @top, eg 7141 04.76)
            tagging "+0+0" "west" $(find ${HTML_MOD_DIR} -name fw_header980.gif)
            # even older (big header @top, eg 7050 04.03)
            tagging "+0-5" "west" $(find ${HTML_MOD_DIR} -name fw_header.gif)
        fi
fwmod müsste (wenn mein laienhaftes Wissen dbzgl. mich nicht täuscht) u.a. wohl um folgendes ergänzt werden:
            # newest lua (small logo @left, eg 7390 06.23)
            tagging "+0+0" "center" $(find ${HTML_MOD_DIR} -name kopfbalken_links.png)
Ich hoffe ich habe nichts übersehen...
Schönes Pfingstwochenende
Qwertz
Ich habe zu danken!
Mit r13125:
STEP 2: MODIFY
  integrated Box-Info
[highlight]  tagging avm webif (tag by cuma)
    build/modified/filesystem/usr/www.nas/all/css/default/images/kopfbalken_links.png[/highlight]
done.
und "»»/build/modified/filesystem/usr/www/all/css/default/images/kopfbalken_links.png":
Habe aber soeben bemerkt, dass für den "perfekten Sitz" des tagging (ja ja, bin gerade etwas pingelig ;)) das Offset im vertikalen für kopfbalken_links.png im Gegensatz zu kopfbalken_links.gif zusätzlich doch noch etwas korrigiert werden müsste.
Derzeit s.o., mit "composite -dissolve 100% -gravity center -geometry +0+5 -quality 100 cuma.png kopfbalken_links.png test.png" sieht es dann wieder so aus wie bei FritzOS 6.0x bzw. kopfbalken_links.gif:
Wobei evtl. "+0+6" evtl. noch etwas besser passen würde?
Basierend auf Deinen Screenshots (i.e. auf der Box nicht getestet) finde "+0+6" besser: r13128
Danke!
Auch schön das seit r13124 das AVM NAS WebIf ("»»/www.nas/all/css/default/images/kopfbalken_links.*") mit berücksichtigt wird, war mir bis jetzt noch gar nicht aufgefallen dass das bis dahin fehlte.
AVM WebIF tagging ab FritzOS 6.50
Seit FritzOS 6.50 funktionierte mal wieder das WebIf-Tagging nicht mehr, hatte mich bisher nicht besonders interessiert aber nun (mit FritzOS 6.80) habe ich mir das doch mal genauer angesehen.
Für das FRITZ!-Logo ist nun keine GIF- oder PNG-Datei mehr zuständig sondern eine SVG-Datei, also eine Vektorgrafik, somit funktioniert das tagging mit "composite" aus dem ImageMagick-Paket nicht mehr.
Allerdings ist eine SVG-Datei letztlich nichts anderes als eine XML-Datei, also habe ich mir mal eine SVG-Datei gebastelt die als Basis für ein alternatives tagging dienen könnte:
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" version="1.1" x="0px" y="0px" width="100px" height="80px" viewBox="0 0 100 80" enable-background="new 0 0 100 80" xml:space="preserve">
	<title>FREETZ!Mod</title>
	<desc>Add FREETZ!Mod tagging to FRITZ!Logo</desc>
	<g>
		<text x="44" y="18" style="font-style:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">FREETZ<tspan x="44" y="68">MOD</tspan></text>
	</g>
</svg>
Das Ergebnis sieht dann so aus (als PNG, die Forumsoftware erlaubt leider nicht das hochladen einer SVG-Datei):
Ein komplett neues Logo, mit dem vorhandenen als Basis, kann man wohl aufgrund der Lizenzvereinbarung nicht hinterlegen. Aber man kann den bestehenden Logos, welche übrigens an folgenden Stellen zu finden sind:
./filesystem/usr/www/all/css/rd/images/fritzLogo.svg
./filesystem/usr/www/all/guest/css/rd/images/fritzLogo.svg
./filesystem/usr/www.myfritz/all/css/default/images/fritzLogo.svg
./filesystem/usr/www.nas/all/css/default/images/fritzLogo.svg
(ob man auch das unter "www.myfritz" modifizieren möchte lass ich mal außen vor, ich habe es nicht getan)
einfach als vorletzte Zeile (beim bis jetzt von AVM verwendeten wäre das nach der Zeile 394) folgende Zeile (aus obiger SVG-Datei) hinzufügen (also eine Zeile vor der mit "</svg>"):
Das Ergebnis (wieder als PNG) sieht dann so aus:
Das Original sieht so aus:
Und hier das Ergebnis als diff:
--- fritzLogo.svg	2017-02-07 12:23:36.000000000 +0100
+++ fritzLogo-FreetzMod.svg	2017-02-14 15:59:30.147076899 +0100
@@ -394,2 +394,3 @@
 	l4.737,0.175l1.88-12.223l-5.858-0.455L91.26,38.658 M89.897,42.619l3.007,3.708l3.698-3.003l-2.999-3.698L89.897,42.619"/>
+<text x="44" y="18" style="font-style:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">FREETZ<tspan x="44" y="68">MOD</tspan></text>
 </svg>
Das ganze ist jetzt natürlich nur ein Beispiel, es unterscheidet sich schließlich vom bisherigen "Tagging-Design by cuma". Für mich war das jetzt mit dem "sans-serif" Text allerdings schnell und einfach umsetzbar. Dabei ist der Text übrigens schwarz mit einer Trasnparenz/Durchlässigkeut von 50% (fill-opacity="0.5"), habe es auch mal mit 40% und 60% versucht, hier die 3 Versuche:
Mit 40%
Mit 50% (in meinem Beispiel oben verwendet):
Mit 60%:
BTW:
Das bisherige Logo, welches seit FritzOS 6.20 enthalten ist ("kopfbalken_links.png"), ist auch in FritzOS >=6.50 enthalten. Habe bis jetzt zwar noch nicht untersucht wo das verwendet wird aber ich denke, dass man das bisherige tagging mit "composite" (zusätzlich) wohl beibehalten sollte, auch bei FritzOS >=6.50.
Cool, und dank SVG mit "nützlichen" Infos kombinieren...
uhr.svg (oder: uhr.xml)
HTML:
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.0//EN" "http://www.w3.org/TR/2001/REC-SVG-20010904/DTD/svg10.dtd">
<svg xmlns="http://www.w3.org/2000/svg" onload="SetTime(evt)">
  <defs>
    <script type="text/javascript">
      <![CDATA[
        function SetTime(LoadEvent)
            var Now = new Date();
            var Seconds = Now.getSeconds();
            var Minutes = Now.getMinutes() + Seconds / 60;
            var Hours = Now.getHours() + Minutes / 60;
            var SVGDocument = LoadEvent.target.ownerDocument;
            SVGDocument.getElementById("seconds").setAttribute('transform', 'rotate(' + (Seconds * 6) + ')');
            SVGDocument.getElementById("minutes").setAttribute('transform', 'rotate(' + (Minutes * 6) + ')');
            SVGDocument.getElementById("hours").setAttribute('transform', 'rotate(' + (Hours * 30) + ')');
    </script>
  </defs>
<!-- Das Ziffernblatt -->
  <circle cx="100" cy="100" r="80" style="fill:rgb(255,255,255);stroke:rgb(0,0,0);"/>
  <text x="130" y="46" style="font:bold 15px Arial sans-serif;">I</text>
  <text x="154" y="71" style="font:bold 15px Arial sans-serif;">II</text>
  <text x="160" y="106" style="font:bold 15px Arial sans-serif;">III</text>
  <text x="155" y="140" style="font:bold 15px Arial sans-serif;">IV</text>
  <text x="130" y="166" style="font:bold 15px Arial sans-serif;">V</text>
  <text x="93" y="175" style="font:bold 15px Arial sans-serif;">VI</text>
  <text x="57" y="166" style="font:bold 15px Arial sans-serif;">VII</text>
  <text x="33" y="140" style="font:bold 15px Arial sans-serif;;">VIII</text>
  <text x="25" y="106" style="font:bold 15px Arial sans-serif;">IX</text>
  <text x="34" y="71" style="font:bold 15px Arial sans-serif;">X</text>
  <text x="58" y="46" style="font:bold 15px Arial sans-serif;">XI</text>
  <text x="92" y="37" style="font:bold 15px Arial sans-serif;">XII</text>
  <g transform="translate(100 100)">
<!-- Der Stundenzeiger -->
    <g id="hours">
      <line x1="0" y1="0" x2="0" y2="-55" style="stroke-width:4;stroke:rgb(0,0,0);">
        <animateTransform attributeName="transform" type="rotate" dur="43200s" values="0;360" repeatCount="indefinite"/>
      </line>
    </g>
<!-- Der Minutenzeiger -->
    <g id="minutes">
      <line x1="0" y1="0" x2="0" y2="-70" style="stroke-width:3;stroke:rgb(0,0,0);">
        <animateTransform attributeName="transform" type="rotate" dur="3600s" values="0;360" repeatCount="indefinite"/>
      </line>
    </g>
<!-- Der Sekundenzeiger -->
    <g id="seconds">
      <line x1="0" y1="0" x2="0" y2="-75" style="stroke-width:2;stroke:rgb(200,0,0);">
        <animateTransform attributeName="transform" type="rotate" dur="60s" values="0;360" repeatCount="indefinite"/>
      </line>
    </g>
  </g>
<!-- Die Verblendung -->
  <circle cx="100" cy="100" r="3" style="fill:rgb(0,0,0);stroke:rgb(200,0,0);"/>
</svg>
Vielleicht kann auch in der Uhr-SVG der Alphakanal (Transparenz) genutzt werden?
...würde eventuell mit Logo zusammen hübsch aussehen.
Transparenz ist eigentlich kein Problem, zuerst hatte ich es versucht das FRITZ!Logo so wie es ist beizubehalten, das sieht aber nicht gut aus. Also habe mal ich das FRITZ!Logo auf 50% verkleinert und dann mal deine Uhr (leicht verändert mit moderner wirkenden Ziffern) "draufgebastelt", Ergebnis (als PNG) pur:
Ergebnis im WebIf:
Oder ganz ohne FRITZ!Logo, Clock pur:
Im WebIf:
Uhr mit verkleinertem FRITZ!Logo und FREETZ tagging (oh je, kann es sein, dass das so lizenzrechtliche Probleme bereitet?):
HTML:
<!-- Generator: Adobe Illustrator 16.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 0)  -->
<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" version="1.1" onload="SetTime(evt)" id="Ebene_1" x="0px" y="0px" width="100px" height="80px" viewBox="0 0 100 80" enable-background="new 0 0 100 80" xml:space="preserve">
	<title>FREETZ!Mod with Clock</title>
	<desc>Small FRITZ!Logo with FREETZ!Mod and Clock tagging</desc>
	<g>
		<path d="M 60.5115,41.6855 62.438,38.176 c -1.46,-1.5155 -3.895,-3.91 -7.969,-7.6835 -9.5105,-8.8 -10.063,-8.761 -10.2975,-8.761 -0.233,0 -0.692,-0.1685 -10.1635,8.7455 -10.618,10.008 -10.2635,10.3455 -10.2635,10.3455 0,0 -0.3265,0.5405 10.373,10.433 9.605,8.887 9.79,8.6385 10.0535,8.6385 0.27,0 0.839,0.156 10.311,-8.7645 5.129,-4.8105 7.663,-7.382 8.913,-8.7505 l -2.8835,-0.6935"/>
		<path d="m 60.5115,41.6855 0.0905,0.051 1.9685,-3.579 -0.0555,-0.0525 c -1.46,-1.521 -3.8975,-3.9165 -7.9725,-7.683 -4.7095,-4.367 -7.2245,-6.5595 -8.593,-7.6625 -0.6815,-0.55 -1.08,-0.8265 -1.336,-0.9775 -0.1205,-0.073 -0.208,-0.1085 -0.2765,-0.129 -0.0685,-0.0235 -0.1235,-0.028 -0.156,-0.028 l -0.034,0 c -0.04,0 -0.101,0.0085 -0.1715,0.0325 -0.2535,0.087 -0.7535,0.3935 -2.2075,1.6195 -1.448,1.2225 -3.839,3.372 -7.83,7.1305 -4.978,4.6845 -7.547,7.251 -8.871,8.6575 -0.662,0.6965 -1.0145,1.1085 -1.2035,1.356 -0.094,0.1235 -0.146,0.201 -0.181,0.259 -0.0285,0.0595 -0.0435,0.0915 -0.0445,0.131 0,0.024 0.01,0.0645 0.0345,0.0855 l 0.071,-0.0735 -0.0895,-0.06 c -0.0125,0.0215 -0.016,0.0485 -0.016,0.064 10e-4,0.0365 0.0105,0.073 0.0435,0.1405 0.111,0.203 0.49,0.7555 1.9515,2.271 1.4585,1.517 3.9985,4.014 8.4095,8.094 4.552,4.2055 6.9895,6.375 8.3255,7.48 0.664,0.5525 1.058,0.847 1.3065,1.0085 0.125,0.073 0.212,0.125 0.2835,0.1465 C 44.0265,59.9985 44.086,60 44.1305,60 l 0.0685,0 c 0.037,0 0.1025,-0.002 0.176,-0.0295 0.2705,-0.08 0.805,-0.388 2.2785,-1.6115 1.47,-1.2245 3.8855,-3.3725 7.901,-7.145 5.13,-4.8225 7.6605,-7.39 8.9165,-8.7695 l 0.123,-0.132 -3.057,-0.727 -0.0255,0.1 0.0905,0.051 -0.0905,-0.051 -0.02,0.1025 2.8765,0.695 0.0275,-0.104 -0.0785,-0.071 c -1.245,1.36 -3.7785,3.9295 -8.9025,8.7505 -4.5815,4.3075 -7.078,6.4965 -8.4725,7.6105 -0.6905,0.5545 -1.104,0.834 -1.358,0.9825 -0.1255,0.072 -0.2105,0.106 -0.2625,0.1205 -0.0645,0.0185 -0.088,0.0185 -0.1205,0.0185 l -0.0685,0 c -0.031,0 -0.0505,0 -0.102,-0.0185 -0.0895,-0.0335 -0.259,-0.125 -0.575,-0.3595 -0.964,-0.715 -3.2995,-2.713 -9.266,-8.2345 -5.0435,-4.6665 -7.6355,-7.2505 -8.9645,-8.681 -0.6645,-0.703 -1.0145,-1.134 -1.195,-1.3775 -0.088,-0.122 -0.137,-0.205 -0.1615,-0.25 -0.013,-0.026 -0.0195,-0.043 -0.0205,-0.043 l -0.0015,-0.008 -0.042,0.008 0.042,0 0,-0.008 -0.042,0.008 0.042,0 -0.0925,0 0.0795,0.049 c 0.012,-0.023 0.0145,-0.045 0.0125,-0.049 l -0.092,0 0.0795,0.049 0.0455,-0.074 -0.0635,-0.0615 -0.0655,0.071 0.096,0 c 0.0015,-0.0145 -0.0055,-0.044 -0.031,-0.0715 l -0.065,0.0715 0.096,0 -0.0575,0 0.058,0.0155 0,-0.0155 -0.058,0 0.058,0.0155 -0.009,0 0.009,0 0,0 -0.009,0 0.009,0 c 0,-0.008 0.0515,-0.1195 0.267,-0.382 0.663,-0.8235 2.851,-3.1825 9.969,-9.8845 4.5585,-4.297 7.03,-6.4845 8.39,-7.593 0.673,-0.5555 1.0755,-0.845 1.318,-0.986 0.12,-0.0695 0.202,-0.1085 0.2545,-0.124 0.052,-0.019 0.071,-0.019 0.103,-0.019 l 0.034,0 c 0.024,0 0.041,0 0.0885,0.0105 0.084,0.029 0.2565,0.107 0.581,0.3375 0.9695,0.6775 3.371,2.6625 9.547,8.3895 4.073,3.7585 6.5105,6.153 7.968,7.6735 l 0.0725,-0.073 -0.0895,-0.052 -1.992,3.6305 0.1355,0.0335 0.0185,-0.1025" style="fill:#231f20"/>
		<path d="m 60.5115,41.6855 1.662,-3.028 c -1.249,-1.379 -3.782,-3.945 -8.9475,-8.7175 -9.4355,-8.734 -9.947,-8.765 -10.296,-8.765 -0.345,0 -0.6725,-0.189 -10.162,8.75 -10.619,10.0055 -10.2655,10.3335 -10.2655,10.3335 0,0 -0.326,0.552 10.3715,10.436 9.5395,8.823 9.771,8.645 10.0565,8.645 0.288,0 0.838,0.139 10.314,-8.763 4.8735,-4.5805 7.405,-7.1305 8.713,-8.542 l -1.446,-0.349" style="fill:#f8ec17"/>
		<path d="m 60.5115,41.6855 0.137,0.0705 1.6655,-3.013 -0.0285,-0.189 c -1.244,-1.3845 -3.7905,-3.9615 -8.948,-8.7315 -4.725,-4.367 -7.21,-6.562 -8.57,-7.665 C 44.095,21.6055 43.697,21.33 43.439,21.1755 43.307,21.1065 43.2125,21.0665 43.1285,21.0385 43.0415,21.02 42.975,21.018 42.93,21.018 l -0.043,0 c -0.052,0 -0.122,0.002 -0.2075,0.032 -0.148,0.0455 -0.3445,0.152 -0.6865,0.3955 -1.0165,0.7275 -3.354,2.7375 -9.3325,8.3595 -4.9785,4.693 -7.5465,7.2575 -8.874,8.6635 -0.663,0.706 -1.0165,1.1195 -1.206,1.36 -0.0945,0.1245 -0.151,0.2055 -0.1815,0.27 -0.0335,0.056 -0.0515,0.0915 -0.055,0.16 -0.002,0.0325 0.0125,0.0875 0.0515,0.1205 l 0.1075,-0.1205 -0.1355,-0.079 c -0.0175,0.027 -0.0235,0.0625 -0.0235,0.092 0.0035,0.054 0.015,0.0905 0.0495,0.159 0.0595,0.1145 0.1815,0.302 0.4745,0.654 0.879,1.0675 3.281,3.6025 9.9005,9.7315 4.5855,4.238 7.0185,6.3945 8.3455,7.4955 0.6705,0.553 1.0525,0.843 1.3025,1.001 0.127,0.078 0.214,0.119 0.2905,0.152 0.0775,0.0245 0.1455,0.033 0.188,0.0325 l 0.0655,0 c 0.0455,5e-4 0.116,-0.0085 0.1945,-0.0325 0.1485,-0.044 0.3525,-0.1415 0.701,-0.382 1.0505,-0.723 3.4735,-2.729 9.4925,-8.3925 4.875,-4.5805 7.407,-7.129 8.731,-8.5515 l -0.0865,-0.2605 -1.4455,-0.345 -0.036,0.1525 0.137,0.0705 -0.137,-0.0705 -0.034,0.154 1.4465,0.35 0.033,-0.155 -0.1155,-0.106 c -1.312,1.409 -3.831,3.954 -8.701,8.528 -4.59,4.318 -7.079,6.5085 -8.4625,7.61 -0.6915,0.5545 -1.1015,0.8375 -1.3515,0.978 -0.123,0.073 -0.2075,0.107 -0.2595,0.12 C 43.014,59.18 42.9895,59.18 42.961,59.18 l -0.066,0 c -0.026,0 -0.0365,0 -0.085,-0.011 -0.0775,-0.0315 -0.24,-0.117 -0.5525,-0.3425 -0.947,-0.7045 -3.263,-2.686 -9.2745,-8.2465 -5.042,-4.655 -7.6325,-7.238 -8.962,-8.669 -0.665,-0.708 -1.009,-1.1335 -1.1905,-1.3775 -0.0855,-0.121 -0.1355,-0.207 -0.156,-0.2425 -0.011,-0.028 -0.016,-0.0325 -0.017,-0.0385 l 0,-0.004 -0.034,0.0105 0.035,-0.004 -5e-4,-0.0065 -0.034,0.0105 0.035,-0.004 -0.097,0.017 0.097,0 0,-0.017 -0.097,0.017 0.097,0 -0.145,0 0.125,0.0745 c 0.0155,-0.0355 0.0205,-0.0635 0.0205,-0.0745 l -0.145,0 0.125,0.0745 -0.0295,-0.2 -0.0985,0.113 0.148,0 c 5e-4,-0.028 -0.0095,-0.079 -0.0495,-0.113 l -0.0985,0.113 0.148,0 -0.1125,0 0.111,0.0185 5e-4,-0.0185 -0.1115,0 0.111,0.0185 -0.0415,-10e-4 0.0375,0.0065 0.004,-0.0055 -0.0415,-10e-4 0.0375,0.0065 c 0.004,-0.0055 0.065,-0.1275 0.2945,-0.4015 0.693,-0.854 2.9225,-3.2455 9.929,-9.8435 4.549,-4.2845 6.9935,-6.4705 8.337,-7.5865 0.6685,-0.5525 1.067,-0.837 1.307,-0.9825 0.1195,-0.0685 0.201,-0.1035 0.253,-0.1205 0.052,-0.0165 0.0775,-0.0165 0.113,-0.0165 l 0.043,0 c 0.042,0 0.068,0 0.1155,0.0125 0.083,0.021 0.246,0.097 0.5685,0.326 0.964,0.6725 3.3175,2.6555 9.5065,8.383 5.159,4.772 7.698,7.3405 8.94,8.713 l 0.113,-0.108 -0.137,-0.0685 -1.6625,3.0155 0.1035,0.235 0.0335,-0.1555"/>
		<g transform="matrix(0.5,0,0,0.5,21,20.7055)">
			<defs>
				<path id="SVGID_1_" d="m 43.841,1.525 -0.033,-0.009 0.062,0.009 0.042,-0.004 -0.02,0.004 c 0.11,0 -0.154,0 -0.051,0 M 82.108,36.764 C 79.845,34.251 75.044,29.101 64.061,18.89 47.372,3.41 44.315,1.723 43.861,1.527 43.422,1.707 40.39,3.352 23.95,18.869 15.596,26.741 9.639,32.56 6.237,36.165 c -1.484,1.562 -2.505,2.772 -2.623,2.909 0.311,0.571 2.668,3.919 20.537,20.472 7.66,7.091 13.309,12.129 16.795,14.972 0.5,0.393 2.799,2.17 2.799,2.17 l 0.089,-0.001 C 44.081,76.622 46.726,75.659 64.076,59.298 74.782,49.233 79.596,44.104 81.919,41.542 l 0.189,-4.778 M 3.521,39.418 C 3.581,39.313 3.595,39.21 3.595,39.124 L 3.592,39.107 3.521,39.418"/>
			</defs>
			<clipPath id="SVGID_2_">
				<use xlink:href="#SVGID_1_" overflow="visible" x="0" y="0" width="100%" height="100%"/>
			</clipPath>
			<g clip-path="url(#SVGID_2_)">
				<path d="M 36.981,69.551 34.936,67.086 32.819,64.704 31.403,63.235 C 23.875,55.709 8.507,40.276 8.357,40.145 8.312,40.099 8.29,40.047 8.29,40.004 l 0,-10e-4 C 8.294,39.963 8.325,39.923 8.348,39.899 9.005,39.269 24,24.822 32.182,17.888 L 44.756,7.719 44.408,-0.044 25.24,17.031 C 18.22,23.21 4.844,37.869 4.713,37.999 c -0.328,0.29 -0.52,0.729 -0.52,1.206 0,0.452 0.191,0.903 0.551,1.229 l 0.069,0.072 c 2.31,2.18 14.122,13.443 20.094,19.199 2.036,1.968 2.772,2.565 3.514,3.174 l 3.279,2.671 5.281,4.001" style="fill:#ffe600"/>
				<path d="m 34.888,67.122 0.031,0.026 c -0.053,-0.04 -0.309,-0.33 -2.15,-2.405 L 31.356,63.286 11.532,43.413 8.312,40.174 8.227,40.004 8.311,39.852 c 1.604,-1.541 15.9,-15.28 23.833,-22.004 0,0 12.325,-9.96 12.559,-10.156 0,-0.061 -0.361,-7.347 -0.361,-7.609 C 44.147,0.265 25.283,17.087 25.283,17.087 18.253,23.264 4.886,37.903 4.762,38.04 c -0.325,0.286 -0.511,0.723 -0.511,1.166 0,0.452 0.19,0.864 0.532,1.177 l 0,0 0.077,0.065 c 2.306,2.211 14.122,13.456 20.09,19.228 1.997,1.929 2.744,2.531 3.467,3.125 l 3.319,2.7 c 0.002,0 3.622,2.753 4.863,3.679 -0.474,-0.55 -1.711,-2.058 -1.711,-2.058" style="fill:#ffe700"/>
				<path d="m 34.838,67.171 0.047,0.018 C 34.82,67.149 34.643,66.945 32.731,64.781 L 31.318,63.323 8.274,40.216 8.176,40.042 l 0,0 c 0,-0.039 0.082,-0.208 0.082,-0.208 1.605,-1.559 15.857,-15.263 23.844,-22.045 0,0 12.308,-9.932 12.54,-10.134 0,-0.045 -0.354,-7.178 -0.354,-7.438 -0.205,0.173 -18.965,16.911 -18.965,16.911 -7.02,6.167 -20.39,20.815 -20.521,20.944 -0.314,0.285 -0.486,0.69 -0.486,1.133 0,0.423 0.175,0.837 0.507,1.138 l 0.08,0.075 c 4.204,3.996 14.58,13.883 20.091,19.214 1.989,1.917 2.74,2.522 3.462,3.109 l 3.32,2.716 c 0.007,0.001 3.847,2.91 4.436,3.366 -0.431,-0.529 -1.374,-1.652 -1.374,-1.652" style="fill:#ffe703"/>
				<path d="m 34.795,67.204 0.05,0.036 c -0.062,-0.052 -0.22,-0.234 -2.162,-2.409 L 31.271,63.36 8.228,40.26 8.123,40.068 l 0,0 c 0,-0.049 0.076,-0.273 0.076,-0.273 0.166,-0.167 15.408,-14.871 23.861,-22.043 0,0 12.291,-9.922 12.521,-10.126 C 44.581,7.583 44.22,0.607 44.22,0.355 44.024,0.526 25.364,17.167 25.364,17.167 18.498,23.197 5.388,37.581 4.852,38.11 4.542,38.384 4.37,38.795 4.37,39.205 c 0,0.421 0.176,0.798 0.495,1.106 L 4.94,40.38 c 4.205,3.996 14.575,13.874 20.094,19.198 1.993,1.925 2.737,2.539 3.458,3.125 l 3.324,2.713 c 0,0 3.37,2.559 4.018,3.043 -0.38,-0.462 -1.039,-1.255 -1.039,-1.255" style="fill:#ffe716"/>
				<path d="m 34.747,67.25 0.061,0.038 c -0.066,-0.055 -0.18,-0.179 -2.056,-2.279 L 32.634,64.871 31.228,63.392 8.186,40.315 8.071,40.101 l 0,-0.014 c 0,-0.046 0.072,-0.312 0.072,-0.312 0.134,-0.138 15.476,-14.935 23.88,-22.067 0,0 12.268,-9.914 12.493,-10.105 0,-0.052 -0.35,-6.871 -0.35,-7.113 C 43.964,0.665 25.406,17.215 25.406,17.215 18.489,23.294 5.429,37.628 4.9,38.143 c -0.3,0.273 -0.466,0.656 -0.466,1.062 0,0.387 0.166,0.761 0.473,1.044 l 0.078,0.082 c 4.193,3.991 14.557,13.867 20.094,19.207 1.99,1.924 2.729,2.531 3.453,3.12 l 3.324,2.7 c 0,0 2.575,1.959 3.599,2.729 -0.312,-0.358 -0.708,-0.837 -0.708,-0.837" style="fill:#ffe722"/>
				<path d="m 34.695,67.288 -0.003,-0.031 c -0.136,-0.143 -0.531,-0.582 -1.98,-2.21 L 32.592,64.909 31.181,63.438 8.139,40.343 8.017,40.126 8.015,40.108 c 0,-0.049 0.071,-0.351 0.071,-0.351 0.102,-0.102 15.402,-14.886 23.897,-22.099 0,0 12.246,-9.893 12.478,-10.077 0,-0.064 -0.36,-6.712 -0.36,-6.961 C 43.905,0.801 25.444,17.266 25.444,17.266 18.526,23.329 5.47,37.661 4.937,38.194 c -0.278,0.26 -0.447,0.632 -0.447,1.01 0,0.382 0.167,0.734 0.461,1.006 l 0.07,0.065 c 4.183,3.995 14.512,13.821 20.1,19.221 1.979,1.926 2.728,2.522 3.443,3.108 l 3.324,2.72 c 0.013,0 2.668,2.014 3.188,2.407 -0.188,-0.236 -0.381,-0.443 -0.381,-0.443" style="fill:#ffe82b"/>
				<path d="m 34.652,67.317 -0.008,-0.023 -2.1,-2.349 -1.406,-1.461 -23.037,-23.102 -0.137,-0.237 -0.002,0 c 0,-0.076 0.063,-0.391 0.063,-0.391 0.076,-0.098 15.252,-14.784 23.916,-22.144 0,0 12.225,-9.864 12.458,-10.059 0,-0.059 -0.355,-6.543 -0.355,-6.792 C 43.841,0.93 25.482,17.302 25.482,17.302 18.767,23.204 6.327,36.9 4.986,38.243 c -0.274,0.245 -0.429,0.59 -0.429,0.962 0,0.354 0.155,0.702 0.431,0.969 l 0.076,0.068 c 4.166,3.964 14.459,13.77 20.103,19.223 1.98,1.898 2.722,2.517 3.435,3.103 l 3.322,2.703 c 0,0 2.205,1.67 2.769,2.091 l -0.041,-0.045" style="fill:#ffe835"/>
				<path d="M 32.499,64.979 31.096,63.531 11.273,43.658 8.056,40.43 7.91,40.174 l -0.002,0 c 0,-0.069 0.06,-0.443 0.06,-0.443 0.053,-0.074 15.303,-14.843 23.938,-22.158 0,0 12.203,-9.853 12.435,-10.055 0,-0.045 -0.362,-6.379 -0.362,-6.626 C 43.783,1.068 25.526,17.342 25.526,17.342 18.81,23.258 6.37,36.938 5.025,38.28 c -0.263,0.241 -0.411,0.576 -0.411,0.925 0,0.354 0.147,0.668 0.415,0.93 l 0.078,0.076 c 4.157,3.938 14.436,13.734 20.102,19.195 1.979,1.922 2.72,2.523 3.437,3.103 -0.006,-10e-4 -0.006,-10e-4 3.322,2.716 0.002,0 1.529,1.168 2.314,1.753 -0.465,-0.519 -1.783,-1.999 -1.783,-1.999" style="fill:#ffe93c"/>
				<path d="M 32.456,65.02 31.048,63.569 8.015,40.475 7.856,40.211 l 0,-0.004 c 0,-0.1 0.051,-0.479 0.051,-0.479 0.04,-0.072 15.113,-14.7 23.959,-22.207 0,0 12.183,-9.83 12.406,-10.036 0,-0.042 -0.351,-6.212 -0.351,-6.471 C 43.724,1.197 25.565,17.398 25.565,17.398 18.884,23.263 6.418,36.972 5.071,38.313 c -0.256,0.244 -0.395,0.552 -0.395,0.892 0,0.324 0.138,0.645 0.397,0.87 l 0.075,0.077 c 4.14,3.951 14.379,13.697 20.101,19.216 1.974,1.925 2.712,2.514 3.434,3.099 l -0.066,-0.002 c 0.069,0.003 0.399,0.276 3.06,2.445 l 0.33,0.274 c 0.002,0 1.49,1.133 1.813,1.378 -0.486,-0.549 -1.364,-1.541 -1.364,-1.542" style="fill:#ffe943"/>
				<path d="M 32.404,65.047 32.406,65.06 31.01,63.6 7.972,40.523 7.805,40.242 7.801,40.224 c 0,-0.098 0.044,-0.496 0.044,-0.496 0.033,-0.072 15.117,-14.731 23.974,-22.256 0,0 12.167,-9.817 12.399,-10.004 0,-0.054 -0.358,-6.065 -0.358,-6.32 C 43.662,1.324 25.604,17.439 25.604,17.439 18.921,23.304 6.457,37.015 5.11,38.354 c -0.241,0.237 -0.377,0.538 -0.377,0.85 0,0.316 0.133,0.614 0.378,0.837 l 0.083,0.065 c 4.142,3.957 14.399,13.709 20.098,19.22 1.977,1.911 2.71,2.513 3.428,3.098 l 0.002,0.003 -0.002,0.033 c 0.186,0.109 0.754,0.587 2.979,2.391 l 0.342,0.281 c 0,0 0.803,0.601 1.33,1.008 -0.161,-0.19 -0.967,-1.093 -0.967,-1.093" style="fill:#ffea49"/>
				<path d="m 32.356,65.091 0.011,0.023 -1.406,-1.47 L 7.931,40.551 7.753,40.277 7.742,40.234 7.788,39.718 C 7.811,39.656 22.71,25.13 31.785,17.437 c 0,0 12.141,-9.806 12.37,-9.992 0,-0.064 -0.353,-5.912 -0.353,-6.161 C 43.6,1.455 25.649,17.472 25.649,17.472 18.968,23.356 6.502,37.064 5.156,38.405 c -0.233,0.214 -0.358,0.494 -0.358,0.799 0,0.29 0.123,0.581 0.358,0.798 l 0.077,0.065 c 4.146,3.942 14.398,13.714 20.098,19.219 1.979,1.903 2.715,2.513 3.424,3.087 0.188,0.155 3.324,2.707 3.324,2.707 0,0 0.462,0.349 0.839,0.639 -0.274,-0.296 -0.562,-0.628 -0.562,-0.628" style="fill:#ffea50"/>
				<path d="M 32.315,65.141 32.321,65.146 30.922,63.687 7.886,40.589 7.702,40.316 7.68,40.237 7.726,39.706 C 7.802,39.521 23.12,24.708 31.749,17.39 c 0,0 12.118,-9.78 12.352,-9.976 0,-0.059 -0.363,-5.752 -0.363,-5.993 -0.196,0.173 -18.049,16.104 -18.049,16.104 -6.68,5.873 -19.146,19.583 -20.49,20.93 -0.218,0.196 -0.343,0.467 -0.343,0.75 0,0.28 0.119,0.549 0.34,0.747 l 0.08,0.089 c 4.139,3.92 14.388,13.681 20.099,19.2 1.968,1.909 2.707,2.498 3.414,3.081 l 3.324,2.726 c 0.009,0 0.081,0.044 0.345,0.246 -0.055,-0.058 -0.143,-0.153 -0.143,-0.153" style="fill:#ffea56"/>
				<path d="M 30.875,63.738 11.058,43.856 7.843,40.635 7.65,40.34 7.622,40.237 7.665,39.694 C 7.741,39.52 23.054,24.677 31.704,17.335 c 0,0 12.104,-9.753 12.326,-9.955 0,-0.043 -0.353,-5.581 -0.353,-5.827 -0.196,0.179 -17.955,16.019 -17.955,16.019 -6.672,5.86 -19.134,19.57 -20.478,20.916 -0.209,0.19 -0.327,0.449 -0.327,0.717 0,0.258 0.11,0.524 0.318,0.695 l 0.079,0.079 c 4.137,3.954 14.382,13.701 20.101,19.211 1.963,1.91 2.702,2.518 3.41,3.096 0.008,0.006 2.583,2.104 3.042,2.469 -0.411,-0.428 -0.992,-1.017 -0.992,-1.017" style="fill:#ffea5b"/>
				<path d="M 30.835,63.774 7.798,40.691 7.598,40.369 7.564,40.242 c 0,-0.031 0.042,-0.55 0.042,-0.55 0.071,-0.181 15.381,-15.024 24.06,-22.391 0,0 12.079,-9.75 12.313,-9.951 0,-0.043 -0.358,-5.415 -0.358,-5.659 C 43.421,1.862 25.768,17.61 25.768,17.61 19.126,23.449 6.632,37.179 5.283,38.52 c -0.192,0.183 -0.309,0.431 -0.309,0.684 0,0.246 0.111,0.488 0.306,0.657 l 0.075,0.075 c 4.128,3.92 14.342,13.65 20.106,19.221 1.961,1.89 2.689,2.493 3.4,3.063 0,0 2.12,1.742 2.269,1.857 -0.124,-0.128 -0.295,-0.303 -0.295,-0.303" style="fill:#ffeb61"/>
				<path d="M 10.972,43.953 7.758,40.73 7.547,40.401 7.519,40.315 7.501,40.242 7.546,39.692 c 0.067,-0.188 15.379,-15.051 24.081,-22.434 0,0 12.059,-9.741 12.287,-9.929 0,-0.053 -0.351,-5.261 -0.351,-5.507 C 43.36,1.999 25.808,17.654 25.808,17.654 19.169,23.5 6.674,37.223 5.329,38.564 c -0.186,0.171 -0.291,0.405 -0.291,0.64 0,0.227 0.101,0.452 0.279,0.629 l 0.082,0.065 c 4.117,3.925 14.32,13.632 20.102,19.22 1.964,1.898 2.698,2.487 3.404,3.07 0,0 0.768,0.616 1.414,1.148 -1.702,-1.704 -8.176,-8.191 -19.347,-19.383" style="fill:#ffec66"/>
				<path d="M 7.712,40.758 7.497,40.432 7.461,40.316 7.446,40.245 7.486,39.693 c 0.066,-0.198 15.38,-15.089 24.1,-22.492 0,0 12.039,-9.709 12.273,-9.894 0,-0.062 -0.363,-5.104 -0.363,-5.356 -0.196,0.18 -17.65,15.757 -17.65,15.757 -6.632,5.829 -19.132,19.565 -20.478,20.909 -0.173,0.146 -0.271,0.37 -0.271,0.588 0,0.213 0.096,0.421 0.265,0.57 l 0.08,0.085 c 4.127,3.93 14.358,13.663 20.104,19.211 1.968,1.908 2.693,2.494 3.395,3.069 0,0 0.231,0.182 0.503,0.417 C 27.985,61.084 7.712,40.758 7.712,40.758" style="fill:#ffec6b"/>
				<path d="M 7.672,40.803 7.664,40.797 7.446,40.454 7.4,40.343 C 7.394,40.295 7.382,40.245 7.382,40.245 L 7.424,39.692 C 7.491,39.484 22.81,24.571 31.545,17.165 c 0,0 12.023,-9.694 12.245,-9.889 0,-0.059 -0.352,-4.95 -0.352,-5.196 C 43.238,2.256 25.891,17.751 25.891,17.751 19.282,23.546 6.763,37.316 5.413,38.658 5.249,38.8 5.158,39.003 5.158,39.205 c 0,0.191 0.089,0.382 0.242,0.524 l 0.086,0.08 c 4.133,3.942 14.363,13.678 20.1,19.211 1.592,1.545 2.369,2.229 2.98,2.723 C 27.011,60.188 7.672,40.803 7.672,40.803" style="fill:#ffec6b"/>
				<path d="M 7.628,40.849 7.615,40.828 7.398,40.486 7.349,40.347 7.327,40.27 7.364,39.686 c 0.064,-0.201 15.381,-15.14 24.147,-22.562 0,0 11.992,-9.678 12.226,-9.879 0,-0.042 -0.358,-4.787 -0.358,-5.029 C 43.181,2.387 25.93,17.784 25.93,17.784 19.325,23.601 6.808,37.349 5.452,38.695 5.3,38.832 5.215,39.016 5.215,39.204 c 0,0.18 0.083,0.354 0.227,0.488 l 0.081,0.065 c 3.202,3.062 14.122,13.441 20.108,19.228 0.663,0.653 1.185,1.135 1.607,1.517 C 24.981,58.249 7.628,40.849 7.628,40.849" style="fill:#ffec71"/>
				<path d="M 7.589,40.9 7.565,40.863 7.348,40.523 7.288,40.381 7.262,40.27 7.304,39.674 C 7.365,39.485 22.692,24.525 31.47,17.069 c 0,0 11.975,-9.654 12.202,-9.858 C 43.672,7.169 43.32,2.593 43.32,2.352 43.119,2.523 25.966,17.838 25.966,17.838 19.367,23.64 6.849,37.385 5.498,38.729 5.357,38.865 5.28,39.04 5.28,39.205 c 0,0.162 0.069,0.316 0.208,0.452 l 0.077,0.072 C 8.431,42.45 17.456,51.044 23.62,56.957 18.834,52.159 7.589,40.9 7.589,40.9" style="fill:#ffec71"/>
				<path d="M 7.543,40.93 7.515,40.9 7.297,40.55 7.23,40.401 7.206,40.276 7.245,39.666 C 7.3,39.485 22.632,24.498 31.424,17.025 c 0,0 11.96,-9.644 12.195,-9.832 0,-0.054 -0.363,-4.463 -0.363,-4.705 C 43.06,2.664 26.01,17.885 26.01,17.885 19.41,23.674 6.893,37.43 5.542,38.779 c -0.132,0.12 -0.205,0.267 -0.205,0.426 0,0.143 0.065,0.28 0.187,0.396 0.001,0.002 9.298,8.875 14.568,13.909 C 15.818,49.231 7.543,40.93 7.543,40.93" style="fill:#ffed7a"/>
				<path d="M 7.5,40.966 7.465,40.93 7.244,40.589 7.174,40.418 7.145,40.276 7.183,39.656 c 0.062,-0.171 15.39,-15.19 24.206,-22.669 0,0 11.938,-9.631 12.16,-9.82 0,-0.059 -0.351,-4.305 -0.351,-4.547 C 42.997,2.794 26.05,17.921 26.05,17.921 19.456,23.714 6.934,37.483 5.585,38.831 c -0.118,0.105 -0.186,0.242 -0.186,0.373 0,0.131 0.057,0.246 0.167,0.354 0.001,0 7.317,6.99 10.996,10.503 C 12.926,46.407 7.5,40.966 7.5,40.966" style="fill:#ffed7e"/>
				<path d="M 7.455,41.018 7.411,40.966 7.194,40.626 7.123,40.447 7.089,40.277 7.124,39.656 c 0.054,-0.171 15.397,-15.222 24.228,-22.723 0,0 11.911,-9.598 12.144,-9.794 0,-0.057 -0.357,-4.147 -0.357,-4.382 -0.2,0.173 -17.052,15.207 -17.052,15.207 -6.564,5.778 -19.103,19.56 -20.461,20.901 -0.105,0.104 -0.17,0.216 -0.17,0.339 0,0.108 0.053,0.217 0.152,0.316 0,0 4.804,4.582 7.426,7.094 C 10.395,43.96 7.455,41.018 7.455,41.018" style="fill:#ffee83"/>
				<path d="m 7.415,41.067 -0.051,-0.062 0.018,0 C 7.349,40.966 7.284,40.88 7.141,40.655 l -0.082,-0.199 -0.035,-0.18 0.037,-0.62 c 0.057,-0.176 15.403,-15.259 24.25,-22.769 0,0 11.894,-9.58 12.121,-9.78 0,-0.044 -0.352,-3.99 -0.352,-4.222 -0.201,0.177 -16.948,15.134 -16.948,15.134 -6.56,5.758 -19.107,19.538 -20.461,20.88 -0.097,0.104 -0.15,0.208 -0.15,0.306 0,0.096 0.044,0.185 0.125,0.275 0,0.002 2.756,2.621 3.858,3.678 C 8.522,42.177 7.415,41.067 7.415,41.067" style="fill:#ffef87"/>
				<path d="m 7.369,41.108 0,0 0,0 M 7.095,40.692 7.007,40.484 6.967,40.31 l 0,-0.004 0.038,-0.65 c 0.051,-0.184 15.404,-15.293 24.266,-22.805 0,0 11.871,-9.574 12.107,-9.776 0,-0.043 -0.362,-3.826 -0.362,-4.062 C 42.819,3.192 26.171,18.058 26.171,18.058 19.608,23.812 7.068,37.59 5.711,38.942 c -0.085,0.092 -0.133,0.167 -0.133,0.262 0,0.077 0.042,0.158 0.113,0.221 0,0.003 1.023,0.992 1.553,1.484 C 7.175,40.82 7.095,40.692 7.095,40.692 Z" style="fill:#ffef8b"/>
				<path d="m 7.044,40.73 0,0 0,0 m -0.091,-0.211 -0.046,-0.203 0,0 0.035,-0.659 c 0.051,-0.192 15.414,-15.327 24.29,-22.856 0,0 11.855,-9.557 12.077,-9.743 0,-0.054 -0.352,-3.671 -0.352,-3.911 -0.2,0.173 -16.748,14.95 -16.748,14.95 -6.521,5.747 -19.099,19.532 -20.454,20.898 -0.074,0.066 -0.116,0.148 -0.116,0.21 0,0.065 0.035,0.13 0.093,0.18 0,0 0.877,0.842 1.251,1.205 l -0.03,-0.071 z" style="fill:#ffef8f"/>
				<path d="m 6.849,40.32 c 0,-0.044 0.033,-0.664 0.033,-0.664 0.052,-0.202 15.417,-15.359 24.31,-22.906 0,0 11.831,-9.536 12.063,-9.721 0,-0.062 -0.359,-3.514 -0.359,-3.747 C 42.697,3.453 26.251,18.147 26.251,18.147 19.73,23.88 7.156,37.679 5.797,39.04 l -0.1,0.165 0.076,0.143 c 0.005,0 0.92,0.874 1.088,1.035 L 6.849,40.32" style="fill:#ffef93"/>
				<path d="M 6.822,39.656 C 6.869,39.45 22.243,24.259 31.149,16.714 c 0.122,-0.101 11.644,-9.373 12.04,-9.711 0,-0.056 -0.02,-0.833 -0.02,-0.833 0,0 -0.323,-2.517 -0.323,-2.756 C 42.654,3.586 26.294,18.197 26.294,18.197 21.216,22.641 12.427,32.048 8.208,36.557 l -2.373,2.518 0.002,0 c 0,0 -0.049,0.098 -0.071,0.136 l 0.061,0.104 c 0.004,0 0.696,0.659 0.968,0.929 0.005,-0.137 0.027,-0.588 0.027,-0.588" style="fill:#fff197"/>
				<path d="m 6.763,39.651 0,-0.025 C 6.812,39.45 22.193,24.229 31.116,16.668 31.116,16.667 42.896,7.173 43.137,6.965 43.135,6.919 43.1,6.169 43.1,6.169 c 0,0 -0.298,-2.094 -0.312,-2.623 C 42.602,3.707 26.327,18.232 26.327,18.232 21.254,22.7 12.47,32.086 8.247,36.603 L 5.883,39.105 5.898,39.05 c 0,0 -0.049,0.099 -0.065,0.152 L 5.882,39.281 5.853,39.28 c 0.083,0.066 0.296,0.264 0.889,0.826 0.007,-0.164 0.021,-0.455 0.021,-0.455" style="fill:#fff19b"/>
				<path d="M 6.707,39.645 6.711,39.626 C 6.754,39.443 22.15,24.192 31.08,16.613 c 0,0 11.748,-9.472 11.988,-9.674 0,-0.046 -0.021,-0.767 -0.021,-0.767 0,0 -0.304,-1.985 -0.321,-2.51 -0.184,0.173 -16.353,14.614 -16.353,14.614 -5.075,4.465 -13.852,13.837 -18.074,18.351 0.01,0 0,0 -2.375,2.522 L 5.907,39.176 5.899,39.2 5.932,39.262 5.886,39.241 c 0.084,0.044 0.28,0.243 0.803,0.724 0.004,-0.131 0.018,-0.32 0.018,-0.32" style="fill:#fff19f"/>
				<path d="m 6.645,39.639 0.004,-0.041 c 0.047,-0.18 15.456,-15.441 24.389,-23.02 -0.002,0.002 0.002,-10e-4 6.522,-5.373 0,0 5.403,-4.244 5.453,-4.287 C 43.01,6.865 42.689,4.306 42.67,3.797 42.481,3.971 26.41,18.33 26.41,18.33 21.34,22.78 12.565,32.161 8.345,36.673 l 0,-0.013 C 8.312,36.713 8.214,36.812 8,37.042 l -2.029,2.155 0.02,0.044 c 0.098,0.071 0.284,0.243 0.646,0.592 0.003,-0.089 0.008,-0.194 0.008,-0.194" style="fill:#fff1a3"/>
				<path d="M 6.588,39.632 6.591,39.587 C 6.64,39.418 22.061,24.121 30.996,16.534 l -0.003,0.009 c 0.028,-0.034 0.071,-0.067 0.192,-0.171 0,0 11.723,-9.446 11.761,-9.48 0,-0.063 -0.324,-2.73 -0.327,-2.961 C 42.43,4.1 26.446,18.37 26.446,18.37 21.377,22.816 12.606,32.214 8.386,36.722 l -0.319,0.342 c -0.026,0.013 -1.822,1.934 -2.015,2.138 0.058,0.068 0.368,0.357 0.529,0.504 l 0.007,-0.074" style="fill:#fff2a7"/>
				<path d="M 26.49,18.403 C 21.417,22.875 12.65,32.255 8.431,36.764 l -0.322,0.345 c 0,0 -1.768,1.861 -1.978,2.087 0.058,0.046 0.289,0.281 0.404,0.39 C 6.58,39.385 22.017,24.08 30.958,16.476 l 0.189,-0.142 c 0,0 11.47,-9.263 11.744,-9.469 C 42.877,6.813 42.807,6.171 42.807,6.171 42.722,5.418 42.602,4.377 42.566,4.045 42.397,4.208 26.49,18.403 26.49,18.403" style="fill:#fff3ab"/>
				<path d="m 26.531,18.458 c -5.071,4.456 -13.838,13.83 -18.049,18.341 -0.011,0 -2.054,2.17 -2.266,2.393 0.061,0.05 0.255,0.25 0.317,0.294 1.004,-1.102 15.729,-15.708 24.392,-23.047 l 0.19,-0.158 c 0,-0.008 11.353,-9.159 11.712,-9.451 -0.007,-0.049 -0.078,-0.654 -0.078,-0.654 0,0 -0.182,-1.57 -0.227,-2.001 -0.164,0.142 -15.991,14.283 -15.991,14.283" style="fill:#fff3af"/>
				<path d="M 26.567,18.504 C 21.505,22.95 12.743,32.32 8.535,36.833 8.521,36.835 6.372,39.107 6.301,39.192 6.347,39.241 6.486,39.372 6.53,39.418 7.784,38.046 22.36,23.634 30.885,16.397 l 0.192,-0.162 c 0,0 11.632,-9.376 11.679,-9.419 0,-0.061 -0.066,-0.638 -0.066,-0.638 0,-0.001 -0.167,-1.47 -0.208,-1.892 C 42.31,4.445 26.567,18.504 26.567,18.504" style="fill:#fff3b3"/>
				<path d="m 26.605,18.541 c -5.056,4.444 -13.817,13.814 -18.031,18.327 0,0 -2.118,2.239 -2.191,2.318 0.04,0.046 0.122,0.127 0.142,0.138 1.448,-1.539 15.789,-15.73 24.319,-22.983 l 0.19,-0.146 c -0.003,0.004 -0.003,0.004 6.523,-5.267 0,0 5.095,-4.098 5.145,-4.139 C 42.691,6.726 42.636,6.191 42.636,6.191 42.636,6.189 42.45,4.591 42.431,4.417 42.26,4.558 26.605,18.541 26.605,18.541" style="fill:#fff5b8"/>
				<path d="M 26.646,18.586 C 21.587,23.036 12.828,32.4 8.62,36.9 c 0.004,0 0.003,0 -1.121,1.198 0,0 -0.958,1.008 -1.029,1.083 l 0.054,0.061 c 1.605,-1.691 15.809,-15.741 24.28,-22.94 l 0.189,-0.157 -10e-4,0.047 c 0.038,-0.064 0.234,-0.235 1.12,-0.958 0,0 10.474,-8.44 10.526,-8.473 -0.006,-0.064 -0.071,-0.56 -0.071,-0.56 0,-0.007 -0.161,-1.506 -0.184,-1.674 -0.168,0.16 -15.737,14.059 -15.737,14.059" style="fill:#fff5bb"/>
				<path d="M 26.686,18.641 C 21.624,23.085 12.87,32.451 8.663,36.939 l 0,-0.009 c -0.02,0.041 -0.072,0.087 -0.223,0.25 0,0 -0.386,0.411 -0.646,0.69 4.076,-4.1 15.653,-15.401 22.977,-21.606 l 0.188,-0.167 -0.019,0.063 c 0.038,-0.066 0.175,-0.194 1.138,-0.959 0,0 10.442,-8.426 10.49,-8.475 C 42.567,6.68 42.514,6.205 42.514,6.205 42.514,6.203 42.358,4.789 42.344,4.658 42.17,4.799 26.686,18.641 26.686,18.641" style="fill:#fff5bf"/>
				<path d="m 50.703,9.138 2.036,2.459 2.105,2.394 1.428,1.453 c 7.526,7.541 22.884,22.958 23.033,23.113 0.052,0.034 0.063,0.07 0.063,0.119 l 0,0.009 c 0,0.044 -0.028,0.077 -0.044,0.115 -0.659,0.619 -15.666,15.058 -23.828,22.01 l -12.585,10.163 0.357,7.753 19.153,-17.079 c 7.023,-6.171 20.397,-20.818 20.527,-20.954 0.338,-0.305 0.521,-0.743 0.521,-1.208 0,-0.463 -0.183,-0.895 -0.548,-1.232 L 82.847,38.176 C 80.54,35.989 68.722,24.741 62.759,18.985 60.727,17.015 59.995,16.408 59.245,15.816 L 55.977,13.133 50.703,9.138" style="fill:#ffe600"/>
				<path d="m 76.582,47.172 c 2.343,-2.484 4.295,-4.586 5.34,-5.724 l -0.002,0.093 c -0.177,0.193 -0.377,0.424 -0.593,0.646 -0.142,0.16 -0.311,0.338 -0.481,0.536 -1.03,1.105 -2.407,2.561 -4.264,4.449 M 43.43,76.443 C 43.383,76.409 43.34,76.375 43.289,76.337 43.188,74.139 43.035,71.07 43.035,71.033 43.26,70.831 55.564,60.886 55.564,60.886 63.553,54.121 77.802,40.418 79.409,38.865 c 0,0 0.096,-0.17 0.096,-0.208 l 0,-0.003 L 79.4,38.461 76.179,35.247 56.355,15.372 54.939,13.899 c -1.913,-2.152 -2.096,-2.352 -2.154,-2.396 l 0.053,0.011 c 0,0 -0.958,-1.132 -1.373,-1.653 0.584,0.455 4.423,3.368 4.44,3.372 l 3.312,2.707 c 0.719,0.597 1.477,1.19 3.459,3.121 C 67.9,24.12 77.507,33.27 82.08,37.619 l -0.013,0.152 C 77.546,33.463 67.868,24.258 62.588,19.153 60.595,17.231 59.866,16.615 59.14,16.029 l -3.33,-2.705 c 0,0 -2.562,-1.947 -3.591,-2.733 0.312,0.375 0.704,0.857 0.704,0.857 L 52.872,11.41 c 0.06,0.04 0.177,0.174 2.037,2.276 l 0.133,0.137 1.408,1.464 23.025,23.098 0.132,0.208 0,0 c 0,0.063 -0.08,0.308 -0.08,0.308 -0.128,0.146 -15.484,14.95 -23.88,22.081 0,0 -12.265,9.916 -12.497,10.104 0.002,0.025 0.175,3.258 0.28,5.357" style="fill:#ffe600"/>
				<path d="m 72.715,51.025 c 3.973,-4.137 7.612,-8.084 9.225,-9.785 l -0.018,0.208 c -1.045,1.138 -2.997,3.239 -5.34,5.724 -1.109,1.12 -2.385,2.408 -3.867,3.853 M 43.567,76.552 c -0.045,-0.035 -0.085,-0.073 -0.137,-0.108 -0.105,-2.1 -0.278,-5.332 -0.278,-5.36 0.232,-0.188 12.497,-10.104 12.497,-10.104 8.396,-7.131 23.752,-21.934 23.88,-22.081 0,0 0.08,-0.244 0.08,-0.308 l 0,0 L 79.477,38.383 56.451,15.286 55.043,13.822 54.91,13.685 c -1.86,-2.103 -1.978,-2.236 -2.037,-2.276 l 0.051,0.038 c 0,0 -0.393,-0.482 -0.704,-0.857 1.028,0.786 3.591,2.733 3.591,2.733 l 3.33,2.705 c 0.727,0.585 1.455,1.201 3.448,3.124 5.279,5.105 14.957,14.311 19.479,18.618 l -0.006,0.166 C 77.608,33.696 67.915,24.464 62.507,19.23 60.521,17.314 59.782,16.714 59.073,16.13 l -3.341,-2.719 c 0,0 -2.201,-1.66 -2.754,-2.091 l 0.034,0.051 0,0.012 2.107,2.367 1.406,1.451 23.045,23.099 0.142,0.235 0,0.019 c 0,0.059 -0.074,0.384 -0.074,0.384 -0.067,0.104 -15.251,14.779 -23.906,22.138 0,0 -12.229,9.866 -12.458,10.068 10e-4,0.037 0.189,3.415 0.293,5.408" style="fill:#ffe600"/>
				<path d="M 69.678,53.99 C 74.768,48.787 80.019,43.1 81.951,41.052 l -0.012,0.188 c -1.612,1.701 -5.252,5.648 -9.225,9.785 -0.926,0.915 -1.949,1.899 -3.036,2.965 m -19.004,17.5 c 2.562,-2.274 5.369,-4.783 7.545,-6.733 -3.138,2.878 -5.609,5.075 -7.545,6.733 m -6.97,5.166 C 43.671,76.62 43.62,76.582 43.567,76.552 43.463,74.559 43.275,71.181 43.275,71.143 43.503,70.941 55.733,61.075 55.733,61.075 64.388,53.717 79.572,39.041 79.639,38.937 c 0,0 0.074,-0.325 0.074,-0.384 l 0,-0.019 -0.142,-0.235 -23.045,-23.098 -1.406,-1.451 -2.107,-2.367 0,-0.012 -0.034,-0.051 c 0.553,0.431 2.754,2.091 2.754,2.091 l 3.341,2.719 c 0.709,0.584 1.447,1.185 3.434,3.1 5.407,5.234 15.101,14.465 19.555,18.706 l -0.006,0.161 C 77.66,33.907 67.932,24.642 62.421,19.324 60.449,17.407 59.701,16.803 58.988,16.223 l 0.059,0.008 C 58.979,16.223 58.654,15.95 55.999,13.785 l -0.332,-0.273 c 0,-0.002 -1.486,-1.134 -1.822,-1.378 0.482,0.547 1.38,1.527 1.38,1.527 l 1.398,1.465 19.814,19.868 3.207,3.221 0.173,0.266 0,0.008 c 0,0.094 -0.066,0.479 -0.066,0.479 -0.031,0.072 -15.093,14.685 -23.942,22.187 0,0 -12.188,9.851 -12.415,10.04 -10e-4,0.04 0.207,3.63 0.31,5.461" style="fill:#ffe600"/>
				<path d="m 65.658,57.82 c 6.101,-5.936 13.96,-14.474 16.293,-16.957 l 0,0.188 c -1.933,2.049 -7.184,7.735 -12.273,12.938 -1.233,1.175 -2.573,2.454 -4.02,3.831 M 47.843,73.863 c 5.338,-4.76 14.186,-12.652 14.186,-12.652 0.22,-0.193 0.457,-0.402 0.701,-0.635 -1.646,1.541 -3.135,2.919 -4.512,4.181 -2.176,1.95 -4.982,4.459 -7.545,6.733 -1.109,0.965 -2.045,1.735 -2.83,2.373 m -4.097,2.824 c 0,0 -0.018,-0.019 -0.042,-0.03 -0.103,-1.831 -0.311,-5.421 -0.311,-5.462 0.227,-0.19 12.415,-10.041 12.415,-10.041 8.85,-7.502 23.911,-22.115 23.942,-22.187 0,0 0.066,-0.384 0.066,-0.479 l 0,-0.008 L 79.643,38.214 76.436,34.993 56.622,15.125 55.224,13.66 c 0,0 -0.897,-0.98 -1.38,-1.527 0.336,0.244 1.822,1.375 1.822,1.378 l 0.332,0.273 c 2.655,2.165 2.979,2.438 3.048,2.446 l -0.059,-0.008 c 0.713,0.581 1.461,1.185 3.433,3.101 5.511,5.318 15.238,14.583 19.636,18.773 l 0,0.15 C 77.686,34.11 67.863,24.741 62.344,19.404 c -1.98,-1.902 -2.721,-2.517 -3.434,-3.098 -0.173,-0.145 -3.311,-2.7 -3.311,-2.7 0,0 -0.464,-0.343 -0.841,-0.642 0.271,0.306 0.563,0.619 0.563,0.619 l -0.016,-0.002 1.389,1.452 23.045,23.11 0.18,0.273 0.005,0.038 -0.043,0.515 c -0.03,0.062 -14.911,14.579 -23.994,22.285 0,0 -12.149,9.796 -12.372,9.993 0,0.041 0.225,3.82 0.321,5.438 -10e-4,0 -10e-4,0 -10e-4,0 l -0.089,0.002" style="fill:#ffe200"/>
				<path d="m 46.332,75.041 c 4.87,-4.338 15.606,-13.919 15.606,-13.919 6.194,-5.45 17.338,-17.605 20.021,-20.43 l -0.008,0.171 c -2.333,2.483 -10.192,11.021 -16.293,16.957 -0.519,0.485 -1.037,0.983 -1.581,1.477 -0.454,0.445 -0.901,0.867 -1.347,1.279 -0.244,0.232 -0.481,0.441 -0.701,0.635 0,0 -8.848,7.893 -14.186,12.652 -0.582,0.462 -1.079,0.859 -1.511,1.178 m -2.496,1.645 C 43.74,75.068 43.515,71.289 43.515,71.248 43.738,71.051 55.887,61.255 55.887,61.255 64.97,53.549 79.851,39.032 79.881,38.97 l 0.043,-0.515 -0.005,-0.038 -0.18,-0.273 -23.045,-23.11 -1.389,-1.452 0.016,0.002 c 0,0 -0.293,-0.313 -0.563,-0.619 0.377,0.298 0.841,0.642 0.841,0.642 0,0 3.138,2.555 3.311,2.7 0.713,0.581 1.453,1.196 3.434,3.098 5.519,5.337 15.342,14.706 19.712,18.842 l -0.002,0.17 C 77.717,34.302 67.825,24.882 62.249,19.488 c -1.964,-1.91 -2.692,-2.497 -3.411,-3.083 0,0 -2.583,-2.102 -3.03,-2.479 0.406,0.433 0.993,1.034 0.993,1.034 l 19.811,19.868 3.211,3.211 0.2,0.312 0.026,0.104 -0.05,0.528 c -0.074,0.193 -15.378,15.02 -24.026,22.355 0,0 -12.111,9.767 -12.339,9.968 0,0.045 0.251,3.905 0.331,5.324 -0.071,0.034 -0.105,0.044 -0.129,0.056" style="fill:#ffde00"/>
				<path d="m 45.304,75.798 c 3.987,-3.55 16.562,-14.767 16.562,-14.767 6.221,-5.464 17.59,-17.893 20.096,-20.51 l -0.002,0.171 c -2.683,2.824 -13.826,14.979 -20.021,20.43 0,0 -10.736,9.581 -15.606,13.919 -0.397,0.306 -0.731,0.553 -1.029,0.757 m -1.34,0.832 c -0.08,-1.419 -0.331,-5.279 -0.331,-5.324 0.228,-0.201 12.339,-9.968 12.339,-9.968 8.648,-7.335 23.952,-22.162 24.026,-22.355 l 0.05,-0.528 -0.026,-0.104 -0.2,-0.312 -3.211,-3.211 -19.81,-19.868 c 0,0 -0.587,-0.601 -0.993,-1.034 0.447,0.377 3.03,2.479 3.03,2.479 0.719,0.585 1.447,1.173 3.411,3.083 5.576,5.394 15.468,14.814 19.805,18.929 L 82.04,38.566 C 77.783,34.525 67.837,25.053 62.173,19.575 c -1.964,-1.898 -2.697,-2.499 -3.408,-3.067 0,0 -0.768,-0.632 -1.406,-1.166 1.688,1.717 8.163,8.195 19.334,19.391 l 3.227,3.238 0.208,0.309 0.025,0.104 0.01,0.071 -0.035,0.548 c -0.074,0.174 -15.382,15.054 -24.082,22.431 0,0 -12.064,9.736 -12.289,9.923 0,0.046 0.273,4.055 0.344,5.214 -0.052,0.02 -0.101,0.049 -0.137,0.059" style="fill:#ffda00"/>
				<path d="m 44.604,76.277 c 2.507,-2.244 17.178,-15.332 17.178,-15.332 6.279,-5.51 17.894,-18.22 20.195,-20.621 l -0.016,0.197 c -2.506,2.617 -13.875,15.046 -20.096,20.51 0,0 -12.574,11.217 -16.562,14.767 -0.281,0.199 -0.514,0.368 -0.699,0.479 m -0.503,0.293 c -0.071,-1.159 -0.344,-5.168 -0.344,-5.214 0.225,-0.187 12.289,-9.923 12.289,-9.923 8.7,-7.377 24.008,-22.257 24.082,-22.431 L 80.163,38.454 80.153,38.383 80.128,38.279 79.92,37.97 76.693,34.732 C 65.521,23.537 59.046,17.059 57.358,15.342 c 0.639,0.534 1.406,1.166 1.406,1.166 0.711,0.568 1.444,1.169 3.408,3.067 5.664,5.479 15.61,14.951 19.867,18.991 l -0.016,0.163 C 77.81,34.7 67.756,25.126 62.072,19.661 60.493,18.125 59.717,17.44 59.114,16.936 c 1.548,1.562 20.879,20.938 20.879,20.938 l 0.006,0.016 0.226,0.329 0.036,0.133 c 0.01,0.034 0.029,0.081 0.029,0.081 l -0.055,0.571 c -0.058,0.189 -15.37,15.107 -24.124,22.529 0,0 -12.006,9.684 -12.237,9.886 0,0.043 0.313,4.326 0.356,5.079 -0.044,0.026 -0.097,0.057 -0.129,0.072" style="fill:#ffd800"/>
				<path d="M 44.23,76.496 C 44.187,75.743 43.874,71.46 43.874,71.417 44.105,71.215 56.111,61.531 56.111,61.531 64.865,54.109 80.177,39.192 80.235,39.002 l 0.055,-0.571 c 0,0 -0.02,-0.046 -0.029,-0.081 l -0.036,-0.133 -0.226,-0.329 -0.006,-0.016 c 0,0 -19.331,-19.375 -20.879,-20.938 0.603,0.504 1.379,1.189 2.958,2.725 5.684,5.467 15.738,15.041 19.952,19.07 l 0,0.168 C 79.076,36.078 70.158,27.6 64.044,21.718 c 4.782,4.8 16.046,16.08 16.046,16.08 l 0.01,0.027 0.228,0.341 0.047,0.146 0.033,0.104 -0.043,0.586 c -0.061,0.207 -15.39,15.16 -24.162,22.61 0,0 -11.977,9.671 -12.206,9.856 0,0.052 0.361,4.629 0.361,4.877 C 44.554,76.164 61.693,60.847 61.693,60.847 68.066,55.266 79.92,42.292 81.982,40.144 l -0.006,0.18 c -2.302,2.401 -13.916,15.111 -20.195,20.621 0,0 -14.671,13.088 -17.178,15.332 -0.154,0.098 -0.276,0.173 -0.373,0.219" style="fill:#fed600"/>
				<path d="m 44.358,76.346 c 0,-0.248 -0.361,-4.825 -0.361,-4.877 0.229,-0.186 12.206,-9.856 12.206,-9.856 8.772,-7.45 24.102,-22.403 24.162,-22.61 L 80.408,38.417 80.375,38.313 80.328,38.167 80.1,37.825 80.09,37.798 c 0,0 -11.264,-11.28 -16.046,-16.08 6.114,5.881 15.032,14.359 17.98,17.179 l -0.008,0.149 C 81.214,38.28 74.55,31.922 71.102,28.637 c 3.649,3.638 9.062,9.083 9.062,9.083 l 0.037,0.046 0.225,0.338 0.078,0.162 0.016,0.151 -0.043,0.605 C 80.43,39.21 65.103,54.228 56.29,61.707 c 0,0 -11.941,9.616 -12.173,9.813 0,0.058 0.357,4.307 0.357,4.55 0.202,-0.178 17.151,-15.303 17.151,-15.303 6.451,-5.682 18.6,-18.997 20.357,-20.802 l 0,0.179 c -2.062,2.148 -13.916,15.122 -20.289,20.703 0,10e-4 -17.139,15.318 -17.335,15.499" style="fill:#fdd402"/>
				<path d="m 44.474,76.07 c 0,-0.243 -0.357,-4.492 -0.357,-4.55 C 44.349,71.323 56.29,61.707 56.29,61.707 65.102,54.228 80.43,39.21 80.477,39.022 L 80.52,38.417 80.504,38.266 80.426,38.104 80.201,37.766 80.164,37.72 c 0,0 -5.412,-5.444 -9.062,-9.083 3.448,3.285 10.112,9.643 10.914,10.409 l 0,0.165 c -0.134,-0.137 -2.78,-2.654 -3.854,-3.682 0.979,0.995 2.098,2.1 2.098,2.1 l 0.045,0.066 -0.008,-0.01 c 0.025,0.035 0.084,0.113 0.229,0.354 l 0.081,0.179 0.029,0.185 -0.029,0.636 c -0.063,0.172 -15.403,15.263 -24.253,22.772 0,0 -11.886,9.576 -12.118,9.776 0,0.04 0.363,3.976 0.363,4.211 C 44.796,75.625 61.54,60.669 61.54,60.669 68.094,54.917 80.606,41.174 81.984,39.795 l -0.004,0.171 c -1.758,1.805 -13.906,15.12 -20.357,20.802 0.002,0 -16.947,15.125 -17.149,15.302" style="fill:#fdd303"/>
				<path d="m 44.601,75.798 c 0,-0.235 -0.363,-4.171 -0.363,-4.211 0.232,-0.2 12.118,-9.776 12.118,-9.776 8.85,-7.51 24.189,-22.601 24.253,-22.772 l 0.029,-0.636 -0.029,-0.185 -0.081,-0.179 c -0.146,-0.241 -0.204,-0.32 -0.229,-0.354 l 0.008,0.01 -0.045,-0.066 c 0,0 -1.118,-1.105 -2.098,-2.1 1.073,1.027 3.72,3.545 3.854,3.682 l -0.008,0.183 c -0.022,-0.033 -0.04,-0.063 -0.071,-0.09 0,0 -0.884,-0.845 -1.255,-1.192 l 0.03,0.066 0.046,0.208 -0.045,0.656 c -0.037,0.178 -15.405,15.322 -24.28,22.841 0,0 -11.85,9.562 -12.073,9.749 0,0.06 0.357,3.678 0.357,3.903 0.195,-0.17 16.739,-14.946 16.739,-14.946 6.535,-5.736 19.097,-19.542 20.458,-20.895 0.037,-0.036 0.068,-0.066 0.078,-0.105 l -0.006,0.208 C 80.61,41.176 68.097,54.919 61.544,60.671 61.542,60.669 44.798,75.625 44.601,75.798" style="fill:#fcd006"/>
				<path d="m 80.885,38.455 c -0.016,0.137 -0.039,0.585 -0.039,0.585 -0.047,0.195 -15.431,15.371 -24.319,22.941 -0.13,0.101 -11.641,9.369 -12.048,9.709 0,0.046 0.086,0.831 0.086,0.831 0,0 0.257,2.514 0.271,2.758 0.186,-0.174 16.545,-14.781 16.545,-14.781 5.071,-4.464 13.859,-13.85 18.086,-18.377 l 2.357,-2.495 -0.007,0 c 0,-0.006 0.065,-0.105 0.077,-0.141 l -0.047,-0.101 c 0.001,0 -0.704,-0.68 -0.962,-0.929 M 44.717,75.533 c 0,-0.226 -0.357,-3.844 -0.357,-3.903 0.224,-0.188 12.073,-9.749 12.073,-9.749 8.875,-7.519 24.243,-22.663 24.28,-22.841 l 0.045,-0.656 -0.046,-0.208 -0.03,-0.066 c 0.371,0.348 1.255,1.192 1.255,1.192 0.031,0.027 0.049,0.058 0.071,0.09 l -0.017,0.194 c -0.01,0.039 -0.041,0.069 -0.078,0.105 -1.361,1.353 -13.923,15.158 -20.458,20.895 0.001,0.001 -16.543,14.777 -16.738,14.947" style="fill:#fccf07"/>
				<path d="m 80.987,38.723 c -0.006,0.132 -0.029,0.317 -0.029,0.317 l -0.002,0.033 c -0.044,0.169 -15.44,15.423 -24.363,23.001 0,0 -11.744,9.472 -11.989,9.668 0,0.052 0.082,0.827 0.082,0.827 0,0 0.241,1.925 0.261,2.443 C 45.134,74.85 61.301,60.399 61.301,60.399 66.377,55.955 75.147,46.563 79.363,42.052 l 0,10e-4 c 0,0 0.08,-0.085 2.38,-2.529 l 0.014,-0.004 0.023,-0.036 -0.037,-0.067 0.037,0.032 C 81.698,39.388 81.498,39.21 80.987,38.723 M 44.835,75.279 c -0.014,-0.244 -0.271,-2.758 -0.271,-2.758 0,0 -0.086,-0.785 -0.086,-0.831 0.407,-0.34 11.918,-9.608 12.048,-9.709 8.889,-7.57 24.272,-22.746 24.319,-22.941 0,0 0.023,-0.449 0.039,-0.585 0.258,0.25 0.963,0.93 0.963,0.93 l 0.047,0.101 c -0.012,0.036 -0.077,0.135 -0.077,0.141 l 0.007,0 -2.357,2.495 c -4.227,4.527 -13.015,13.913 -18.086,18.377 0,-0.001 -16.36,14.606 -16.546,14.78" style="fill:#fbcd0b"/>
				<path d="m 56.668,62.15 c -0.012,0.026 -0.073,0.066 -0.174,0.17 0,0 -11.724,9.446 -11.776,9.474 0,0.067 0.33,2.727 0.335,2.966 0.184,-0.167 16.159,-14.432 16.159,-14.432 5.069,-4.466 13.846,-13.846 18.061,-18.359 l 0.336,-0.35 c 0.021,-0.01 1.824,-1.927 2.001,-2.134 -0.049,-0.067 -0.355,-0.344 -0.519,-0.512 l 0,0.078 -0.008,0.056 C 81.022,39.282 65.607,54.578 56.668,62.155 l 0,-0.005 M 44.946,75.013 c -0.021,-0.519 -0.261,-2.443 -0.261,-2.443 0,0 -0.082,-0.775 -0.082,-0.827 0.245,-0.196 11.989,-9.668 11.989,-9.668 8.923,-7.578 24.319,-22.832 24.363,-23.001 l 0,-0.034 c 0,0 0.025,-0.186 0.031,-0.317 0.511,0.487 0.711,0.665 0.793,0.728 l -0.037,-0.032 0.037,0.067 -0.023,0.036 -0.014,0.004 c -2.3,2.444 -2.38,2.529 -2.38,2.529 l 0,-10e-4 C 75.145,46.565 66.376,55.956 61.3,60.401 61.301,60.399 45.133,74.851 44.946,75.013" style="fill:#facb0c"/>
				<path d="m 45.053,74.76 c -0.005,-0.239 -0.335,-2.898 -0.335,-2.966 0.052,-0.027 11.776,-9.474 11.776,-9.474 0.101,-0.104 0.162,-0.144 0.174,-0.17 l 0,0.004 C 65.607,54.577 81.022,39.281 81.083,39.106 l 0.008,-0.056 0,-0.078 c 0.163,0.168 0.47,0.445 0.519,0.512 -0.177,0.208 -1.979,2.125 -2.001,2.134 l -0.336,0.35 c -4.215,4.514 -12.991,13.894 -18.061,18.359 0,0.001 -15.975,14.266 -16.159,14.433" style="fill:#fac90e"/>
			</g>
		</g>
		<path d="m 25.399,37.451 -1.835,-1.8415 1.888,-1.8785 1.8345,1.838 -1.8875,1.882 m 33.6135,-3.491 0,2.0625 0.5365,0 0,-2.0625 -0.5365,0 z" style="fill:#f8ec17"/>
		<path d="m 45.424,33.473 0,12.0195 -3.5425,0 -0.0185,-9.831 1.5315,-0.381 -0.448,-1.7905 2.4775,-0.017 m -14.3355,2.6015 0,12.407 3.498,0 0,-10.1 0.755,0 c 0.35,0 1.3265,0.4815 1.3265,1.516 0,1.101 -0.981,2.0035 -1.7885,2.638 l 3.65,6.0575 c 1.008,-0.8325 2.8685,-2.583 2.8685,-2.583 -1.483,-1.698 -3.1115,-3.4615 -3.1115,-3.4615 1.594,-1.301 1.99,-2.2715 1.905,-3.4095 -0.182,-2.4105 -2.4275,-2.8595 -4.1435,-3.0645 -1.3455,-0.1555 -3.492,-0.0575 -4.9595,0 m 18.473,12.3675 3.611,0 0,-9.508 3.412,0 0,-3.0515 -10.438,0 0,3.0515 3.415,0 0,9.508 M 29.7365,32.9385 c 0,0 -3.644,0.0015 -7.31,0.162 l 0,13.411 3.65,0 0.0035,-4.8685 3.354,0.002 0,-2.891 -3.4025,0.0125 0.005,-2.802 3.6915,0.0055 0.0085,-3.0315 M 67.694,40.603 70.0565,40.6885 71,34.582 68.072,34.351 67.694,40.603 m -1.064,1.346 0.467,0.581 1.5005,1.846 1.851,-1.499 -1.963,-2.4295 -1.8555,1.5015" style="clip-rule:evenodd;fill-rule:evenodd"/>
		<path d="m 44.614,44.8005 -4.1655,0 -0.0165,-10.385 1.464,-0.369 -0.4655,-1.8845 3.183,-0.003 0,12.6415 m 3.5135,-6.564 0,9.5155 4.2385,0 0,-9.5155 3.038,0.112 0.374,5e-4 0,-3.782 -11.0595,0 0,3.782 0.3425,-0.036 c -0.0335,0 3.0665,-0.0765 3.0665,-0.0765 m 7.424,-6.693 0,3.753 0.151,-0.0155 c 1.5185,-0.0685 2.794,-0.0745 3.8455,-0.0845 l -4.929,9.5065 0.73,0 c 0.1525,0 9.82,0 9.82,0 l -0.003,-3.755 -0.385,0.0195 C 63.017,41.0845 61.69,41.071 60.676,41.052 l 4.9745,-9.2655 -0.536,-0.035 C 60.38,31.488 56.8805,31.546 55.6895,31.5435 l -0.1385,0 m -26.724,0.104 c 0,0 -3.86,-0.011 -7.5365,0.152 L 21,31.8055 l 0,14.016 4.2605,0 0.006,-4.8785 2.997,0.0025 0.352,0 0.002,-3.5625 -3.4015,0.0165 0.0045,-2.0825 3.359,0.008 0.3405,-0.0075 0.007,-3.4125" style="clip-rule:evenodd;fill-rule:evenodd"/>
		<path d="m 33.7635,41.1555 c 0.7605,-0.622 1.4855,-1.3955 1.4855,-2.2575 0,-0.828 -0.8025,-1.223 -1.0285,-1.223 l -0.457,0 0,3.4805 m 1.197,-6.374 c 1.6795,0.191 4.206,0.659 4.4075,3.3285 0.091,1.203 -0.332,2.223 -1.7825,3.476 l 3.1135,3.6505 -0.189,0.189 c -0.8485,0.878 -1.818,1.704 -2.825,2.5325 l -0.2665,0.224 -3.655,-6.063 0,5.6585 -4.095,0 0,-12.9885 0.285,-0.007 c 1.4835,-0.0695 3.6505,-0.156 5.007,-5e-4 z m 31.7565,-1.3385 3.575,0.289 -1.0305,6.716 -2.9655,-0.114 0.421,-6.891 m 3.032,8.969 -2.335,1.8895 -1.431,-1.767 0.002,2.8575 c 0,0 -9.3645,0 -9.518,0 l -0.216,0 4.9225,-9.5085 c -1.141,0.0175 -2.469,0 -5.539,0.1555 l 0,-3.1085 c 2.4845,-0.0695 5.916,-0.13 10.6475,0.129 l -4.9935,9.287 c 0.928,0.03 2.194,0.057 3.8595,-0.0195 l 0,-0.3635 0.375,0 2.3315,-1.894 1.8945,2.3425" style="clip-rule:evenodd;fill-rule:evenodd"/>
		<path d="m 44.303,32.4735 0,12.0155 -3.5425,0 -0.0185,-9.827 1.534,-0.3845 -0.4595,-1.803 2.4865,-10e-4 m -14.336,2.6025 0,12.399 3.4985,0 0,-10.0945 0.755,0 c 0.35,0 1.327,0.4835 1.327,1.518 0,1.0955 -0.9805,1.9985 -1.7885,2.635 l 3.736,6.2005 c 1.0085,-0.827 1.965,-1.653 2.8015,-2.5125 l -3.13,-3.671 c 1.594,-1.307 1.9905,-2.274 1.906,-3.4115 -0.182,-2.409 -2.4295,-2.86 -4.1445,-3.063 -1.346,-0.156 -3.492,-0.064 -4.961,0 m 18.4735,12.363 3.6125,0 0,-9.5055 3.4125,0.072 0,-3.1255 -10.4385,0 0,3.1255 3.4135,-0.072 0,9.5055 M 55.808,34.972 c 1.7765,-0.0875 3.104,-0.075 4.244,-0.0875 l -4.921,9.5065 0.216,0 c 0.1515,0 9.517,0 9.517,0 l -0.0035,-3.117 c -2.082,0.1385 -3.6215,0.1035 -4.693,0.0715 l 4.994,-9.2845 c -4.7335,-0.263 -8.163,-0.2045 -9.354,-0.2065 l 0,3.1175 m -27.1905,-1.138 0,-1.878 -7.3115,0.1425 0,13.416 3.652,0 0.003,-4.878 3.3515,0 0,-2.888 -3.401,0.0145 0.006,-2.8035 3.704,-0.004 -0.004,-1.1215 m 38.013,6.2005 2.3685,0.0875 0.94,-6.1115 -2.929,-0.2275 -0.3795,6.2515 m -0.6815,1.9805 1.5035,1.854 1.849,-1.5015 -1.4995,-1.849 -1.853,1.4965" style="clip-rule:evenodd;fill:#e2001a;fill-rule:evenodd"/>
	</g>
	<g>
		<defs>
				<![CDATA[
			</script>
		</defs>
		<g>
			<circle cx="43" cy="40" r="38" style="fill:#FFFFFF;stroke:#000000;fill-opacity:0.3;opacity:0.6"/>
			<text x="59" y="16" style="font-style:normal;font-weight:normal;font-stretch:normal;font-size:8px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">1<tspan x="71" y="28">2</tspan><tspan x="75" y="44">3</tspan><tspan x="71" y="60">4</tspan><tspan x="59" y="72">5</tspan><tspan x="43" y="76">6</tspan><tspan x="27" y="72">7</tspan><tspan x="15" y="60">8</tspan><tspan x="11" y="44">9</tspan><tspan x="15" y="28">10</tspan><tspan x="27" y="16">11</tspan><tspan x="43" y="12">12</tspan></text>
			<g transform="translate(43 40)">
				<g id="hours">
					<line x1="0" y1="0" x2="0" y2="-22" style="stroke-width:3;stroke:#000000;opacity:0.6">
					</line>
				</g>
				<g id="minutes">
					<line x1="0" y1="0" x2="0" y2="-30" style="stroke-width:2;stroke:#000000;opacity:0.6">
					</line>
				</g>
				<g id="seconds">
					<line x1="0" y1="0" x2="0" y2="-35" style="stroke-width:1;stroke:#c80000;opacity:0.8">
					</line>
				</g>
			</g>
			<circle cx="43" cy="40" r="2" style="fill:#000000;stroke:#c80000;opacity:0.8"/>
		</g>
		<g>
			<text x="44" y="22" style="font-style:bold;font-weight:normal;font-stretch:normal;font-size:7px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">FREETZ<tspan x="44" y="66" style="font-weight:bold;font-size:8px">MOD</tspan></text>
		</g>
	</g>
</svg>
Uhr pur mit FREETZ tagging:
HTML:
	<desc>FREETZ!Mod and Clock tagging</desc>
	<defs>
			<![CDATA[
		</script>
	</defs>
	<g>
		<circle cx="43" cy="40" r="38" style="fill:#FFFFFF;stroke:#000000;fill-opacity:0.6;opacity:0.6"/>
			<g id="hours">
				</line>
			</g>
			<g id="minutes">
				</line>
			</g>
			<g id="seconds">
				</line>
			</g>
		</g>
	</g>
	<g>
		<text x="44" y="34" style="font-style:normal;font-weight:normal;font-stretch:normal;font-size:10px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">FREETZ<tspan x="44" y="56" style="font-weight:bold;font-size:12px">MOD</tspan></text>
	</g>
</svg>
Ein weiteres Problem gibt es dabei (wie man auf den Screenshots vom WebIf sehen kann), das Javascript in der SVG-Datei wird ignoriert wenn die SVG-Datei im WebIf eingebettet ist, die Uhr fängt als immer bei 12:00:00 an...
- - - Aktualisiert - - -
Dabei fällt mir gerade ein, es ist vielleicht sogar besser die Uhr zu einer Stoppuhr umzubauen (lediglich die Beschriftung ist dafür zu ändern, die Uhrzeit hat man ja i.d.R. so schon auf dem Bildschirm), damit kann man dann auch auf das JavaScript verzichten.
Vorteil: Man sieht wie lange man das WebIf bzw. den entsprechenden Teil des WebIf schon aufgerufen hat (man muss so nicht immer oben rechts in das Menü klicken um zu schauen wann die 20 Minuten abgelaufen sind bis zum Auto-Logout).
Hm, dann wäre die Uhr so nur als Anzeige für das automatische Logout tauglich?
...weil bei Seitenwechsel z.B. Übersicht --> Heimnetz wieder bei 12:00 gestartet wird?
Dann vielleicht auf 20 Minuten "eichen" und das Ziffernblatt anpassen?
Spontan :gruebel:
IFrame oder Object und das "Eingebettete" so umbetten.
IFrame
HTML:
<iframe id="myFrame" name="myFrame" src="uhr.svg"></iframe>
Object
HTML:
<object type="application/xhtml+xml" data="uhr.svg"></object>
Die brauchen feste height="200px" Angaben, width="100%" klappt aber.
:oops: wie darf ich mir als DAU das ganze bildlich vorstellen?
:) Keine Ahnung ob ein DAU soviel Fantasie besitzt :noidea:
...aber Post #10 ist mit Bildchen geflutet worden.
:blonk: die sind mir durchgegangen. Sorry ;)
Sollte AVM mal als Standard einpflegen :mrgreen:
Hätte da noch einen "Trick" :D
Es lässt sich auch "data:" referenzieren.
Damit alles schön formatiert bleibt, als BASE64 codiert.
Beispiele für die Adresszeile des Webbrowsers...
Nicht kodiert
data:text/html,hello
BASE64 kodiert
(Mit: echo hello | base64)
data:text/html;base64,aGVsbG8K
Sowas lässt sich dann auch in "href=", "src=" oder "data=" nutzen.
Natürlich dann nicht unbedingt als text/html, für SVG halte ich application/xhtml+xml für "bezeichnend" und text/xml für "mindestens benötigt"
Wer die verschiedenen SVG-Logo Beispiele/Vorschläge mal Live begutachten möchte (also in echt mit Farbe, Bewegung und so) öffnet z.B. im Webbrowser die Login-Seite der FritzBox (http://fritz.box, FritzOS >=6.50 natürlich vorausgesetzt), geht dann auf "Seite speichern unter" aka STRG+S (bzw. je nachdem wie dies beim jeweils verwendeten Browser benannt ist) und speichert diese dann als "Website, komplett/vollständig" (nicht als "Webarchiv" und auch nicht als "HTML-only") ab.
Das Ergebnis ist dann eine HTML-Datei mit dazugehörigem Unterordner, in diesem Unterordner befindet sich die "fritzLogo.svg" welche nun durch eine eigene Variante ersetzt werden kann und/oder man editiert die vorhandene SVG-Datei mit einem geeigneten Texteditor (dieser sollte mit LE-Zeilenenden umgehen können, was man da z.B. ändern könnte s.h. Beispiel in Beitrag #6). Anschließend die HTML-Datei eine Ebene höher (Dateiname normalerweise "FRITZ!Box.html") mit einem Browser aufrufen.
Man kann auch den Inhalt der beiden Code-Blöcke aus Beitrag #10 jeweils komplett kopieren und daraus jeweils eine entsprechende SVG-Datei erstellen (Inhalt in eine leere Textdatei einfügen, Zeichenkodierung UTF-8 und LF-Zeilenenden) um diese Live zu testen.
Hier nun ein weiteres Beispiel (Countdown):
HTML:
<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" version="1.1" id="Ebene_1" x="0px" y="0px" width="100px" height="80px" viewBox="0 0 100 80" enable-background="new 0 0 100 80" xml:space="preserve">
	<title>FREETZ!Mod with Logout-Countdown</title>
	<desc>FREETZ!Mod and Logout-Countdown tagging</desc>
	<g>
		<path style="opacity:1;fill:#ffffff;fill-opacity:0.25;stroke:no" d="M 75.909,59 A 38,38 0 0 1 30.003,75.708 38,38 0 0 1 5.577,33.401 38,38 0 0 1 43,2 L 43,40 Z"/>
		<path style="opacity:1;fill:#ffffff;fill-opacity:0.50;stroke:no" d="m 43,2 a 38,38 0 0 1 32.909,19 38,38 0 0 1 -1e-6,38 L 43,40 Z"/>
		<circle cx="43" cy="40" r="38" style="fill:no;stroke:#000000;fill-opacity:0;opacity:0.6"/>
		<line x1="43" y1="40" x2="76" y2="59" style="stroke-width:1;stroke:#c80000;opacity:0.4"/>
		<text x="74" y="43" style="font-style:normal;font-weight:normal;font-stretch:normal;font-size:8px;font-family:sans-serif;text-align:center;text-anchor:middle;fill:#000000;fill-opacity:0.5">15<tspan x="43" y="75">30</tspan><tspan x="12" y="43">45</tspan><tspan x="43" y="12">60</tspan></text>
			<g id="hours">
				</line>
			</g>
			<g id="minutes">
				</line>
			</g>
			<g id="seconds">
				</line>
			</g>
		</g>
	</g>
	<g>
	</g>
</svg>
Als Vorschau im PNG-Format:
Und im WebIf:
BTW:
Ich wollte erst, wie koy vorgeschlagen hatte, den Minutenzeiger auf 20 Min. für 360° umstellen aber dann fiel mir auf, dass man dann nicht sieht ob die 20 Minuten bereits abgelaufen sind oder noch nicht. Daher nun eine "klassische" Stoppuhr mit "roter Linie" bei 20 Min. (incl. unterschiedlicher Hintergründe). Ab der 60. Minute ist man dann aber auch wieder im unklaren... :mrgreen:
Und als "Live" data: für die Browserzeile....
data:text/xml;base64,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
Screenshot: Screenshot_2017-02-15-15-21-06.png (Maximum Zoom :cool: )
Das sieht man nur leider nicht wie sich die verschiedenen Hintergründe (zur Abgrenzung des 20 Min.-Countdown) auswirken.
