[Frage] svn: Der Server hat einen unerwarteten Rückgabewert (400 Bad request) in Antwort auf
vipost
8 Nov 2008
Hallo.
Bräuchte Hilfe, beim Installieren der Freetz.
PHP:
Your settings from the last run of speed-to-fritz:
Speedporttype=W7150V
OEM=avme
CONFIG_PRODUKT=Fritz_Box_7170
ANNEX=A
Imagename=fw_C_7150_38.04.72-27518_Fritz_Box_7170_29.04.88-27403_sp2fr-1484-866_OEM_avme_annexA_de.image
AVM Type=7170
The following script should do this for you:
Installing or updating freetz/trunk
Updating your LINUX system and installing missing tools needed for freetz
invoking 'make menuconfig'
invoking 'make'
invoking 'speed-to-freetz'
Download Freetz the first time, or do a freetz update?
In case of problems do a 'make dirclean' at the commandline this will remove all changes made by you.
For using the commandline you must change to the freetz-trunk directory first. 'cd ../freetz-trunk'
To download a specific revision of the trunk you would need to set the number via menu option!
--> You shuld type 'y' <--
   Execute: 'svn co http://svn.freetz.org/tags/freetz-2.0 freetz-trunk'  (y/n)?
Looking for new freetz version, wait ...
svn: Der Server hat einen unerwarteten Rückgabewert (400 Bad request) in Antwort auf die Anfrage OPTIONS für »http://svn.freetz.org/tags/freetz-2.0« zurückgeliefert
--Image files present in './freetz-trunk/dl/fw':
-rw-r--r-- 1 fritz fritz 6010880 2016-02-03 02:15 ./freetz-trunk/dl/fw/FRITZ.Box_Fon_WLAN_7113.de-en-es-it-fr.90.04.86.image
-rwxrw-rw- 1 fritz fritz 8540160 2014-05-14 01:44 ./freetz-trunk/dl/fw/FRITZ.Box_Fon_WLAN_7170.29.04.88.image
Firmware copied to './freetz-trunk/dl' directory
If you terminate with control C or skip all following questions you will be left
with a clean freetz installation, and you can use freetz in command line mode,
as it is explained on freetz help page. Change directory to freetz-trunk
and type in 'make menuconfig' first.
If started:
Ignore WARNINGS, especially the first time this tool is started!
   Invoke 'make menuconfig' now? (y/n)?
Be patient ...
find: Warnung:  Unix Dateinamen enthalten gewöhnlich keine Schrägstriche (anders als Pfadbezeichnungen).  Deshalb wird '-name "sys/acl.h"' wahrscheinlich immer "Falsch" auf diesem System ergeben.  Möglicherweise sind '-wholename' oder '-samefile' bessere Tests.  Alternativ kann auch GNU grep verwendet werden:  'find ... -print0 | grep -FzZ "sys/acl.h"'.
ERROR: The header file sys/acl.h was not found in /usr/(local/)include.
find: Warnung:  Unix Dateinamen enthalten gewöhnlich keine Schrägstriche (anders als Pfadbezeichnungen).  Deshalb wird '-name "sys/capability.h"' wahrscheinlich immer "Falsch" auf diesem System ergeben.  Möglicherweise sind '-wholename' oder '-samefile' bessere Tests.  Alternativ kann auch GNU grep verwendet werden:  'find ... -print0 | grep -FzZ "sys/capability.h"'.
ERROR: The header file sys/capability.h was not found in /usr/(local/)include.
Makefile:135: *** Some build prerequisites are missing! Please install the missing packages before trying again.  Schluss.
If started:
Be prepared that the first time this could take one hour or more!
   Invoke 'make' now? (y/n)?
Be patient ...
modimage=
_______________________________________________________________________________________________________________
Something went wrong, Freetzfirmware not found!
If Firmware was created, you may copy the freetz image yourself to:
/home/fritz/Desktop/speed-to-fritz/Firmware.orig
Then start speed-to-fretz setup (./start) again and select freetz image as AVM LABOR source
All done .... Press 'ENTER' to return to the calling shell.
Also, was mache ich falsch,
und was soll ich korrigieren?
Hallo.
Könnte jemand hier bitte schauen?
PHP:
